--- ray/src/rt/aniso.c 1992/05/20 11:01:40 2.19 +++ ray/src/rt/aniso.c 2023/11/15 18:02:52 2.62 @@ -1,55 +1,54 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: aniso.c,v 2.62 2023/11/15 18:02:52 greg Exp $"; #endif - /* * Shading functions for anisotropic materials. */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" +#include "ambient.h" #include "otypes.h" - +#include "rtotypes.h" +#include "source.h" #include "func.h" - #include "random.h" +#include "pmapmat.h" -extern double specthresh; /* specular sampling threshold */ -extern double specjitter; /* specular sampling jitter */ +#ifndef MAXITER +#define MAXITER 10 /* maximum # specular ray attempts */ +#endif /* - * This anisotropic reflection model uses a variant on the - * exponential Gaussian used in normal.c. + * This routine implements the anisotropic Gaussian + * model described by Ward in Siggraph `92 article, updated with + * normalization and sampling adjustments due to Geisler-Moroder and Duer. * We orient the surface towards the incoming ray, so a single * surface can be used to represent an infinitely thin object. * * Arguments for MAT_PLASTIC2 and MAT_METAL2 are: * 4+ ux uy uz funcfile [transform...] * 0 - * 6 red grn blu specular-frac. u-facet-slope v-facet-slope + * 6 red grn blu specular-frac. u-rough v-rough * * Real arguments for MAT_TRANS2 are: * 8 red grn blu rspec u-rough v-rough trans tspec */ -#define BSPEC(m) (6.0) /* specularity parameter b */ - /* specularity flags */ #define SP_REFL 01 /* has reflected specular component */ #define SP_TRAN 02 /* has transmitted specular */ #define SP_FLAT 04 /* reflecting surface is flat */ #define SP_RBLT 010 /* reflection below sample threshold */ #define SP_TBLT 020 /* transmission below threshold */ -#define SP_BADU 040 /* bad u direction calculation */ typedef struct { OBJREC *mp; /* material pointer */ RAY *rp; /* ray pointer */ short specfl; /* specularity flags, defined above */ - COLOR mcolor; /* color of this material */ - COLOR scolor; /* color of specular component */ + SCOLOR mcolor; /* color of this material */ + SCOLOR scolor; /* color of specular component */ FVECT vrefl; /* vector in reflected direction */ FVECT prdir; /* vector in transmitted direction */ FVECT u, v; /* u and v vectors orienting anisotropy */ @@ -62,180 +61,186 @@ typedef struct { double pdot; /* perturbed dot product */ } ANISODAT; /* anisotropic material data */ +static void getacoords(ANISODAT *np); +static void agaussamp(ANISODAT *np); -diraniso(cval, np, ldir, omega) /* compute source contribution */ -COLOR cval; /* returned coefficient */ -register ANISODAT *np; /* material data */ -FVECT ldir; /* light source direction */ -double omega; /* light source size */ + +static void +diraniso( /* compute source contribution */ + SCOLOR scval, /* returned coefficient */ + void *nnp, /* material data */ + FVECT ldir, /* light source direction */ + double omega /* light source size */ +) { + ANISODAT *np = nnp; double ldot; double dtmp, dtmp1, dtmp2; FVECT h; double