root/radiance/ray/src/rt/ambio.c
Thu Jun 19 16:26:55 2014 UTC (9 years, 10 months ago) by greg
Wed May 7 01:16:03 2014 UTC (9 years, 11 months ago) by greg
Thu Apr 24 06:03:15 2014 UTC (10 years ago) by greg
Changes since 2.6: +9 -9 lines
Fixed floating-point errors due to use of float where double needed
Fri Apr 11 20:31:37 2014 UTC (10 years ago) by greg
Changes since 2.5: +101 -14 lines
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1
Changes since 2.3: +64 -11 lines
Tue May 28 13:42:46 1996 UTC (27 years, 11 months ago) by greg
Changes since 2.2: +32 -1 lines
Thu Jul 16 12:08:47 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.1: +19 -0 lines
Diff to previous 2.1
Mon Jul 13 16:15:21 1992 UTC (31 years, 9 months ago) by greg
