| 1 |
/* Copyright (c) 1992 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Shading functions for anisotropic materials.
| 9 |
| 10 |
| 11 |
#include "ray.h"
| 12 |
| 13 |
#include "otypes.h"
| 14 |
| 15 |
#include "func.h"
| 16 |
| 17 |
#include "random.h"
| 18 |
| 19 |
| 20 |
* This anisotropic reflection model uses a variant on the
| 21 |
* exponential Gaussian used in normal.c.
| 22 |
* We orient the surface towards the incoming ray, so a single
| 23 |
* surface can be used to represent an infinitely thin object.
| 24 |
| 25 |
* Arguments for MAT_PLASTIC2 and MAT_METAL2 are:
| 26 |
* 4+ ux uy uz funcfile [transform...]
| 27 |
* 0
| 28 |
* 6 red grn blu specular-frac. u-facet-slope v-facet-slope
| 29 |
| 30 |
* Real arguments for MAT_TRANS2 are:
| 31 |
* 8 red grn blu rspec u-rough v-rough trans tspec
| 32 |
| 33 |
| 34 |
#define BSPEC(m) (6.0) /* specularity parameter b */
| 35 |
| 36 |
/* specularity flags */
| 37 |
#define SP_REFL 01 /* has reflected specular component */
| 38 |
#define SP_TRAN 02 /* has transmitted specular */
| 39 |
#define SP_PURE 010 /* purely specular (zero roughness) */
| 40 |
#define SP_BADU 020 /* bad u direction calculation */
| 41 |
#define SP_FLAT 040 /* reflecting surface is flat */
| 42 |
| 43 |
typedef struct {
| 44 |
OBJREC *mp; /* material pointer */
| 45 |
RAY *rp; /* ray pointer */
| 46 |
short specfl; /* specularity flags, defined above */
| 47 |
COLOR mcolor; /* color of this material */
| 48 |
COLOR scolor; /* color of specular component */
| 49 |
FVECT prdir; /* vector in transmitted direction */
| 50 |
FVECT u, v; /* u and v vectors orienting anisotropy */
| 51 |
double u_alpha; /* u roughness */
| 52 |
double v_alpha; /* v roughness */
| 53 |
double rdiff, rspec; /* reflected specular, diffuse */
| 54 |
double trans; /* transmissivity */
| 55 |
double tdiff, tspec; /* transmitted specular, diffuse */
| 56 |
FVECT pnorm; /* perturbed surface normal */
| 57 |
double pdot; /* perturbed dot product */
| 58 |
} ANISODAT; /* anisotropic material data */
| 59 |
| 60 |
| 61 |
diraniso(cval, np, ldir, omega) /* compute source contribution */
| 62 |
COLOR cval; /* returned coefficient */
| 63 |
register ANISODAT *np; /* material data */
| 64 |
FVECT ldir; /* light source direction */
| 65 |
double omega; /* light source size */
| 66 |
| 67 |
double ldot;
| 68 |
double dtmp, dtmp2;
| 69 |
FVECT h;
| 70 |
double au2, av2;
| 71 |
COLOR ctmp;
| 72 |
| 73 |
setcolor(cval, 0.0, 0.0, 0.0);
| 74 |
| 75 |
ldot = DOT(np->pnorm, ldir);
| 76 |
| 77 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
| 78 |
return; /* wrong side */
| 79 |
| 80 |
if (ldot > FTINY && np->rdiff > FTINY) {
| 81 |
| 82 |
* Compute and add diffuse reflected component to returned
| 83 |
* color. The diffuse reflected component will always be
| 84 |
* modified by the color of the material.
| 85 |
| 86 |
copycolor(ctmp, np->mcolor);
| 87 |
dtmp = ldot * omega * np->rdiff / PI;
| 88 |
scalecolor(ctmp, dtmp);
| 89 |
addcolor(cval, ctmp);
| 90 |
| 91 |
if (ldot > FTINY && (np->specfl&(SP_REFL|SP_PURE|SP_BADU)) == SP_REFL) {
| 92 |
| 93 |
* Compute specular reflection coefficient using
| 94 |
* anisotropic gaussian distribution model.
