root/radiance/ray/src/rt/aniso.c
Revision: 2.71
Committed: Fri Jun 20 16:48:39 2025 UTC (62 minutes, 50 seconds ago) by greg
Changes since 2.70: +3 -3 lines
fix: Last change would have caused array underrun
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.71 static const char RCSid[] = "$Id: aniso.c,v 2.70 2025/06/20 16:34:23 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * Shading functions for anisotropic materials.
6     */
7
8 greg 2.35 #include "copyright.h"
9 greg 2.34
10 greg 2.1 #include "ray.h"
11 greg 2.40 #include "ambient.h"
12 greg 2.1 #include "otypes.h"
13 schorsch 2.41 #include "rtotypes.h"
14     #include "source.h"
15 greg 2.1 #include "func.h"
16     #include "random.h"
17 greg 2.61 #include "pmapmat.h"
18 greg 2.1
19 greg 2.32 #ifndef MAXITER
20     #define MAXITER 10 /* maximum # specular ray attempts */
21     #endif
22
23 greg 2.1 /*
24 greg 2.22 * This routine implements the anisotropic Gaussian
25 greg 2.54 * model described by Ward in Siggraph `92 article, updated with
26     * normalization and sampling adjustments due to Geisler-Moroder and Duer.
27 greg 2.1 * We orient the surface towards the incoming ray, so a single
28     * surface can be used to represent an infinitely thin object.
29     *
30     * Arguments for MAT_PLASTIC2 and MAT_METAL2 are:
31     * 4+ ux uy uz funcfile [transform...]
32     * 0
33 greg 2.54 * 6 red grn blu specular-frac. u-rough v-rough
34 greg 2.1 *
35     * Real arguments for MAT_TRANS2 are:
36     * 8 red grn blu rspec u-rough v-rough trans tspec
37     */
38
39     /* specularity flags */
40     #define SP_REFL 01 /* has reflected specular component */
41     #define SP_TRAN 02 /* has transmitted specular */
42 greg 2.10 #define SP_FLAT 04 /* reflecting surface is flat */
43     #define SP_RBLT 010 /* reflection below sample threshold */
44     #define SP_TBLT 020 /* transmission below threshold */
45 greg 2.1
46     typedef struct {
47 greg 2.2 OBJREC *mp; /* material pointer */
48 greg 2.1 RAY *rp; /* ray pointer */
49     short specfl; /* specularity flags, defined above */
50 greg 2.62 SCOLOR mcolor; /* color of this material */
51     SCOLOR scolor; /* color of specular component */
52 greg 2.1 FVECT prdir; /* vector in transmitted direction */
53     FVECT u, v; /* u and v vectors orienting anisotropy */
54 greg 2.18 double u_alpha; /* u roughness */
55     double v_alpha; /* v roughness */
56 greg 2.1 double rdiff, rspec; /* reflected specular, diffuse */
57     double trans; /* transmissivity */
58     double tdiff, tspec; /* transmitted specular, diffuse */
59     FVECT pnorm; /* perturbed surface normal */
60     double pdot; /* perturbed dot product */
61     } ANISODAT; /* anisotropic material data */
62
63 greg 2.55 static void getacoords(ANISODAT *np);
64     static void agaussamp(ANISODAT *np);
65 greg 2.34
66 greg 2.1
67 greg 2.34 static void
68 schorsch 2.41 diraniso( /* compute source contribution */
69 greg 2.62 SCOLOR scval, /* returned coefficient */
70 greg 2.54 void *nnp, /* material data */
71 schorsch 2.41 FVECT ldir, /* light source direction */
72     double omega /* light source size */
73     )
74 greg 2.1 {
75 greg 2.54 ANISODAT *np = nnp;
76 greg 2.1 double ldot;
77 greg 2.16 double dtmp, dtmp1, dtmp2;
78 greg 2.1 FVECT h;
79     double au2, av2;
80 greg 2.62 SCOLOR sctmp;
81 greg 2.1
82 greg 2.62 scolorblack(scval);
83 greg 2.1
84     ldot = DOT(np->pnorm, ldir);
85
86     if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
87     return; /* wrong side */
88
89 greg 2.54 if ((ldot > FTINY) & (np->rdiff > FTINY)) {
90 greg 2.1 /*
91     * Compute and add diffuse reflected component to returned
92     * color. The diffuse reflected component will always be
93     * modified by the color of the material.
