root/radiance/ray/src/rt/aniso.c
Revision: 2.39
Committed: Wed Mar 12 17:26:58 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.38: +1 -2 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.38 static const char RCSid[] = "$Id$";
3 greg 2.1 #endif
4     /*
5     * Shading functions for anisotropic materials.
6     */
7
8 greg 2.35 #include "copyright.h"
9 greg 2.34
10 greg 2.1 #include "ray.h"
11
12     #include "otypes.h"
13
14     #include "func.h"
15
16     #include "random.h"
17
18 greg 2.32 #ifndef MAXITER
19     #define MAXITER 10 /* maximum # specular ray attempts */
20     #endif
21
22 greg 2.1 /*
23 greg 2.22 * This routine implements the anisotropic Gaussian
24     * model described by Ward in Siggraph `92 article.
25 greg 2.1 * We orient the surface towards the incoming ray, so a single
26     * surface can be used to represent an infinitely thin object.
27     *
28     * Arguments for MAT_PLASTIC2 and MAT_METAL2 are:
29     * 4+ ux uy uz funcfile [transform...]
30     * 0
31     * 6 red grn blu specular-frac. u-facet-slope v-facet-slope
32     *
33     * Real arguments for MAT_TRANS2 are:
34     * 8 red grn blu rspec u-rough v-rough trans tspec
35     */
36
37     /* specularity flags */
38     #define SP_REFL 01 /* has reflected specular component */
39     #define SP_TRAN 02 /* has transmitted specular */
40 greg 2.10 #define SP_FLAT 04 /* reflecting surface is flat */
41     #define SP_RBLT 010 /* reflection below sample threshold */
42     #define SP_TBLT 020 /* transmission below threshold */
43     #define SP_BADU 040 /* bad u direction calculation */
44 greg 2.1
45     typedef struct {
46 greg 2.2 OBJREC *mp; /* material pointer */
47 greg 2.1 RAY *rp; /* ray pointer */
48     short specfl; /* specularity flags, defined above */
49     COLOR mcolor; /* color of this material */
50     COLOR scolor; /* color of specular component */
51 greg 2.6 FVECT vrefl; /* vector in reflected direction */
52 greg 2.1 FVECT prdir; /* vector in transmitted direction */
53     FVECT u, v; /* u and v vectors orienting anisotropy */
54 greg 2.18 double u_alpha; /* u roughness */
55     double v_alpha; /* v roughness */
56 greg 2.1 double rdiff, rspec; /* reflected specular, diffuse */
57     double trans; /* transmissivity */
58     double tdiff, tspec; /* transmitted specular, diffuse */
59     FVECT pnorm; /* perturbed surface normal */
60     double pdot; /* perturbed dot product */
61     } ANISODAT; /* anisotropic material data */
62
63 greg 2.34 static void getacoords();
64     static void agaussamp();
65
66 greg 2.1
67 greg 2.34 static void
68 greg 2.1 diraniso(cval, np, ldir, omega) /* compute source contribution */
69     COLOR cval; /* returned coefficient */
70     register ANISODAT *np; /* material data */
71     FVECT ldir; /* light source direction */
72     double omega; /* light source size */
73     {
74     double ldot;
75 greg 2.16 double dtmp, dtmp1, dtmp2;
76 greg 2.1 FVECT h;
77     double au2, av2;
78     COLOR ctmp;
79
80     setcolor(cval, 0.0, 0.0, 0.0);
81
82     ldot = DOT(np->pnorm, ldir);
83
84     if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
85     return; /* wrong side */
86
87     if (ldot > FTINY && np->rdiff > FTINY) {
88     /*
89     * Compute and add diffuse reflected component to returned
90     * color. The diffuse reflected component will always be
91     * modified by the color of the material.
92     */
93     copycolor(ctmp, np->mcolor);
94     dtmp = ldot * omega * np->rdiff / PI;
95     scalecolor(ctmp, dtmp);
96     addcolor(cval, ctmp);
97     }
98 greg 2.10 if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) {
99 greg 2.1 /*
100     * Compute specular reflection coefficient using
101     * anisotropic gaussian distribution model.
