1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: ashikhmin.c,v 2.5 2015/05/21 05:54:54 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Shading functions for Ashikhmin-Shirley anisotropic materials. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "ambient.h" |
12 |
#include "otypes.h" |
13 |
#include "rtotypes.h" |
14 |
#include "source.h" |
15 |
#include "func.h" |
16 |
#include "random.h" |
17 |
#include "pmapmat.h" |
18 |
19 |
#ifndef MAXITER |
20 |
#define MAXITER 10 /* maximum # specular ray attempts */ |
21 |
#endif |
22 |
23 |
24 |
* Ashikhmin-Shirley model |
25 |
26 |
* Arguments for MAT_ASHIKHMIN are: |
27 |
* 4+ ux uy uz funcfile [transform...] |
28 |
* 0 |
29 |
* 8 dred dgrn dblu sred sgrn sblu u-power v-power |
30 |
31 |
32 |
/* specularity flags */ |
33 |
#define SPA_REFL 01 /* has reflected specular component */ |
34 |
#define SPA_FLAT 02 /* reflecting surface is flat */ |
35 |
#define SPA_RBLT 010 /* reflection below sample threshold */ |
36 |
37 |
typedef struct { |
38 |
OBJREC *mp; /* material pointer */ |
39 |
RAY *rp; /* ray pointer */ |
40 |
short specfl; /* specularity flags, defined above */ |
41 |
COLOR mcolor; /* color of this material */ |
42 |
COLOR scolor; /* color of specular component */ |
43 |
FVECT u, v; /* u and v vectors orienting anisotropy */ |
44 |
double u_power; /* u power */ |
45 |
double v_power; /* v power */ |
46 |
FVECT pnorm; /* perturbed surface normal */ |
47 |
double pdot; /* perturbed dot product */ |
48 |
} ASHIKDAT; /* anisotropic material data */ |
49 |
50 |
static void getacoords_as(ASHIKDAT *np); |
51 |
static void ashiksamp(ASHIKDAT *np); |
52 |
53 |
#undef MAX |
54 |
#define MAX(a,b) ((a)>(b) ? (a) : (b)) |
55 |
56 |
57 |
static double |
58 |
schlick_fres(double dprod) |
59 |
60 |
double pf = 1. - dprod; |
61 |
62 |
return(pf*pf*pf*pf*pf); |
63 |
64 |
65 |
66 |
static void |
67 |
dirashik( /* compute source contribution */ |
68 |
COLOR cval, /* returned coefficient */ |
69 |
void *nnp, /* material data */ |
70 |
FVECT ldir, /* light source direction */ |
71 |
double omega /* light source size */ |
72 |
73 |
74 |
ASHIKDAT *np = nnp; |
75 |
double ldot; |
76 |
double dtmp, dtmp1, dtmp2; |
77 |
FVECT h; |
78 |
COLOR ctmp; |
79 |
80 |
setcolor(cval, 0.0, 0.0, 0.0); |
81 |
82 |
ldot = DOT(np->pnorm, ldir); |
83 |
84 |
if (ldot < 0.0) |
85 |
return; /* wrong side */ |
86 |
87 |
88 |
* Compute and add diffuse reflected component to returned |
89 |
* color. |
90 |
91 |
copycolor(ctmp, np->mcolor); |
92 |
dtmp = ldot * omega * (1.0/PI) * (1. - schlick_fres(ldot)); |
93 |
scalecolor(ctmp, dtmp); |
94 |
addcolor(cval, ctmp); |
95 |
96 |
if (!(np->specfl & SPA_REFL) || ambRayInPmap(np->rp)) |
97 |
return; |
98 |
99 |
* Compute specular reflection coefficient |
100 |
101 |
/* half vector */ |
102 |
VSUB(h, ldir, np->rp->rdir); |
103 |
normalize(h); |
104 |
/* ellipse */ |