94     */
95 greg 2.62 copyscolor(sctmp, np->mcolor);
96 greg 2.42 dtmp = ldot * omega * np->rdiff * (1.0/PI);
97 greg 2.62 scalescolor(sctmp, dtmp);
98     saddscolor(scval, sctmp);
99 greg 2.1 }
100 greg 2.58
101     if ((ldot < -FTINY) & (np->tdiff > FTINY)) {
102     /*
103     * Compute diffuse transmission.
104     */
105 greg 2.62 copyscolor(sctmp, np->mcolor);
106 greg 2.58 dtmp = -ldot * omega * np->tdiff * (1.0/PI);
107 greg 2.62 scalescolor(sctmp, dtmp);
108     saddscolor(scval, sctmp);
109 greg 2.58 }
110
111 greg 2.61 if (ambRayInPmap(np->rp))
112     return; /* specular accounted for in photon map */
113
114 greg 2.57 if (ldot > FTINY && np->specfl&SP_REFL) {
115 greg 2.1 /*
116     * Compute specular reflection coefficient using
117 greg 2.46 * anisotropic Gaussian distribution model.
118 greg 2.1 */
119 greg 2.2 /* add source width if flat */
120     if (np->specfl & SP_FLAT)
121 greg 2.68 au2 = av2 = (1. - dstrsrc) * omega * (0.25/PI);
122 greg 2.2 else
123     au2 = av2 = 0.0;
124 greg 2.18 au2 += np->u_alpha*np->u_alpha;
125     av2 += np->v_alpha*np->v_alpha;
126 greg 2.1 /* half vector */
127 greg 2.54 VSUB(h, ldir, np->rp->rdir);
128 greg 2.1 /* ellipse */
129 greg 2.16 dtmp1 = DOT(np->u, h);
130     dtmp1 *= dtmp1 / au2;
131 greg 2.1 dtmp2 = DOT(np->v, h);
132     dtmp2 *= dtmp2 / av2;
133 greg 2.46 /* new W-G-M-D model */
134 greg 2.23 dtmp = DOT(np->pnorm, h);
135 greg 2.46 dtmp *= dtmp;
136     dtmp1 = (dtmp1 + dtmp2) / dtmp;
137     dtmp = exp(-dtmp1) * DOT(h,h) /
138     (PI * dtmp*dtmp * sqrt(au2*av2));
139 greg 2.1 /* worth using? */
140     if (dtmp > FTINY) {
141 greg 2.62 copyscolor(sctmp, np->scolor);
142 greg 2.46 dtmp *= ldot * omega;
143 greg 2.62 scalescolor(sctmp, dtmp);
144     saddscolor(scval, sctmp);
145 greg 2.1 }
146     }
147 greg 2.58
148 greg 2.57 if (ldot < -FTINY && np->specfl&SP_TRAN) {
149 greg 2.1 /*
150     * Compute specular transmission. Specular transmission
151     * is always modified by material color.
