root/Development/ray/src/rt/ambient.h
Revision: 2.23
Committed: Thu Jun 19 16:26:55 2014 UTC (11 years, 4 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad4R2
1 /* RCSid $Id: ambient.h,v 2.22 2014/05/07 01:16:03 greg Exp $ */
2 /*
3 * Common definitions for interreflection routines.
4 *
5 * Include after ray.h
6 */
7
8 #ifndef _RAD_AMBIENT_H_
9 #define _RAD_AMBIENT_H_
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #ifndef OLDAMB
15
16 /*
17 * Normal and u-vector directions encoded using dircode.c
18 */
19 typedef struct ambrec {
20 struct ambrec *next; /* next in list */
21 unsigned long latick; /* last accessed tick */
22 float pos[3]; /* position in space */
23 int32 ndir; /* encoded surface normal */
24 int32 udir; /* u-vector direction */
25 int lvl; /* recursion level of parent ray */
26 float weight; /* weight of parent ray */
27 float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */
28 COLOR val; /* computed ambient value */
29 float gpos[2]; /* (u,v) gradient wrt. position */
30 float gdir[2]; /* (u,v) gradient wrt. direction */
31 uint32 corral; /* potential light leak direction flags */
32 } AMBVAL; /* ambient value */
33
34 typedef struct ambtree {
35 AMBVAL *alist; /* ambient value list */
36 struct ambtree *kid; /* 8 child nodes */
37 } AMBTREE; /* ambient octree */
38
39 extern double maxarad; /* maximum ambient radius */
40 extern double minarad; /* minimum ambient radius */
41
42 #ifndef AVGREFL
43 #define AVGREFL 0.5 /* assumed average reflectance */
44 #endif
45
46 #define AMBVALSIZ 67 /* number of bytes in portable AMBVAL struct */
47 #define AMBMAGIC 559 /* magic number for ambient value files */
48 #define AMBFMT "Radiance_ambval" /* format id string */
49
50 /* defined in ambient.c */
51 extern void setambres(int ar);
52 extern void setambacc(double newa);
53 extern void setambient(void);
54 extern void multambient(COLOR aval, RAY *r, FVECT nrm);
55 extern void ambdone(void);
56 extern void ambnotify(OBJECT obj);
57 extern int ambsync(void);
58 /* defined in ambcomp.c */
59 extern int doambient(COLOR acol, RAY *r, double wt,
60 FVECT uv[2], float rad[2],
61 float gpos[2], float gdir[2], uint32 *crlp);
62 /* defined in ambio.c */
63 extern void putambmagic(FILE *fp);
64 extern int hasambmagic(FILE *fp);
65 extern int writambval(AMBVAL *av, FILE *fp);
66 extern int readambval(AMBVAL *av, FILE *fp);
67 extern int ambvalOK(AMBVAL *av);
68
69 #else /* ! NEWAMB */
70
71 /*
72 * Since we've defined our vectors as float below to save space,
73 * watch out for changes in the definitions of VCOPY() and DOT()
74 * and don't pass these vectors to fvect routines.
75 */
76 typedef struct ambrec {
77 struct ambrec *next; /* next in list */
78 unsigned long latick; /* last accessed tick */
79 float pos[3]; /* position in space */
80 float dir[3]; /* normal direction */
81 int lvl; /* recursion level of parent ray */
82 float weight; /* weight of parent ray */
83 float rad; /* validity radius */
84 COLOR val; /* computed ambient value */
85 float gpos[3]; /* gradient wrt. position */
86 float gdir[3]; /* gradient wrt. direction */
87 } AMBVAL; /* ambient value */
88
89 typedef struct ambtree {
90 AMBVAL *alist; /* ambient value list */
91 struct ambtree *kid; /* 8 child nodes */
92 } AMBTREE; /* ambient octree */
93
94 typedef struct {
95 COLOR v; /* division sum (partial) */
96 float r; /* 1/distance sum */
97 float k; /* variance for this division */
98 int n; /* number of subsamples */
99 unsigned short t, p; /* theta, phi indices */
100 } AMBSAMP; /* ambient sample division */
101
102 typedef struct {
103 FVECT ux, uy, uz; /* x, y and z axis directions */
104 COLOR acoef; /* division contribution coefficient */
105 int ns; /* number of super-samples */
106 int nt, np; /* number of theta and phi directions */
107 } AMBHEMI; /* ambient sample hemisphere */
108
109 extern double maxarad; /* maximum ambient radius */
110 extern double minarad; /* minimum ambient radius */
111
112 #ifndef AVGREFL
113 #define AVGREFL 0.5 /* assumed average reflectance */
114 #endif
115
116 #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
117 #define AMBMAGIC 557 /* magic number for ambient value files */
118 #define AMBFMT "Radiance_ambval" /* format id string */
119
120 /* defined in ambient.c */
121 extern void setambres(int ar);
122 extern void setambacc(double newa);
123 extern void setambient(void);
124 extern void multambient(COLOR aval, RAY *r, FVECT nrm);
125 extern void ambdone(void);
126 extern void ambnotify(OBJECT obj);
127 extern int ambsync(void);
128 /* defined in ambcomp.c */
129 extern double doambient(COLOR acol, RAY *r, double wt,
130 FVECT pg, FVECT dg);
131 extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt);
132 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
133 extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
134 extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
135 extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
136 /* defined in ambio.c */
137 extern void putambmagic(FILE *fp);
138 extern int hasambmagic(FILE *fp);
139 extern int writambval(AMBVAL *av, FILE *fp);
140 extern int ambvalOK(AMBVAL *av);
141 extern int readambval(AMBVAL *av, FILE *fp);
142
143 #endif /* ! NEWAMB */
144
145 #ifdef __cplusplus
146 }
147 #endif
148 #endif /* _RAD_AMBIENT_H_ */
149
