--- ray/src/rt/colortab.c 1991/11/12 17:09:57 2.1 +++ ray/src/rt/colortab.c 2003/06/30 14:59:12 2.8 @@ -1,9 +1,6 @@ -/* Copyright (c) 1989 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: colortab.c,v 2.8 2003/06/30 14:59:12 schorsch Exp $"; #endif - /* * colortab.c - allocate and control dynamic color table. * @@ -14,11 +11,17 @@ static char SCCSid[] = "$SunId$ LBL"; * histogram is cleared. This algorithm * performs only as well as the next drawing's color * distribution is correlated to the last. + * + * External symbols declared in drvier.h */ -#include "standard.h" +#include "copyright.h" +#include + +#include "standard.h" #include "color.h" + /* histogram resolution */ #define NRED 24 #define NGRN 32 @@ -33,7 +36,7 @@ static char SCCSid[] = "$SunId$ LBL"; (int)(colval(c,p)*256.) : 255 ] /* color partition tree */ #define CNODE short -#define set_branch(p,c) ((c)<<2|(p)) +#define set_branch(p,c) ((c)<<2|(p)) #define set_pval(pv) ((pv)<<2|3) #define is_branch(cn) (((cn)&3)!=3) #define is_pval(cn) (((cn)&3)==3) @@ -53,9 +56,12 @@ static BYTE clrmap[3][256]; /* histogram of colors used */ static unsigned short histo[NRED][NGRN][NBLU]; /* initial color cube boundary */ -static int CLRCUBE[3][2] = {0,NRED,0,NGRN,0,NBLU}; +static int CLRCUBE[3][2] = {{0,NRED},{0,NGRN},{0,NBLU}}; +static int split(); +static void cut(); + int new_ctab(ncolors) /* start new color table with max ncolors */ int ncolors; @@ -66,9 +72,9 @@ int ncolors; return(0); /* free old tables */ if (clrtab != NULL) - free((char *)clrtab); + free((void *)clrtab); if (ctree != NULL) - free((char *)ctree); + free((void *)ctree); /* get new tables */ for (treesize = 1; treesize < ncolors; treesize <<= 1) ; @@ -80,7 +86,7 @@ int ncolors; /* partition color space */ cut(ctree, 0, CLRCUBE, 0, ncolors); /* clear histogram */ - bzero((char *)histo, sizeof(histo)); + memset((void *)histo, '\0', sizeof(histo)); /* return number of colors used */ return(ncolors); } @@ -89,9 +95,8 @@ int ncolors; int get_pixel(col, set_pixel) /* get pixel for color */ COLOR col; -int (*set_pixel)(); +void (*set_pixel)(); { - extern char errmsg[]; int r, g, b; int cv[3]; register CNODE *tp; @@ -128,7 +133,7 @@ int (*set_pixel)(); (g-clrtab[h].ent[GRN])*(g-clrtab[h].ent[GRN]) + (b-clrtab[h].ent[BLU])*(b-clrtab[h].ent[BLU]) > MAXDST2) { clrtab[h].ent[RED] = r; - clrtab[h].ent[GRN] = g; /* reassign pixel */ + clrtab[h].ent[GRN] = g; /* reassign pixel */ clrtab[h].ent[BLU] = b; #ifdef DEBUG sprintf(errmsg, "pixel %d = (%d,%d,%d) (%d refs)\n", @@ -141,10 +146,10 @@ int (*set_pixel)(); } +void make_gmap(gam) /* make gamma correction map */ -double gam; +double gam; { - extern double pow(); register int i; for (i = 0; i < 256; i++) @@ -154,15 +159,17 @@ double gam; } +void set_cmap(rmap, gmap, bmap) /* set custom color correction map */ BYTE *rmap, *gmap, *bmap; { - bcopy((char *)rmap, (char *)clrmap[RED], 256); - bcopy((char *)gmap, (char *)clrmap[GRN], 256); - bcopy((char *)bmap, (char *)clrmap[BLU], 256); + memcpy((void *)clrmap[RED], (void *)rmap, 256); + memcpy((void *)clrmap[GRN], (void *)gmap, 256); + memcpy((void *)clrmap[BLU], (void *)bmap, 256); } +void map_color(rgb, col) /* map a color to a byte triplet */ BYTE rgb[3]; COLOR col; @@ -173,7 +180,7 @@ COLOR col; } -static +static void cut(tree, level, box, c0, c1) /* partition color space */ register CNODE *tree; int level; @@ -188,7 +195,7 @@ int c0, c1; } /* split box */ *tree = split(box); - bcopy((char *)box, (char *)kb, sizeof(kb)); + memcpy((void *)kb, (void *)box, sizeof(kb)); /* do left (lesser) branch */ kb[prim(*tree)][1] = part(*tree); cut(tree+(1<>1); @@ -206,7 +213,7 @@ register int box[3][2]; #define c0 r register int r, g, b; int pri; - int t[HMAX], med; + long t[HMAX], med; /* find dominant axis */ pri = RED; if (box[GRN][1]-box[GRN][0] > box[pri][1]-box[pri][0])