152     */
153     /* roughness + source */
154 greg 2.42 au2 = av2 = omega * (1.0/PI);
155 greg 2.18 au2 += np->u_alpha*np->u_alpha;
156     av2 += np->v_alpha*np->v_alpha;
157 greg 2.16 /* "half vector" */
158 greg 2.54 VSUB(h, ldir, np->prdir);
159 greg 2.19 dtmp = DOT(h,h);
160 greg 2.16 if (dtmp > FTINY*FTINY) {
161 greg 2.19 dtmp1 = DOT(h,np->pnorm);
162     dtmp = 1.0 - dtmp1*dtmp1/dtmp;
163 greg 2.66 }
164     if (dtmp > FTINY*FTINY) {
165     dtmp1 = DOT(h,np->u);
166     dtmp1 *= dtmp1 / au2;
167     dtmp2 = DOT(h,np->v);
168     dtmp2 *= dtmp2 / av2;
169     dtmp = (dtmp1 + dtmp2) / dtmp;
170     dtmp = exp(-dtmp);
171 greg 2.16 } else
172 greg 2.66 dtmp = 1.0;
173 greg 2.46 /* Gaussian */
174 greg 2.66 dtmp *= (1.0/PI) * sqrt(-ldot/(np->pdot*au2*av2));
175 greg 2.1 /* worth using? */
176     if (dtmp > FTINY) {
177 greg 2.62 copyscolor(sctmp, np->mcolor);
178 greg 2.16 dtmp *= np->tspec * omega;
179 greg 2.62 scalescolor(sctmp, dtmp);
180     saddscolor(scval, sctmp);
181 greg 2.1 }
182     }
183     }
184
185
186 greg 2.54 int
187 schorsch 2.41 m_aniso( /* shade ray that hit something anisotropic */
188 greg 2.54 OBJREC *m,
189     RAY *r
190 schorsch 2.41 )
191 greg 2.1 {
192     ANISODAT nd;
193 greg 2.62 SCOLOR sctmp;
194 greg 2.54 int i;
195 greg 2.1 /* easy shadow test */
196 greg 2.10 if (r->crtype & SHADOW)
197 greg 2.27 return(1);
198 greg 2.1
199     if (m->oargs.nfargs != (m->otype == MAT_TRANS2 ? 8 : 6))
200     objerror(m, USER, "bad number of real arguments");
201 greg 2.36 /* check for back side */
202     if (r->rod < 0.0) {
203 greg 2.56 if (!backvis) {
204 greg 2.36 raytrans(r);
205     return(1);
206     }
207     raytexture(r, m->omod);
208     flipsurface(r); /* reorient if backvis */
209     } else
210     raytexture(r, m->omod);
211     /* get material color */
212 greg 2.2 nd.mp = m;
213 greg 2.1 nd.rp = r;
214 greg 2.62 setscolor(nd.mcolor, m->oargs.farg[0],
215 greg 2.1 m->oargs.farg[1],
216     m->oargs.farg[2]);
217     /* get roughness */
218     nd.specfl = 0;
219 greg 2.18 nd.u_alpha = m->oargs.farg[4];
220     nd.v_alpha = m->oargs.farg[5];
221 greg 2.54 if ((nd.u_alpha <= FTINY) | (nd.v_alpha <= FTINY))
222 greg 2.10 objerror(m, USER, "roughness too small");
223 greg 2.36
224 greg 2.1 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
225     if (nd.pdot < .001)
226     nd.pdot = .001; /* non-zero for diraniso() */
227 greg 2.62 smultscolor(nd.mcolor, r->pcol); /* modify material color */
228 greg 2.1 /* get specular component */
229     if ((nd.rspec = m->oargs.farg[3]) > FTINY) {
230     nd.specfl |= SP_REFL;
231     /* compute specular color */