| 95 |
| 96 |
/* add source width if flat */
| 97 |
if (np->specfl & SP_FLAT)
| 98 |
au2 = av2 = omega/(4.0*PI);
| 99 |
else
| 100 |
au2 = av2 = 0.0;
| 101 |
au2 += np->u_alpha * np->u_alpha;
| 102 |
av2 += np->v_alpha * np->v_alpha;
| 103 |
/* half vector */
| 104 |
h[0] = ldir[0] - np->rp->rdir[0];
| 105 |
h[1] = ldir[1] - np->rp->rdir[1];
| 106 |
h[2] = ldir[2] - np->rp->rdir[2];
| 107 |
normalize(h);
| 108 |
/* ellipse */
| 109 |
dtmp = DOT(np->u, h);
| 110 |
dtmp *= dtmp / au2;
| 111 |
dtmp2 = DOT(np->v, h);
| 112 |
dtmp2 *= dtmp2 / av2;
| 113 |
/* gaussian */
| 114 |
dtmp = (dtmp + dtmp2) / (1.0 + DOT(np->pnorm, h));
| 115 |
dtmp = exp(-2.0*dtmp) / (4.0*PI * sqrt(au2*av2));
| 116 |
/* worth using? */
| 117 |
if (dtmp > FTINY) {
| 118 |
copycolor(ctmp, np->scolor);
| 119 |
dtmp *= omega / np->pdot;
| 120 |
| 121 |
| 122 |
| 123 |
| 124 |
if (ldot < -FTINY && np->tdiff > FTINY) {
| 125 |
| 126 |
* Compute diffuse transmission.
| 127 |
| 128 |
| 129 |
dtmp = -ldot * omega * np->tdiff / PI;
| 130 |
| 131 |
| 132 |
| 133 |
if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_PURE|SP_BADU)) == SP_TRAN) {
| 134 |
| 135 |
* Compute specular transmission. Specular transmission
| 136 |
* is always modified by material color.
| 137 |
| 138 |
/* roughness + source */
| 139 |
/* gaussian */
| 140 |
dtmp = 0.0;
| 141 |
/* worth using? */
| 142 |
if (dtmp > FTINY) {
| 143 |
| 144 |
dtmp *= np->tspec * omega / np->pdot;
| 145 |
| 146 |
| 147 |
| 148 |
| 149 |
| 150 |
| 151 |
| 152 |
m_aniso(m, r) /* shade ray that hit something anisotropic */
| 153 |
register OBJREC *m;
| 154 |
register RAY *r;
| 155 |
| 156 |
ANISODAT nd;
| 157 |
double transtest, transdist;
| 158 |
double dtmp;
| 159 |
COLOR ctmp;
| 160 |
register int i;
| 161 |
/* easy shadow test */
| 162 |
if (r->crtype & SHADOW && m->otype != MAT_TRANS2)
| 163 |
return;
| 164 |
| 165 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6))
| 166 |
objerror(m, USER, "bad number of real arguments");
| 167 |
nd.mp = m;
| 168 |
nd.rp = r;
| 169 |
/* get material color */
| 170 |
setcolor(nd.mcolor, m->oargs.farg[0],
| 171 |
m->oargs.farg[1],
| 172 |
m->oargs.farg[2]);
| 173 |
/* get roughness */
| 174 |
nd.specfl = 0;
| 175 |
nd.u_alpha = m->oargs.farg[4];
| 176 |
nd.v_alpha = m->oargs.farg[5];
| 177 |
if (nd.u_alpha <= FTINY || nd.v_alpha <= FTINY)
| 178 |
nd.specfl |= SP_PURE;
| 179 |
/* reorient if necessary */
| 180 |
if (r->rod < 0.0)
| 181 |
flipsurface(r);
| 182 |
/* get modifiers */
| 183 |
raytexture(r, m->omod);
| 184 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
| 185 |
if (nd.pdot < .001)
| 186 |
nd.pdot = .001; /* non-zero for diraniso() */
