--- ray/src/rt/aniso.c 1992/01/06 18:01:41 2.3 +++ ray/src/rt/aniso.c 1992/01/14 16:16:48 2.4 @@ -16,6 +16,9 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" +extern double specthresh; /* specular sampling threshold */ +extern double specjitter; /* specular sampling jitter */ + /* * This anisotropic reflection model uses a variant on the * exponential Gaussian used in normal.c. @@ -37,8 +40,10 @@ static char SCCSid[] = "$SunId$ LBL"; #define SP_REFL 01 /* has reflected specular component */ #define SP_TRAN 02 /* has transmitted specular */ #define SP_PURE 010 /* purely specular (zero roughness) */ -#define SP_BADU 020 /* bad u direction calculation */ -#define SP_FLAT 040 /* reflecting surface is flat */ +#define SP_FLAT 020 /* reflecting surface is flat */ +#define SP_RBLT 040 /* reflection below sample threshold */ +#define SP_TBLT 0100 /* transmission below threshold */ +#define SP_BADU 0200 /* bad u direction calculation */ typedef struct { OBJREC *mp; /* material pointer */ @@ -200,6 +205,9 @@ register RAY *r; for (i = 0; i < 3; i++) colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; nd.rspec += (1.0-nd.rspec)*dtmp; + /* check threshold */ + if (nd.rspec <= specthresh+FTINY) + nd.specfl |= SP_RBLT; if (!(r->crtype & SHADOW) && nd.specfl & SP_PURE) { RAY lr; @@ -220,6 +228,9 @@ register RAY *r; nd.tdiff = nd.trans - nd.tspec; if (nd.tspec > FTINY) { nd.specfl |= SP_TRAN; + /* check threshold */ + if (nd.tspec <= specthresh+FTINY) + nd.specfl |= SP_TBLT; if (r->crtype & SHADOW || DOT(r->pert,r->pert) <= FTINY*FTINY) { VCOPY(nd.prdir, r->rdir); @@ -255,6 +266,9 @@ register RAY *r; if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY) return; /* 100% pure specular */ + if (r->ro->otype == OBJ_FACE || r->ro->otype == OBJ_RING) + nd.specfl |= SP_FLAT; + getacoords(r, &nd); /* set up coordinates */ if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & (SP_PURE|SP_BADU))) @@ -262,14 +276,20 @@ register RAY *r; if (nd.rdiff > FTINY) { /* ambient from this side */ ambient(ctmp, r); - scalecolor(ctmp, nd.rdiff); + if (nd.specfl & SP_RBLT) + scalecolor(ctmp, 1.0-nd.trans); + else + scalecolor(ctmp, nd.rdiff); multcolor(ctmp, nd.mcolor); /* modified by material color */ addcolor(r->rcol, ctmp); /* add to returned color */ } if (nd.tdiff > FTINY) { /* ambient from other side */ flipsurface(r); ambient(ctmp, r); - scalecolor(ctmp, nd.tdiff); + if (nd.specfl & SP_TBLT) + scalecolor(ctmp, nd.trans); + else + scalecolor(ctmp, nd.tdiff); multcolor(ctmp, nd.mcolor); /* modified by color */ addcolor(r->rcol, ctmp); flipsurface(r); @@ -323,7 +343,7 @@ register ANISODAT *np; int ntries; register int i; /* compute reflection */ - if (np->specfl & SP_REFL && + if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && rayorigin(&sr, r, SPECULAR, np->rspec) == 0) { dimlist[ndims++] = (int)np->mp; for (ntries = 0; ntries < 10; ntries++) { @@ -336,6 +356,7 @@ register ANISODAT *np; d = sqrt(cosp*cosp + sinp*sinp); cosp /= d; sinp /= d; + rv[1] = 1.0 - specjitter*rv[1]; if (rv[1] <= FTINY) d = 1.0; else