102     */
103 greg 2.2 /* add source width if flat */
104     if (np->specfl & SP_FLAT)
105     au2 = av2 = omega/(4.0*PI);
106     else
107     au2 = av2 = 0.0;
108 greg 2.18 au2 += np->u_alpha*np->u_alpha;
109     av2 += np->v_alpha*np->v_alpha;
110 greg 2.1 /* half vector */
111     h[0] = ldir[0] - np->rp->rdir[0];
112     h[1] = ldir[1] - np->rp->rdir[1];
113     h[2] = ldir[2] - np->rp->rdir[2];
114     /* ellipse */
115 greg 2.16 dtmp1 = DOT(np->u, h);
116     dtmp1 *= dtmp1 / au2;
117 greg 2.1 dtmp2 = DOT(np->v, h);
118     dtmp2 *= dtmp2 / av2;
119     /* gaussian */
120 greg 2.23 dtmp = DOT(np->pnorm, h);
121     dtmp = (dtmp1 + dtmp2) / (dtmp*dtmp);
122     dtmp = exp(-dtmp) * (0.25/PI)
123 greg 2.16 * sqrt(ldot/(np->pdot*au2*av2));
124 greg 2.1 /* worth using? */
125     if (dtmp > FTINY) {
126     copycolor(ctmp, np->scolor);
127 greg 2.16 dtmp *= omega;
128 greg 2.1 scalecolor(ctmp, dtmp);
129     addcolor(cval, ctmp);
130     }
131     }
132     if (ldot < -FTINY && np->tdiff > FTINY) {
133     /*
134     * Compute diffuse transmission.
135     */
136     copycolor(ctmp, np->mcolor);
137     dtmp = -ldot * omega * np->tdiff / PI;
138     scalecolor(ctmp, dtmp);
139     addcolor(cval, ctmp);
140     }
141 greg 2.10 if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) {
142 greg 2.1 /*
143     * Compute specular transmission. Specular transmission
144     * is always modified by material color.
145     */
146     /* roughness + source */
147 greg 2.16 au2 = av2 = omega / PI;
148 greg 2.18 au2 += np->u_alpha*np->u_alpha;
149     av2 += np->v_alpha*np->v_alpha;
150 greg 2.16 /* "half vector" */
151     h[0] = ldir[0] - np->prdir[0];
152     h[1] = ldir[1] - np->prdir[1];
153     h[2] = ldir[2] - np->prdir[2];
154 greg 2.19 dtmp = DOT(h,h);
155 greg 2.16 if (dtmp > FTINY*FTINY) {
156 greg 2.19 dtmp1 = DOT(h,np->pnorm);
157     dtmp = 1.0 - dtmp1*dtmp1/dtmp;
158     if (dtmp > FTINY*FTINY) {
159     dtmp1 = DOT(h,np->u);
160 greg 2.23 dtmp1 *= dtmp1 / au2;
161 greg 2.19 dtmp2 = DOT(h,np->v);
162 greg 2.23 dtmp2 *= dtmp2 / av2;
163 greg 2.19 dtmp = (dtmp1 + dtmp2) / dtmp;
164     }
165 greg 2.16 } else
166     dtmp = 0.0;
167 greg 2.1 /* gaussian */
168 greg 2.21 dtmp = exp(-dtmp) * (1.0/PI)
169 greg 2.16 * sqrt(-ldot/(np->pdot*au2*av2));
170 greg 2.1 /* worth using? */
171     if (dtmp > FTINY) {
172     copycolor(ctmp, np->mcolor);
173 greg 2.16 dtmp *= np->tspec * omega;
174 greg 2.1 scalecolor(ctmp, dtmp);
175     addcolor(cval, ctmp);
176     }
177     }
178     }
179
180
181 greg 2.34 int
182 greg 2.1 m_aniso(m, r) /* shade ray that hit something anisotropic */
183     register OBJREC *m;
184     register RAY *r;
185     {
186     ANISODAT nd;
187     COLOR ctmp;
188     register int i;
189     /* easy shadow test */
190 greg 2.10 if (r->crtype & SHADOW)
191 greg 2.27 return(1);
192 greg 2.1
193     if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6))
194     objerror(m, USER, "bad number of real arguments");
195 greg 2.36 /* check for back side */
196     if (r->rod < 0.0) {
197     if (!backvis && m->otype != MAT_TRANS2) {
198     raytrans(r);
199     return(1);
200     }
201     raytexture(r, m->omod);
202     flipsurface(r); /* reorient if backvis */
203     } else
204     raytexture(r, m->omod);
205     /* get material color */
206 greg 2.2 nd.mp = m;
207 greg 2.1 nd.rp = r;
208     setcolor(nd.mcolor, m->oargs.farg[0],
209     m->oargs.farg[1],
210     m->oargs.farg[2]);
211     /* get roughness */
212     nd.specfl = 0;
213 greg 2.18 nd.u_alpha = m->oargs.farg[4];