| 187 |
multcolor(nd.mcolor, r->pcol); /* modify material color */
| 188 |
transtest = 0;
| 189 |
/* get specular component */
| 190 |
if ((nd.rspec = m->oargs.farg[3]) > FTINY) {
| 191 |
nd.specfl |= SP_REFL;
| 192 |
/* compute specular color */
| 193 |
if (m->otype == MAT_METAL2)
| 194 |
copycolor(nd.scolor, nd.mcolor);
| 195 |
else
| 196 |
setcolor(nd.scolor, 1.0, 1.0, 1.0);
| 197 |
scalecolor(nd.scolor, nd.rspec);
| 198 |
/* improved model */
| 199 |
dtmp = exp(-BSPEC(m)*nd.pdot);
| 200 |
for (i = 0; i < 3; i++)
| 201 |
colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp;
| 202 |
nd.rspec += (1.0-nd.rspec)*dtmp;
| 203 |
| 204 |
if (!(r->crtype & SHADOW) && nd.specfl & SP_PURE) {
| 205 |
RAY lr;
| 206 |
if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) {
| 207 |
| 208 |
lr.rdir[i] = r->rdir[i] +
| 209 |
2.0*nd.pdot*nd.pnorm[i];
| 210 |
rayvalue(&lr);
| 211 |
multcolor(lr.rcol, nd.scolor);
| 212 |
addcolor(r->rcol, lr.rcol);
| 213 |
| 214 |
| 215 |
| 216 |
/* compute transmission */
| 217 |
if (m->otype == MAT_TRANS) {
| 218 |
nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec);
| 219 |
nd.tspec = nd.trans * m->oargs.farg[7];
| 220 |
nd.tdiff = nd.trans - nd.tspec;
| 221 |
if (nd.tspec > FTINY) {
| 222 |
nd.specfl |= SP_TRAN;
| 223 |
if (r->crtype & SHADOW ||
| 224 |
DOT(r->pert,r->pert) <= FTINY*FTINY) {
| 225 |
VCOPY(nd.prdir, r->rdir);
| 226 |
transtest = 2;
| 227 |
} else {
| 228 |
for (i = 0; i < 3; i++) /* perturb */
| 229 |
nd.prdir[i] = r->rdir[i] -
| 230 |
.75*r->pert[i];
| 231 |
normalize(nd.prdir);
| 232 |
| 233 |
| 234 |
} else
| 235 |
nd.tdiff = nd.tspec = nd.trans = 0.0;
| 236 |
/* transmitted ray */
| 237 |
if ((nd.specfl&(SP_TRAN|SP_PURE)) == (SP_TRAN|SP_PURE)) {
| 238 |
RAY lr;
| 239 |
if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) {
| 240 |
VCOPY(lr.rdir, nd.prdir);
| 241 |
rayvalue(&lr);
| 242 |
scalecolor(lr.rcol, nd.tspec);
| 243 |
multcolor(lr.rcol, nd.mcolor); /* modified by color */
| 244 |
| 245 |
transtest *= bright(lr.rcol);
| 246 |
transdist = r->rot + lr.rt;
| 247 |
| 248 |
| 249 |
| 250 |
if (r->crtype & SHADOW) /* the rest is shadow */
| 251 |
return;
| 252 |
/* diffuse reflection */
| 253 |
nd.rdiff = 1.0 - nd.trans - nd.rspec;
| 254 |
| 255 |
if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY)
| 256 |
return; /* 100% pure specular */
| 257 |
| 258 |
getacoords(r, &nd); /* set up coordinates */
| 259 |
| 260 |
if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & (SP_PURE|SP_BADU)))
| 261 |
agaussamp(r, &nd);
| 262 |
| 263 |
if (nd.rdiff > FTINY) { /* ambient from this side */
| 264 |
ambient(ctmp, r);
| 265 |
scalecolor(ctmp, nd.rdiff);
