| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: aniso.c,v 2.62 2023/11/15 18:02:52 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Shading functions for anisotropic materials.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "ambient.h"
| 12 |
#include "otypes.h"
| 13 |
#include "rtotypes.h"
| 14 |
#include "source.h"
| 15 |
#include "func.h"
| 16 |
#include "random.h"
| 17 |
#include "pmapmat.h"
| 18 |
| 19 |
#ifndef MAXITER
| 20 |
#define MAXITER 10 /* maximum # specular ray attempts */
| 21 |
#endif
| 22 |
| 23 |
| 24 |
* This routine implements the anisotropic Gaussian
| 25 |
* model described by Ward in Siggraph `92 article, updated with
| 26 |
* normalization and sampling adjustments due to Geisler-Moroder and Duer.
| 27 |
* We orient the surface towards the incoming ray, so a single
| 28 |
* surface can be used to represent an infinitely thin object.
| 29 |
| 30 |
* Arguments for MAT_PLASTIC2 and MAT_METAL2 are:
| 31 |
* 4+ ux uy uz funcfile [transform...]
| 32 |
* 0
| 33 |
* 6 red grn blu specular-frac. u-rough v-rough
| 34 |
| 35 |
* Real arguments for MAT_TRANS2 are:
| 36 |
* 8 red grn blu rspec u-rough v-rough trans tspec
| 37 |
| 38 |
| 39 |
/* specularity flags */
| 40 |
#define SP_REFL 01 /* has reflected specular component */
| 41 |
#define SP_TRAN 02 /* has transmitted specular */
| 42 |
#define SP_FLAT 04 /* reflecting surface is flat */
| 43 |
#define SP_RBLT 010 /* reflection below sample threshold */
| 44 |
#define SP_TBLT 020 /* transmission below threshold */
| 45 |
| 46 |
typedef struct {
| 47 |
OBJREC *mp; /* material pointer */
| 48 |
RAY *rp; /* ray pointer */
| 49 |
short specfl; /* specularity flags, defined above */
| 50 |
SCOLOR mcolor; /* color of this material */
| 51 |
SCOLOR scolor; /* color of specular component */
| 52 |
FVECT vrefl; /* vector in reflected direction */
| 53 |
FVECT prdir; /* vector in transmitted direction */
| 54 |
FVECT u, v; /* u and v vectors orienting anisotropy */
| 55 |
double u_alpha; /* u roughness */
| 56 |
double v_alpha; /* v roughness */
| 57 |
double rdiff, rspec; /* reflected specular, diffuse */
| 58 |
double trans; /* transmissivity */
| 59 |
double tdiff, tspec; /* transmitted specular, diffuse */
| 60 |
FVECT pnorm; /* perturbed surface normal */
| 61 |
double pdot; /* perturbed dot product */
| 62 |
} ANISODAT; /* anisotropic material data */
| 63 |
| 64 |
static void getacoords(ANISODAT *np);
| 65 |
static void agaussamp(ANISODAT *np);
| 66 |
| 67 |
| 68 |
static void
| 69 |
diraniso( /* compute source contribution */
| 70 |
SCOLOR scval, /* returned coefficient */
| 71 |
void *nnp, /* material data */
| 72 |
FVECT ldir, /* light source direction */
| 73 |
double omega /* light source size */
| 74 |
| 75 |
| 76 |
ANISODAT *np = nnp;
| 77 |
double ldot;
| 78 |
double dtmp, dtmp1, dtmp2;
| 79 |
FVECT h;
| 80 |
double au2, av2;
| 81 |
SCOLOR sctmp;
| 82 |
| 83 |
scolorblack(scval);
| 84 |
| 85 |
ldot = DOT(np->pnorm, ldir);
| 86 |
| 87 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
| 88 |
return; /* wrong side */
| 89 |
| 90 |
if ((ldot > FTINY) & (np->rdiff > FTINY)) {
| 91 |
| 92 |
* Compute and add diffuse reflected component to returned
| 93 |
* color. The diffuse reflected component will always be
| 94 |
* modified by the color of the material.
