| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: ashikhmin.c,v 2.5 2015/05/21 05:54:54 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Shading functions for Ashikhmin-Shirley anisotropic materials.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "ambient.h"
| 12 |
#include "otypes.h"
| 13 |
#include "rtotypes.h"
| 14 |
#include "source.h"
| 15 |
#include "func.h"
| 16 |
#include "random.h"
| 17 |
#include "pmapmat.h"
| 18 |
| 19 |
#ifndef MAXITER
| 20 |
#define MAXITER 10 /* maximum # specular ray attempts */
| 21 |
#endif
| 22 |
| 23 |
| 24 |
* Ashikhmin-Shirley model
| 25 |
| 26 |
* Arguments for MAT_ASHIKHMIN are:
| 27 |
* 4+ ux uy uz funcfile [transform...]
| 28 |
* 0
| 29 |
* 8 dred dgrn dblu sred sgrn sblu u-power v-power
| 30 |
| 31 |
| 32 |
/* specularity flags */
| 33 |
#define SPA_REFL 01 /* has reflected specular component */
| 34 |
#define SPA_FLAT 02 /* reflecting surface is flat */
| 35 |
#define SPA_RBLT 010 /* reflection below sample threshold */
| 36 |
| 37 |
typedef struct {
| 38 |
OBJREC *mp; /* material pointer */
| 39 |
RAY *rp; /* ray pointer */
| 40 |
short specfl; /* specularity flags, defined above */
| 41 |
COLOR mcolor; /* color of this material */
| 42 |
COLOR scolor; /* color of specular component */
| 43 |
FVECT u, v; /* u and v vectors orienting anisotropy */
| 44 |
double u_power; /* u power */
| 45 |
double v_power; /* v power */
| 46 |
FVECT pnorm; /* perturbed surface normal */
| 47 |
double pdot; /* perturbed dot product */
| 48 |
} ASHIKDAT; /* anisotropic material data */
| 49 |
| 50 |
static void getacoords_as(ASHIKDAT *np);
| 51 |
static void ashiksamp(ASHIKDAT *np);
| 52 |
| 53 |
#undef MAX
| 54 |
#define MAX(a,b) ((a)>(b) ? (a) : (b))
| 55 |
| 56 |
| 57 |
static double
| 58 |
schlick_fres(double dprod)
| 59 |
| 60 |
double pf = 1. - dprod;
| 61 |
| 62 |
return(pf*pf*pf*pf*pf);
| 63 |
| 64 |
| 65 |
| 66 |
static void
| 67 |
dirashik( /* compute source contribution */
| 68 |
COLOR cval, /* returned coefficient */
| 69 |
void *nnp, /* material data */
| 70 |
FVECT ldir, /* light source direction */
| 71 |
double omega /* light source size */
| 72 |
| 73 |
| 74 |
ASHIKDAT *np = nnp;
| 75 |
double ldot;
| 76 |
double dtmp, dtmp1, dtmp2;
| 77 |
FVECT h;
| 78 |
COLOR ctmp;
| 79 |
| 80 |
setcolor(cval, 0.0, 0.0, 0.0);
| 81 |
| 82 |
ldot = DOT(np->pnorm, ldir);
| 83 |
| 84 |
if (ldot < 0.0)
| 85 |
return; /* wrong side */
| 86 |
| 87 |
| 88 |
* Compute and add diffuse reflected component to returned
| 89 |
* color.
