1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Shading functions for anisotropic materials. |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "otypes.h" |
14 |
15 |
#include "func.h" |
16 |
17 |
#include "random.h" |
18 |
19 |
extern double specthresh; /* specular sampling threshold */ |
20 |
extern double specjitter; /* specular sampling jitter */ |
21 |
22 |
23 |
* This anisotropic reflection model uses a variant on the |
24 |
* exponential Gaussian used in normal.c. |
25 |
* We orient the surface towards the incoming ray, so a single |
26 |
* surface can be used to represent an infinitely thin object. |
27 |
28 |
* Arguments for MAT_PLASTIC2 and MAT_METAL2 are: |
29 |
* 4+ ux uy uz funcfile [transform...] |
30 |
* 0 |
31 |
* 6 red grn blu specular-frac. u-facet-slope v-facet-slope |
32 |
33 |
* Real arguments for MAT_TRANS2 are: |
34 |
* 8 red grn blu rspec u-rough v-rough trans tspec |
35 |
36 |
37 |
#define BSPEC(m) (6.0) /* specularity parameter b */ |
38 |
39 |
/* specularity flags */ |
40 |
#define SP_REFL 01 /* has reflected specular component */ |
41 |
#define SP_TRAN 02 /* has transmitted specular */ |
42 |
#define SP_FLAT 04 /* reflecting surface is flat */ |
43 |
#define SP_RBLT 010 /* reflection below sample threshold */ |
44 |
#define SP_TBLT 020 /* transmission below threshold */ |
45 |
#define SP_BADU 040 /* bad u direction calculation */ |
46 |
47 |
typedef struct { |
48 |
OBJREC *mp; /* material pointer */ |
49 |
RAY *rp; /* ray pointer */ |
50 |
short specfl; /* specularity flags, defined above */ |
51 |
COLOR mcolor; /* color of this material */ |
52 |
COLOR scolor; /* color of specular component */ |
53 |
FVECT vrefl; /* vector in reflected direction */ |
54 |
FVECT prdir; /* vector in transmitted direction */ |
55 |
FVECT u, v; /* u and v vectors orienting anisotropy */ |
56 |
double u_alpha; /* u roughness */ |
57 |
double v_alpha; /* v roughness */ |
58 |
double rdiff, rspec; /* reflected specular, diffuse */ |
59 |
double trans; /* transmissivity */ |
60 |
double tdiff, tspec; /* transmitted specular, diffuse */ |
61 |
FVECT pnorm; /* perturbed surface normal */ |
62 |
double pdot; /* perturbed dot product */ |
63 |
} ANISODAT; /* anisotropic material data */ |
64 |
65 |
66 |
diraniso(cval, np, ldir, omega) /* compute source contribution */ |
67 |
COLOR cval; /* returned coefficient */ |
68 |
register ANISODAT *np; /* material data */ |
69 |
FVECT ldir; /* light source direction */ |
70 |
double omega; /* light source size */ |
71 |
72 |
double ldot; |
73 |
double dtmp, dtmp1, dtmp2; |
74 |
FVECT h; |
75 |
double au2, av2; |
76 |
COLOR ctmp; |
77 |
78 |
setcolor(cval, 0.0, 0.0, 0.0); |
79 |
80 |
ldot = DOT(np->pnorm, ldir); |
81 |
82 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) |
83 |
return; /* wrong side */ |
84 |
85 |
if (ldot > FTINY && np->rdiff > FTINY) { |
86 |
87 |
* Compute and add diffuse reflected component to returned |
88 |
* color. The diffuse reflected component will always be |
89 |
* modified by the color of the material. |
90 |
91 |
copycolor(ctmp, np->mcolor); |