au2, av2; - COLOR ctmp; + SCOLOR sctmp; - setcolor(cval, 0.0, 0.0, 0.0); + scolorblack(scval); ldot = DOT(np->pnorm, ldir); if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) return; /* wrong side */ - if (ldot > FTINY && np->rdiff > FTINY) { + if ((ldot > FTINY) & (np->rdiff > FTINY)) { /* * Compute and add diffuse reflected component to returned * color. The diffuse reflected component will always be * modified by the color of the material. */ - copycolor(ctmp, np->mcolor); - dtmp = ldot * omega * np->rdiff / PI; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + copyscolor(sctmp, np->mcolor); + dtmp = ldot * omega * np->rdiff * (1.0/PI); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } - if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) { + + if ((ldot < -FTINY) & (np->tdiff > FTINY)) { /* + * Compute diffuse transmission. + */ + copyscolor(sctmp, np->mcolor); + dtmp = -ldot * omega * np->tdiff * (1.0/PI); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); + } + + if (ambRayInPmap(np->rp)) + return; /* specular accounted for in photon map */ + + if (ldot > FTINY && np->specfl&SP_REFL) { + /* * Compute specular reflection coefficient using - * anisotropic gaussian distribution model. + * anisotropic Gaussian distribution model. */ /* add source width if flat */ if (np->specfl & SP_FLAT) - au2 = av2 = omega/(4.0*PI); + au2 = av2 = omega * (0.25/PI); else au2 = av2 = 0.0; au2 += np->u_alpha*np->u_alpha; av2 += np->v_alpha*np->v_alpha; /* half vector */ - h[0] = ldir[0] - np->rp->rdir[0]; - h[1] = ldir[1] - np->rp->rdir[1]; - h[2] = ldir[2] - np->rp->rdir[2]; - normalize(h); + VSUB(h, ldir, np->rp->rdir); /* ellipse */ dtmp1 = DOT(np->u, h); dtmp1 *= dtmp1 / au2; dtmp2 = DOT(np->v, h); dtmp2 *= dtmp2 / av2; - /* gaussian */ - dtmp = (dtmp1 + dtmp2) / (1.0 + DOT(np->pnorm, h)); - dtmp = exp(-2.0*dtmp) * 1.0/(4.0*PI) - * sqrt(ldot/(np->pdot*au2*av2)); + /* new W-G-M-D model */ + dtmp = DOT(np->pnorm, h); + dtmp *= dtmp; + dtmp1 = (dtmp1 + dtmp2) / dtmp; + dtmp = exp(-dtmp1) * DOT(h,h) / + (PI * dtmp*dtmp * sqrt(au2*av2)); /* worth using? */ if (dtmp > FTINY) { - copycolor(ctmp, np->scolor); - dtmp *= omega; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + copyscolor(sctmp, np->scolor); + dtmp *= ldot * omega; + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } } - if (ldot < -FTINY && np->tdiff > FTINY) { + + if (ldot < -FTINY && np->specfl&SP_TRAN) { /* - * Compute diffuse transmission. - */ - copycolor(ctmp, np->mcolor); - dtmp = -ldot * omega * np->tdiff / PI; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); - } - if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) { - /* * Compute specular transmission. Specular transmission * is always modified by material color. */ /* roughness + source */ - au2 = av2 = omega / PI; + au2 = av2 = omega * (1.0/PI); au2 += np->u_alpha*np->u_alpha; av2 += np->v_alpha*np->v_alpha; /* "half vector" */ - h[0] = ldir[0] - np->prdir[0]; - h[1] = ldir[1] - np->prdir[1]; - h[2] = ldir[2] - np->prdir[2]; + VSUB(h, ldir, np->prdir); dtmp = DOT(h,h); if (dtmp > FTINY*FTINY) { dtmp1 = DOT(h,np->pnorm); dtmp = 1.0 - dtmp1*dtmp1/dtmp; if (dtmp > FTINY*FTINY) { dtmp1 = DOT(h,np->u); - dtmp1 = dtmp1*dtmp1 / au2; + dtmp1 *= dtmp1 / au2; dtmp2 = DOT(h,np->v); - dtmp2 = dtmp2*dtmp2 / av2; + dtmp2 *= dtmp2 / av2; dtmp = (dtmp1 + dtmp2) / dtmp; } } else dtmp = 0.0; - /* gaussian */ - dtmp = exp(-dtmp) * 1.0/(4.0*PI) - * sqrt(-ldot/(np->pdot*au2*av2)); + /* Gaussian */ + dtmp = exp(-dtmp) * (1.0/PI) * sqrt(-ldot/(np->pdot*au2*av2)); /* worth using? */ if (dtmp > FTINY) { - copycolor(ctmp, np->mcolor); + copyscolor(sctmp, np->mcolor); dtmp *= np->tspec * omega; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } } } -m_aniso(m, r) /* shade ray that hit something anisotropic */ -register OBJREC *m; -register RAY *r; +int +m_aniso( /* shade ray that hit something anisotropic */ + OBJREC *m, + RAY *r +) { ANISODAT nd; - double dtmp; - COLOR ctmp; - register int i; + SCOLOR sctmp; + int i; /* easy shadow test */ if (r->crtype & SHADOW) - return; + return(1); if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6)) objerror(m, USER, "bad number of real arguments"); + /* check for back side */ + if (r->rod < 0.0) { + if (!backvis) { + raytrans(r); + return(1); + } + raytexture(r, m->omod); + flipsurface(r); /* reorient if backvis */ + } else + raytexture(r, m->omod); + /* get material color */ nd.mp = m; nd.rp = r; - /* get material color */ - setcolor(nd.mcolor, m->oargs.farg[0], + setscolor(nd.mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); /* get roughness */ nd.specfl = 0; nd.u_alpha = m->oargs.farg[4]; nd.v_alpha = m->oargs.farg[5]; - if (nd.u_alpha < FTINY || nd.v_alpha <= FTINY) + if ((nd.u_alpha <= FTINY) | (nd.v_alpha <= FTINY)) objerror(m, USER, "roughness too small"); - /* reorient if necessary */ - if (r->rod < 0.0) - flipsurface(r); - /* get modifiers */ - raytexture(r, m->omod); + nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ if (nd.pdot < .001) nd.pdot = .001; /* non-zero for diraniso() */ - multcolor(nd.mcolor, r->pcol); /* modify material color */ + smultscolor(nd.mcolor, r->pcol); /* modify material color */ /* get specular component */ if ((nd.rspec = m->oargs.farg[3]) > FTINY) { nd.specfl |= SP_REFL; /* compute specular color */ if (m->otype == MAT_METAL2) - copycolor(nd.scolor, nd.mcolor); + copyscolor(nd.scolor, nd.mcolor); else - setcolor(nd.scolor, 1.0, 1.0, 1.0); - scalecolor(nd.scolor, nd.rspec); - /* improved model */ - dtmp = exp(-BSPEC(m)*nd.pdot); - for (i = 0; i < 3; i++) - colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; - nd.rspec += (1.0-nd.rspec)*dtmp; + setscolor(nd.scolor, 1.0, 1.0, 1.0); + scalescolor(nd.scolor, nd.rspec); /* check threshold */ - if (specthresh > FTINY && - (specthresh >= 1.