232     if (m->otype == MAT_METAL2)
233 greg 2.62 copyscolor(nd.scolor, nd.mcolor);
234 greg 2.1 else
235 greg 2.62 setscolor(nd.scolor, 1.0, 1.0, 1.0);
236     scalescolor(nd.scolor, nd.rspec);
237 greg 2.4 /* check threshold */
238 greg 2.25 if (specthresh >= nd.rspec-FTINY)
239 greg 2.4 nd.specfl |= SP_RBLT;
240 greg 2.1 }
241     /* compute transmission */
242 greg 2.16 if (m->otype == MAT_TRANS2) {
243 greg 2.1 nd.trans = m->oargs.farg[6]*(1.0 - nd.rspec);
244     nd.tspec = nd.trans * m->oargs.farg[7];
245     nd.tdiff = nd.trans - nd.tspec;
246     if (nd.tspec > FTINY) {
247     nd.specfl |= SP_TRAN;
248 greg 2.4 /* check threshold */
249 greg 2.25 if (specthresh >= nd.tspec-FTINY)
250 greg 2.4 nd.specfl |= SP_TBLT;
251 greg 2.10 if (DOT(r->pert,r->pert) <= FTINY*FTINY) {
252 greg 2.1 VCOPY(nd.prdir, r->rdir);
253     } else {
254     for (i = 0; i < 3; i++) /* perturb */
255 greg 2.17 nd.prdir[i] = r->rdir[i] - r->pert[i];
256 greg 2.6 if (DOT(nd.prdir, r->ron) < -FTINY)
257     normalize(nd.prdir); /* OK */
258     else
259     VCOPY(nd.prdir, r->rdir);
260 greg 2.1 }
261     }
262     } else
263     nd.tdiff = nd.tspec = nd.trans = 0.0;
264
265     /* diffuse reflection */
266     nd.rdiff = 1.0 - nd.trans - nd.rspec;
267
268 greg 2.67 if (r->ro != NULL && isflat(r->ro->otype) &&
269     DOT(r->pert,r->pert) <= FTINY*FTINY)
270 greg 2.4 nd.specfl |= SP_FLAT;
271
272 greg 2.55 getacoords(&nd); /* set up coordinates */
273 greg 2.1
274 greg 2.60 if (nd.specfl & (SP_REFL|SP_TRAN))
275 greg 2.55 agaussamp(&nd);
276 greg 2.1
277     if (nd.rdiff > FTINY) { /* ambient from this side */
278 greg 2.62 copyscolor(sctmp, nd.mcolor); /* modified by material color */
279     scalescolor(sctmp, nd.rdiff);
280 greg 2.52 if (nd.specfl & SP_RBLT) /* add in specular as well? */
281 greg 2.62 saddscolor(sctmp, nd.scolor);
282     multambient(sctmp, r, nd.pnorm);
283     saddscolor(r->rcol, sctmp); /* add to returned color */
284 greg 2.1 }
285 greg 2.58
286 greg 2.1 if (nd.tdiff > FTINY) { /* ambient from other side */
287 greg 2.31 FVECT bnorm;
288     bnorm[0] = -nd.pnorm[0];
289     bnorm[1] = -nd.pnorm[1];
290     bnorm[2] = -nd.pnorm[2];
291 greg 2.62 copyscolor(sctmp, nd.mcolor); /* modified by color */
292     if (nd.specfl & SP_TBLT) {
293     scalescolor(sctmp, nd.trans);
294     } else {
295     scalescolor(sctmp, nd.tdiff);
296     }
297     multambient(sctmp, r, bnorm);
298     saddscolor(r->rcol, sctmp);
299 greg 2.1 }
300     /* add direct component */
301     direct(r, diraniso, &nd);
302 greg 2.27
303     return(1);
304 greg 2.1 }
305
306 greg 2.34 static void