92 |
dtmp = ldot * omega * np->rdiff / PI; |
93 |
scalecolor(ctmp, dtmp); |
94 |
addcolor(cval, ctmp); |
95 |
96 |
if (ldot > FTINY && (np->specfl&(SP_REFL|SP_BADU)) == SP_REFL) { |
97 |
98 |
* Compute specular reflection coefficient using |
99 |
* anisotropic gaussian distribution model. |
100 |
101 |
/* add source width if flat */ |
102 |
if (np->specfl & SP_FLAT) |
103 |
au2 = av2 = omega/(4.0*PI); |
104 |
else |
105 |
au2 = av2 = 0.0; |
106 |
au2 += np->u_alpha*np->u_alpha; |
107 |
av2 += np->v_alpha*np->v_alpha; |
108 |
/* half vector */ |
109 |
h[0] = ldir[0] - np->rp->rdir[0]; |
110 |
h[1] = ldir[1] - np->rp->rdir[1]; |
111 |
h[2] = ldir[2] - np->rp->rdir[2]; |
112 |
normalize(h); |
113 |
/* ellipse */ |
114 |
dtmp1 = DOT(np->u, h); |
115 |
dtmp1 *= dtmp1 / au2; |
116 |
dtmp2 = DOT(np->v, h); |
117 |
dtmp2 *= dtmp2 / av2; |
118 |
/* gaussian */ |
119 |
dtmp = (dtmp1 + dtmp2) / (1.0 + DOT(np->pnorm, h)); |
120 |
dtmp = exp(-2.0*dtmp) * 1.0/(4.0*PI) |
121 |
* sqrt(ldot/(np->pdot*au2*av2)); |
122 |
/* worth using? */ |
123 |
if (dtmp > FTINY) { |
124 |
copycolor(ctmp, np->scolor); |
125 |
dtmp *= omega; |
126 |
127 |
128 |
129 |
130 |
if (ldot < -FTINY && np->tdiff > FTINY) { |
131 |
132 |
* Compute diffuse transmission. |
133 |
134 |
135 |
dtmp = -ldot * omega * np->tdiff / PI; |
136 |
137 |
138 |
139 |
if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_BADU)) == SP_TRAN) { |
140 |
141 |
* Compute specular transmission. Specular transmission |
142 |
* is always modified by material color. |
143 |
144 |
/* roughness + source */ |
145 |
au2 = av2 = omega / PI; |
146 |
147 |
148 |
/* "half vector" */ |
149 |
h[0] = ldir[0] - np->prdir[0]; |
150 |
h[1] = ldir[1] - np->prdir[1]; |
151 |
h[2] = ldir[2] - np->prdir[2]; |
152 |
dtmp = DOT(h,h); |
153 |
if (dtmp > FTINY*FTINY) { |
154 |
dtmp1 = DOT(h,np->pnorm); |
155 |
dtmp = 1.0 - dtmp1*dtmp1/dtmp; |
156 |
157 |
dtmp1 = DOT(h,np->u); |
158 |
dtmp1 = dtmp1*dtmp1 / au2; |
159 |
dtmp2 = DOT(h,np->v); |
160 |
dtmp2 = dtmp2*dtmp2 / av2; |
161 |
dtmp = (dtmp1 + dtmp2) / dtmp; |
162 |
163 |
} else |
164 |
dtmp = 0.0; |
165 |
/* gaussian */ |
166 |
dtmp = exp(-dtmp) * 1.0/(4.0*PI) |
167 |
* sqrt(-ldot/(np->pdot*au2*av2)); |
168 |
169 |
170 |
171 |
dtmp *= np->tspec * omega; |
172 |
173 |
174 |
175 |
176 |
177 |
178 |
179 |
m_aniso(m, r) /* shade ray that hit something anisotropic */ |
180 |
register OBJREC *m; |
181 |
register RAY *r; |
182 |
183 |
ANISODAT nd; |
184 |
double dtmp; |
185 |
COLOR ctmp; |
186 |
register int i; |
187 |
/* easy shadow test */ |
188 |
if (r->crtype & SHADOW) |
189 |
return; |
190 |
191 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6)) |
192 |
objerror(m, USER, "bad number of real arguments"); |
193 |
nd.mp = m; |
194 |
nd.rp = r; |
195 |
/* get material color */ |
196 |
setcolor(nd.mcolor, m->oargs.farg[0], |
197 |
m->oargs.farg[1], |
198 |
m->oargs.farg[2]); |
199 |
/* get roughness */ |
200 |
nd.specfl = 0; |
201 |
nd.u_alpha = m->oargs.farg[4]; |
202 |
nd.v_alpha = m->oargs.farg[5]; |
203 |
if (nd.u_alpha < FTINY || nd.v_alpha <= FTINY) |
