--- ray/src/rt/ambient.h 2014/06/19 16:26:55 2.23 +++ ray/src/rt/ambient.h 2019/05/14 17:39:10 2.25 @@ -1,4 +1,4 @@ -/* RCSid $Id: ambient.h,v 2.23 2014/06/19 16:26:55 greg Exp $ */ +/* RCSid $Id: ambient.h,v 2.25 2019/05/14 17:39:10 greg Exp $ */ /* * Common definitions for interreflection routines. * @@ -11,8 +11,6 @@ extern "C" { #endif -#ifndef OLDAMB - /* * Normal and u-vector directions encoded using dircode.c */ @@ -22,7 +20,7 @@ typedef struct ambrec { float pos[3]; /* position in space */ int32 ndir; /* encoded surface normal */ int32 udir; /* u-vector direction */ - int lvl; /* recursion level of parent ray */ + short lvl; /* recursion level of parent ray */ float weight; /* weight of parent ray */ float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */ COLOR val; /* computed ambient value */ @@ -65,82 +63,6 @@ extern int hasambmagic(FILE *fp); extern int writambval(AMBVAL *av, FILE *fp); extern int readambval(AMBVAL *av, FILE *fp); extern int ambvalOK(AMBVAL *av); - -#else /* ! NEWAMB */ - -/* - * Since we've defined our vectors as float below to save space, - * watch out for changes in the definitions of VCOPY() and DOT() - * and don't pass these vectors to fvect routines. - */ -typedef struct ambrec { - struct ambrec *next; /* next in list */ - unsigned long latick; /* last accessed tick */ - float pos[3]; /* position in space */ - float dir[3]; /* normal direction */ - int lvl; /* recursion level of parent ray */ - float weight; /* weight of parent ray */ - float rad; /* validity radius */ - COLOR val; /* computed ambient value */ - float gpos[3]; /* gradient wrt. position */ - float gdir[3]; /* gradient wrt. direction */ -} AMBVAL; /* ambient value */ - -typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ -} AMBTREE; /* ambient octree */ - -typedef struct { - COLOR v; /* division sum (partial) */ - float r; /* 1/distance sum */ - float k; /* variance for this division */ - int n; /* number of subsamples */ - unsigned short t, p; /* theta, phi indices */ -} AMBSAMP; /* ambient sample division */ - -typedef struct { - FVECT ux, uy, uz; /* x, y and z axis directions */ - COLOR acoef; /* division contribution coefficient */ - int ns; /* number of super-samples */ - int nt, np; /* number of theta and phi directions */ -} AMBHEMI; /* ambient sample hemisphere */ - -extern double maxarad; /* maximum ambient radius */ -extern double minarad; /* minimum ambient radius */ - -#ifndef AVGREFL -#define AVGREFL 0.5 /* assumed average reflectance */ -#endif - -#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ -#define AMBMAGIC 557 /* magic number for ambient value files */ -#define AMBFMT "Radiance_ambval" /* format id string */ - - /* defined in ambient.c */ -extern void setambres(int ar); -extern void setambacc(double newa); -extern void setambient(void); -extern void multambient(COLOR aval, RAY *r, FVECT nrm); -extern void ambdone(void); -extern void ambnotify(OBJECT obj); -extern int ambsync(void); - /* defined in ambcomp.c */ -extern double doambient(COLOR acol, RAY *r, double wt, - FVECT pg, FVECT dg); -extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt); -extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); -extern void comperrs(AMBSAMP *da, AMBHEMI *hp); -extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); -extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); - /* defined in ambio.c */ -extern void putambmagic(FILE *fp); -extern int hasambmagic(FILE *fp); -extern int writambval(AMBVAL *av, FILE *fp); -extern int ambvalOK(AMBVAL *av); -extern int readambval(AMBVAL *av, FILE *fp); - -#endif /* ! NEWAMB */ #ifdef __cplusplus }