| 95 |
| 96 |
copyscolor(sctmp, np->mcolor);
| 97 |
dtmp = ldot * omega * np->rdiff * (1.0/PI);
| 98 |
scalescolor(sctmp, dtmp);
| 99 |
saddscolor(scval, sctmp);
| 100 |
| 101 |
| 102 |
if ((ldot < -FTINY) & (np->tdiff > FTINY)) {
| 103 |
| 104 |
* Compute diffuse transmission.
| 105 |
| 106 |
| 107 |
dtmp = -ldot * omega * np->tdiff * (1.0/PI);
| 108 |
| 109 |
| 110 |
| 111 |
| 112 |
if (ambRayInPmap(np->rp))
| 113 |
return; /* specular accounted for in photon map */
| 114 |
| 115 |
if (ldot > FTINY && np->specfl&SP_REFL) {
| 116 |
| 117 |
* Compute specular reflection coefficient using
| 118 |
* anisotropic Gaussian distribution model.
| 119 |
| 120 |
/* add source width if flat */
| 121 |
if (np->specfl & SP_FLAT)
| 122 |
au2 = av2 = omega * (0.25/PI);
| 123 |
else
| 124 |
au2 = av2 = 0.0;
| 125 |
au2 += np->u_alpha*np->u_alpha;
| 126 |
av2 += np->v_alpha*np->v_alpha;
| 127 |
/* half vector */
| 128 |
VSUB(h, ldir, np->rp->rdir);
| 129 |
/* ellipse */
| 130 |
dtmp1 = DOT(np->u, h);
| 131 |
dtmp1 *= dtmp1 / au2;
| 132 |
dtmp2 = DOT(np->v, h);
| 133 |
dtmp2 *= dtmp2 / av2;
| 134 |
/* new W-G-M-D model */
| 135 |
dtmp = DOT(np->pnorm, h);
| 136 |
dtmp *= dtmp;
| 137 |
dtmp1 = (dtmp1 + dtmp2) / dtmp;
| 138 |
dtmp = exp(-dtmp1) * DOT(h,h) /
| 139 |
(PI * dtmp*dtmp * sqrt(au2*av2));
| 140 |
/* worth using? */
| 141 |
if (dtmp > FTINY) {
| 142 |
copyscolor(sctmp, np->scolor);
| 143 |
dtmp *= ldot * omega;
| 144 |
| 145 |
| 146 |
| 147 |
| 148 |
| 149 |
if (ldot < -FTINY && np->specfl&SP_TRAN) {
| 150 |
| 151 |
* Compute specular transmission. Specular transmission
| 152 |
* is always modified by material color.
| 153 |
| 154 |
/* roughness + source */
| 155 |
au2 = av2 = omega * (1.0/PI);
| 156 |
| 157 |
| 158 |
/* "half vector" */
| 159 |
VSUB(h, ldir, np->prdir);
| 160 |
dtmp = DOT(h,h);
| 161 |
if (dtmp > FTINY*FTINY) {
| 162 |
dtmp1 = DOT(h,np->pnorm);
| 163 |
dtmp = 1.0 - dtmp1*dtmp1/dtmp;
| 164 |
| 165 |
dtmp1 = DOT(h,np->u);
| 166 |
| 167 |
dtmp2 = DOT(h,np->v);
| 168 |
| 169 |
dtmp = (dtmp1 + dtmp2) / dtmp;
| 170 |
| 171 |
} else
| 172 |
dtmp = 0.0;
| 173 |
/* Gaussian */
| 174 |
dtmp = exp(-dtmp) * (1.0/PI) * sqrt(-ldot/(np->pdot*au2*av2));
| 175 |
/* worth using? */
| 176 |
if (dtmp > FTINY) {
| 177 |
| 178 |
dtmp *= np->tspec * omega;
| 179 |
| 180 |
| 181 |
| 182 |
| 183 |
| 184 |
| 185 |
| 186 |
int
| 187 |
m_aniso( /* shade ray that hit something anisotropic */
| 188 |
OBJREC *m,
| 189 |
RAY *r
| 190 |
| 191 |
| 192 |
ANISODAT nd;
| 193 |
SCOLOR sctmp;
| 194 |
int i;
| 195 |
/* easy shadow test */
| 196 |
if (r->crtype & SHADOW)
| 197 |
return(1);
| 198 |
| 199 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6))
| 200 |
objerror(m, USER, "bad number of real arguments");
| 201 |
/* check for back side */
| 202 |
if (r->rod < 0.0) {
| 203 |
if (!backvis) {
| 204 |
raytrans(r);
| 205 |
return(1);
| 206 |
| 207 |