204 |
objerror(m, USER, "roughness too small"); |
205 |
/* reorient if necessary */ |
206 |
if (r->rod < 0.0) |
207 |
flipsurface(r); |
208 |
/* get modifiers */ |
209 |
raytexture(r, m->omod); |
210 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
211 |
if (nd.pdot < .001) |
212 |
nd.pdot = .001; /* non-zero for diraniso() */ |
213 |
multcolor(nd.mcolor, r->pcol); /* modify material color */ |
214 |
/* get specular component */ |
215 |
if ((nd.rspec = m->oargs.farg[3]) > FTINY) { |
216 |
nd.specfl |= SP_REFL; |
217 |
/* compute specular color */ |
218 |
if (m->otype == MAT_METAL2) |
219 |
copycolor(nd.scolor, nd.mcolor); |
220 |
else |
221 |
setcolor(nd.scolor, 1.0, 1.0, 1.0); |
222 |
scalecolor(nd.scolor, nd.rspec); |
223 |
/* improved model */ |
224 |
dtmp = exp(-BSPEC(m)*nd.pdot); |
225 |
for (i = 0; i < 3; i++) |
226 |
colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; |
227 |
nd.rspec += (1.0-nd.rspec)*dtmp; |
228 |
/* check threshold */ |
229 |
if (specthresh > FTINY && |
230 |
(specthresh >= 1.-FTINY || |
231 |
specthresh + .05 - .1*frandom() > nd.rspec)) |
232 |
nd.specfl |= SP_RBLT; |
233 |
/* compute refl. direction */ |
234 |
235 |
nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; |
236 |
if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */ |
237 |
for (i = 0; i < 3; i++) /* safety measure */ |
238 |
nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; |
239 |
240 |
/* compute transmission */ |
241 |
if (m->otype == MAT_TRANS2) { |
242 |
nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec); |
243 |
nd.tspec = nd.trans * m->oargs.farg[7]; |
244 |
nd.tdiff = nd.trans - nd.tspec; |
245 |
if (nd.tspec > FTINY) { |
246 |
nd.specfl |= SP_TRAN; |
247 |
248 |
249 |
250 |
specthresh + .05 - .1*frandom() > nd.tspec)) |
251 |
nd.specfl |= SP_TBLT; |
252 |
if (DOT(r->pert,r->pert) <= FTINY*FTINY) { |
253 |
VCOPY(nd.prdir, r->rdir); |
254 |
} else { |
255 |
for (i = 0; i < 3; i++) /* perturb */ |
256 |
nd.prdir[i] = r->rdir[i] - r->pert[i]; |
257 |
if (DOT(nd.prdir, r->ron) < -FTINY) |
258 |
normalize(nd.prdir); /* OK */ |
259 |
else |
260 |
261 |
262 |
263 |
} else |
264 |
nd.tdiff = nd.tspec = nd.trans = 0.0; |
265 |
266 |
/* diffuse reflection */ |
267 |
nd.rdiff = 1.0 - nd.trans - nd.rspec; |
268 |
269 |
if (r->ro != NULL && (r->ro->otype == OBJ_FACE || |
270 |
r->ro->otype == OBJ_RING)) |
271 |
nd.specfl |= SP_FLAT; |
272 |
273 |
getacoords(r, &nd); /* set up coordinates */ |
274 |
275 |
if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_BADU)) |
276 |
agaussamp(r, &nd); |
277 |
278 |
if (nd.rdiff > FTINY) { /* ambient from this side */ |
279 |
ambient(ctmp, r); |
280 |
if (nd.specfl & SP_RBLT) |
281 |
scalecolor(ctmp, 1.0-nd.trans); |
282 |
else |
283 |
scalecolor(ctmp, nd.rdiff); |
284 |
multcolor(ctmp, nd.mcolor); /* modified by material color */ |
285 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
286 |
287 |
if (nd.tdiff > FTINY) { /* ambient from other side */ |
288 |
flipsurface(r); |
289 |
ambient(ctmp, r); |
290 |
if (nd.specfl & SP_TBLT) |
291 |
scalecolor(ctmp, nd.trans); |
