root/Development/ray/src/rt/ambient.h
Revision: 2.9
Committed: Sat Jun 7 00:54:58 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.8: +12 -28 lines
Removed NOPROTO sections.
1 /* RCSid $Id: ambient.h,v 2.8 2003/02/25 02:47:22 greg Exp $ */
2 /*
3 * Common definitions for interreflection routines.
4 *
5 * Include after ray.h
6 */
7 #ifndef _RAD_AMBIENT_H_
8 #define _RAD_AMBIENT_H_
9 #ifdef __cplusplus
10 extern "C" {
11 #endif
12
13
14 #include "copyright.h"
15
16 /*
17 * Since we've defined our vectors as float below to save space,
18 * watch out for changes in the definitions of VCOPY() and DOT()
19 * and don't pass these vectors to fvect routines.
20 */
21 typedef struct ambrec {
22 unsigned long latick; /* last accessed tick */
23 float pos[3]; /* position in space */
24 float dir[3]; /* normal direction */
25 int lvl; /* recursion level of parent ray */
26 float weight; /* weight of parent ray */
27 float rad; /* validity radius */
28 COLOR val; /* computed ambient value */
29 float gpos[3]; /* gradient wrt. position */
30 float gdir[3]; /* gradient wrt. direction */
31 struct ambrec *next; /* next in list */
32 } AMBVAL; /* ambient value */
33
34 typedef struct ambtree {
35 AMBVAL *alist; /* ambient value list */
36 struct ambtree *kid; /* 8 child nodes */
37 } AMBTREE; /* ambient octree */
38
39 typedef struct {
40 short t, p; /* theta, phi indices */
41 COLOR v; /* value sum */
42 float r; /* 1/distance sum */
43 float k; /* variance for this division */
44 int n; /* number of subsamples */
45 } AMBSAMP; /* ambient sample division */
46
47 typedef struct {
48 FVECT ux, uy, uz; /* x, y and z axis directions */
49 short nt, np; /* number of theta and phi directions */
50 } AMBHEMI; /* ambient sample hemisphere */
51
52 extern double maxarad; /* maximum ambient radius */
53 extern double minarad; /* minimum ambient radius */
54
55 #define AVGREFL 0.5 /* assumed average reflectance */
56
57 #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
58 #define AMBMAGIC 557 /* magic number for ambient value files */
59 #define AMBFMT "Radiance_ambval" /* format id string */
60
61 /* defined in ambcomp.c */
62 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
63 extern double doambient(COLOR acol, RAY *r, double wt, FVECT pg, FVECT dg);
64 extern void inithemi(AMBHEMI *hp, RAY *r, double wt);
65 extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
66 extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
67 extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
68 /* defined in ambient.c */
69 extern void setambres(int ar);
70 extern void setambacc(double newa);
71 extern void setambient(void);
72 extern void ambdone(void);
73 extern void ambnotify(OBJECT obj);
74 extern void ambient(COLOR acol, RAY *r, FVECT nrm);
75 extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
76 AMBTREE *at, FVECT c0, double s);
77 extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
78 extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
79 extern int ambsync(void);
80 /* defined in ambio.c */
81 extern void putambmagic(FILE *fp);
82 extern int hasambmagic(FILE *fp);
83 extern int writambval(AMBVAL *av, FILE *fp);
84 extern int ambvalOK(AMBVAL *av);
85 extern int readambval(AMBVAL *av, FILE *fp);
86 /* defined in lookamb.c */
87 extern void lookamb(FILE *fp);
88 extern void writamb(FILE *fp);
89
90
91 #ifdef __cplusplus
92 }
93 #endif
94 #endif /* _RAD_AMBIENT_H_ */
95
