1 |
/* RCSid $Id: ambient.h,v 2.21 2014/04/19 02:39:44 greg Exp $ */ |
2 |
3 |
* Common definitions for interreflection routines. |
4 |
5 |
* Include after ray.h |
6 |
7 |
8 |
#ifndef _RAD_AMBIENT_H_ |
9 |
#define _RAD_AMBIENT_H_ |
10 |
#ifdef __cplusplus |
11 |
extern "C" { |
12 |
#endif |
13 |
14 |
#ifdef NEWAMB |
15 |
16 |
17 |
* Normal and u-vector directions encoded using dircode.c |
18 |
19 |
typedef struct ambrec { |
20 |
struct ambrec *next; /* next in list */ |
21 |
unsigned long latick; /* last accessed tick */ |
22 |
float pos[3]; /* position in space */ |
23 |
int32 ndir; /* encoded surface normal */ |
24 |
int32 udir; /* u-vector direction */ |
25 |
int lvl; /* recursion level of parent ray */ |
26 |
float weight; /* weight of parent ray */ |
27 |
float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */ |
28 |
COLOR val; /* computed ambient value */ |
29 |
float gpos[2]; /* (u,v) gradient wrt. position */ |
30 |
float gdir[2]; /* (u,v) gradient wrt. direction */ |
31 |
uint32 corral; /* potential light leak direction flags */ |
32 |
} AMBVAL; /* ambient value */ |
33 |
34 |
typedef struct ambtree { |
35 |
AMBVAL *alist; /* ambient value list */ |
36 |
struct ambtree *kid; /* 8 child nodes */ |
37 |
} AMBTREE; /* ambient octree */ |
38 |
39 |
extern double maxarad; /* maximum ambient radius */ |
40 |
extern double minarad; /* minimum ambient radius */ |
41 |
42 |
#ifndef AVGREFL |
43 |
#define AVGREFL 0.5 /* assumed average reflectance */ |
44 |
#endif |
45 |
46 |
#define AMBVALSIZ 67 /* number of bytes in portable AMBVAL struct */ |
47 |
#define AMBMAGIC 559 /* magic number for ambient value files */ |
48 |
#define AMBFMT "Radiance_ambval" /* format id string */ |
49 |
50 |
/* defined in ambient.c */ |
51 |
extern void setambres(int ar); |
52 |
extern void setambacc(double newa); |
53 |
extern void setambient(void); |
54 |
extern void multambient(COLOR aval, RAY *r, FVECT nrm); |
55 |
extern void ambdone(void); |
56 |
extern void ambnotify(OBJECT obj); |
57 |
extern int ambsync(void); |
58 |
/* defined in ambcomp.c */ |
59 |
extern int doambient(COLOR acol, RAY *r, double wt, |
60 |
FVECT uv[2], float rad[2], |
61 |
float gpos[2], float gdir[2], uint32 *crlp); |
62 |
/* defined in ambio.c */ |
63 |
extern void putambmagic(FILE *fp); |
64 |
extern int hasambmagic(FILE *fp); |
65 |
extern int writambval(AMBVAL *av, FILE *fp); |
66 |
extern int readambval(AMBVAL *av, FILE *fp); |
67 |
extern int ambvalOK(AMBVAL *av); |
68 |
69 |
#else /* ! NEWAMB */ |
70 |
71 |
72 |
* Since we've defined our vectors as float below to save space, |
73 |
* watch out for changes in the definitions of VCOPY() and DOT() |
74 |
* and don't pass these vectors to fvect routines. |
75 |
76 |
77 |
78 |
79 |
80 |
float dir[3]; /* normal direction */ |
81 |
82 |
83 |
float rad; /* validity radius */ |
84 |
85 |
float gpos[3]; /* gradient wrt. position */ |
86 |
float gdir[3]; /* gradient wrt. direction */ |
87 |
88 |
89 |
90 |
91 |
92 |
93 |
94 |
typedef struct { |
95 |
COLOR v; /* division sum (partial) */ |
96 |
float r; /* 1/distance sum */ |
97 |
float k; /* variance for this division */ |
98 |
int n; /* number of subsamples */ |
99 |
unsigned short t, p; /* theta, phi indices */ |
100 |
} AMBSAMP; /* ambient sample division */ |
101 |
102 |
typedef struct { |
103 |
FVECT ux, uy, uz; /* x, y and z axis directions */ |
104 |
COLOR acoef; /* division contribution coefficient */ |
105 |
int ns; /* number of super-samples */ |
106 |
int nt, np; /* number of theta and phi directions */ |
107 |
} AMBHEMI; /* ambient sample hemisphere */ |
108 |
109 |
110 |
111 |
112 |
#ifndef AVGREFL |
113 |
114 |
#endif |
115 |
116 |
#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ |
117 |
#define AMBMAGIC 557 /* magic number for ambient value files */ |
118 |
119 |
120 |
121 |
122 |
123 |
124 |
125 |
126 |
127 |
128 |
129 |
extern double doambient(COLOR acol, RAY *r, double wt, |
130 |
FVECT pg, FVECT dg); |
131 |
extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt); |
132 |
extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); |
133 |
extern void comperrs(AMBSAMP *da, AMBHEMI *hp); |
134 |
extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
135 |
extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
136 |
137 |
138 |
139 |
140 |
141 |
142 |
143 |
#endif /* ! NEWAMB */ |
144 |
145 |
146 |
147 |
#endif |
148 |
#endif /* _RAD_AMBIENT_H_ */ |
149 |
