--- ray/src/rt/aniso.c 2010/10/13 15:29:02 2.50 +++ ray/src/rt/aniso.c 2014/12/04 05:26:28 2.57 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: aniso.c,v 2.50 2010/10/13 15:29:02 greg Exp $"; +static const char RCSid[] = "$Id: aniso.c,v 2.57 2014/12/04 05:26:28 greg Exp $"; #endif /* * Shading functions for anisotropic materials. @@ -21,14 +21,15 @@ static const char RCSid[] = "$Id: aniso.c,v 2.50 2010/ /* * This routine implements the anisotropic Gaussian - * model described by Ward in Siggraph `92 article. + * model described by Ward in Siggraph `92 article, updated with + * normalization and sampling adjustments due to Geisler-Moroder and Duer. * We orient the surface towards the incoming ray, so a single * surface can be used to represent an infinitely thin object. * * Arguments for MAT_PLASTIC2 and MAT_METAL2 are: * 4+ ux uy uz funcfile [transform...] * 0 - * 6 red grn blu specular-frac. u-facet-slope v-facet-slope + * 6 red grn blu specular-frac. u-rough v-rough * * Real arguments for MAT_TRANS2 are: * 8 red grn blu rspec u-rough v-rough trans tspec @@ -40,7 +41,6 @@ static const char RCSid[] = "$Id: aniso.c,v 2.50 2010/ #define SP_FLAT 04 /* reflecting surface is flat */ #define SP_RBLT 010 /* reflection below sample threshold */ #define SP_TBLT 020 /* transmission below threshold */ -#define SP_BADU 040 /* bad u direction calculation */ typedef struct { OBJREC *mp; /* material pointer */ @@ -60,20 +60,19 @@ typedef struct { double pdot; /* perturbed dot product */ } ANISODAT; /* anisotropic material data */ -static srcdirf_t diraniso; -static void getacoords(RAY *r, ANISODAT *np); -static void agaussamp(RAY *r, ANISODAT *np); +static void getacoords(ANISODAT *np); +static void agaussamp(ANISODAT *np); static void diraniso( /* compute source contribution */ COLOR cval, /* returned coefficient */ - void *nnp, /* material data */ + void *nnp, /* material data */ FVECT ldir, /* light source direction */ double omega /* light source size */ ) { - register ANISODAT *np = nnp; + ANISODAT *np = nnp; double ldot; double dtmp, dtmp1, dtmp2; FVECT h; @@ -87,7 +86,7 @@ diraniso( /* compute source contribution */ if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) return; /* wrong side */ - if (ldot > FTINY && np->rdiff > FTINY) { + if ((ldot > FTINY) & (np->rdiff > FTINY)) { /* * Compute and add diffuse reflected component to returned * color. The diffuse reflected component will always be @@ -98,7 +97,7 @@ diraniso( /* compute source contribution */ scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) { + if (ldot > FTINY && np->specfl&SP_REFL) { /* * Compute specular reflection coefficient using * anisotropic Gaussian distribution model. @@ -111,9 +110,7 @@ diraniso( /* compute source contribution */ au2 += np->u_alpha*np->u_alpha; av2 += np->v_alpha*np->v_alpha; /* half vector */ - h[0] = ldir[0] - np->rp->rdir[0]; - h[1] = ldir[1] - np->rp->rdir[1]; - h[2] = ldir[2] - np->rp->rdir[2]; + VSUB(h, ldir, np->rp->rdir); /* ellipse */ dtmp1 = DOT(np->u, h); dtmp1 *= dtmp1 / au2; @@ -133,7 +130,7 @@ diraniso( /* compute source contribution */ addcolor(cval, ctmp); } } - if (ldot < -FTINY && np->tdiff > FTINY) { + if ((ldot < -FTINY) & (np->tdiff > FTINY)) { /* * Compute diffuse transmission. */ @@ -142,7 +139,7 @@ diraniso( /* compute source contribution */ scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) { + if (ldot < -FTINY && np->specfl&SP_TRAN) { /* * Compute specular transmission. Specular transmission * is always modified by material color. @@ -152,9 +149,7 @@ diraniso( /* compute source contribution */ au2 += np->u_alpha*np->u_alpha; av2 += np->v_alpha*np->v_alpha; /* "half vector" */ - h[0] = ldir[0] - np->prdir[0]; - h[1] = ldir[1] - np->prdir[1]; - h[2] = ldir[2] - np->prdir[2]; + VSUB(h, ldir, np->prdir); dtmp = DOT(h,h); if (dtmp > FTINY*FTINY) { dtmp1 = DOT(h,np->pnorm); @@ -181,15 +176,15 @@ diraniso( /* compute source contribution */ } -extern int +int m_aniso( /* shade ray that hit something anisotropic */ - register OBJREC *m, - register RAY *r + OBJREC *m, + RAY *r ) { ANISODAT nd; COLOR ctmp; - register int i; + int i; /* easy shadow test */ if (r->crtype & SHADOW) return(1); @@ -198,7 +193,7 @@ m_aniso( /* shade ray that hit something anisotropic objerror(m, USER, "bad number of real arguments"); /* check for back side */ if (r->rod < 0.0) { - if (!backvis && m->otype != MAT_TRANS2) { + if (!backvis) { raytrans(r); return(1); } @@ -216,7 +211,7 @@ m_aniso( /* shade ray that hit something anisotropic nd.specfl = 0; nd.u_alpha = m->oargs.farg[4]; nd.v_alpha = m->oargs.farg[5]; - if (nd.u_alpha <= FTINY || nd.v_alpha <= FTINY) + if ((nd.u_alpha <= FTINY) | (nd.v_alpha <= FTINY)) objerror(m, USER, "roughness too small"); nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ @@ -270,17 +265,16 @@ m_aniso( /* shade ray that hit something anisotropic if (r->ro != NULL && isflat(r->ro->otype)) nd.specfl |= SP_FLAT; - getacoords(r, &nd); /* set up coordinates */ + getacoords(&nd); /* set up coordinates */ - if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU)) - agaussamp(r, &nd); + if (nd.specfl & (SP_REFL|SP_TRAN)) + agaussamp(&nd); if (nd.rdiff > FTINY) { /* ambient from this side */ copycolor(ctmp, nd.mcolor); /* modified by material color */ - if (nd.specfl & SP_RBLT) - scalecolor(ctmp, 1.0-nd.trans); - else - scalecolor(ctmp, nd.rdiff); + scalecolor(ctmp, nd.rdiff); + if (nd.specfl & SP_RBLT) /* add in specular as well? */ + addcolor(ctmp, nd.scolor); multambient(ctmp, r, nd.pnorm); addcolor(r->rcol, ctmp); /* add to returned color */ } @@ -309,39 +303,37 @@ m_aniso( /* shade ray that hit something anisotropic static void getacoords( /* set up coordinate system */ - RAY *r, - register ANISODAT *np + ANISODAT *np ) { - register MFUNC *mf; - register int i; + MFUNC *mf; + int i; mf = getfunc(np->mp, 3, 0x7, 1); - setfunc(np->mp, r); + setfunc(np->mp, np->rp); errno = 0; for (i = 0; i < 3; i++) np->u[i] = evalue(mf->ep[i]); - if (errno == EDOM || errno == ERANGE) { - objerror(np->mp, WARNING, "compute error"); - np->specfl |= SP_BADU; - return; - } - if (mf->f != &unitxf) - multv3(np->u, np->u, mf->f->xfm); + if ((errno == EDOM) | (errno == ERANGE)) + np->u[0] = np->u[1] = np->u[2] = 0.0; + if (mf->fxp != &unitxf) + multv3(np->u, np->u, mf->fxp->xfm); fcross(np->v, np->pnorm, np->u); if (normalize(np->v) == 0.0) { - objerror(np->mp, WARNING, "illegal orientation vector"); - np->specfl |= SP_BADU; - return; - } - fcross(np->u, np->v, np->pnorm); + if (fabs(np->u_alpha - np->v_alpha) > 0.001) + objerror(np->mp, WARNING, "illegal orientation vector"); + getperpendicular(np->u, np->pnorm); /* punting */ + fcross(np->v, np->pnorm, np->u); + np->u_alpha = np->v_alpha = sqrt( 0.5 * + (np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) ); + } else + fcross(np->u, np->v, np->pnorm); } static