307 schorsch 2.41 getacoords( /* set up coordinate system */
308 greg 2.54 ANISODAT *np
309 schorsch 2.41 )
310 greg 2.1 {
311 greg 2.54 MFUNC *mf;
312     int i;
313 greg 2.1
314     mf = getfunc(np->mp, 3, 0x7, 1);
315 greg 2.55 setfunc(np->mp, np->rp);
316 greg 2.1 errno = 0;
317     for (i = 0; i < 3; i++)
318     np->u[i] = evalue(mf->ep[i]);
319 greg 2.57 if ((errno == EDOM) | (errno == ERANGE))
320     np->u[0] = np->u[1] = np->u[2] = 0.0;
321 greg 2.65 else if (mf->fxp != &unitxf)
322 greg 2.53 multv3(np->u, np->u, mf->fxp->xfm);
323 greg 2.1 fcross(np->v, np->pnorm, np->u);
324     if (normalize(np->v) == 0.0) {
325 greg 2.57 if (fabs(np->u_alpha - np->v_alpha) > 0.001)
326     objerror(np->mp, WARNING, "illegal orientation vector");
327 greg 2.69 getperpendicular(np->u, np->pnorm, 0); /* punting */
328 greg 2.57 fcross(np->v, np->pnorm, np->u);
329     np->u_alpha = np->v_alpha = sqrt( 0.5 *
330     (np->u_alpha*np->u_alpha + np->v_alpha*np->v_alpha) );
331     } else
332     fcross(np->u, np->v, np->pnorm);
333 greg 2.1 }
334
335
336 greg 2.34 static void
337 greg 2.46 agaussamp( /* sample anisotropic Gaussian specular */
338 greg 2.54 ANISODAT *np
339 schorsch 2.41 )
340 greg 2.1 {
341     RAY sr;
342     FVECT h;
343     double rv[2];
344     double d, sinp, cosp;
345 greg 2.50 int maxiter, ntrials, nstarget, nstaken;
346 greg 2.54 int i;
347 greg 2.1 /* compute reflection */
348 greg 2.4 if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
349 greg 2.64 rayorigin(&sr, RSPECULAR, np->rp, np->scolor) == 0) {
350 greg 2.65 SCOLOR scol;
351 greg 2.50 nstarget = 1;
352 greg 2.47 if (specjitter > 1.5) { /* multiple samples? */
353 greg 2.55 nstarget = specjitter*np->rp->rweight + .5;
354 greg 2.50 if (sr.rweight <= minweight*nstarget)
355     nstarget = sr.rweight/minweight;
356     if (nstarget > 1) {
357     d = 1./nstarget;
358 greg 2.63 scalescolor(sr.rcoef, d);
359 greg 2.48 sr.rweight *= d;
360 greg 2.47 } else
361 greg 2.50 nstarget = 1;
362 greg 2.47 }
363 greg 2.62 scolorblack(scol);
364 greg 2.70 dimlist[ndims_inc] = (int)(size_t)np->mp;
365 greg 2.50 maxiter = MAXITER*nstarget;
366 greg 2.65 for (nstaken = ntrials = 0; (nstaken < nstarget) &
367     (ntrials < maxiter); ntrials++) {
368 greg 2.50 if (ntrials)
369 greg 2.32 d = frandom();
370     else
371     d = urand(ilhash(dimlist,ndims)+samplendx);
372     multisamp(rv, 2, d);
373     d = 2.0*PI * rv[0];
374 gwlarson 2.33 cosp = tcos(d) * np->u_alpha;
375     sinp = tsin(d) * np->v_alpha;
376 greg 2.47 d = 1./sqrt(cosp*cosp + sinp*sinp);
377     cosp *= d;
378     sinp *= d;
379     if ((0. <= specjitter) & (specjitter < 1.))
