1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* Shading functions for Ashikhmin-Shirley anisotropic materials. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "ambient.h" |
12 |
#include "otypes.h" |
13 |
#include "rtotypes.h" |
14 |
#include "source.h" |
15 |
#include "func.h" |
16 |
#include "random.h" |
17 |
18 |
#ifndef MAXITER |
19 |
#define MAXITER 10 /* maximum # specular ray attempts */ |
20 |
#endif |
21 |
22 |
23 |
* Ashikhmin-Shirley model |
24 |
25 |
* Arguments for MAT_ASHIKHMIN are: |
26 |
* 4+ ux uy uz funcfile [transform...] |
27 |
* 0 |
28 |
* 8 dred dgrn dblu sred sgrn sblu u-power v-power |
29 |
30 |
31 |
/* specularity flags */ |
32 |
#define SPA_REFL 01 /* has reflected specular component */ |
33 |
#define SPA_FLAT 02 /* reflecting surface is flat */ |
34 |
#define SPA_RBLT 010 /* reflection below sample threshold */ |
35 |
#define SPA_BADU 020 /* bad u direction calculation */ |
36 |
37 |
typedef struct { |
38 |
OBJREC *mp; /* material pointer */ |
39 |
RAY *rp; /* ray pointer */ |
40 |
short specfl; /* specularity flags, defined above */ |
41 |
COLOR mcolor; /* color of this material */ |
42 |
COLOR scolor; /* color of specular component */ |
43 |
FVECT u, v; /* u and v vectors orienting anisotropy */ |
44 |
double u_power; /* u power */ |
45 |
double v_power; /* v power */ |
46 |
FVECT pnorm; /* perturbed surface normal */ |
47 |
double pdot; /* perturbed dot product */ |
48 |
} ASHIKDAT; /* anisotropic material data */ |
49 |
50 |
static void getacoords_as(RAY *r, ASHIKDAT *np); |
51 |
static void ashiksamp(RAY *r, ASHIKDAT *np); |
52 |
53 |
54 |
static double |
55 |
max(double a, double b) { |
56 |
if (a > b) |
57 |
return(a); |
58 |
return(b); |
59 |
60 |
61 |
62 |
static double |
63 |
schlick_fres(double dprod) |
64 |
65 |
double pf = 1. - dprod; |
66 |
67 |
return(pf*pf*pf*pf*pf); |
68 |
69 |
70 |
71 |
static void |
72 |
dirashik( /* compute source contribution */ |
73 |
COLOR cval, /* returned coefficient */ |
74 |
void *nnp, /* material data */ |
75 |
FVECT ldir, /* light source direction */ |
76 |
double omega /* light source size */ |
77 |
78 |
79 |
ASHIKDAT *np = nnp; |
80 |
double ldot; |
81 |
double dtmp, dtmp1, dtmp2; |
82 |
FVECT h; |
83 |
COLOR ctmp; |
84 |
85 |
setcolor(cval, 0.0, 0.0, 0.0); |
86 |
87 |
ldot = DOT(np->pnorm, ldir); |
88 |
89 |
if (ldot < 0.0) |
90 |
return; /* wrong side */ |
91 |
92 |
93 |
* Compute and add diffuse reflected component to returned |
94 |
* color. |
95 |
96 |
copycolor(ctmp, np->mcolor); |
97 |
dtmp = ldot * omega * (1.0/PI) * (1. - schlick_fres(ldot)); |
98 |
scalecolor(ctmp, dtmp); |
99 |
addcolor(cval, ctmp); |
100 |
101 |
if ((np->specfl & (SPA_REFL|SPA_BADU)) != SPA_REFL) |
102 |
return; |
103 |
104 |
* Compute specular reflection coefficient |
105 |
106 |
/* half vector */ |
107 |
VSUB(h, ldir, np->rp->rdir); |
