| 1 |
/* RCSid $Id: ambient.h,v 2.14 2005/05/28 22:27:54 greg Exp $ */
| 2 |
| 3 |
* Common definitions for interreflection routines.
| 4 |
| 5 |
* Include after ray.h
| 6 |
| 7 |
#ifndef _RAD_AMBIENT_H_
| 8 |
#define _RAD_AMBIENT_H_
| 9 |
#ifdef __cplusplus
| 10 |
extern "C" {
| 11 |
#endif
| 12 |
| 13 |
| 14 |
* Since we've defined our vectors as float below to save space,
| 15 |
* watch out for changes in the definitions of VCOPY() and DOT()
| 16 |
* and don't pass these vectors to fvect routines.
| 17 |
| 18 |
typedef struct ambrec {
| 19 |
unsigned long latick; /* last accessed tick */
| 20 |
float pos[3]; /* position in space */
| 21 |
float dir[3]; /* normal direction */
| 22 |
int lvl; /* recursion level of parent ray */
| 23 |
float weight; /* weight of parent ray */
| 24 |
float rad; /* validity radius */
| 25 |
COLOR val; /* computed ambient value */
| 26 |
float gpos[3]; /* gradient wrt. position */
| 27 |
float gdir[3]; /* gradient wrt. direction */
| 28 |
struct ambrec *next; /* next in list */
| 29 |
} AMBVAL; /* ambient value */
| 30 |
| 31 |
typedef struct ambtree {
| 32 |
AMBVAL *alist; /* ambient value list */
| 33 |
struct ambtree *kid; /* 8 child nodes */
| 34 |
} AMBTREE; /* ambient octree */
| 35 |
| 36 |
typedef struct {
| 37 |
short t, p; /* theta, phi indices */
| 38 |
COLOR v; /* division sum (partial) */
| 39 |
float r; /* 1/distance sum */
| 40 |
float k; /* variance for this division */
| 41 |
int n; /* number of subsamples */
| 42 |
} AMBSAMP; /* ambient sample division */
| 43 |
| 44 |
typedef struct {
| 45 |
COLOR acoef; /* division contribution coefficient */
| 46 |
FVECT ux, uy, uz; /* x, y and z axis directions */
| 47 |
short nt, np; /* number of theta and phi directions */
| 48 |
int ns; /* number of super-samples */
| 49 |
} AMBHEMI; /* ambient sample hemisphere */
| 50 |
| 51 |
extern double maxarad; /* maximum ambient radius */
| 52 |
extern double minarad; /* minimum ambient radius */
| 53 |
| 54 |
#ifndef AVGREFL
| 55 |
#define AVGREFL 0.5 /* assumed average reflectance */
| 56 |
#endif
| 57 |
| 58 |
#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
| 59 |
#define AMBMAGIC 557 /* magic number for ambient value files */
| 60 |
#define AMBFMT "Radiance_ambval" /* format id string */
| 61 |
| 62 |
/* defined in ambient.c */
| 63 |
extern void setambres(int ar);
| 64 |
extern void setambacc(double newa);
| 65 |
extern void setambient(void);
| 66 |
extern void multambient(COLOR aval, RAY *r, FVECT nrm);
| 67 |
extern void ambdone(void);
| 68 |
extern void ambnotify(OBJECT obj);
| 69 |
extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
| 70 |
AMBTREE *at, FVECT c0, double s);
| 71 |
extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
| 72 |
extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
| 73 |
extern int ambsync(void);
| 74 |
/* defined in ambcomp.c */
| 75 |
extern double doambient(COLOR acol, RAY *r, double wt,
| 76 |
FVECT pg, FVECT dg);
| 77 |
extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt);
| 78 |
extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
| 79 |
extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
| 80 |
extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
| 81 |
extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
| 82 |
/* defined in ambio.c */
| 83 |
extern void putambmagic(FILE *fp);
| 84 |
extern int hasambmagic(FILE *fp);
| 85 |
extern int writambval(AMBVAL *av, FILE *fp);
| 86 |
extern int ambvalOK(AMBVAL *av);
| 87 |
extern int readambval(AMBVAL *av, FILE *fp);
| 88 |
/* defined in lookamb.c */
| 89 |
extern void lookamb(FILE *fp);
| 90 |
extern void writamb(FILE *fp);
| 91 |
| 92 |
| 93 |
#ifdef __cplusplus
| 94 |
| 95 |
#endif
| 96 |
#endif /* _RAD_AMBIENT_H_ */
| 97 |