raytexture(r, m->omod);
| 208 |
flipsurface(r); /* reorient if backvis */
| 209 |
} else
| 210 |
| 211 |
/* get material color */
| 212 |
nd.mp = m;
| 213 |
nd.rp = r;
| 214 |
setscolor(nd.mcolor, m->oargs.farg[0],
| 215 |
m->oargs.farg[1],
| 216 |
m->oargs.farg[2]);
| 217 |
/* get roughness */
| 218 |
nd.specfl = 0;
| 219 |
nd.u_alpha = m->oargs.farg[4];
| 220 |
nd.v_alpha = m->oargs.farg[5];
| 221 |
if ((nd.u_alpha <= FTINY) | (nd.v_alpha <= FTINY))
| 222 |
objerror(m, USER, "roughness too small");
| 223 |
| 224 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
| 225 |
if (nd.pdot < .001)
| 226 |
nd.pdot = .001; /* non-zero for diraniso() */
| 227 |
smultscolor(nd.mcolor, r->pcol); /* modify material color */
| 228 |
/* get specular component */
| 229 |
if ((nd.rspec = m->oargs.farg[3]) > FTINY) {
| 230 |
nd.specfl |= SP_REFL;
| 231 |
/* compute specular color */
| 232 |
if (m->otype == MAT_METAL2)
| 233 |
copyscolor(nd.scolor, nd.mcolor);
| 234 |
else
| 235 |
setscolor(nd.scolor, 1.0, 1.0, 1.0);
| 236 |
scalescolor(nd.scolor, nd.rspec);
| 237 |
/* check threshold */
| 238 |
if (specthresh >= nd.rspec-FTINY)
| 239 |
nd.specfl |= SP_RBLT;
| 240 |
/* compute refl. direction */
| 241 |
VSUM(nd.vrefl, r->rdir, nd.pnorm, 2.0*nd.pdot);
| 242 |
if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */
| 243 |
VSUM(nd.vrefl, r->rdir, r->ron, 2.0*r->rod);
| 244 |
| 245 |
/* compute transmission */
| 246 |
if (m->otype == MAT_TRANS2) {
| 247 |
nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec);
| 248 |
nd.tspec = nd.trans * m->oargs.farg[7];
| 249 |
nd.tdiff = nd.trans - nd.tspec;
| 250 |
if (nd.tspec > FTINY) {
| 251 |
nd.specfl |= SP_TRAN;
| 252 |
| 253 |
if (specthresh >= nd.tspec-FTINY)
| 254 |
nd.specfl |= SP_TBLT;
| 255 |
if (DOT(r->pert,r->pert) <= FTINY*FTINY) {
| 256 |
VCOPY(nd.prdir, r->rdir);
| 257 |
} else {
| 258 |
for (i = 0; i < 3; i++) /* perturb */
| 259 |
nd.prdir[i] = r->rdir[i] - r->pert[i];
| 260 |
if (DOT(nd.prdir, r->ron) < -FTINY)
| 261 |
normalize(nd.prdir); /* OK */
| 262 |
else
| 263 |
| 264 |
| 265 |
| 266 |
} else
| 267 |
nd.tdiff = nd.tspec = nd.trans = 0.0;
| 268 |
| 269 |
/* diffuse reflection */
| 270 |
nd.rdiff = 1.0 - nd.trans - nd.rspec;
| 271 |
| 272 |
if (r->ro != NULL && isflat(r->ro->otype))
| 273 |
nd.specfl |= SP_FLAT;
| 274 |
| 275 |
getacoords(&nd); /* set up coordinates */
| 276 |
| 277 |
if (nd.specfl & (SP_REFL|SP_TRAN))
| 278 |
agaussamp(&nd);
| 279 |
| 280 |
if (nd.rdiff > FTINY) { /* ambient from this side */
| 281 |
copyscolor(sctmp, nd.mcolor); /* modified by material color */
| 282 |
scalescolor(sctmp, nd.rdiff);
| 283 |
if (nd.specfl & SP_RBLT) /* add in specular as well? */
| 284 |
saddscolor(sctmp, nd.scolor);
| 285 |
multambient(sctmp, r, nd.pnorm);
| 286 |
saddscolor(r->rcol, sctmp); /* add to returned color */
| 287 |
| 288 |
| 289 |
if (nd.tdiff > FTINY) { /* ambient from other side */
