--- ray/src/rt/ambient.h 1991/06/07 10:03:51 1.1 +++ ray/src/rt/ambient.h 2003/02/22 02:07:28 2.7 @@ -1,17 +1,74 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: ambient.h,v 2.7 2003/02/22 02:07:28 greg Exp $ */ /* * Common definitions for interreflection routines. + * + * Include after ray.h */ +/* ==================================================================== + * The Radiance Software License, Version 1.0 + * + * Copyright (c) 1990 - 2002 The Regents of the University of California, + * through Lawrence Berkeley National Laboratory. All rights reserved. + * + * Redistribution and use in source and binary forms, with or without + * modification, are permitted provided that the following conditions + * are met: + * + * 1. Redistributions of source code must retain the above copyright + * notice, this list of conditions and the following disclaimer. + * + * 2. Redistributions in binary form must reproduce the above copyright + * notice, this list of conditions and the following disclaimer in + * the documentation and/or other materials provided with the + * distribution. + * + * 3. The end-user documentation included with the redistribution, + * if any, must include the following acknowledgment: + * "This product includes Radiance software + * (http://radsite.lbl.gov/) + * developed by the Lawrence Berkeley National Laboratory + * (http://www.lbl.gov/)." + * Alternately, this acknowledgment may appear in the software itself, + * if and wherever such third-party acknowledgments normally appear. + * + * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" + * and "The Regents of the University of California" must + * not be used to endorse or promote products derived from this + * software without prior written permission. For written + * permission, please contact radiance@radsite.lbl.gov. + * + * 5. Products derived from this software may not be called "Radiance", + * nor may "Radiance" appear in their name, without prior written + * permission of Lawrence Berkeley National Laboratory. + * + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES + * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE + * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR + * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, + * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT + * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND + * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, + * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT + * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF + * SUCH DAMAGE. + * ==================================================================== + * + * This software consists of voluntary contributions made by many + * individuals on behalf of Lawrence Berkeley National Laboratory. For more + * information on Lawrence Berkeley National Laboratory, please see + * . + */ + /* * Since we've defined our vectors as float below to save space, * watch out for changes in the definitions of VCOPY() and DOT() * and don't pass these vectors to fvect routines. */ typedef struct ambrec { + unsigned long latick; /* last accessed tick */ float pos[3]; /* position in space */ float dir[3]; /* normal direction */ int lvl; /* recursion level of parent ray */ @@ -23,15 +80,87 @@ typedef struct ambrec { struct ambrec *next; /* next in list */ } AMBVAL; /* ambient value */ -extern COLOR ambval; /* global ambient component */ -extern double ambacc; /* ambient accuracy */ -extern int ambres; /* ambient resolution */ -extern int ambdiv; /* number of divisions for calculation */ -extern int ambssamp; /* number of super-samples */ -extern int ambounce; /* number of ambient bounces */ -extern char *amblist[]; /* ambient include/exclude list */ -extern int ambincl; /* include == 1, exclude == 0 */ +typedef struct ambtree { + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ +} AMBTREE; /* ambient octree */ + +typedef struct { + short t, p; /* theta, phi indices */ + COLOR v; /* value sum */ + float r; /* 1/distance sum */ + float k; /* variance for this division */ + int n; /* number of subsamples */ +} AMBSAMP; /* ambient sample division */ + +typedef struct { + FVECT ux, uy, uz; /* x, y and z axis directions */ + short nt, np; /* number of theta and phi directions */ +} AMBHEMI; /* ambient sample hemisphere */ + extern double maxarad; /* maximum ambient radius */ extern double minarad; /* minimum ambient radius */ -extern double sumambient(), doambient(), makeambient(); +#define AVGREFL 0.5 /* assumed average reflectance */ + +#define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ +#define AMBMAGIC 557 /* magic number for ambient value files */ +#define AMBFMT "Radiance_ambval" /* format id string */ + +#ifdef NOPROTO + +extern int divsample(); +extern double doambient(); +extern void inithemi(); +extern void comperrs(); +extern void posgradient(); +extern void dirgradient(); +extern void setambres(); +extern void setambacc(); +extern void setambient(); +extern void ambdone(); +extern void ambnotify(); +extern void ambient(); +extern double sumambient(); +extern double makeambient(); +extern void extambient(); +extern int ambsync(); +extern void putambmagic(); +extern int hasambmagic(); +extern int writambval(); +extern int ambvalOK(); +extern int readambval(); +extern void lookamb(); +extern void writamb(); + +#else + /* defined in ambcomp.c */ +extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); +extern double doambient(COLOR acol, RAY *r, double wt, FVECT pg, FVECT dg); +extern void inithemi(AMBHEMI *hp, RAY *r, double wt); +extern void comperrs(AMBSAMP *da, AMBHEMI *hp); +extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); +extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); + /* defined in ambient.c */ +extern void setambres(int ar); +extern void setambacc(double newa); +extern void setambient(void); +extern void ambdone(void); +extern void ambnotify(OBJECT obj); +extern void ambient(COLOR acol, RAY *r, FVECT nrm); +extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al, + AMBTREE *at, FVECT c0, double s); +extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al); +extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); +extern int ambsync(void); + /* defined in ambio.c */ +extern void putambmagic(FILE *fp); +extern int hasambmagic(FILE *fp); +extern int writambval(AMBVAL *av, FILE *fp); +extern int ambvalOK(AMBVAL *av); +extern int readambval(AMBVAL *av, FILE *fp); + /* defined in lookamb.c */ +extern void lookamb(FILE *fp); +extern void writamb(FILE *fp); + +#endif
