--- ray/src/rt/aniso.c 2012/07/29 21:56:16 2.55 +++ ray/src/rt/aniso.c 2014/12/04 05:26:28 2.57 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: aniso.c,v 2.55 2012/07/29 21:56:16 greg Exp $"; +static const char RCSid[] = "$Id: aniso.c,v 2.57 2014/12/04 05:26:28 greg Exp $"; #endif /* * Shading functions for anisotropic materials. @@ -41,7 +41,6 @@ static const char RCSid[] = "$Id: aniso.c,v 2.55 2012/ #define SP_FLAT 04 /* reflecting surface is flat */ #define SP_RBLT 010 /* reflection below sample threshold */ #define SP_TBLT 020 /* transmission below threshold */ -#define SP_BADU 040 /* bad u direction calculation */ typedef struct { OBJREC *mp; /* material pointer */ @@ -98,7 +97,7 @@ diraniso( /* compute source contribution */ scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) { + if (ldot > FTINY && np->specfl&SP_REFL) { /* * Compute specular reflection coefficient using * anisotropic Gaussian distribution model. @@ -140,7 +139,7 @@ diraniso( /* compute source contribution */ scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) { + if (ldot < -FTINY && np->specfl&SP_TRAN) { /* * Compute specular transmission. Specular transmission * is always modified by material color. @@ -194,7 +193,7 @@ m_aniso( /* shade ray that hit something anisotropic objerror(m, USER, "bad number of real arguments"); /* check for back side */ if (r->rod < 0.0) { - if (!backvis && m->otype != MAT_TRANS2) { + if (!backvis) { raytrans(r); return(1); } @@ -268,7 +267,7 @@ m_aniso( /* shade ray that hit something anisotropic getacoords(&nd); /* set up coordinates */ - if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU)) + if (nd.specfl & (SP_REFL|SP_TRAN)) agaussamp(&nd); if (nd.rdiff > FTINY) { /* ambient from this side */ @@ -315,20 +314,20 @@ getacoords( /* set up coordinate system */ errno = 0; for (i = 0; i < 3; i++) np->u[i] = evalue(mf->ep[i]); - if ((errno == EDOM) | (errno == ERANGE)) { - objerror(np->mp, WARNING, "compute error"); - np->specfl |= SP_BADU; - return; - } + if ((errno == EDOM) | (errno == ERANGE)) + np->u[0] = np->u[1] = np->u[2] = 0.0; if (mf->fxp != &unitxf) multv3(np->u, np->u, mf->fxp->xfm); fcross(np->v, np->pnorm, np->u); if (normalize(np->v) == 0.0) { - objerror(np->mp, WARNING, "illegal orientation vector"); - np->specfl |= SP_BADU; - return; - } - fcross(np->u, np->v, np->pnorm); + if (fabs(np->u_alpha - np->v_alpha) > 0.001) + objerror(np->mp, WARNING, "illegal orientation vector"); + getperpendicular(np->u, np->pnorm); /* punting */ + fcross(np->v, np->pnorm, np->u); + np->u_alpha = np->v_alpha = sqrt( 0.5 * + (np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) ); + } else + fcross(np->u, np->v, np->pnorm); }
