--- ray/src/rt/ambient.h 2005/02/23 18:18:21 2.11 +++ ray/src/rt/ambient.h 2005/04/19 01:15:06 2.12 @@ -1,4 +1,4 @@ -/* RCSid $Id: ambient.h,v 2.11 2005/02/23 18:18:21 greg Exp $ */ +/* RCSid $Id: ambient.h,v 2.12 2005/04/19 01:15:06 greg Exp $ */ /* * Common definitions for interreflection routines. * @@ -42,6 +42,7 @@ typedef struct { } AMBSAMP; /* ambient sample division */ typedef struct { + COLOR acoef; /* coefficient for rayorigin() */ FVECT ux, uy, uz; /* x, y and z axis directions */ short nt, np; /* number of theta and phi directions */ } AMBHEMI; /* ambient sample hemisphere */ @@ -57,25 +58,26 @@ extern double minarad; /* minimum ambient radius */ #define AMBMAGIC 557 /* magic number for ambient value files */ #define AMBFMT "Radiance_ambval" /* format id string */ - /* defined in ambcomp.c */ -extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); -extern double doambient(COLOR acol, RAY *r, double wt, FVECT pg, FVECT dg); -extern void inithemi(AMBHEMI *hp, RAY *r, double wt); -extern void comperrs(AMBSAMP *da, AMBHEMI *hp); -extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); -extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); /* defined in ambient.c */ extern void setambres(int ar); extern void setambacc(double newa); extern void setambient(void); +extern void multambient(COLOR aval, RAY *r, FVECT nrm); extern void ambdone(void); extern void ambnotify(OBJECT obj); -extern void ambient(COLOR acol, RAY *r, FVECT nrm); extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al, AMBTREE *at, FVECT c0, double s); -extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al); +extern double makeambient(COLOR acol, RAY *r, COLOR ac, FVECT rn, int al); extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); extern int ambsync(void); + /* defined in ambcomp.c */ +extern double doambient(COLOR acol, RAY *r, COLOR ac, double wt, + FVECT pg, FVECT dg); +extern int inithemi(AMBHEMI *hp, RAY *r, COLOR ac, double wt); +extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); +extern void comperrs(AMBSAMP *da, AMBHEMI *hp); +extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); +extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); /* defined in ambio.c */ extern void putambmagic(FILE *fp); extern int hasambmagic(FILE *fp);