105 |
dtmp1 = DOT(np->u, h); |
106 |
dtmp1 *= dtmp1 * np->u_power; |
107 |
dtmp2 = DOT(np->v, h); |
108 |
dtmp2 *= dtmp2 * np->v_power; |
109 |
/* Ashikhmin-Shirley model*/ |
110 |
dtmp = DOT(np->pnorm, h); |
111 |
dtmp = pow(dtmp, (dtmp1+dtmp2)/(1.-dtmp*dtmp)); |
112 |
dtmp *= sqrt((np->u_power+1.)*(np->v_power+1.)); |
113 |
dtmp /= 8.*PI * DOT(ldir,h) * MAX(ldot,np->pdot); |
114 |
/* worth using? */ |
115 |
if (dtmp > FTINY) { |
116 |
copycolor(ctmp, np->scolor); |
117 |
dtmp *= ldot * omega; |
118 |
119 |
120 |
121 |
122 |
123 |
124 |
int |
125 |
m_ashikhmin( /* shade ray that hit something anisotropic */ |
126 |
OBJREC *m, |
127 |
RAY *r |
128 |
129 |
130 |
ASHIKDAT nd; |
131 |
COLOR ctmp; |
132 |
double fres; |
133 |
int i; |
134 |
/* easy shadow test */ |
135 |
if (r->crtype & SHADOW) |
136 |
return(1); |
137 |
138 |
if (m->oargs.nfargs != 8) |
139 |
objerror(m, USER, "bad number of real arguments"); |
140 |
/* check for back side */ |
141 |
if (r->rod < 0.0) { |
142 |
if (!backvis) { |
143 |
raytrans(r); |
144 |
return(1); |
145 |
146 |
raytexture(r, m->omod); |
147 |
flipsurface(r); /* reorient if backvis */ |
148 |
} else |
149 |
150 |
/* get material color */ |
151 |
nd.mp = m; |
152 |
nd.rp = r; |
153 |
setcolor(nd.mcolor, m->oargs.farg[0], |
154 |
m->oargs.farg[1], |
155 |
m->oargs.farg[2]); |
156 |
setcolor(nd.scolor, m->oargs.farg[3], |
157 |
m->oargs.farg[4], |
158 |
m->oargs.farg[5]); |
159 |
/* get specular power */ |
160 |
nd.specfl = 0; |
161 |
nd.u_power = m->oargs.farg[6]; |
162 |
nd.v_power = m->oargs.farg[7]; |
163 |
164 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
165 |
if (nd.pdot < .001) |
166 |
nd.pdot = .001; /* non-zero for dirashik() */ |
167 |
multcolor(nd.mcolor, r->pcol); /* modify diffuse color */ |
168 |
169 |
if (bright(nd.scolor) > FTINY) { /* adjust specular color */ |
170 |
nd.specfl |= SPA_REFL; |
171 |
/* check threshold */ |
172 |
if (specthresh >= bright(nd.scolor)-FTINY) |
173 |
nd.specfl |= SPA_RBLT; |
174 |
fres = schlick_fres(nd.pdot); /* Schick's Fresnel approx */ |
175 |
for (i = 0; i < 3; i++) |
176 |
colval(nd.scolor,i) += (1.-colval(nd.scolor,i))*fres; |
177 |
178 |
if (r->ro != NULL && isflat(r->ro->otype)) |
179 |
nd.specfl |= SPA_FLAT; |
180 |
/* set up coordinates */ |
181 |
getacoords_as(&nd); |
182 |
/* specular sampling? */ |
183 |
if ((nd.specfl & (SPA_REFL|SPA_RBLT)) == SPA_REFL) |
184 |
ashiksamp(&nd); |
185 |
/* diffuse interreflection */ |
186 |
if (bright(nd.mcolor) > FTINY) { |
187 |
copycolor(ctmp, nd.mcolor); /* modified by material color */ |
188 |
if (nd.specfl & SPA_RBLT) /* add in specular as well? */ |
189 |
addcolor(ctmp, nd.scolor); |
190 |
multambient(ctmp, r, nd.pnorm); |
191 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
192 |
193 |
direct(r, dirashik, &nd); /* add direct component */ |
194 |
195 |
return(1); |
196 |
197 |
198 |
199 |