214     nd.v_alpha = m->oargs.farg[5];
215     if (nd.u_alpha < FTINY || nd.v_alpha <= FTINY)
216 greg 2.10 objerror(m, USER, "roughness too small");
217 greg 2.36
218 greg 2.1 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
219     if (nd.pdot < .001)
220     nd.pdot = .001; /* non-zero for diraniso() */
221     multcolor(nd.mcolor, r->pcol); /* modify material color */
222     /* get specular component */
223     if ((nd.rspec = m->oargs.farg[3]) > FTINY) {
224     nd.specfl |= SP_REFL;
225     /* compute specular color */
226     if (m->otype == MAT_METAL2)
227     copycolor(nd.scolor, nd.mcolor);
228     else
229     setcolor(nd.scolor, 1.0, 1.0, 1.0);
230     scalecolor(nd.scolor, nd.rspec);
231 greg 2.4 /* check threshold */
232 greg 2.25 if (specthresh >= nd.rspec-FTINY)
233 greg 2.4 nd.specfl |= SP_RBLT;
234 greg 2.6 /* compute refl. direction */
235     for (i = 0; i < 3; i++)
236     nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i];
237     if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */
238     for (i = 0; i < 3; i++) /* safety measure */
239     nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
240 greg 2.1 }
241     /* compute transmission */
242 greg 2.16 if (m->otype == MAT_TRANS2) {
243 greg 2.1 nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec);
244     nd.tspec = nd.trans * m->oargs.farg[7];
245     nd.tdiff = nd.trans - nd.tspec;
246     if (nd.tspec > FTINY) {
247     nd.specfl |= SP_TRAN;
248 greg 2.4 /* check threshold */
249 greg 2.25 if (specthresh >= nd.tspec-FTINY)
250 greg 2.4 nd.specfl |= SP_TBLT;
251 greg 2.10 if (DOT(r->pert,r->pert) <= FTINY*FTINY) {
252 greg 2.1 VCOPY(nd.prdir, r->rdir);
253     } else {
254     for (i = 0; i < 3; i++) /* perturb */
255 greg 2.17 nd.prdir[i] = r->rdir[i] - r->pert[i];
256 greg 2.6 if (DOT(nd.prdir, r->ron) < -FTINY)
257     normalize(nd.prdir); /* OK */
258     else
259     VCOPY(nd.prdir, r->rdir);
260 greg 2.1 }
261     }
262     } else
263     nd.tdiff = nd.tspec = nd.trans = 0.0;
264
265     /* diffuse reflection */
266     nd.rdiff = 1.0 - nd.trans - nd.rspec;
267
268 greg 2.39 if (r->ro != NULL && isflat(r->ro->otype))
269 greg 2.4 nd.specfl |= SP_FLAT;
270
271 greg 2.1 getacoords(r, &nd); /* set up coordinates */
272
273 greg 2.10 if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU))
274 greg 2.1 agaussamp(r, &nd);
275
276     if (nd.rdiff > FTINY) { /* ambient from this side */
277 greg 2.30 ambient(ctmp, r, nd.pnorm);
278 greg 2.4 if (nd.specfl & SP_RBLT)
279     scalecolor(ctmp, 1.0-nd.trans);
280     else
281     scalecolor(ctmp, nd.rdiff);
282 greg 2.1 multcolor(ctmp, nd.mcolor); /* modified by material color */
283     addcolor(r->rcol, ctmp); /* add to returned color */
284     }
285     if (nd.tdiff > FTINY) { /* ambient from other side */
286 greg 2.31 FVECT bnorm;
287
288 greg 2.1 flipsurface(r);
289 greg 2.31 bnorm[0] = -nd.pnorm[0];
290     bnorm[1] = -nd.pnorm[1];
291     bnorm[2] = -nd.pnorm[2];
292     ambient(ctmp, r, bnorm);
293 greg 2.4 if (nd.specfl & SP_TBLT)
294     scalecolor(ctmp, nd.trans);
295     else
296     scalecolor(ctmp, nd.tdiff);
297 greg 2.1 multcolor(ctmp, nd.mcolor); /* modified by color */
298     addcolor(r->rcol, ctmp);
299     flipsurface(r);
300     }
301     /* add direct component */
302     direct(r, diraniso, &nd);
303 greg 2.27
304     return(1);
305 greg 2.1 }
306
307
308 greg 2.34 static void
309 greg 2.1 getacoords(r, np) /* set up coordinate system */
310     RAY *r;
311     register ANISODAT *np;
312     {
