1 |
/* Copyright (c) 1989 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* colortab.c - allocate and control dynamic color table. |
9 |
10 |
* We start off with a uniform partition of color space. |
11 |
* As pixels are sent to the frame buffer, a histogram is built. |
12 |
* When a new color table is requested, the histogram is used |
13 |
* to make a pseudo-optimal partition, after which the |
14 |
* histogram is cleared. This algorithm |
15 |
* performs only as well as the next drawing's color |
16 |
* distribution is correlated to the last. |
17 |
18 |
19 |
#include "color.h" |
20 |
21 |
#define NULL 0 |
22 |
/* histogram resolution */ |
23 |
#define NRED 24 |
24 |
#define NGRN 32 |
25 |
#define NBLU 16 |
26 |
#define HMAX NGRN |
27 |
/* minimum box count for adaptive partition */ |
28 |
#define MINSAMP 7 |
29 |
/* maximum distance^2 before color reassign */ |
30 |
#define MAXDST2 12 |
31 |
/* map a color */ |
32 |
#define map_col(c,p) clrmap[p][ colval(c,p)<1. ? \ |
33 |
(int)(colval(c,p)*256.) : 255 ] |
34 |
/* color partition tree */ |
35 |
#define CNODE short |
36 |
#define set_branch(p,c) ((c)<<2|(p)) |
37 |
#define set_pval(pv) ((pv)<<2|3) |
38 |
#define is_branch(cn) (((cn)&3)!=3) |
39 |
#define is_pval(cn) (((cn)&3)==3) |
40 |
#define part(cn) ((cn)>>2) |
41 |
#define prim(cn) ((cn)&3) |
42 |
#define pval(cn) ((cn)>>2) |
43 |
/* our color table */ |
44 |
static struct tabent { |
45 |
long sum[3]; /* sum of colors using this entry */ |
46 |
long n; /* number of colors */ |
47 |
short ent[3]; /* current table value */ |
48 |
} *clrtab = NULL; |
49 |
/* color cube partition */ |
50 |
static CNODE *ctree = NULL; |
51 |
/* our color correction map */ |
52 |
static BYTE clrmap[3][256]; |
53 |
/* histogram of colors used */ |
54 |
static unsigned short histo[NRED][NGRN][NBLU]; |
55 |
/* initial color cube boundary */ |
56 |
static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; |
57 |
58 |
59 |
int |
60 |
new_ctab(ncolors) /* start new color table with max ncolors */ |
61 |
int ncolors; |
62 |
63 |
int treesize; |
64 |
65 |
if (ncolors < 1) |
66 |
return(0); |
67 |
/* free old tables */ |
68 |
if (clrtab != NULL) |
69 |
free((char *)clrtab); |
70 |
if (ctree != NULL) |
71 |
free((char *)ctree); |
72 |
/* get new tables */ |
73 |
for (treesize = 1; treesize < ncolors; treesize <<= 1) |
74 |
75 |
treesize <<= 1; |
76 |
clrtab = (struct tabent *)calloc(ncolors, sizeof(struct tabent)); |
77 |
ctree = (CNODE *)malloc(treesize*sizeof(CNODE)); |
78 |
if (clrtab == NULL || ctree == NULL) |
79 |
return(0); |
80 |
/* partition color space */ |
81 |
cut(ctree, 0, CLRCUBE, 0, ncolors); |
82 |
/* clear histogram */ |
83 |
bzero((char *)histo, sizeof(histo)); |
84 |
/* return number of colors used */ |
85 |
return(ncolors); |
86 |
87 |
88 |
89 |
int |
90 |
get_pixel(col, set_pixel) /* get pixel for color */ |
91 |
COLOR col; |
92 |
int (*set_pixel)(); |
93 |
94 |
int r, g, b; |
95 |
int cv[3]; |
96 |
register CNODE *tp; |
97 |
register int h; |
98 |
/* map color */ |
99 |
r = map_col(col,RED); |
100 |
g = map_col(col,GRN); |
101 |
b = map_col(col,BLU); |
102 |
/* reduce resolution */ |
103 |
cv[RED] = (r*NRED)>>8; |
104 |
cv[GRN] = (g*NGRN)>>8; |
105 |
cv[BLU] = (b*NBLU)>>8; |
106 |
/* add to histogram */ |
107 |
histo[cv[RED]][cv[GRN]][cv[BLU]]++; |
108 |
/* find pixel in tree */ |
109 |
for (tp = ctree, h = 0; is_branch(*tp); h++) |
110 |
if (cv[prim(*tp)] < part(*tp)) |
111 |
tp += 1<<h; /* left branch */ |
112 |
else |
113 |
tp += 1<<(h+1); /* right branch */ |
114 |
h = pval(*tp); |
115 |
/* add to color table */ |
116 |
clrtab[h].sum[RED] += r; |
117 |
clrtab[h].sum[GRN] += g; |
118 |
clrtab[h].sum[BLU] += b; |
119 |
clrtab[h].n++; |
