1 |
/* RCSid $Id: ambient.h,v 2.18 2011/09/22 02:15:56 greg Exp $ */ |
2 |
3 |
* Common definitions for interreflection routines. |
4 |
5 |
* Include after ray.h |
6 |
7 |
8 |
#ifndef _RAD_AMBIENT_H_ |
9 |
#define _RAD_AMBIENT_H_ |
10 |
#ifdef __cplusplus |
11 |
extern "C" { |
12 |
#endif |
13 |
14 |
#ifdef NEWAMB |
15 |
16 |
17 |
* Normal and u-vector directions encoded using dircode.c |
18 |
19 |
typedef struct ambrec { |
20 |
struct ambrec *next; /* next in list */ |
21 |
unsigned long latick; /* last accessed tick */ |
22 |
float pos[3]; /* position in space */ |
23 |
int32 ndir; /* encoded surface normal */ |
24 |
int32 udir; /* u-vector direction */ |
25 |
int lvl; /* recursion level of parent ray */ |
26 |
float weight; /* weight of parent ray */ |
27 |
float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */ |
28 |
COLOR val; /* computed ambient value */ |
29 |
float gpos[2]; /* (u,v) gradient wrt. position */ |
30 |
float gdir[2]; /* (u,v) gradient wrt. direction */ |
31 |
} AMBVAL; /* ambient value */ |
32 |
33 |
typedef struct ambtree { |
34 |
AMBVAL *alist; /* ambient value list */ |
35 |
struct ambtree *kid; /* 8 child nodes */ |
36 |
} AMBTREE; /* ambient octree */ |
37 |
38 |
typedef struct { |
39 |
COLOR v; /* division sum (partial) */ |
40 |
float r; /* 1/distance sum */ |
41 |
float k; /* variance for this division */ |
42 |
int n; /* number of subsamples */ |
43 |
unsigned short t, p; /* theta, phi indices */ |
44 |
} AMBSAMP; /* ambient sample division */ |
45 |
46 |
typedef struct { |
47 |
FVECT ux, uy, uz; /* x, y and z axis directions */ |
48 |
COLOR acoef; /* division contribution coefficient */ |
49 |
int ns; /* number of super-samples */ |
50 |
int nt, np; /* number of theta and phi directions */ |
51 |
} AMBHEMI; /* ambient sample hemisphere */ |
52 |
53 |
extern double maxarad; /* maximum ambient radius */ |
54 |
extern double minarad; /* minimum ambient radius */ |
55 |
56 |
#ifndef AVGREFL |
57 |
#define AVGREFL 0.5 /* assumed average reflectance */ |
58 |
#endif |
59 |
60 |
#define AMBVALSIZ 63 /* number of bytes in portable AMBVAL struct */ |
61 |
#define AMBMAGIC 558 /* magic number for ambient value files */ |
62 |
#define AMBFMT "Radiance_ambval" /* format id string */ |
63 |
64 |
/* defined in ambient.c */ |
65 |
extern void setambres(int ar); |
66 |
extern void setambacc(double newa); |
67 |
extern void setambient(void); |
68 |
extern void multambient(COLOR aval, RAY *r, FVECT nrm); |
69 |
extern void ambdone(void); |
70 |
extern void ambnotify(OBJECT obj); |
71 |
extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al, |
72 |
AMBTREE *at, FVECT c0, double s); |
73 |
extern int makeambient(COLOR acol, RAY *r, FVECT rn, int al); |
74 |
extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); |
75 |
extern int ambsync(void); |
76 |
/* defined in ambcomp.c */ |
77 |
extern int doambient(COLOR acol, RAY *r, double wt, |
78 |
FVECT uv[2], float rad[2], |
79 |
float gpos[2], float gdir[2]); |
80 |
extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt); |
81 |
extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); |
82 |
extern void comperrs(AMBSAMP *da, AMBHEMI *hp); |
83 |
extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
84 |
extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
85 |
/* defined in ambio.c */ |
86 |
extern void putambmagic(FILE *fp); |
87 |
extern int hasambmagic(FILE *fp); |
88 |
extern int writambval(AMBVAL *av, FILE *fp); |
89 |
extern int ambvalOK(AMBVAL *av); |
90 |
extern int readambval(AMBVAL *av, FILE *fp); |
91 |
92 |
#else /* ! NEWAMB */ |
93 |
94 |
95 |
* Since we've defined our vectors as float below to save space, |
96 |
* watch out for changes in the definitions of VCOPY() and DOT() |
97 |
* and don't pass these vectors to fvect routines. |
98 |
99 |
100 |
101 |
102 |
103 |
float dir[3]; /* normal direction */ |
104 |
105 |
106 |
float rad; /* validity radius */ |
107 |
108 |
float gpos[3]; /* gradient wrt. position */ |
109 |
float gdir[3]; /* gradient wrt. direction */ |
110 |
111 |
112 |
113 |
114 |
115 |
116 |
117 |
typedef struct { |
118 |
119 |
120 |
121 |
122 |
123 |
124 |
125 |
typedef struct { |
126 |
127 |
128 |
129 |
130 |
131 |
132 |
133 |
134 |
135 |
#ifndef AVGREFL |
136 |
137 |
#endif |
138 |
139 |
#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ |
140 |
#define AMBMAGIC 557 /* magic number for ambient value files */ |
141 |
142 |
143 |
144 |
145 |
146 |
147 |
148 |
149 |
150 |
151 |
152 |
extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al); |
153 |
154 |
155 |
156 |
extern double doambient(COLOR acol, RAY *r, double wt, |
157 |
FVECT pg, FVECT dg); |
158 |
159 |
160 |
161 |
162 |
163 |
164 |
165 |
166 |
167 |
168 |
169 |
170 |
#endif /* ! NEWAMB */ |
171 |
172 |
173 |
174 |
#endif |
175 |
#endif /* _RAD_AMBIENT_H_ */ |
176 |