| 90 |
| 91 |
copycolor(ctmp, np->mcolor);
| 92 |
dtmp = ldot * omega * (1.0/PI) * (1. - schlick_fres(ldot));
| 93 |
scalecolor(ctmp, dtmp);
| 94 |
addcolor(cval, ctmp);
| 95 |
| 96 |
if (!(np->specfl & SPA_REFL) || ambRayInPmap(np->rp))
| 97 |
return;
| 98 |
| 99 |
* Compute specular reflection coefficient
| 100 |
| 101 |
/* half vector */
| 102 |
VSUB(h, ldir, np->rp->rdir);
| 103 |
normalize(h);
| 104 |
/* ellipse */
| 105 |
dtmp1 = DOT(np->u, h);
| 106 |
dtmp1 *= dtmp1 * np->u_power;
| 107 |
dtmp2 = DOT(np->v, h);
| 108 |
dtmp2 *= dtmp2 * np->v_power;
| 109 |
/* Ashikhmin-Shirley model*/
| 110 |
dtmp = DOT(np->pnorm, h);
| 111 |
dtmp = pow(dtmp, (dtmp1+dtmp2)/(1.-dtmp*dtmp));
| 112 |
dtmp *= sqrt((np->u_power+1.)*(np->v_power+1.));
| 113 |
dtmp /= 8.*PI * DOT(ldir,h) * MAX(ldot,np->pdot);
| 114 |
/* worth using? */
| 115 |
if (dtmp > FTINY) {
| 116 |
copycolor(ctmp, np->scolor);
| 117 |
dtmp *= ldot * omega;
| 118 |
| 119 |
| 120 |
| 121 |
| 122 |
| 123 |
| 124 |
int
| 125 |
m_ashikhmin( /* shade ray that hit something anisotropic */
| 126 |
OBJREC *m,
| 127 |
RAY *r
| 128 |
| 129 |
| 130 |
ASHIKDAT nd;
| 131 |
COLOR ctmp;
| 132 |
double fres;
| 133 |
int i;
| 134 |
/* easy shadow test */
| 135 |
if (r->crtype & SHADOW)
| 136 |
return(1);
| 137 |
| 138 |
if (m->oargs.nfargs != 8)
| 139 |
objerror(m, USER, "bad number of real arguments");
| 140 |
/* check for back side */
| 141 |
if (r->rod < 0.0) {
| 142 |
if (!backvis) {
| 143 |
raytrans(r);
| 144 |
return(1);
| 145 |
| 146 |
raytexture(r, m->omod);
| 147 |
flipsurface(r); /* reorient if backvis */
| 148 |
} else
| 149 |
| 150 |
/* get material color */
| 151 |
nd.mp = m;
| 152 |
nd.rp = r;
| 153 |
setcolor(nd.mcolor, m->oargs.farg[0],
| 154 |
m->oargs.farg[1],
| 155 |
m->oargs.farg[2]);
| 156 |
setcolor(nd.scolor, m->oargs.farg[3],
| 157 |
m->oargs.farg[4],
| 158 |
m->oargs.farg[5]);
| 159 |
/* get specular power */
| 160 |
nd.specfl = 0;
| 161 |
nd.u_power = m->oargs.farg[6];
| 162 |
nd.v_power = m->oargs.farg[7];
| 163 |
| 164 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
| 165 |
if (nd.pdot < .001)
| 166 |
nd.pdot = .001; /* non-zero for dirashik() */
| 167 |
multcolor(nd.mcolor, r->pcol); /* modify diffuse color */
| 168 |
| 169 |
if (bright(nd.scolor) > FTINY) { /* adjust specular color */
| 170 |
nd.specfl |= SPA_REFL;
| 171 |
/* check threshold */
| 172 |
if (specthresh >= bright(nd.scolor)-FTINY)
| 173 |
nd.specfl |= SPA_RBLT;
| 174 |
fres = schlick_fres(nd.pdot); /* Schick's Fresnel approx */
| 175 |
for (i = 0; i < 3; i++)
| 176 |
colval(nd.scolor,i) += (1.-colval(nd.scolor,i))*fres;
| 177 |
| 178 |
if (r->ro != NULL && isflat(r->ro->otype))
| 179 |
nd.specfl |= SPA_FLAT;
| 180 |
/* set up coordinates */
| 181 |
getacoords_as(&nd);
| 182 |
/* specular sampling? */
| 183 |
if ((nd.specfl & (SPA_REFL|SPA_RBLT)) == SPA_REFL)
| 184 |
ashiksamp(&nd);
| 185 |
/* diffuse interreflection */
| 186 |
if (bright(nd.mcolor) > FTINY) {
| 187 |
copycolor(ctmp, nd.mcolor); /* modified by material color */
| 188 |
if (nd.specfl & SPA_RBLT) /* add in specular as well? */
| 189 |
addcolor(ctmp, nd.scolor);
| 190 |
