root/radiance/ray/src/rt/ambient.h
Thu Jun 19 16:26:55 2014 UTC (9 years, 10 months ago) by greg
Diff to previous 2.22 , to selected 2.3
Wed May 7 01:16:03 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.21: +6 -5 lines
Diff to previous 2.21 , to selected 2.3
Sat Apr 19 02:39:44 2014 UTC (10 years ago) by greg
Changes since 2.20: +1 -16 lines
Diff to previous 2.20 , to selected 2.3
Fri Apr 11 22:54:34 2014 UTC (10 years ago) by greg
Changes since 2.19: +2 -15 lines
Diff to previous 2.19 , to selected 2.3
Fixed compile errors and tidied up new code
Fri Apr 11 20:31:37 2014 UTC (10 years ago) by greg
Changes since 2.18: +83 -4 lines
Diff to previous 2.18 , to selected 2.3
Thu Sep 22 02:15:56 2011 UTC (12 years, 7 months ago) by greg
Diff to previous 2.17 , to selected 2.3
Minor optimizations
Tue Oct 5 18:05:23 2010 UTC (13 years, 7 months ago) by greg
Diff to previous 2.16 , to selected 2.3
Fixed issues with integer overflow
Fri Sep 23 19:04:53 2005 UTC (18 years, 7 months ago) by greg
Diff to previous 2.15 , to selected 2.3
Tue May 31 18:01:09 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.14: +7 -8 lines
Diff to previous 2.14 , to selected 2.3
Sat May 28 22:27:54 2005 UTC (18 years, 11 months ago) by greg
Changes since 2.13: +6 -4 lines
Diff to previous 2.13 , to selected 2.3
Wed May 25 18:06:22 2005 UTC (18 years, 11 months ago) by greg
Diff to previous 2.12 , to selected 2.3
Fixed bug introduced with ray contribution output in ambient calculation
Tue Apr 19 01:15:06 2005 UTC (19 years ago) by greg
Changes since 2.11: +12 -10 lines
Diff to previous 2.11 , to selected 2.3
Wed Feb 23 18:18:21 2005 UTC (19 years, 2 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Added ability to redefine AVGREFL with a compile switch
Changes since 2.9: +1 -4 lines
Diff to previous 2.9 , to selected 2.3
Sat Jun 7 00:54:58 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.8: +12 -28 lines
Removed NOPROTO sections.
Changes since 2.6: +136 -15 lines
Wed Feb 14 15:18:19 1996 UTC (28 years, 2 months ago) by greg
Thu Apr 27 14:12:09 1995 UTC (29 years ago) by greg
added memory sorting to ambient caching module
Mon Aug 10 08:46:38 1992 UTC (31 years, 8 months ago) by greg
changed magic number for ambient files
Thu Jul 16 12:08:46 1992 UTC (31 years, 9 months ago) by greg
Mon Jul 13 16:17:48 1992 UTC (31 years, 9 months ago) by greg
Tue Nov 12 17:10:27 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.3
Tue Aug 20 10:02:43 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.1 , to selected 2.3
made ambient value weighting incremental (fewer stored values)
Fri Jun 7 10:03:51 1991 UTC (32 years, 11 months ago) by greg
Diff to selected 2.3