| 266 |
multcolor(ctmp, nd.mcolor); /* modified by material color */
| 267 |
addcolor(r->rcol, ctmp); /* add to returned color */
| 268 |
| 269 |
if (nd.tdiff > FTINY) { /* ambient from other side */
| 270 |
flipsurface(r);
| 271 |
ambient(ctmp, r);
| 272 |
scalecolor(ctmp, nd.tdiff);
| 273 |
multcolor(ctmp, nd.mcolor); /* modified by color */
| 274 |
| 275 |
flipsurface(r);
| 276 |
| 277 |
/* add direct component */
| 278 |
direct(r, diraniso, &nd);
| 279 |
/* check distance */
| 280 |
if (transtest > bright(r->rcol))
| 281 |
r->rt = transdist;
| 282 |
| 283 |
| 284 |
| 285 |
static
| 286 |
getacoords(r, np) /* set up coordinate system */
| 287 |
RAY *r;
| 288 |
| 289 |
| 290 |
register MFUNC *mf;
| 291 |
register int i;
| 292 |
| 293 |
mf = getfunc(np->mp, 3, 0x7, 1);
| 294 |
setfunc(np->mp, r);
| 295 |
errno = 0;
| 296 |
| 297 |
np->u[i] = evalue(mf->ep[i]);
| 298 |
if (errno) {
| 299 |
objerror(np->mp, WARNING, "compute error");
| 300 |
np->specfl |= SP_BADU;
| 301 |
return;
| 302 |
| 303 |
multv3(np->u, np->u, mf->f->xfm);
| 304 |
fcross(np->v, np->pnorm, np->u);
| 305 |
if (normalize(np->v) == 0.0) {
| 306 |
objerror(np->mp, WARNING, "illegal orientation vector");
| 307 |
| 308 |
return;
| 309 |
| 310 |
fcross(np->u, np->v, np->pnorm);
| 311 |
| 312 |
| 313 |
| 314 |
static
| 315 |
agaussamp(r, np) /* sample anisotropic gaussian specular */
| 316 |
RAY *r;
| 317 |
| 318 |
| 319 |
RAY sr;
| 320 |
FVECT h;
| 321 |
double rv[2];
| 322 |
double d, sinp, cosp;
| 323 |
int ntries;
| 324 |
register int i;
| 325 |
/* compute reflection */
| 326 |
if (np->specfl & SP_REFL &&
| 327 |
rayorigin(&sr, r, SPECULAR, np->rspec) == 0) {
| 328 |
dimlist[ndims++] = (int)np->mp;
| 329 |
for (ntries = 0; ntries < 10; ntries++) {
| 330 |
dimlist[ndims] = ntries * 3601;
| 331 |
d = urand(ilhash(dimlist,ndims+1)+samplendx);
| 332 |
multisamp(rv, 2, d);
| 333 |
d = 2.0*PI * rv[0];
| 334 |
cosp = np->u_alpha * cos(d);
| 335 |
sinp = np->v_alpha * sin(d);
| 336 |
d = sqrt(cosp*cosp + sinp*sinp);
| 337 |
cosp /= d;
| 338 |
sinp /= d;
| 339 |
if (rv[1] <= FTINY)
| 340 |
d = 1.0;
| 341 |
else
| 342 |
d = sqrt(-log(rv[1]) /
| 343 |
(cosp*cosp/(np->u_alpha*np->u_alpha) +
| 344 |
sinp*sinp/(np->v_alpha*np->v_alpha)));
| 345 |
| 346 |
h[i] = np->pnorm[i] +
| 347 |
d*(cosp*np->u[i] + sinp*np->v[i]);
| 348 |
d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d);
| 349 |
| 350 |
sr.rdir[i] = r->rdir[i] + d*h[i];
| 351 |
if (DOT(sr.rdir, r->ron) > FTINY) {
| 352 |
rayvalue(&sr);
| 353 |
multcolor(sr.rcol, np->scolor);
| 354 |
addcolor(r->rcol, sr.rcol);
| 355 |
break;
| 356 |
| 357 |
| 358 |
ndims--;
| 359 |
| 360 |
| 361 |