292 |
else |
293 |
scalecolor(ctmp, nd.tdiff); |
294 |
multcolor(ctmp, nd.mcolor); /* modified by color */ |
295 |
addcolor(r->rcol, ctmp); |
296 |
flipsurface(r); |
297 |
298 |
/* add direct component */ |
299 |
direct(r, diraniso, &nd); |
300 |
301 |
302 |
303 |
static |
304 |
getacoords(r, np) /* set up coordinate system */ |
305 |
RAY *r; |
306 |
register ANISODAT *np; |
307 |
308 |
register MFUNC *mf; |
309 |
register int i; |
310 |
311 |
mf = getfunc(np->mp, 3, 0x7, 1); |
312 |
setfunc(np->mp, r); |
313 |
errno = 0; |
314 |
315 |
np->u[i] = evalue(mf->ep[i]); |
316 |
if (errno) { |
317 |
objerror(np->mp, WARNING, "compute error"); |
318 |
np->specfl |= SP_BADU; |
319 |
return; |
320 |
321 |
if (mf->f != &unitxf) |
322 |
multv3(np->u, np->u, mf->f->xfm); |
323 |
fcross(np->v, np->pnorm, np->u); |
324 |
if (normalize(np->v) == 0.0) { |
325 |
objerror(np->mp, WARNING, "illegal orientation vector"); |
326 |
327 |
return; |
328 |
329 |
fcross(np->u, np->v, np->pnorm); |
330 |
331 |
332 |
333 |
static |
334 |
agaussamp(r, np) /* sample anisotropic gaussian specular */ |
335 |
RAY *r; |
336 |
337 |
338 |
RAY sr; |
339 |
FVECT h; |
340 |
double rv[2]; |
341 |
double d, sinp, cosp; |
342 |
register int i; |
343 |
/* compute reflection */ |
344 |
if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && |
345 |
rayorigin(&sr, r, SPECULAR, np->rspec) == 0) { |
346 |
dimlist[ndims++] = (int)np->mp; |
347 |
d = urand(ilhash(dimlist,ndims)+samplendx); |
348 |
multisamp(rv, 2, d); |
349 |
d = 2.0*PI * rv[0]; |
350 |
cosp = cos(d) * np->u_alpha; |
351 |
sinp = sin(d) * np->v_alpha; |
352 |
d = sqrt(cosp*cosp + sinp*sinp); |
353 |
cosp /= d; |
354 |
sinp /= d; |
355 |
rv[1] = 1.0 - specjitter*rv[1]; |
356 |
if (rv[1] <= FTINY) |
357 |
d = 1.0; |
358 |
else |
359 |
d = sqrt(-log(rv[1]) / |
360 |
(cosp*cosp/(np->u_alpha*np->u_alpha) + |
361 |
sinp*sinp/(np->v_alpha*np->v_alpha))); |
362 |
363 |
h[i] = np->pnorm[i] + |
364 |
d*(cosp*np->u[i] + sinp*np->v[i]); |
365 |
d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d); |
366 |
367 |
sr.rdir[i] = r->rdir[i] + d*h[i]; |
368 |
if (DOT(sr.rdir, r->ron) <= FTINY) /* penetration? */ |
369 |
VCOPY(sr.rdir, np->vrefl); /* jitter no good */ |
370 |
rayvalue(&sr); |
371 |
multcolor(sr.rcol, np->scolor); |
372 |
addcolor(r->rcol, sr.rcol); |
373 |
ndims--; |
374 |
375 |
376 |
if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && |
377 |
rayorigin(&sr, r, SPECULAR, np->tspec) == 0) { |
378 |
379 |
d = urand(ilhash(dimlist,ndims)+1823+samplendx); |
380 |
381 |
382 |
383 |
384 |
385 |
cosp /= d; |
386 |
sinp /= d; |
387 |
388 |
389 |
d = 1.0; |
390 |
else |
391 |
392 |
393 |
sinp*sinp/(np->v_alpha*np->u_alpha))); |
394 |
395 |
sr.rdir[i] = np->prdir[i] + |
396 |
397 |
if (DOT(sr.rdir, r->ron) < -FTINY) |
398 |
normalize(sr.rdir); /* OK, normalize */ |
399 |
else |
400 |
VCOPY(sr.rdir, np->prdir); /* else no jitter */ |
401 |
rayvalue(&sr); |
402 |
scalecolor(sr.rcol, np->tspec); |
403 |
multcolor(sr.rcol, np->mcolor); /* modify by color */ |
404 |
405 |
ndims--; |
406 |
407 |