multambient(ctmp, r, nd.pnorm);
| 191 |
addcolor(r->rcol, ctmp); /* add to returned color */
| 192 |
| 193 |
direct(r, dirashik, &nd); /* add direct component */
| 194 |
| 195 |
return(1);
| 196 |
| 197 |
| 198 |
| 199 |
static void
| 200 |
getacoords_as( /* set up coordinate system */
| 201 |
ASHIKDAT *np
| 202 |
| 203 |
| 204 |
MFUNC *mf;
| 205 |
int i;
| 206 |
| 207 |
mf = getfunc(np->mp, 3, 0x7, 1);
| 208 |
setfunc(np->mp, np->rp);
| 209 |
errno = 0;
| 210 |
| 211 |
np->u[i] = evalue(mf->ep[i]);
| 212 |
if ((errno == EDOM) | (errno == ERANGE))
| 213 |
np->u[0] = np->u[1] = np->u[2] = 0.0;
| 214 |
if (mf->fxp != &unitxf)
| 215 |
multv3(np->u, np->u, mf->fxp->xfm);
| 216 |
fcross(np->v, np->pnorm, np->u);
| 217 |
if (normalize(np->v) == 0.0) {
| 218 |
if (fabs(np->u_power - np->v_power) > 0.1)
| 219 |
objerror(np->mp, WARNING, "bad orientation vector");
| 220 |
getperpendicular(np->u, np->pnorm, 1); /* punting */
| 221 |
| 222 |
np->u_power = np->v_power =
| 223 |
2./(1./(np->u_power+1e-5) + 1./(np->v_power+1e-5));
| 224 |
} else
| 225 |
fcross(np->u, np->v, np->pnorm);
| 226 |
| 227 |
| 228 |
| 229 |
static void
| 230 |
ashiksamp( /* sample anisotropic Ashikhmin-Shirley specular */
| 231 |
ASHIKDAT *np
| 232 |
| 233 |
| 234 |
RAY sr;
| 235 |
FVECT h;
| 236 |
double rv[2], dtmp;
| 237 |
double cosph, sinph, costh, sinth;
| 238 |
int maxiter, ntrials, nstarget, nstaken;
| 239 |
int i;
| 240 |
| 241 |
if (rayorigin(&sr, SPECULAR, np->rp, np->scolor) < 0)
| 242 |
return;
| 243 |
| 244 |
nstarget = 1;
| 245 |
if (specjitter > 1.5) { /* multiple samples? */
| 246 |
nstarget = specjitter*np->rp->rweight + .5;
| 247 |
if (sr.rweight <= minweight*nstarget)
| 248 |
nstarget = sr.rweight/minweight;
| 249 |
if (nstarget > 1) {
| 250 |
dtmp = 1./nstarget;
| 251 |
scalecolor(sr.rcoef, dtmp);
| 252 |
sr.rweight *= dtmp;
| 253 |
} else
| 254 |
nstarget = 1;
| 255 |
| 256 |
dimlist[ndims++] = (int)(size_t)np->mp;
| 257 |
maxiter = MAXITER*nstarget;
| 258 |
for (nstaken = ntrials = 0; nstaken < nstarget &&
| 259 |
ntrials < maxiter; ntrials++) {
| 260 |
if (ntrials)
| 261 |
dtmp = frandom();
| 262 |
else
| 263 |
dtmp = urand(ilhash(dimlist,ndims)+647+samplendx);
| 264 |
multisamp(rv, 2, dtmp);
| 265 |
dtmp = 2.*PI * rv[0];
| 266 |
cosph = sqrt(np->v_power + 1.) * tcos(dtmp);
| 267 |
sinph = sqrt(np->u_power + 1.) * tsin(dtmp);
| 268 |
dtmp = 1./sqrt(cosph*cosph + sinph*sinph);
| 269 |
cosph *= dtmp;
| 270 |
sinph *= dtmp;
| 271 |
costh = pow(rv[1], 1./(np->u_power*cosph*cosph+np->v_power*sinph*sinph+1.));
| 272 |
if (costh <= FTINY)
| 273 |
continue;
| 274 |
sinth = sqrt(1. - costh*costh);
| 275 |
| 276 |
h[i] = cosph*sinth*np->u[i] + sinph*sinth*np->v[i] + costh*np->pnorm[i];
| 277 |
| 278 |
if (nstaken)
| 279 |
rayclear(&sr);
| 280 |
dtmp = -2.*DOT(h, np->rp->rdir);
| 281 |
VSUM(sr.rdir, np->rp->rdir, h, dtmp);
| 282 |
/* sample rejection test */
| 283 |
if (DOT(sr.rdir, np->rp->ron) <= FTINY)
| 284 |
continue;
| 285 |
checknorm(sr.rdir);
| 286 |
rayvalue(&sr);
| 287 |
multcolor(sr.rcol, sr.rcoef);
| 288 |
addcolor(np->rp->rcol, sr.rcol);
| 289 |
++nstaken;
| 290 |
| 291 |
ndims--;
| 292 |