108 |
normalize(h); |
109 |
/* ellipse */ |
110 |
dtmp1 = DOT(np->u, h); |
111 |
dtmp1 *= dtmp1 * np->u_power; |
112 |
dtmp2 = DOT(np->v, h); |
113 |
dtmp2 *= dtmp2 * np->v_power; |
114 |
/* Ashikhmin-Shirley model*/ |
115 |
dtmp = DOT(np->pnorm, h); |
116 |
dtmp = pow(dtmp, (dtmp1+dtmp2)/(1.-dtmp*dtmp)); |
117 |
dtmp *= sqrt((np->u_power+1.)*(np->v_power+1.)); |
118 |
dtmp /= 8.*PI * DOT(ldir,h) * max(ldot,np->pdot); |
119 |
/* worth using? */ |
120 |
if (dtmp > FTINY) { |
121 |
copycolor(ctmp, np->scolor); |
122 |
dtmp *= ldot * omega; |
123 |
124 |
125 |
126 |
127 |
128 |
129 |
int |
130 |
m_ashikhmin( /* shade ray that hit something anisotropic */ |
131 |
OBJREC *m, |
132 |
RAY *r |
133 |
134 |
135 |
ASHIKDAT nd; |
136 |
COLOR ctmp; |
137 |
double fres; |
138 |
int i; |
139 |
/* easy shadow test */ |
140 |
if (r->crtype & SHADOW) |
141 |
return(1); |
142 |
143 |
if (m->oargs.nfargs != 8) |
144 |
objerror(m, USER, "bad number of real arguments"); |
145 |
/* check for back side */ |
146 |
if (r->rod < 0.0) { |
147 |
if (!backvis) { |
148 |
raytrans(r); |
149 |
return(1); |
150 |
151 |
raytexture(r, m->omod); |
152 |
flipsurface(r); /* reorient if backvis */ |
153 |
} else |
154 |
155 |
/* get material color */ |
156 |
nd.mp = m; |
157 |
nd.rp = r; |
158 |
setcolor(nd.mcolor, m->oargs.farg[0], |
159 |
m->oargs.farg[1], |
160 |
m->oargs.farg[2]); |
161 |
setcolor(nd.scolor, m->oargs.farg[3], |
162 |
m->oargs.farg[4], |
163 |
m->oargs.farg[5]); |
164 |
/* get specular power */ |
165 |
nd.specfl = 0; |
166 |
nd.u_power = m->oargs.farg[6]; |
167 |
nd.v_power = m->oargs.farg[7]; |
168 |
169 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
170 |
if (nd.pdot < .001) |
171 |
nd.pdot = .001; /* non-zero for dirashik() */ |
172 |
multcolor(nd.mcolor, r->pcol); /* modify diffuse color */ |
173 |
174 |
if (bright(nd.scolor) > FTINY) { /* adjust specular color */ |
175 |
nd.specfl |= SPA_REFL; |
176 |
/* check threshold */ |
177 |
if (specthresh >= bright(nd.scolor)-FTINY) |
178 |
nd.specfl |= SPA_RBLT; |
179 |
fres = schlick_fres(nd.pdot); /* Schick's Fresnel approx */ |
180 |
for (i = 0; i < 3; i++) |
181 |
colval(nd.scolor,i) += (1.-colval(nd.scolor,i))*fres; |
182 |
183 |
if (r->ro != NULL && isflat(r->ro->otype)) |
184 |
nd.specfl |= SPA_FLAT; |
185 |
/* set up coordinates */ |
186 |
getacoords_as(r, &nd); |
187 |
/* specular sampling? */ |
188 |
if ((nd.specfl & (SPA_REFL|SPA_RBLT)) == SPA_REFL) |
189 |
ashiksamp(r, &nd); |
190 |
/* diffuse interreflection */ |
191 |
if (bright(nd.mcolor) > FTINY) { |
192 |
copycolor(ctmp, nd.mcolor); /* modified by material color */ |
193 |
if (nd.specfl & SPA_RBLT) /* add in specular as well? */ |
194 |
addcolor(ctmp, nd.scolor); |
195 |
multambient(ctmp, r, nd.pnorm); |
196 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
197 |
198 |