| 290 |
FVECT bnorm;
| 291 |
| 292 |
flipsurface(r);
| 293 |
bnorm[0] = -nd.pnorm[0];
| 294 |
bnorm[1] = -nd.pnorm[1];
| 295 |
bnorm[2] = -nd.pnorm[2];
| 296 |
copyscolor(sctmp, nd.mcolor); /* modified by color */
| 297 |
if (nd.specfl & SP_TBLT) {
| 298 |
scalescolor(sctmp, nd.trans);
| 299 |
} else {
| 300 |
scalescolor(sctmp, nd.tdiff);
| 301 |
| 302 |
multambient(sctmp, r, bnorm);
| 303 |
| 304 |
flipsurface(r);
| 305 |
| 306 |
/* add direct component */
| 307 |
direct(r, diraniso, &nd);
| 308 |
| 309 |
return(1);
| 310 |
| 311 |
| 312 |
static void
| 313 |
getacoords( /* set up coordinate system */
| 314 |
ANISODAT *np
| 315 |
| 316 |
| 317 |
MFUNC *mf;
| 318 |
int i;
| 319 |
| 320 |
mf = getfunc(np->mp, 3, 0x7, 1);
| 321 |
setfunc(np->mp, np->rp);
| 322 |
errno = 0;
| 323 |
| 324 |
np->u[i] = evalue(mf->ep[i]);
| 325 |
if ((errno == EDOM) | (errno == ERANGE))
| 326 |
np->u[0] = np->u[1] = np->u[2] = 0.0;
| 327 |
if (mf->fxp != &unitxf)
| 328 |
multv3(np->u, np->u, mf->fxp->xfm);
| 329 |
fcross(np->v, np->pnorm, np->u);
| 330 |
if (normalize(np->v) == 0.0) {
| 331 |
if (fabs(np->u_alpha - np->v_alpha) > 0.001)
| 332 |
objerror(np->mp, WARNING, "illegal orientation vector");
| 333 |
getperpendicular(np->u, np->pnorm, 1); /* punting */
| 334 |
| 335 |
np->u_alpha = np->v_alpha = sqrt( 0.5 *
| 336 |
(np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) );
| 337 |
} else
| 338 |
fcross(np->u, np->v, np->pnorm);
| 339 |
| 340 |
| 341 |
| 342 |
static void
| 343 |
agaussamp( /* sample anisotropic Gaussian specular */
| 344 |
ANISODAT *np
| 345 |
| 346 |
| 347 |
RAY sr;
| 348 |
FVECT h;
| 349 |
double rv[2];
| 350 |
double d, sinp, cosp;
| 351 |
SCOLOR scol;
| 352 |
int maxiter, ntrials, nstarget, nstaken;
| 353 |
int i;
| 354 |
/* compute reflection */
| 355 |
if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
| 356 |
rayorigin(&sr, SPECULAR, np->rp, np->scolor) == 0) {
| 357 |
nstarget = 1;
| 358 |
if (specjitter > 1.5) { /* multiple samples? */
| 359 |
nstarget = specjitter*np->rp->rweight + .5;
| 360 |
if (sr.rweight <= minweight*nstarget)
| 361 |
nstarget = sr.rweight/minweight;
| 362 |
if (nstarget > 1) {
| 363 |
d = 1./nstarget;
| 364 |
scalescolor(sr.rcoef, d);
| 365 |
sr.rweight *= d;
| 366 |
} else
| 367 |
nstarget = 1;
| 368 |
| 369 |
scolorblack(scol);
| 370 |
dimlist[ndims++] = (int)(size_t)np->mp;
| 371 |
maxiter = MAXITER*nstarget;
| 372 |
for (nstaken = ntrials = 0; nstaken < nstarget &&
| 373 |
ntrials < maxiter; ntrials++) {
| 374 |
if (ntrials)
| 375 |
d = frandom();
| 376 |
else
| 377 |
d = urand(ilhash(dimlist,ndims)+samplendx);
| 378 |
multisamp(rv, 2, d);
| 379 |
d = 2.0*PI * rv[0];
| 380 |
cosp = tcos(d) * np->u_alpha;
| 381 |
sinp = tsin(d) * np->v_alpha;
| 382 |
d = 1./sqrt(cosp*cosp + sinp*sinp);
| 383 |
cosp *= d;
| 384 |
sinp *= d;
| 385 |
if ((0. <= specjitter) & (specjitter < 1.))