120 |
/* recompute average */ |
121 |
r = clrtab[h].sum[RED] / clrtab[h].n; |
122 |
g = clrtab[h].sum[GRN] / clrtab[h].n; |
123 |
b = clrtab[h].sum[BLU] / clrtab[h].n; |
124 |
/* check for movement */ |
125 |
if (clrtab[h].n == 1 || |
126 |
(r-clrtab[h].ent[RED])*(r-clrtab[h].ent[RED]) + |
127 |
(g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) + |
128 |
(b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) { |
129 |
clrtab[h].ent[RED] = r; |
130 |
clrtab[h].ent[GRN] = g; /* reassign pixel */ |
131 |
clrtab[h].ent[BLU] = b; |
132 |
#ifdef notdef |
133 |
printf("pixel %d = (%d,%d,%d) (%d refs)\n", |
134 |
h, r, g, b, clrtab[h].n); |
135 |
#endif |
136 |
(*set_pixel)(h, r, g, b); |
137 |
138 |
return(h); /* return pixel value */ |
139 |
140 |
141 |
142 |
make_gmap(gam) /* make gamma correction map */ |
143 |
double gam; |
144 |
145 |
extern double pow(); |
146 |
register int i; |
147 |
148 |
for (i = 0; i < 256; i++) |
149 |
clrmap[RED][i] = |
150 |
clrmap[GRN][i] = |
151 |
clrmap[BLU][i] = 256.0 * pow(i/256.0, 1.0/gam); |
152 |
153 |
154 |
155 |
set_cmap(rmap, gmap, bmap) /* set custom color correction map */ |
156 |
BYTE *rmap, *gmap, *bmap; |
157 |
158 |
bcopy((char *)rmap, (char *)clrmap[RED], 256); |
159 |
bcopy((char *)gmap, (char *)clrmap[GRN], 256); |
160 |
bcopy((char *)bmap, (char *)clrmap[BLU], 256); |
161 |
162 |
163 |
164 |
static |
165 |
cut(tree, level, box, c0, c1) /* partition color space */ |
166 |
register CNODE *tree; |
167 |
int level; |
168 |
register int box[3][2]; |
169 |
int c0, c1; |
170 |
171 |
int kb[3][2]; |
172 |
173 |
if (c1-c0 <= 1) { /* assign pixel */ |
174 |
*tree = set_pval(c0); |
175 |
return; |
176 |
177 |
/* split box */ |
178 |
*tree = split(box); |
179 |
bcopy((char *)box, (char *)kb, sizeof(kb)); |
180 |
/* do left (lesser) branch */ |
181 |
kb[prim(*tree)][1] = part(*tree); |
182 |
cut(tree+(1<<level), level+1, kb, c0, (c0+c1)>>1); |
183 |
/* do right branch */ |
184 |
kb[prim(*tree)][0] = part(*tree); |
185 |
kb[prim(*tree)][1] = box[prim(*tree)][1]; |
186 |
cut(tree+(1<<(level+1)), level+1, kb, (c0+c1)>>1, c1); |
187 |
188 |
189 |
190 |
static int |
191 |
split(box) /* find median cut for box */ |
192 |
193 |
194 |
#define c0 r |
195 |
register int r, g, b; |
196 |
int pri; |
197 |
int t[HMAX], med; |
198 |
/* find dominant axis */ |
199 |
pri = RED; |
200 |
if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0]) |
201 |
pri = GRN; |
202 |
if (box[BLU][1]-box[BLU][0] > box[pri][1]-box[pri][0]) |
203 |
pri = BLU; |
204 |
/* sum histogram over box */ |
205 |
med = 0; |
206 |
switch (pri) { |
207 |
case RED: |
208 |
for (r = box[RED][0]; r < box[RED][1]; r++) { |
209 |
t[r] = 0; |
210 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) |
211 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) |
212 |
t[r] += histo[r][g][b]; |
213 |
med += t[r]; |
214 |
215 |
break; |
216 |
case GRN: |
217 |
for (g = box[GRN][0]; g < box[GRN][1]; g++) { |
218 |
t[g] = 0; |
219 |
220 |
for (r = box[RED][0]; r < box[RED][1]; r++) |
221 |
t[g] += histo[r][g][b]; |
222 |
med += t[g]; |
223 |
224 |
break; |
225 |
case BLU: |
226 |
for (b = box[BLU][0]; b < box[BLU][1]; b++) { |
227 |
t[b] = 0; |
228 |
229 |
230 |
t[b] += histo[r][g][b]; |
231 |
med += t[b]; |
232 |
233 |
break; |
234 |
235 |
if (med < MINSAMP) /* if too sparse, split at midpoint */ |
236 |
return(set_branch(pri,(box[pri][0]+box[pri][1])>>1)); |
237 |
/* find median position */ |
238 |
med >>= 1; |
239 |
for (c0 = box[pri][0]; med > 0; c0++) |
240 |
med -= t[c0]; |
241 |
if (c0 > (box[pri][0]+box[pri][1])>>1) /* if past the midpoint */ |
242 |
c0--; /* part left of median */ |
243 |
return(set_branch(pri,c0)); |
244 |
#undef c0 |
245 |
