1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* colortab.c - allocate and control dynamic color table. |
6 |
7 |
* We start off with a uniform partition of color space. |
8 |
* As pixels are sent to the frame buffer, a histogram is built. |
9 |
* When a new color table is requested, the histogram is used |
10 |
* to make a pseudo-optimal partition, after which the |
11 |
* histogram is cleared. This algorithm |
12 |
* performs only as well as the next drawing's color |
13 |
* distribution is correlated to the last. |
14 |
15 |
* External symbols declared in drvier.h |
16 |
17 |
18 |
#include "copyright.h" |
19 |
20 |
#include "standard.h" |
21 |
22 |
#include "color.h" |
23 |
/* histogram resolution */ |
24 |
#define NRED 24 |
25 |
#define NGRN 32 |
26 |
#define NBLU 16 |
27 |
#define HMAX NGRN |
28 |
/* minimum box count for adaptive partition */ |
29 |
#define MINSAMP 7 |
30 |
/* maximum distance^2 before color reassign */ |
31 |
#define MAXDST2 12 |
32 |
/* map a color */ |
33 |
#define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \ |
34 |
(int)(colval(c,p)*256.) : 255 ] |
35 |
/* color partition tree */ |
36 |
#define CNODE short |
37 |
#define set_branch(p,c) ((c)<<2|(p)) |
38 |
#define set_pval(pv) ((pv)<<2|3) |
39 |
#define is_branch(cn) (((cn)&3)!=3) |
40 |
#define is_pval(cn) (((cn)&3)==3) |
41 |
#define part(cn) ((cn)>>2) |
42 |
#define prim(cn) ((cn)&3) |
43 |
#define pval(cn) ((cn)>>2) |
44 |
/* our color table */ |
45 |
static struct tabent { |
46 |
long sum[3]; /* sum of colors using this entry */ |
47 |
int n; /* number of colors */ |
48 |
BYTE ent[3]; /* current table value */ |
49 |
} *clrtab = NULL; |
50 |
/* color cube partition */ |
51 |
static CNODE *ctree = NULL; |
52 |
/* our color correction map */ |
53 |
static BYTE clrmap[3][256]; |
54 |
/* histogram of colors used */ |
55 |
static unsigned short histo[NRED][NGRN][NBLU]; |
56 |
/* initial color cube boundary */ |
57 |
static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}}; |
58 |
59 |
static int split(); |
60 |
static void cut(); |
61 |
62 |
63 |
int |
64 |
new_ctab(ncolors) /* start new color table with max ncolors */ |
65 |
int ncolors; |
66 |
67 |
int treesize; |
68 |
69 |
if (ncolors < 1) |
70 |
return(0); |
71 |
/* free old tables */ |
72 |
if (clrtab != NULL) |
73 |
free((void *)clrtab); |
74 |
if (ctree != NULL) |
75 |
free((void *)ctree); |
76 |
/* get new tables */ |
77 |
for (treesize = 1; treesize < ncolors; treesize <<= 1) |
78 |
79 |
treesize <<= 1; |
80 |
clrtab = (struct tabent *)calloc(ncolors, sizeof(struct tabent)); |
81 |
ctree = (CNODE *)malloc(treesize*sizeof(CNODE)); |
82 |
if (clrtab == NULL || ctree == NULL) |
83 |
return(0); |
84 |
/* partition color space */ |
85 |
cut(ctree, 0, CLRCUBE, 0, ncolors); |
86 |
/* clear histogram */ |
87 |
bzero((void *)histo, sizeof(histo)); |
88 |
/* return number of colors used */ |
89 |
return(ncolors); |
90 |
91 |
92 |
93 |
int |
94 |
get_pixel(col, set_pixel) /* get pixel for color */ |
95 |
COLOR col; |
96 |
void (*set_pixel)(); |
97 |
98 |
int r, g, b; |
99 |
int cv[3]; |
100 |
register CNODE *tp; |
101 |
register int h; |
102 |
/* map color */ |
103 |
r = map_col(col,RED); |
104 |
g = map_col(col,GRN); |
105 |
b = map_col(col,BLU); |
106 |
/* reduce resolution */ |
107 |
cv[RED] = (r*NRED)>>8; |
108 |
cv[GRN] = (g*NGRN)>>8; |
109 |
cv[BLU] = (b*NBLU)>>8; |
110 |
/* add to histogram */ |
111 |
histo[cv[RED]][cv[GRN]][cv[BLU]]++; |
112 |
/* find pixel in tree */ |
113 |
for (tp = ctree, h = 0; is_branch(*tp); h++) |
114 |
if (cv[prim(*tp)] < part(*tp)) |
115 |
tp += 1<<h; /* left branch */ |
116 |
else |
117 |
tp += 1<<(h+1); /* right branch */ |
118 |
h = pval(*tp); |
119 |
/* add to color table */ |
120 |
clrtab[h].sum[RED] += r; |
121 |
clrtab[h].sum[GRN] += g; |
122 |
clrtab[h].sum[BLU] += b; |
123 |
clrtab[h].n++; |
124 |
/* recompute average */ |
125 |
r = clrtab[h].sum[RED] / clrtab[h].n; |
