root/radiance/ray/src/rt/ambient.h
Revision: 2.25
Committed: Tue May 14 17:39:10 2019 UTC (6 years, 1 month ago) by greg
Changes since 2.24: +1 -79 lines
Stripped out code related to old (pre-Hessian) ambient calculation
# User Rev Content
1 greg 2.25 /* RCSid $Id: ambient.h,v 2.24 2015/05/21 12:25:53 greg Exp $ */
2 greg 1.1 /*
3     * Common definitions for interreflection routines.
4 greg 2.7 *
5     * Include after ray.h
6     */
7 greg 2.19
8 schorsch 2.9 #ifndef _RAD_AMBIENT_H_
9     #define _RAD_AMBIENT_H_
10     #ifdef __cplusplus
11     extern "C" {
12     #endif
13 greg 1.1
14 greg 2.19 /*
15     * Normal and u-vector directions encoded using dircode.c
16     */
17     typedef struct ambrec {
18     struct ambrec *next; /* next in list */
19     unsigned long latick; /* last accessed tick */
20     float pos[3]; /* position in space */
21     int32 ndir; /* encoded surface normal */
22     int32 udir; /* u-vector direction */
23 greg 2.24 short lvl; /* recursion level of parent ray */
24 greg 2.19 float weight; /* weight of parent ray */
25     float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */
26     COLOR val; /* computed ambient value */
27     float gpos[2]; /* (u,v) gradient wrt. position */
28     float gdir[2]; /* (u,v) gradient wrt. direction */
29 greg 2.22 uint32 corral; /* potential light leak direction flags */
30 greg 2.19 } AMBVAL; /* ambient value */
31
32     typedef struct ambtree {
33     AMBVAL *alist; /* ambient value list */
34     struct ambtree *kid; /* 8 child nodes */
35     } AMBTREE; /* ambient octree */
36
37     extern double maxarad; /* maximum ambient radius */
38     extern double minarad; /* minimum ambient radius */
39
40     #ifndef AVGREFL
41     #define AVGREFL 0.5 /* assumed average reflectance */
42     #endif
43
44 greg 2.22 #define AMBVALSIZ 67 /* number of bytes in portable AMBVAL struct */
45     #define AMBMAGIC 559 /* magic number for ambient value files */
46 greg 2.19 #define AMBFMT "Radiance_ambval" /* format id string */
47
48     /* defined in ambient.c */
49     extern void setambres(int ar);
50     extern void setambacc(double newa);
51     extern void setambient(void);
52     extern void multambient(COLOR aval, RAY *r, FVECT nrm);
53     extern void ambdone(void);
54     extern void ambnotify(OBJECT obj);
55     extern int ambsync(void);
56     /* defined in ambcomp.c */
57     extern int doambient(COLOR acol, RAY *r, double wt,
58     FVECT uv[2], float rad[2],
59 greg 2.22 float gpos[2], float gdir[2], uint32 *crlp);
60 greg 2.19 /* defined in ambio.c */
61     extern void putambmagic(FILE *fp);
62     extern int hasambmagic(FILE *fp);
63     extern int writambval(AMBVAL *av, FILE *fp);
64 greg 2.20 extern int readambval(AMBVAL *av, FILE *fp);
65 greg 2.19 extern int ambvalOK(AMBVAL *av);
66
67 schorsch 2.9 #ifdef __cplusplus
68     }
69 greg 2.7 #endif
70 schorsch 2.9 #endif /* _RAD_AMBIENT_H_ */
71
