root/radiance/ray/src/rt/aniso.c
Tue Apr 19 01:15:06 2005 UTC (19 years ago) by greg
Changes since 2.42: +11 -10 lines
Diff to previous 2.42 , to selected 2.14
Mon Sep 20 17:32:04 2004 UTC (19 years, 7 months ago) by greg
Changes since 2.41: +7 -9 lines
Diff to previous 2.41 , to selected 2.14
Corrected Gaussian reflectance model normalization (cosine factor)
Tue Mar 30 16:13:00 2004 UTC (20 years, 1 month ago) by schorsch
Changes since 2.40: +26 -22 lines
Diff to previous 2.40 , to selected 2.14
Thu Aug 28 03:22:16 2003 UTC (20 years, 8 months ago) by greg
Changes since 2.39: +3 -1 lines
Diff to previous 2.39 , to selected 2.14
Created proper prototypes for function pointers and included missing headers
Wed Mar 12 17:26:58 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.38: +1 -2 lines
Diff to previous 2.38 , to selected 2.14
Wed Mar 12 04:59:05 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.37: +3 -2 lines
Diff to previous 2.37 , to selected 2.14
Wed Mar 5 16:16:52 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.36: +1 -1 lines
Diff to previous 2.36 , to selected 2.14
Mon Mar 3 00:10:51 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.35: +12 -11 lines
Diff to previous 2.35 , to selected 2.14
Changed call order for proper function of two-sided, textured surfaces
Changes since 2.34: +1 -56 lines
Diff to previous 2.34 , to selected 2.14
Changes since 2.33: +65 -13 lines
Diff to previous 2.33 , to selected 2.14
Wed Dec 16 18:14:57 1998 UTC (25 years, 4 months ago) by gwlarson
Changes since 2.32: +7 -7 lines
Diff to previous 2.32 , to selected 2.14
switched to faster table-lookup for sin() and cos() functions
Wed Apr 24 15:47:25 1996 UTC (28 years ago) by greg
Changes since 2.31: +69 -53 lines
Diff to previous 2.31 , to selected 2.14
changed code to iterate until specular sample succeeds (MAXITER)
Wed Nov 22 09:27:51 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.30: +6 -1 lines
Diff to previous 2.30 , to selected 2.14
fixed problem with back side normal computation for ambient()
Mon Nov 6 12:03:20 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.29 , to selected 2.14
added texturing to ambient value computation using extambient()
Fri Sep 15 15:47:32 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.28: +1 -2 lines
Diff to previous 2.28 , to selected 2.14
added isflat() macro and effective ray distance for mirror reflection
Wed Dec 21 09:51:44 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.27: +10 -3 lines
Diff to previous 2.27 , to selected 2.14
added -bv option for back face visibility (normally on)
Wed Jan 12 16:46:32 1994 UTC (30 years, 3 months ago) by greg
Changes since 2.26: +3 -1 lines
Diff to previous 2.26 , to selected 2.14
Thu Nov 18 09:42:55 1993 UTC (30 years, 5 months ago) by greg
Diff to previous 2.25 , to selected 2.14
minor compiler warning fixes
Thu May 27 15:27:57 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.24: +2 -14 lines
Diff to previous 2.24 , to selected 2.14
removed approximation to Fresnel reflection, since the direct
component was not being calculated accordingly (BRDF not bidirectional)
changed BRDTfunc arguments and operation, fixed one or two bugs there also
Mon Mar 8 12:37:18 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.23: +2 -0 lines
Diff to previous 2.23 , to selected 2.14
Fri Feb 12 10:41:05 1993 UTC (31 years, 2 months ago) by greg
Diff to previous 2.22 , to selected 2.14
improved specular component calculation
Fri Oct 16 10:20:27 1992 UTC (31 years, 6 months ago) by greg
Diff to previous 2.21 , to selected 2.14
fixed comments in header
Sun Aug 23 08:48:54 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.20 , to selected 2.14
minor optimization
Wed May 20 14:23:45 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.19 , to selected 2.14
fixed normalization of transmitted direct component
Wed May 20 11:01:40 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.18: +10 -8 lines
Diff to previous 2.18 , to selected 2.14
made computation of transmitted specular slightly more efficient
Tue May 19 17:09:06 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.17: +21 -20 lines
Diff to previous 2.17 , to selected 2.14
fixed screwed-up normalization in sample generation
Sat May 16 08:37:03 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.16: +3 -4 lines
Diff to previous 2.16 , to selected 2.14
changed effect of perturbation and roughness on transmission
Fri May 15 13:07:58 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.15: +47 -24 lines
Diff to previous 2.15 , to selected 2.14
bug fixes in specular transmission
Thu May 14 11:32:09 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.14
reinstated random testing of specular threshold
Wed Apr 22 09:05:27 1992 UTC (32 years ago) by greg
Changes since 2.13: +7 -0 lines
Diff to previous 2.13
reinstated Fresnel factors for roughened surfaces
Mon Apr 20 09:25:47 1992 UTC (32 years ago) by greg
corrected normalization of light source highlights
Thu Apr 16 13:29:06 1992 UTC (32 years ago) by greg
Changes since 2.11: +4 -12 lines
fixed bug that caused ambient to be overcounted for polished surf's
changed use of Fresnel correction so it will only affect polished surf's
Tue Mar 3 16:20:00 1992 UTC (32 years, 2 months ago) by greg
precautionary test before accessing r->ro member
Fri Feb 21 14:50:23 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.9: +13 -48 lines
bug fixes and removed handling of perfectly smooth surfaces
Thu Jan 30 11:37:04 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.8: +2 -4 lines
changed urand() call to frandom() for specular threshold testing
Thu Jan 16 12:05:32 1992 UTC (32 years, 3 months ago) by greg
changed default values and handling of specthresh
Wed Jan 15 16:59:55 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.6: +28 -1 lines
finally added sampling of transmitted specular
Wed Jan 15 11:41:47 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.5: +38 -35 lines
improved safety measures for grazing angles
Wed Jan 15 11:02:43 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.4: +9 -2 lines
added jittering to specular threshold test
Tue Jan 14 16:16:48 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.3: +26 -5 lines
added specular jitter and threshold controls
Mon Jan 6 18:01:41 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +29 -28 lines
fixed semi-infinite loop bug
Sat Jan 4 23:36:40 1992 UTC (32 years, 4 months ago) by greg
changed direct calculation only to widen hightlight for flat surfaces
Sat Jan 4 19:52:49 1992 UTC (32 years, 4 months ago) by greg
Diff to selected 2.14
