root/Development/ray/src/rt/ambient.h
Revision: 2.24
Committed: Thu May 21 12:25:53 2015 UTC (10 years, 7 months ago) by greg
CVS Tags: rad5R2, rad5R1, rad5R0
Prevent over-padding of AMBVAL struct on 64-bit machines
# User Rev Content
1 greg 2.24 /* RCSid $Id: ambient.h,v 2.23 2014/06/19 16:26:55 greg Exp $ */
2 greg 1.1 /*
3     * Common definitions for interreflection routines.
4 greg 2.7 *
5     * Include after ray.h
6     */
7 greg 2.19
8 schorsch 2.9 #ifndef _RAD_AMBIENT_H_
9     #define _RAD_AMBIENT_H_
10     #ifdef __cplusplus
11     extern "C" {
12     #endif
13 greg 1.1
14 greg 2.23 #ifndef OLDAMB
15 greg 2.19
16     /*
17     * Normal and u-vector directions encoded using dircode.c
18     */
19     typedef struct ambrec {
20     struct ambrec *next; /* next in list */
21     unsigned long latick; /* last accessed tick */
22     float pos[3]; /* position in space */
23     int32 ndir; /* encoded surface normal */
24     int32 udir; /* u-vector direction */
25 greg 2.24 short lvl; /* recursion level of parent ray */
26 greg 2.19 float weight; /* weight of parent ray */
27     float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */
28     COLOR val; /* computed ambient value */
29     float gpos[2]; /* (u,v) gradient wrt. position */
30     float gdir[2]; /* (u,v) gradient wrt. direction */
31 greg 2.22 uint32 corral; /* potential light leak direction flags */
32 greg 2.19 } AMBVAL; /* ambient value */
33
34     typedef struct ambtree {
35     AMBVAL *alist; /* ambient value list */
36     struct ambtree *kid; /* 8 child nodes */
37     } AMBTREE; /* ambient octree */
38
39     extern double maxarad; /* maximum ambient radius */
40     extern double minarad; /* minimum ambient radius */
41
42     #ifndef AVGREFL
43     #define AVGREFL 0.5 /* assumed average reflectance */
44     #endif
45
46 greg 2.22 #define AMBVALSIZ 67 /* number of bytes in portable AMBVAL struct */
47     #define AMBMAGIC 559 /* magic number for ambient value files */
48 greg 2.19 #define AMBFMT "Radiance_ambval" /* format id string */
49
50     /* defined in ambient.c */
51     extern void setambres(int ar);
52     extern void setambacc(double newa);
53     extern void setambient(void);
54     extern void multambient(COLOR aval, RAY *r, FVECT nrm);
55     extern void ambdone(void);
56     extern void ambnotify(OBJECT obj);
57     extern int ambsync(void);
58     /* defined in ambcomp.c */
59     extern int doambient(COLOR acol, RAY *r, double wt,
60     FVECT uv[2], float rad[2],
61 greg 2.22 float gpos[2], float gdir[2], uint32 *crlp);
62 greg 2.19 /* defined in ambio.c */
63     extern void putambmagic(FILE *fp);
64     extern int hasambmagic(FILE *fp);
65     extern int writambval(AMBVAL *av, FILE *fp);
66 greg 2.20 extern int readambval(AMBVAL *av, FILE *fp);
67 greg 2.19 extern int ambvalOK(AMBVAL *av);
68
69     #else /* ! NEWAMB */
70
71 greg 1.1 /*
72     * Since we've defined our vectors as float below to save space,
73     * watch out for changes in the definitions of VCOPY() and DOT()
74     * and don't pass these vectors to fvect routines.
75     */
76     typedef struct ambrec {
77 greg 2.18 struct ambrec *next; /* next in list */
78 greg 2.5 unsigned long latick; /* last accessed tick */
79 greg 1.1 float pos[3]; /* position in space */
80     float dir[3]; /* normal direction */
81 greg 2.24 short lvl; /* recursion level of parent ray */
82 greg 1.1 float weight; /* weight of parent ray */
83     float rad; /* validity radius */
84     COLOR val; /* computed ambient value */
85     float gpos[3]; /* gradient wrt. position */
86     float gdir[3]; /* gradient wrt. direction */
87     } AMBVAL; /* ambient value */
88
89 greg 2.7 typedef struct ambtree {
90     AMBVAL *alist; /* ambient value list */
91     struct ambtree *kid; /* 8 child nodes */
92     } AMBTREE; /* ambient octree */
93
94     typedef struct {
95 greg 2.15 COLOR v; /* division sum (partial) */
96 greg 2.7 float r; /* 1/distance sum */
97     float k; /* variance for this division */
98 greg 2.17 int n; /* number of subsamples */
99     unsigned short t, p; /* theta, phi indices */
100 greg 2.7 } AMBSAMP; /* ambient sample division */
101
102     typedef struct {
103 greg 2.16 FVECT ux, uy, uz; /* x, y and z axis directions */
104 greg 2.15 COLOR acoef; /* division contribution coefficient */
105 greg 2.16 int ns; /* number of super-samples */
106 greg 2.17 int nt, np; /* number of theta and phi directions */
107 greg 2.7 } AMBHEMI; /* ambient sample hemisphere */
108
109 greg 1.1 extern double maxarad; /* maximum ambient radius */
110     extern double minarad; /* minimum ambient radius */
111
112 greg 2.11 #ifndef AVGREFL
113 greg 1.2 #define AVGREFL 0.5 /* assumed average reflectance */
114 greg 2.11 #endif
115 greg 2.2
116     #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
117 greg 2.4 #define AMBMAGIC 557 /* magic number for ambient value files */
118 greg 2.3 #define AMBFMT "Radiance_ambval" /* format id string */
119 greg 2.7
120     /* defined in ambient.c */
121     extern void setambres(int ar);
122     extern void setambacc(double newa);
123     extern void setambient(void);
124 greg 2.12 extern void multambient(COLOR aval, RAY *r, FVECT nrm);
125 greg 2.7 extern void ambdone(void);
126     extern void ambnotify(OBJECT obj);
127     extern int ambsync(void);
128 greg 2.12 /* defined in ambcomp.c */
129 greg 2.15 extern double doambient(COLOR acol, RAY *r, double wt,
130 greg 2.12 FVECT pg, FVECT dg);
131 greg 2.15 extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt);
132 greg 2.12 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
133     extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
134     extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
135     extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
136 greg 2.7 /* defined in ambio.c */
137     extern void putambmagic(FILE *fp);
138     extern int hasambmagic(FILE *fp);
139     extern int writambval(AMBVAL *av, FILE *fp);
140     extern int ambvalOK(AMBVAL *av);
141     extern int readambval(AMBVAL *av, FILE *fp);
142
143 greg 2.19 #endif /* ! NEWAMB */
144 schorsch 2.9
145     #ifdef __cplusplus
146     }
147 greg 2.7 #endif
148 schorsch 2.9 #endif /* _RAD_AMBIENT_H_ */
149