-FTINY || - specthresh + .05 - .1*frandom() > nd.rspec)) + if (specthresh >= nd.rspec-FTINY) nd.specfl |= SP_RBLT; /* compute refl. direction */ - for (i = 0; i < 3; i++) - nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; + VSUM(nd.vrefl, r->rdir, nd.pnorm, 2.0*nd.pdot); if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */ - for (i = 0; i < 3; i++) /* safety measure */ - nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; + VSUM(nd.vrefl, r->rdir, r->ron, 2.0*r->rod); } /* compute transmission */ if (m->otype == MAT_TRANS2) { @@ -245,9 +250,7 @@ register RAY *r; if (nd.tspec > FTINY) { nd.specfl |= SP_TRAN; /* check threshold */ - if (specthresh > FTINY && - (specthresh >= 1.-FTINY || - specthresh + .05 - .1*frandom() > nd.tspec)) + if (specthresh >= nd.tspec-FTINY) nd.specfl |= SP_TBLT; if (DOT(r->pert,r->pert) <= FTINY*FTINY) { VCOPY(nd.prdir, r->rdir); @@ -266,142 +269,210 @@ register RAY *r; /* diffuse reflection */ nd.rdiff = 1.0 - nd.trans - nd.rspec; - if (r->ro != NULL && (r->ro->otype == OBJ_FACE || - r->ro->otype == OBJ_RING)) + if (r->ro != NULL && isflat(r->ro->otype)) nd.specfl |= SP_FLAT; - getacoords(r, &nd); /* set up coordinates */ + getacoords(&nd); /* set up coordinates */ - if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU)) - agaussamp(r, &nd); + if (nd.specfl & (SP_REFL|SP_TRAN)) + agaussamp(&nd); if (nd.rdiff > FTINY) { /* ambient from this side */ - ambient(ctmp, r); - if (nd.specfl & SP_RBLT) - scalecolor(ctmp, 1.0-nd.trans); - else - scalecolor(ctmp, nd.rdiff); - multcolor(ctmp, nd.mcolor); /* modified by material color */ - addcolor(r->rcol, ctmp); /* add to returned color */ + copyscolor(sctmp, nd.mcolor); /* modified by material color */ + scalescolor(sctmp, nd.rdiff); + if (nd.specfl & SP_RBLT) /* add in specular as well? */ + saddscolor(sctmp, nd.scolor); + multambient(sctmp, r, nd.pnorm); + saddscolor(r->rcol, sctmp); /* add to returned color */ } + if (nd.tdiff > FTINY) { /* ambient from other side */ + FVECT bnorm; + flipsurface(r); - ambient(ctmp, r); - if (nd.specfl & SP_TBLT) - scalecolor(ctmp, nd.trans); - else - scalecolor(ctmp, nd.tdiff); - multcolor(ctmp, nd.mcolor); /* modified by color */ - addcolor(r->rcol, ctmp); + bnorm[0] = -nd.pnorm[0]; + bnorm[1] = -nd.pnorm[1]; + bnorm[2] = -nd.pnorm[2]; + copyscolor(sctmp, nd.mcolor); /* modified by color */ + if (nd.specfl & SP_TBLT) { + scalescolor(sctmp, nd.trans); + } else { + scalescolor(sctmp, nd.tdiff); + } + multambient(sctmp, r, bnorm); + saddscolor(r->rcol, sctmp); flipsurface(r); } /* add direct component */ direct(r, diraniso, &nd); + + return(1); } - -static -getacoords(r, np) /* set up coordinate system */ -RAY *r; -register ANISODAT *np; +static void +getacoords( /* set up coordinate system */ + ANISODAT *np +) { - register MFUNC *mf; - register int i; + MFUNC *mf; + int i; mf = getfunc(np->mp, 3, 0x7, 1); - setfunc(np->mp, r); + setfunc(np->mp, np->rp); errno = 0; for (i = 0; i < 3; i++) np->u[i] = evalue(mf->ep[i]); - if (errno) { - objerror(np->mp, WARNING, "compute error"); - np->specfl |= SP_BADU; - return; - } - if (mf->f != &unitxf) - multv3(np->u, np->u, mf->f->xfm); + if ((errno == EDOM) | (errno == ERANGE)) + np->u[0] = np->u[1] = np->u[2] = 0.0; + if (mf->fxp != &unitxf) + multv3(np->u, np->u, mf->fxp->xfm); fcross(np->v, np->pnorm, np->u); if (normalize(np->v) == 0.0) { - objerror(np->mp, WARNING, "illegal orientation vector"); - np->specfl |= SP_BADU; - return; - } - fcross(np->u, np->v, np->pnorm); + if (fabs(np->u_alpha - np->v_alpha) > 0.001) + objerror(np->mp, WARNING, "illegal orientation vector"); + getperpendicular(np->u, np->pnorm, 1); /* punting */ + fcross(np->v, np->pnorm, np->u); + np->u_alpha = np->v_alpha = sqrt( 0.5 * + (np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) ); + } else + fcross(np->u, np->v, np->pnorm); } -static -agaussamp(r, np) /* sample anisotropic gaussian specular */ -RAY *r; -register ANISODAT *np; +static void +agaussamp( /* sample anisotropic Gaussian specular */ + ANISODAT *np +) { RAY sr; FVECT h; double rv[2]; double d, sinp, cosp; - register int i; + SCOLOR scol; + int maxiter, ntrials, nstarget, nstaken; + int i; /* compute reflection */ if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && - rayorigin(&sr, r, SPECULAR, np->rspec) == 0) { - dimlist[ndims++] = (int)np->mp; - d = urand(ilhash(dimlist,ndims)+samplendx); - multisamp(rv, 2, d); - d = 2.0*PI * rv[0]; - cosp = cos(d) * np->u_alpha; - sinp = sin(d) * np->v_alpha; - d = sqrt(cosp*cosp + sinp*sinp); - cosp /= d; - sinp /= d; - rv[1] = 1.0 - specjitter*rv[1]; - if (rv[1] <= FTINY) - d = 1.0; - else - d = sqrt(-log(rv[1]) / - (cosp*cosp/(np->u_alpha*np->u_alpha) + - sinp*sinp/(np->v_alpha*np->v_alpha))); - for (i = 0; i < 3; i++) - h[i] = np->pnorm[i] + - d*(cosp*np->u[i] + sinp*np->v[i]); - d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d); - for (i = 0; i < 3; i++) - sr.rdir[i] = r->rdir[i] + d*h[i]; - if (DOT(sr.rdir, r->ron) <= FTINY) /* penetration? */ - VCOPY(sr.rdir, np->vrefl); /* jitter no good */ - rayvalue(&sr); - multcolor(sr.rcol, np->scolor); - addcolor(r->rcol, sr.rcol); + rayorigin(&sr, SPECULAR, np->rp, np->scolor) == 0) { + nstarget = 1; + if (specjitter > 1.5) { /* multiple samples? */ + nstarget = specjitter*np->rp->rweight + .5; + if (sr.rweight <= minweight*nstarget) + nstarget = sr.rweight/minweight; + if (nstarget > 1) { + d = 1./nstarget; + scalecolor(sr.rcoef, d); + sr.rweight *= d; + } else + nstarget = 1; + } + scolorblack(scol); + dimlist[ndims++] = (int)(size_t)np->mp; + maxiter = MAXITER*nstarget; + for (nstaken = ntrials = 0; nstaken < nstarget && + ntrials < maxiter; ntrials++) { + if (ntrials) + d = frandom(); + else + d = urand(ilhash(dimlist,ndims)+samplendx); + multisamp(rv, 2, d); + d = 2.0*PI * rv[0]; + cosp = tcos(d) * np->u_alpha; + sinp = tsin(d) * np->v_alpha; + d = 1./sqrt(cosp*cosp + sinp*sinp); + cosp *= d; + sinp *= d; + if ((0. <= specjitter) & (specjitter < 1.)) + rv[1] = 1.0 - specjitter*rv[1]; + if (rv[1] <= FTINY) + d = 1.0; + else + d = sqrt(-log(rv[1]) / + (cosp*cosp/(np->u_alpha*np->u_alpha) + + sinp*sinp/(np->v_alpha*np->v_alpha))); + for (i = 0; i < 3; i++) + h[i] = np->pnorm[i] + + d*(cosp*np->u[i] + sinp*np->v[i]); + d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d); + VSUM(sr.rdir, np->rp->rdir, h, d); + /* sample