--- ray/src/rt/ambient.h 2014/04/19 02:39:44 2.21 +++ ray/src/rt/ambient.h 2014/05/07 01:16:03 2.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: ambient.h,v 2.21 2014/04/19 02:39:44 greg Exp $ */ +/* RCSid $Id: ambient.h,v 2.22 2014/05/07 01:16:03 greg Exp $ */ /* * Common definitions for interreflection routines. * @@ -22,12 +22,13 @@ typedef struct ambrec { float pos[3]; /* position in space */ int32 ndir; /* encoded surface normal */ int32 udir; /* u-vector direction */ - int lvl; /* recursion level of parent ray */ + int lvl; /* recursion level of parent ray */ float weight; /* weight of parent ray */ float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */ COLOR val; /* computed ambient value */ float gpos[2]; /* (u,v) gradient wrt. position */ float gdir[2]; /* (u,v) gradient wrt. direction */ + uint32 corral; /* potential light leak direction flags */ } AMBVAL; /* ambient value */ typedef struct ambtree { @@ -42,8 +43,8 @@ extern double minarad; /* minimum ambient radius */ #define AVGREFL 0.5 /* assumed average reflectance */ #endif -#define AMBVALSIZ 63 /* number of bytes in portable AMBVAL struct */ -#define AMBMAGIC 558 /* magic number for ambient value files */ +#define AMBVALSIZ 67 /* number of bytes in portable AMBVAL struct */ +#define AMBMAGIC 559 /* magic number for ambient value files */ #define AMBFMT "Radiance_ambval" /* format id string */ /* defined in ambient.c */ @@ -57,7 +58,7 @@ extern int ambsync(void); /* defined in ambcomp.c */ extern int doambient(COLOR acol, RAY *r, double wt, FVECT uv[2], float rad[2], - float gpos[2], float gdir[2]); + float gpos[2], float gdir[2], uint32 *crlp); /* defined in ambio.c */ extern void putambmagic(FILE *fp); extern int hasambmagic(FILE *fp);
