1 |
/* RCSid $Id: ambient.h,v 2.13 2005/05/25 18:06:22 greg Exp $ */ |
2 |
3 |
* Common definitions for interreflection routines. |
4 |
5 |
* Include after ray.h |
6 |
7 |
#ifndef _RAD_AMBIENT_H_ |
8 |
#define _RAD_AMBIENT_H_ |
9 |
#ifdef __cplusplus |
10 |
extern "C" { |
11 |
#endif |
12 |
13 |
14 |
* Since we've defined our vectors as float below to save space, |
15 |
* watch out for changes in the definitions of VCOPY() and DOT() |
16 |
* and don't pass these vectors to fvect routines. |
17 |
18 |
typedef struct ambrec { |
19 |
unsigned long latick; /* last accessed tick */ |
20 |
float pos[3]; /* position in space */ |
21 |
float dir[3]; /* normal direction */ |
22 |
int lvl; /* recursion level of parent ray */ |
23 |
float weight; /* weight of parent ray */ |
24 |
float rad; /* validity radius */ |
25 |
COLOR val; /* computed ambient value */ |
26 |
float gpos[3]; /* gradient wrt. position */ |
27 |
float gdir[3]; /* gradient wrt. direction */ |
28 |
struct ambrec *next; /* next in list */ |
29 |
} AMBVAL; /* ambient value */ |
30 |
31 |
typedef struct ambtree { |
32 |
AMBVAL *alist; /* ambient value list */ |
33 |
struct ambtree *kid; /* 8 child nodes */ |
34 |
} AMBTREE; /* ambient octree */ |
35 |
36 |
typedef struct { |
37 |
short t, p; /* theta, phi indices */ |
38 |
COLOR v; /* value sum */ |
39 |
float r; /* 1/distance sum */ |
40 |
float k; /* variance for this division */ |
41 |
int n; /* number of subsamples */ |
42 |
} AMBSAMP; /* ambient sample division */ |
43 |
44 |
typedef struct { |
45 |
COLOR acoef; /* ambient contribution coefficient */ |
46 |
float drc; /* daughter ray coefficient */ |
47 |
FVECT ux, uy, uz; /* x, y and z axis directions */ |
48 |
short nt, np; /* number of theta and phi directions */ |
49 |
int ns; /* number of super-samples */ |
50 |
} AMBHEMI; /* ambient sample hemisphere */ |
51 |
52 |
extern double maxarad; /* maximum ambient radius */ |
53 |
extern double minarad; /* minimum ambient radius */ |
54 |
55 |
#ifndef AVGREFL |
56 |
#define AVGREFL 0.5 /* assumed average reflectance */ |
57 |
#endif |
58 |
59 |
#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ |
60 |
#define AMBMAGIC 557 /* magic number for ambient value files */ |
61 |
#define AMBFMT "Radiance_ambval" /* format id string */ |
62 |
63 |
/* defined in ambient.c */ |
64 |
extern void setambres(int ar); |
65 |
extern void setambacc(double newa); |
66 |
extern void setambient(void); |
67 |
extern void multambient(COLOR aval, RAY *r, FVECT nrm); |
68 |
extern void ambdone(void); |
69 |
extern void ambnotify(OBJECT obj); |
70 |
extern double sumambient(COLOR acol, RAY *r, double rw, FVECT rn, int al, |
71 |
AMBTREE *at, FVECT c0, double s); |
72 |
extern double makeambient(COLOR acol, RAY *r, COLOR ac, FVECT rn, int al); |
73 |
extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); |
74 |
extern int ambsync(void); |
75 |
/* defined in ambcomp.c */ |
76 |
extern double doambient(COLOR acol, RAY *r, COLOR ac, double wt, |
77 |
FVECT pg, FVECT dg); |
78 |
extern void inithemi(AMBHEMI *hp, RAY *r, COLOR ac, double wt); |
79 |
extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); |
80 |
extern void comperrs(AMBSAMP *da, AMBHEMI *hp); |
81 |
extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
82 |
extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); |
83 |
/* defined in ambio.c */ |
84 |
extern void putambmagic(FILE *fp); |
85 |
extern int hasambmagic(FILE *fp); |
86 |
extern int writambval(AMBVAL *av, FILE *fp); |
87 |
extern int ambvalOK(AMBVAL *av); |
88 |
extern int readambval(AMBVAL *av, FILE *fp); |
89 |
/* defined in lookamb.c */ |
90 |
extern void lookamb(FILE *fp); |
91 |
extern void writamb(FILE *fp); |
92 |
93 |
94 |
95 |
96 |
#endif |
97 |
#endif /* _RAD_AMBIENT_H_ */ |
98 |
