root/radiance/ray/src/rt/ambio.c
Wed Jan 17 17:35:35 2024 UTC (15 months, 3 weeks ago) by greg
Diff to previous 2.16 , to selected 2.8
perf(rvu, rpict, rtrace, rcontrib): Better rendering of spectral primitives in RGB mode
Mon Dec 11 23:57:32 2023 UTC (16 months, 4 weeks ago) by greg
fix(rpict,rtrace,rvu): Fixed issue with ambvalOK()
Wed Nov 15 18:02:52 2023 UTC (17 months, 3 weeks ago) by greg
Changes since 2.14: +66 -16 lines
Thu Nov 12 21:25:20 2020 UTC (4 years, 5 months ago) by greg
Changes since 2.13: +4 -3 lines
fix: minor improvement to ambient value checks
Tue May 14 17:39:10 2019 UTC (5 years, 11 months ago) by greg
Changes since 2.12: +1 -82 lines
Stripped out code related to old (pre-Hessian) ambient calculation
Fri Jan 27 22:00:49 2017 UTC (8 years, 3 months ago) by greg
CVS Tags: rad5R1, rad5R2
Created independent ambient file pointer to resolve some race issues
Thu Mar 3 22:13:51 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.10: +5 -5 lines
Replaced fread() & fwrite() calls with more efficient replacements
Wed Mar 2 22:03:49 2016 UTC (9 years, 2 months ago) by greg
Changes since 2.9: +17 -18 lines
Minor changes should not affect behavior
Thu Jun 19 16:26:55 2014 UTC (10 years, 10 months ago) by greg
Wed May 7 01:16:03 2014 UTC (11 years ago) by greg
Thu Apr 24 06:03:15 2014 UTC (11 years ago) by greg
Changes since 2.6: +9 -9 lines
Fixed floating-point errors due to use of float where double needed
Fri Apr 11 20:31:37 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.5: +101 -14 lines
Tue Feb 25 02:47:22 2003 UTC (22 years, 2 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1
Sat Feb 22 02:07:28 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.3: +64 -11 lines
Tue May 28 13:42:46 1996 UTC (28 years, 11 months ago) by greg
Changes since 2.2: +32 -1 lines
Thu Jul 16 12:08:47 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.1: +19 -0 lines
Mon Jul 13 16:15:21 1992 UTC (32 years, 10 months ago) by greg
Diff to selected 2.8