| 386 |
rv[1] = 1.0 - specjitter*rv[1];
| 387 |
if (rv[1] <= FTINY)
| 388 |
d = 1.0;
| 389 |
else
| 390 |
d = sqrt(-log(rv[1]) /
| 391 |
(cosp*cosp/(np->u_alpha*np->u_alpha) +
| 392 |
sinp*sinp/(np->v_alpha*np->v_alpha)));
| 393 |
| 394 |
h[i] = np->pnorm[i] +
| 395 |
d*(cosp*np->u[i] + sinp*np->v[i]);
| 396 |
d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d);
| 397 |
VSUM(sr.rdir, np->rp->rdir, h, d);
| 398 |
/* sample rejection test */
| 399 |
if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY)
| 400 |
continue;
| 401 |
checknorm(sr.rdir);
| 402 |
if (nstarget > 1) { /* W-G-M-D adjustment */
| 403 |
if (nstaken) rayclear(&sr);
| 404 |
rayvalue(&sr);
| 405 |
d = 2./(1. + np->rp->rod/d);
| 406 |
scalescolor(sr.rcol, d);
| 407 |
saddscolor(scol, sr.rcol);
| 408 |
} else {
| 409 |
rayvalue(&sr);
| 410 |
smultscolor(sr.rcol, sr.rcoef);
| 411 |
saddscolor(np->rp->rcol, sr.rcol);
| 412 |
| 413 |
++nstaken;
| 414 |
| 415 |
if (nstarget > 1) { /* final W-G-M-D weighting */
| 416 |
smultscolor(scol, sr.rcoef);
| 417 |
d = (double)nstarget/ntrials;
| 418 |
scalescolor(scol, d);
| 419 |
saddscolor(np->rp->rcol, scol);
| 420 |
| 421 |
ndims--;
| 422 |
| 423 |
| 424 |
copyscolor(sr.rcoef, np->mcolor); /* modify by material color */
| 425 |
scalescolor(sr.rcoef, np->tspec);
| 426 |
if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
| 427 |
rayorigin(&sr, SPECULAR, np->rp, sr.rcoef) == 0) {
| 428 |
nstarget = 1;
| 429 |
| 430 |
| 431 |
| 432 |
| 433 |
if (nstarget > 1) {
| 434 |
d = 1./nstarget;
| 435 |
| 436 |
sr.rweight *= d;
| 437 |
} else
| 438 |
nstarget = 1;
| 439 |
| 440 |
| 441 |
| 442 |
| 443 |
| 444 |
if (ntrials)
| 445 |
d = frandom();
| 446 |
else
| 447 |
d = urand(ilhash(dimlist,ndims)+1823+samplendx);
| 448 |
| 449 |
d = 2.0*PI * rv[0];
| 450 |
| 451 |
| 452 |
| 453 |
cosp *= d;
| 454 |
sinp *= d;
| 455 |
| 456 |
| 457 |
if (rv[1] <= FTINY)
| 458 |
d = 1.0;
| 459 |
else
| 460 |
| 461 |
| 462 |
| 463 |
| 464 |
sr.rdir[i] = np->prdir[i] +
| 465 |
| 466 |
if (DOT(sr.rdir, np->rp->ron) >= -FTINY)
| 467 |
continue;
| 468 |
normalize(sr.rdir); /* OK, normalize */
| 469 |
if (nstaken) /* multi-sampling */
| 470 |
rayclear(&sr);
| 471 |
rayvalue(&sr);
| 472 |
| 473 |
| 474 |
++nstaken;
| 475 |
| 476 |
ndims--;
| 477 |
| 478 |
