root/Development/ray/src/rt/ambient.h
Revision: 2.7
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.6: +136 -15 lines
1 /* RCSid: $Id$ */
2 /*
3 * Common definitions for interreflection routines.
4 *
5 * Include after ray.h
6 */
7
8 /* ====================================================================
9 * The Radiance Software License, Version 1.0
10 *
11 * Copyright (c) 1990 - 2002 The Regents of the University of California,
12 * through Lawrence Berkeley National Laboratory. All rights reserved.
13 *
14 * Redistribution and use in source and binary forms, with or without
15 * modification, are permitted provided that the following conditions
16 * are met:
17 *
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 *
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in
23 * the documentation and/or other materials provided with the
24 * distribution.
25 *
26 * 3. The end-user documentation included with the redistribution,
27 * if any, must include the following acknowledgment:
28 * "This product includes Radiance software
29 * (http://radsite.lbl.gov/)
30 * developed by the Lawrence Berkeley National Laboratory
31 * (http://www.lbl.gov/)."
32 * Alternately, this acknowledgment may appear in the software itself,
33 * if and wherever such third-party acknowledgments normally appear.
34 *
35 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
36 * and "The Regents of the University of California" must
37 * not be used to endorse or promote products derived from this
38 * software without prior written permission. For written
39 * permission, please contact [email protected].
40 *
41 * 5. Products derived from this software may not be called "Radiance",
42 * nor may "Radiance" appear in their name, without prior written
43 * permission of Lawrence Berkeley National Laboratory.
44 *
45 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
46 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
47 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
48 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
49 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
50 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
51 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
52 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
53 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
54 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
55 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
56 * SUCH DAMAGE.
57 * ====================================================================
58 *
59 * This software consists of voluntary contributions made by many
60 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
61 * information on Lawrence Berkeley National Laboratory, please see
62 * <http://www.lbl.gov/>.
63 */
64
65 /*
66 * Since we've defined our vectors as float below to save space,
67 * watch out for changes in the definitions of VCOPY() and DOT()
68 * and don't pass these vectors to fvect routines.
69 */
70 typedef struct ambrec {
71 unsigned long latick; /* last accessed tick */
72 float pos[3]; /* position in space */
73 float dir[3]; /* normal direction */
74 int lvl; /* recursion level of parent ray */
75 float weight; /* weight of parent ray */
76 float rad; /* validity radius */
77 COLOR val; /* computed ambient value */
78 float gpos[3]; /* gradient wrt. position */
79 float gdir[3]; /* gradient wrt. direction */
80 struct ambrec *next; /* next in list */
81 } AMBVAL; /* ambient value */
82
83 typedef struct ambtree {
84 AMBVAL *alist; /* ambient value list */
85 struct ambtree *kid; /* 8 child nodes */
86 } AMBTREE; /* ambient octree */
87
88 typedef struct {
89 short t, p; /* theta, phi indices */
90 COLOR v; /* value sum */
91 float r; /* 1/distance sum */
92 float k; /* variance for this division */
93 int n; /* number of subsamples */
94 } AMBSAMP; /* ambient sample division */
95
96 typedef struct {
97 FVECT ux, uy, uz; /* x, y and z axis directions */
98 short nt, np; /* number of theta and phi directions */
99 } AMBHEMI; /* ambient sample hemisphere */
100
101 extern double maxarad; /* maximum ambient radius */
102 extern double minarad; /* minimum ambient radius */
103
104 #define AVGREFL 0.5 /* assumed average reflectance */
105
106 #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
107 #define AMBMAGIC 557 /* magic number for ambient value files */
108 #define AMBFMT "Radiance_ambval" /* format id string */
109
110 #ifdef NOPROTO
111
112 extern int divsample();
113 extern double doambient();
114 extern void inithemi();
115 extern void comperrs();
116 extern void posgradient();
117 extern void dirgradient();
118 extern void setambres();
119 extern void setambacc();
120 extern void setambient();
121 extern void ambdone();
122 extern void ambnotify();
123 extern void ambient();
124 extern double sumambient();
125 extern double makeambient();
126 extern void extambient();
127 extern int ambsync();
128 extern void putambmagic();
129 extern int hasambmagic();
130 extern int writambval();
131 extern int ambvalOK();
132 extern int readambval();
133 extern void lookamb();
134 extern void writamb();
135
136 #else
137 /* defined in ambcomp.c */
138 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
139 extern double doambient(COLOR acol, RAY *r, double wt, FVECT pg, FVECT dg);
140 extern void inithemi(AMBHEMI *hp, RAY *r, double wt);
141 extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
142 extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
143 extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
144 /* defined in ambient.c */
145 extern void setambres(int ar);
146 extern void setambacc(double newa);
147 extern void setambient(void);
148 extern void ambdone(void);
149 extern void ambnotify(OBJECT obj);
150 extern void ambient(COLOR acol, RAY *r, FVECT nrm);
151 extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
152 AMBTREE *at, FVECT c0, double s);
153 extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
154 extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
155 extern int ambsync(void);
156 /* defined in ambio.c */
157 extern void putambmagic(FILE *fp);
158 extern int hasambmagic(FILE *fp);
159 extern int writambval(AMBVAL *av, FILE *fp);
160 extern int ambvalOK(AMBVAL *av);
161 extern int readambval(AMBVAL *av, FILE *fp);
162 /* defined in lookamb.c */
163 extern void lookamb(FILE *fp);
164 extern void writamb(FILE *fp);
165
166 #endif