rejection test */ + if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY) + continue; + checknorm(sr.rdir); + if (nstarget > 1) { /* W-G-M-D adjustment */ + if (nstaken) rayclear(&sr); + rayvalue(&sr); + d = 2./(1. + np->rp->rod/d); + scalescolor(sr.rcol, d); + saddscolor(scol, sr.rcol); + } else { + rayvalue(&sr); + smultscolor(sr.rcol, sr.rcoef); + saddscolor(np->rp->rcol, sr.rcol); + } + ++nstaken; + } + if (nstarget > 1) { /* final W-G-M-D weighting */ + smultscolor(scol, sr.rcoef); + d = (double)nstarget/ntrials; + scalescolor(scol, d); + saddscolor(np->rp->rcol, scol); + } ndims--; } /* compute transmission */ + copyscolor(sr.rcoef, np->mcolor); /* modify by material color */ + scalescolor(sr.rcoef, np->tspec); if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && - rayorigin(&sr, r, SPECULAR, np->tspec) == 0) { - dimlist[ndims++] = (int)np->mp; - d = urand(ilhash(dimlist,ndims)+1823+samplendx); - multisamp(rv, 2, d); - d = 2.0*PI * rv[0]; - cosp = cos(d) * np->u_alpha; - sinp = sin(d) * np->v_alpha; - d = sqrt(cosp*cosp + sinp*sinp); - cosp /= d; - sinp /= d; - rv[1] = 1.0 - specjitter*rv[1]; - if (rv[1] <= FTINY) - d = 1.0; - else - d = sqrt(-log(rv[1]) / - (cosp*cosp/(np->u_alpha*np->u_alpha) + - sinp*sinp/(np->v_alpha*np->u_alpha))); - for (i = 0; i < 3; i++) - sr.rdir[i] = np->prdir[i] + - d*(cosp*np->u[i] + sinp*np->v[i]); - if (DOT(sr.rdir, r->ron) < -FTINY) - normalize(sr.rdir); /* OK, normalize */ - else - VCOPY(sr.rdir, np->prdir); /* else no jitter */ - rayvalue(&sr); - scalecolor(sr.rcol, np->tspec); - multcolor(sr.rcol, np->mcolor); /* modify by color */ - addcolor(r->rcol, sr.rcol); + rayorigin(&sr, SPECULAR, np->rp, sr.rcoef) == 0) { + nstarget = 1; + if (specjitter > 1.5) { /* multiple samples? */ + nstarget = specjitter*np->rp->rweight + .5; + if (sr.rweight <= minweight*nstarget) + nstarget = sr.rweight/minweight; + if (nstarget > 1) { + d = 1./nstarget; + scalecolor(sr.rcoef, d); + sr.rweight *= d; + } else + nstarget = 1; + } + dimlist[ndims++] = (int)(size_t)np->mp; + maxiter = MAXITER*nstarget; + for (nstaken = ntrials = 0; nstaken < nstarget && + ntrials < maxiter; ntrials++) { + if (ntrials) + d = frandom(); + else + d = urand(ilhash(dimlist,ndims)+1823+samplendx); + multisamp(rv, 2, d); + d = 2.0*PI * rv[0]; + cosp = tcos(d) * np->u_alpha; + sinp = tsin(d) * np->v_alpha; + d = 1./sqrt(cosp*cosp + sinp*sinp); + cosp *= d; + sinp *= d; + if ((0. <= specjitter) & (specjitter < 1.)) + rv[1] = 1.0 - specjitter*rv[1]; + if (rv[1] <= FTINY) + d = 1.0; + else + d = sqrt(-log(rv[1]) / + (cosp*cosp/(np->u_alpha*np->u_alpha) + + sinp*sinp/(np->v_alpha*np->v_alpha))); + for (i = 0; i < 3; i++) + sr.rdir[i] = np->prdir[i] + + d*(cosp*np->u[i] + sinp*np->v[i]); + if (DOT(sr.rdir, np->rp->ron) >= -FTINY) + continue; + normalize(sr.rdir); /* OK, normalize */ + if (nstaken) /* multi-sampling */ + rayclear(&sr); + rayvalue(&sr); + smultscolor(sr.rcol, sr.rcoef); + saddscolor(np->rp->rcol, sr.rcol); + ++nstaken; + } ndims--; } }