313     register MFUNC *mf;
314     register int i;
315
316     mf = getfunc(np->mp, 3, 0x7, 1);
317     setfunc(np->mp, r);
318     errno = 0;
319     for (i = 0; i < 3; i++)
320     np->u[i] = evalue(mf->ep[i]);
321 greg 2.37 if (errno == EDOM || errno == ERANGE) {
322 greg 2.1 objerror(np->mp, WARNING, "compute error");
323     np->specfl |= SP_BADU;
324     return;
325     }
326 greg 2.16 if (mf->f != &unitxf)
327     multv3(np->u, np->u, mf->f->xfm);
328 greg 2.1 fcross(np->v, np->pnorm, np->u);
329     if (normalize(np->v) == 0.0) {
330     objerror(np->mp, WARNING, "illegal orientation vector");
331     np->specfl |= SP_BADU;
332     return;
333     }
334     fcross(np->u, np->v, np->pnorm);
335     }
336
337
338 greg 2.34 static void
339 greg 2.1 agaussamp(r, np) /* sample anisotropic gaussian specular */
340     RAY *r;
341     register ANISODAT *np;
342     {
343     RAY sr;
344     FVECT h;
345     double rv[2];
346     double d, sinp, cosp;
347 greg 2.32 int niter;
348 greg 2.1 register int i;
349     /* compute reflection */
350 greg 2.4 if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
351 greg 2.1 rayorigin(&sr, r, SPECULAR, np->rspec) == 0) {
352     dimlist[ndims++] = (int)np->mp;
353 greg 2.32 for (niter = 0; niter < MAXITER; niter++) {
354     if (niter)
355     d = frandom();
356     else
357     d = urand(ilhash(dimlist,ndims)+samplendx);
358     multisamp(rv, 2, d);
359     d = 2.0*PI * rv[0];
360 gwlarson 2.33 cosp = tcos(d) * np->u_alpha;
361     sinp = tsin(d) * np->v_alpha;
362 greg 2.32 d = sqrt(cosp*cosp + sinp*sinp);
363     cosp /= d;
364     sinp /= d;
365     rv[1] = 1.0 - specjitter*rv[1];
366     if (rv[1] <= FTINY)
367     d = 1.0;
368     else
369     d = sqrt(-log(rv[1]) /
370     (cosp*cosp/(np->u_alpha*np->u_alpha) +
371     sinp*sinp/(np->v_alpha*np->v_alpha)));
372     for (i = 0; i < 3; i++)
373     h[i] = np->pnorm[i] +
374     d*(cosp*np->u[i] + sinp*np->v[i]);
375     d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d);
376     for (i = 0; i < 3; i++)
377     sr.rdir[i] = r->rdir[i] + d*h[i];
378     if (DOT(sr.rdir, r->ron) > FTINY) {
379     rayvalue(&sr);
380     multcolor(sr.rcol, np->scolor);
381     addcolor(r->rcol, sr.rcol);
382     break;
383     }
384     }
385 greg 2.1 ndims--;
386     }
387     /* compute transmission */
388 greg 2.7 if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
389     rayorigin(&sr, r, SPECULAR, np->tspec) == 0) {
390     dimlist[ndims++] = (int)np->mp;
391 greg 2.32 for (niter = 0; niter < MAXITER; niter++) {
392     if (niter)
393     d = frandom();
394     else
395     d = urand(ilhash(dimlist,ndims)+1823+samplendx);
396     multisamp(rv, 2, d);
397     d = 2.0*PI * rv[0];
398 gwlarson 2.33 cosp = tcos(d) * np->u_alpha;
399     sinp = tsin(d) * np->v_alpha;
400 greg 2.32 d = sqrt(cosp*cosp + sinp*sinp);
401     cosp /= d;
402     sinp /= d;
403     rv[1] = 1.0 - specjitter*rv[1];
404     if (rv[1] <= FTINY)
405     d = 1.0;
406     else
407     d = sqrt(-log(rv[1]) /
408     (cosp*cosp/(np->u_alpha*np->u_alpha) +
409 gwlarson 2.33 sinp*sinp/(np->v_alpha*np->v_alpha)));
410 greg 2.32 for (i = 0; i < 3; i++)
411     sr.rdir[i] = np->prdir[i] +
412     d*(cosp*np->u[i] + sinp*np->v[i]);
413     if (DOT(sr.rdir, r->ron) < -FTINY) {
414     normalize(sr.rdir); /* OK, normalize */
415     rayvalue(&sr);
416     scalecolor(sr.rcol, np->tspec);
417     multcolor(sr.rcol, np->mcolor); /* modify */
418     addcolor(r->rcol, sr.rcol);
419     break;
420     }
421     }
422 greg 2.7 ndims--;
423     }
424 greg 2.1 }