void agaussamp( /* sample anisotropic Gaussian specular */ - RAY *r, - register ANISODAT *np + ANISODAT *np ) { RAY sr; @@ -350,13 +342,13 @@ agaussamp( /* sample anisotropic Gaussian specular */ double d, sinp, cosp; COLOR scol; int maxiter, ntrials, nstarget, nstaken; - register int i; + int i; /* compute reflection */ if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && - rayorigin(&sr, SPECULAR, r, np->scolor) == 0) { + rayorigin(&sr, SPECULAR, np->rp, np->scolor) == 0) { nstarget = 1; if (specjitter > 1.5) { /* multiple samples? */ - nstarget = specjitter*r->rweight + .5; + nstarget = specjitter*np->rp->rweight + .5; if (sr.rweight <= minweight*nstarget) nstarget = sr.rweight/minweight; if (nstarget > 1) { @@ -367,7 +359,7 @@ agaussamp( /* sample anisotropic Gaussian specular */ nstarget = 1; } setcolor(scol, 0., 0., 0.); - dimlist[ndims++] = (int)np->mp; + dimlist[ndims++] = (int)(size_t)np->mp; maxiter = MAXITER*nstarget; for (nstaken = ntrials = 0; nstaken < nstarget && ntrials < maxiter; ntrials++) { @@ -393,22 +385,22 @@ agaussamp( /* sample anisotropic Gaussian specular */ for (i = 0; i < 3; i++) h[i] = np->pnorm[i] + d*(cosp*np->u[i] + sinp*np->v[i]); - d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d); - VSUM(sr.rdir, r->rdir, h, d); + d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d); + VSUM(sr.rdir, np->rp->rdir, h, d); /* sample rejection test */ - if ((d = DOT(sr.rdir, r->ron)) <= FTINY) + if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY) continue; checknorm(sr.rdir); if (nstarget > 1) { /* W-G-M-D adjustment */ if (nstaken) rayclear(&sr); rayvalue(&sr); - d = 2./(1. + r->rod/d); + d = 2./(1. + np->rp->rod/d); scalecolor(sr.rcol, d); addcolor(scol, sr.rcol); } else { rayvalue(&sr); multcolor(sr.rcol, sr.rcoef); - addcolor(r->rcol, sr.rcol); + addcolor(np->rp->rcol, sr.rcol); } ++nstaken; } @@ -416,7 +408,7 @@ agaussamp( /* sample anisotropic Gaussian specular */ multcolor(scol, sr.rcoef); d = (double)nstarget/ntrials; scalecolor(scol, d); - addcolor(r->rcol, scol); + addcolor(np->rp->rcol, scol); } ndims--; } @@ -424,10 +416,10 @@ agaussamp( /* sample anisotropic Gaussian specular */ copycolor(sr.rcoef, np->mcolor); /* modify by material color */ scalecolor(sr.rcoef, np->tspec); if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && - rayorigin(&sr, SPECULAR, r, sr.rcoef) == 0) { + rayorigin(&sr, SPECULAR, np->rp, sr.rcoef) == 0) { nstarget = 1; if (specjitter > 1.5) { /* multiple samples? */ - nstarget = specjitter*r->rweight + .5; + nstarget = specjitter*np->rp->rweight + .5; if (sr.rweight <= minweight*nstarget) nstarget = sr.rweight/minweight; if (nstarget > 1) { @@ -437,7 +429,7 @@ agaussamp( /* sample anisotropic Gaussian specular */ } else nstarget = 1; } - dimlist[ndims++] = (int)np->mp; + dimlist[ndims++] = (int)(size_t)np->mp; maxiter = MAXITER*nstarget; for (nstaken = ntrials = 0; nstaken < nstarget && ntrials < maxiter; ntrials++) { @@ -463,14 +455,14 @@ agaussamp( /* sample anisotropic Gaussian specular */ for (i = 0; i < 3; i++) sr.rdir[i] = np->prdir[i] + d*(cosp*np->u[i] + sinp*np->v[i]); - if (DOT(sr.rdir, r->ron) >= -FTINY) + if (DOT(sr.rdir, np->rp->ron) >= -FTINY) continue; normalize(sr.rdir); /* OK, normalize */ if (nstaken) /* multi-sampling */ rayclear(&sr); rayvalue(&sr); multcolor(sr.rcol, sr.rcoef); - addcolor(r->rcol, sr.rcol); + addcolor(np->rp->rcol, sr.rcol); ++nstaken; } ndims--;