380     rv[1] = 1.0 - specjitter*rv[1];
381 greg 2.65 d = (rv[1] <= FTINY) ? 1.0 : sqrt( -log(rv[1]) /
382 greg 2.32 (cosp*cosp/(np->u_alpha*np->u_alpha) +
383 greg 2.65 sinp*sinp/(np->v_alpha*np->v_alpha)) );
384 greg 2.32 for (i = 0; i < 3; i++)
385     h[i] = np->pnorm[i] +
386     d*(cosp*np->u[i] + sinp*np->v[i]);
387 greg 2.55 d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d);
388     VSUM(sr.rdir, np->rp->rdir, h, d);
389 greg 2.50 /* sample rejection test */
390 greg 2.55 if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY)
391 greg 2.47 continue;
392     checknorm(sr.rdir);
393 greg 2.50 if (nstarget > 1) { /* W-G-M-D adjustment */
394     if (nstaken) rayclear(&sr);
395     rayvalue(&sr);
396 greg 2.55 d = 2./(1. + np->rp->rod/d);
397 greg 2.62 scalescolor(sr.rcol, d);
398     saddscolor(scol, sr.rcol);
399 greg 2.50 } else {
400     rayvalue(&sr);
401 greg 2.62 smultscolor(sr.rcol, sr.rcoef);
402     saddscolor(np->rp->rcol, sr.rcol);
403 greg 2.32 }
404 greg 2.50 ++nstaken;
405     }
406     if (nstarget > 1) { /* final W-G-M-D weighting */
407 greg 2.62 smultscolor(scol, sr.rcoef);
408 greg 2.50 d = (double)nstarget/ntrials;
409 greg 2.62 scalescolor(scol, d);
410     saddscolor(np->rp->rcol, scol);
411 greg 2.32 }
412 greg 2.71 dec_ndims;
413 greg 2.1 }
414     /* compute transmission */
415 greg 2.62 copyscolor(sr.rcoef, np->mcolor); /* modify by material color */
416     scalescolor(sr.rcoef, np->tspec);
417 greg 2.7 if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
418 greg 2.64 rayorigin(&sr, TSPECULAR, np->rp, sr.rcoef) == 0) {
419 greg 2.50 nstarget = 1;
420 greg 2.47 if (specjitter > 1.5) { /* multiple samples? */
421 greg 2.55 nstarget = specjitter*np->rp->rweight + .5;
422 greg 2.50 if (sr.rweight <= minweight*nstarget)
423     nstarget = sr.rweight/minweight;
424     if (nstarget > 1) {
425     d = 1./nstarget;
426 greg 2.63 scalescolor(sr.rcoef, d);
427 greg 2.48 sr.rweight *= d;
428 greg 2.47 } else
429 greg 2.50 nstarget = 1;
430 greg 2.47 }
431 greg 2.70 dimlist[ndims_inc] = (int)(size_t)np->mp;
432 greg 2.50 maxiter = MAXITER*nstarget;
433 greg 2.65 for (nstaken = ntrials = 0; (nstaken < nstarget) &
434     (ntrials < maxiter); ntrials++) {
435 greg 2.50 if (ntrials)
436 greg 2.32 d = frandom();
437     else
438     d = urand(ilhash(dimlist,ndims)+1823+samplendx);
439     multisamp(rv, 2, d);
440     d = 2.0*PI * rv[0];
441 gwlarson 2.33 cosp = tcos(d) * np->u_alpha;
442     sinp = tsin(d) * np->v_alpha;
443 greg 2.47 d = 1./sqrt(cosp*cosp + sinp*sinp);
444     cosp *= d;
445     sinp *= d;
446     if ((0. <= specjitter) & (specjitter < 1.))
447     rv[1] = 1.0 - specjitter*rv[1];
448 greg 2.32 if (rv[1] <= FTINY)
449     d = 1.0;
450     else
451     d = sqrt(-log(rv[1]) /
452     (cosp*cosp/(np->u_alpha*np->u_alpha) +
453 gwlarson 2.33 sinp*sinp/(np->v_alpha*np->v_alpha)));
454 greg 2.32 for (i = 0; i < 3; i++)
455     sr.rdir[i] = np->prdir[i] +
456     d*(cosp*np->u[i] + sinp*np->v[i]);
457 greg 2.65 if (DOT(sr.rdir,np->rp->ron) >= -FTINY)
458     continue; /* reject sample */
459 greg 2.47 normalize(sr.rdir); /* OK, normalize */
460 greg 2.50 if (nstaken) /* multi-sampling */
461 greg 2.47 rayclear(&sr);
462     rayvalue(&sr);
463 greg 2.62 smultscolor(sr.rcol, sr.rcoef);
464     saddscolor(np->rp->rcol, sr.rcol);
465 greg 2.50 ++nstaken;
466 greg 2.32 }
467 greg 2.71 dec_ndims;
468 greg 2.7 }
469 greg 2.1 }
