root/radiance/ray/src/rt/ambient.h
Revision: 2.5
Committed: Thu Apr 27 14:12:09 1995 UTC (29 years, 1 month ago) by greg
added memory sorting to ambient caching module
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Common definitions for interreflection routines.
7 */
8
9 /*
10 * Since we've defined our vectors as float below to save space,
11 * watch out for changes in the definitions of VCOPY() and DOT()
12 * and don't pass these vectors to fvect routines.
13 */
14 typedef struct ambrec {
15 unsigned long latick; /* last accessed tick */
16 float pos[3]; /* position in space */
17 float dir[3]; /* normal direction */
18 int lvl; /* recursion level of parent ray */
19 float weight; /* weight of parent ray */
20 float rad; /* validity radius */
21 COLOR val; /* computed ambient value */
22 float gpos[3]; /* gradient wrt. position */
23 float gdir[3]; /* gradient wrt. direction */
24 struct ambrec *next; /* next in list */
25 } AMBVAL; /* ambient value */
26
27 extern COLOR ambval; /* global ambient component */
28 extern double ambacc; /* ambient accuracy */
29 extern int ambres; /* ambient resolution */
30 extern int ambdiv; /* number of divisions for calculation */
31 extern int ambssamp; /* number of super-samples */
32 extern int ambounce; /* number of ambient bounces */
33 extern char *amblist[]; /* ambient include/exclude list */
34 extern int ambincl; /* include == 1, exclude == 0 */
35 extern double maxarad; /* maximum ambient radius */
36 extern double minarad; /* minimum ambient radius */
37
38 extern double sumambient(), doambient(), makeambient();
39
40 #define AVGREFL 0.5 /* assumed average reflectance */
41
42 #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
43 #define AMBMAGIC 557 /* magic number for ambient value files */
44 #define AMBFMT "Radiance_ambval" /* format id string */