126 |
g = clrtab[h].sum[GRN] / clrtab[h].n; |
127 |
b = clrtab[h].sum[BLU] / clrtab[h].n; |
128 |
/* check for movement */ |
129 |
if (clrtab[h].n == 1 || |
130 |
(r-clrtab[h].ent[RED])*(r-clrtab[h].ent[RED]) + |
131 |
(g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) + |
132 |
(b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) { |
133 |
clrtab[h].ent[RED] = r; |
134 |
clrtab[h].ent[GRN] = g; /* reassign pixel */ |
135 |
clrtab[h].ent[BLU] = b; |
136 |
#ifdef DEBUG |
137 |
sprintf(errmsg, "pixel %d = (%d,%d,%d) (%d refs)\n", |
138 |
h, r, g, b, clrtab[h].n); |
139 |
eputs(errmsg); |
140 |
#endif |
141 |
(*set_pixel)(h, r, g, b); |
142 |
143 |
return(h); /* return pixel value */ |
144 |
145 |
146 |
147 |
void |
148 |
make_gmap(gam) /* make gamma correction map */ |
149 |
double gam; |
150 |
151 |
register int i; |
152 |
153 |
for (i = 0; i < 256; i++) |
154 |
clrmap[RED][i] = |
155 |
clrmap[GRN][i] = |
156 |
clrmap[BLU][i] = 256.0 * pow((i+0.5)/256.0, 1.0/gam); |
157 |
158 |
159 |
160 |
void |
161 |
set_cmap(rmap, gmap, bmap) /* set custom color correction map */ |
162 |
BYTE *rmap, *gmap, *bmap; |
163 |
164 |
bcopy((void *)rmap, (void *)clrmap[RED], 256); |
165 |
bcopy((void *)gmap, (void *)clrmap[GRN], 256); |
166 |
bcopy((void *)bmap, (void *)clrmap[BLU], 256); |
167 |
168 |
169 |
170 |
void |
171 |
map_color(rgb, col) /* map a color to a byte triplet */ |
172 |
BYTE rgb[3]; |
173 |
COLOR col; |
174 |
175 |
rgb[RED] = map_col(col,RED); |
176 |
rgb[GRN] = map_col(col,GRN); |
177 |
rgb[BLU] = map_col(col,BLU); |
178 |
179 |
180 |
181 |
static void |
182 |
cut(tree, level, box, c0, c1) /* partition color space */ |
183 |
register CNODE *tree; |
184 |
int level; |
185 |
register int box[3][2]; |
186 |
int c0, c1; |
187 |
188 |
int kb[3][2]; |
189 |
190 |
if (c1-c0 <= 1) { /* assign pixel */ |
191 |
*tree = set_pval(c0); |
192 |
return; |
193 |
194 |
/* split box */ |
195 |
*tree = split(box); |
196 |
bcopy((void *)box, (void *)kb, sizeof(kb)); |
197 |
/* do left (lesser) branch */ |
198 |
kb[prim(*tree)][1] = part(*tree); |
199 |
cut(tree+(1<<level), level+1, kb, c0, (c0+c1)>>1); |
200 |
/* do right branch */ |
201 |
kb[prim(*tree)][0] = part(*tree); |
202 |
kb[prim(*tree)][1] = box[prim(*tree)][1]; |
203 |
cut(tree+(1<<(level+1)), level+1, kb, (c0+c1)>>1, c1); |
204 |
205 |
206 |
207 |
static int |
208 |
split(box) /* find median cut for box */ |
209 |
210 |
211 |
#define c0 r |
212 |
register int r, g, b; |
213 |
int pri; |
214 |
long t[HMAX], med; |
215 |
/* find dominant axis */ |
216 |
pri = RED; |
217 |
if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) |
218 |
pri = GRN; |
219 |
if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0]) |
220 |
pri = BLU; |
221 |
/* sum histogram over box */ |
222 |
med = 0; |
223 |
switch (pri) { |
224 |
case RED: |
225 |
for (r = box[RED][0]; r < box[RED][1]; r++) { |
226 |
t[r] = 0; |
227 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) |
228 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) |
229 |
t[r] += histo[r][g][b]; |
230 |
med += t[r]; |
231 |
232 |
break; |
233 |
case GRN: |
234 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) { |
235 |
t[g] = 0; |
236 |
237 |
for (r = box[RED][0]; r < box[RED][1]; r++) |
238 |
t[g] += histo[r][g][b]; |
239 |
med += t[g]; |
240 |
241 |
break; |
242 |
case BLU: |
243 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) { |
244 |
t[b] = 0; |
245 |
246 |
247 |
t[b] += histo[r][g][b]; |
248 |
med += t[b]; |
249 |
250 |
break; |
251 |
252 |
if (med < MINSAMP) /* if too sparse, split at midpoint */ |
253 |
return(set_branch(pri,(box[pri][0]+box[pri][1])>>1)); |
254 |
/* find median position */ |
255 |
med >>= 1; |
256 |
for (c0 = box[pri][0]; med > 0; c0++) |
257 |
med -= t[c0]; |
258 |
if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */ |
259 |
c0--; /* part left of median */ |
260 |
return(set_branch(pri,c0)); |
261 |
#undef c0 |
262 |