direct(r, dirashik, &nd); /* add direct component */ |
199 |
200 |
return(1); |
201 |
202 |
203 |
204 |
static void |
205 |
getacoords_as( /* set up coordinate system */ |
206 |
RAY *r, |
207 |
ASHIKDAT *np |
208 |
209 |
210 |
MFUNC *mf; |
211 |
int i; |
212 |
213 |
mf = getfunc(np->mp, 3, 0x7, 1); |
214 |
setfunc(np->mp, r); |
215 |
errno = 0; |
216 |
217 |
np->u[i] = evalue(mf->ep[i]); |
218 |
if ((errno == EDOM) | (errno == ERANGE)) { |
219 |
objerror(np->mp, WARNING, "compute error"); |
220 |
np->specfl |= SPA_BADU; |
221 |
return; |
222 |
223 |
if (mf->fxp != &unitxf) |
224 |
multv3(np->u, np->u, mf->fxp->xfm); |
225 |
fcross(np->v, np->pnorm, np->u); |
226 |
if (normalize(np->v) == 0.0) { |
227 |
objerror(np->mp, WARNING, "illegal orientation vector"); |
228 |
229 |
return; |
230 |
231 |
fcross(np->u, np->v, np->pnorm); |
232 |
233 |
234 |
235 |
static void |
236 |
ashiksamp( /* sample anisotropic Ashikhmin-Shirley specular */ |
237 |
RAY *r, |
238 |
ASHIKDAT *np |
239 |
240 |
241 |
RAY sr; |
242 |
FVECT h; |
243 |
double rv[2], dtmp; |
244 |
double cosph, sinph, costh, sinth; |
245 |
COLOR scol; |
246 |
int maxiter, ntrials, nstarget, nstaken; |
247 |
int i; |
248 |
249 |
if (np->specfl & SPA_BADU || |
250 |
rayorigin(&sr, SPECULAR, r, np->scolor) < 0) |
251 |
return; |
252 |
253 |
nstarget = 1; |
254 |
if (specjitter > 1.5) { /* multiple samples? */ |
255 |
nstarget = specjitter*r->rweight + .5; |
256 |
if (sr.rweight <= minweight*nstarget) |
257 |
nstarget = sr.rweight/minweight; |
258 |
if (nstarget > 1) { |
259 |
dtmp = 1./nstarget; |
260 |
scalecolor(sr.rcoef, dtmp); |
261 |
sr.rweight *= dtmp; |
262 |
} else |
263 |
nstarget = 1; |
264 |
265 |
dimlist[ndims++] = (int)(size_t)np->mp; |
266 |
maxiter = MAXITER*nstarget; |
267 |
for (nstaken = ntrials = 0; nstaken < nstarget && |
268 |
ntrials < maxiter; ntrials++) { |
269 |
if (ntrials) |
270 |
dtmp = frandom(); |
271 |
else |
272 |
dtmp = urand(ilhash(dimlist,ndims)+1823+samplendx); |
273 |
multisamp(rv, 2, dtmp); |
274 |
dtmp = 2.*PI * rv[0]; |
275 |
cosph = sqrt(np->u_power + 1.) * tcos(dtmp); |
276 |
sinph = sqrt(np->v_power + 1.) * tsin(dtmp); |
277 |
dtmp = 1./(cosph*cosph + sinph*sinph); |
278 |
cosph *= dtmp; |
279 |
sinph *= dtmp; |
280 |
costh = pow(rv[1], 1./(np->u_power*cosph*cosph+np->v_power*sinph*sinph+1.)); |
281 |
if (costh <= FTINY) |
282 |
continue; |
283 |
sinth = sqrt(1. - costh*costh); |
284 |
285 |
h[i] = cosph*sinth*np->u[i] + sinph*sinth*np->v[i] + costh*np->pnorm[i]; |
286 |
287 |
if (nstaken) |
288 |
rayclear(&sr); |
289 |
dtmp = -2.*DOT(h, r->rdir); |
290 |
VSUM(sr.rdir, r->rdir, h, dtmp); |
291 |
/* sample rejection test */ |
292 |
if (DOT(sr.rdir, r->ron) <= FTINY) |
293 |
continue; |
294 |
rayvalue(&sr); |
295 |
multcolor(sr.rcol, sr.rcoef); |
296 |
addcolor(r->rcol, sr.rcol); |
297 |
++nstaken; |
298 |
299 |
ndims--; |
300 |