static void |
200 |
getacoords_as( /* set up coordinate system */ |
201 |
ASHIKDAT *np |
202 |
203 |
204 |
MFUNC *mf; |
205 |
int i; |
206 |
207 |
mf = getfunc(np->mp, 3, 0x7, 1); |
208 |
setfunc(np->mp, np->rp); |
209 |
errno = 0; |
210 |
211 |
np->u[i] = evalue(mf->ep[i]); |
212 |
if ((errno == EDOM) | (errno == ERANGE)) |
213 |
np->u[0] = np->u[1] = np->u[2] = 0.0; |
214 |
if (mf->fxp != &unitxf) |
215 |
multv3(np->u, np->u, mf->fxp->xfm); |
216 |
fcross(np->v, np->pnorm, np->u); |
217 |
if (normalize(np->v) == 0.0) { |
218 |
if (fabs(np->u_power - np->v_power) > 0.1) |
219 |
objerror(np->mp, WARNING, "bad orientation vector"); |
220 |
getperpendicular(np->u, np->pnorm, 1); /* punting */ |
221 |
222 |
np->u_power = np->v_power = |
223 |
2./(1./(np->u_power+1e-5) + 1./(np->v_power+1e-5)); |
224 |
} else |
225 |
fcross(np->u, np->v, np->pnorm); |
226 |
227 |
228 |
229 |
static void |
230 |
ashiksamp( /* sample anisotropic Ashikhmin-Shirley specular */ |
231 |
ASHIKDAT *np |
232 |
233 |
234 |
RAY sr; |
235 |
FVECT h; |
236 |
double rv[2], dtmp; |
237 |
double cosph, sinph, costh, sinth; |
238 |
int maxiter, ntrials, nstarget, nstaken; |
239 |
int i; |
240 |
241 |
if (rayorigin(&sr, SPECULAR, np->rp, np->scolor) < 0) |
242 |
return; |
243 |
244 |
nstarget = 1; |
245 |
if (specjitter > 1.5) { /* multiple samples? */ |
246 |
nstarget = specjitter*np->rp->rweight + .5; |
247 |
if (sr.rweight <= minweight*nstarget) |
248 |
nstarget = sr.rweight/minweight; |
249 |
if (nstarget > 1) { |
250 |
dtmp = 1./nstarget; |
251 |
scalecolor(sr.rcoef, dtmp); |
252 |
sr.rweight *= dtmp; |
253 |
} else |
254 |
nstarget = 1; |
255 |
256 |
dimlist[ndims++] = (int)(size_t)np->mp; |
257 |
maxiter = MAXITER*nstarget; |
258 |
for (nstaken = ntrials = 0; nstaken < nstarget && |
259 |
ntrials < maxiter; ntrials++) { |
260 |
if (ntrials) |
261 |
dtmp = frandom(); |
262 |
else |
263 |
dtmp = urand(ilhash(dimlist,ndims)+647+samplendx); |
264 |
multisamp(rv, 2, dtmp); |
265 |
dtmp = 2.*PI * rv[0]; |
266 |
cosph = sqrt(np->v_power + 1.) * tcos(dtmp); |
267 |
sinph = sqrt(np->u_power + 1.) * tsin(dtmp); |
268 |
dtmp = 1./sqrt(cosph*cosph + sinph*sinph); |
269 |
cosph *= dtmp; |
270 |
sinph *= dtmp; |
271 |
costh = pow(rv[1], 1./(np->u_power*cosph*cosph+np->v_power*sinph*sinph+1.)); |
272 |
if (costh <= FTINY) |
273 |
continue; |
274 |
sinth = sqrt(1. - costh*costh); |
275 |
276 |
h[i] = cosph*sinth*np->u[i] + sinph*sinth*np->v[i] + costh*np->pnorm[i]; |
277 |
278 |
if (nstaken) |
279 |
rayclear(&sr); |
280 |
dtmp = -2.*DOT(h, np->rp->rdir); |
281 |
VSUM(sr.rdir, np->rp->rdir, h, dtmp); |
282 |
/* sample rejection test */ |
283 |
if (DOT(sr.rdir, np->rp->ron) <= FTINY) |
284 |
continue; |
285 |
checknorm(sr.rdir); |
286 |
rayvalue(&sr); |
287 |
multcolor(sr.rcol, sr.rcoef); |
288 |
addcolor(np->rp->rcol, sr.rcol); |
289 |
++nstaken; |
290 |
291 |
ndims--; |
292 |
