root/radiance/ray/src/rt/ambient.h
Revision: 2.19
Committed: Fri Apr 11 20:31:37 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.18: +83 -4 lines
1 /* RCSid $Id: ambient.h,v 2.18 2011/09/22 02:15:56 greg Exp $ */
2 /*
3 * Common definitions for interreflection routines.
4 *
5 * Include after ray.h
6 */
7
8 #ifndef _RAD_AMBIENT_H_
9 #define _RAD_AMBIENT_H_
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 #ifdef NEWAMB
15
16 /*
17 * Normal and u-vector directions encoded using dircode.c
18 */
19 typedef struct ambrec {
20 struct ambrec *next; /* next in list */
21 unsigned long latick; /* last accessed tick */
22 float pos[3]; /* position in space */
23 int32 ndir; /* encoded surface normal */
24 int32 udir; /* u-vector direction */
25 int lvl; /* recursion level of parent ray */
26 float weight; /* weight of parent ray */
27 float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */
28 COLOR val; /* computed ambient value */
29 float gpos[2]; /* (u,v) gradient wrt. position */
30 float gdir[2]; /* (u,v) gradient wrt. direction */
31 } AMBVAL; /* ambient value */
32
33 typedef struct ambtree {
34 AMBVAL *alist; /* ambient value list */
35 struct ambtree *kid; /* 8 child nodes */
36 } AMBTREE; /* ambient octree */
37
38 typedef struct {
39 COLOR v; /* division sum (partial) */
40 float r; /* 1/distance sum */
41 float k; /* variance for this division */
42 int n; /* number of subsamples */
43 unsigned short t, p; /* theta, phi indices */
44 } AMBSAMP; /* ambient sample division */
45
46 typedef struct {
47 FVECT ux, uy, uz; /* x, y and z axis directions */
48 COLOR acoef; /* division contribution coefficient */
49 int ns; /* number of super-samples */
50 int nt, np; /* number of theta and phi directions */
51 } AMBHEMI; /* ambient sample hemisphere */
52
53 extern double maxarad; /* maximum ambient radius */
54 extern double minarad; /* minimum ambient radius */
55
56 #ifndef AVGREFL
57 #define AVGREFL 0.5 /* assumed average reflectance */
58 #endif
59
60 #define AMBVALSIZ 63 /* number of bytes in portable AMBVAL struct */
61 #define AMBMAGIC 558 /* magic number for ambient value files */
62 #define AMBFMT "Radiance_ambval" /* format id string */
63
64 /* defined in ambient.c */
65 extern void setambres(int ar);
66 extern void setambacc(double newa);
67 extern void setambient(void);
68 extern void multambient(COLOR aval, RAY *r, FVECT nrm);
69 extern void ambdone(void);
70 extern void ambnotify(OBJECT obj);
71 extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
72 AMBTREE *at, FVECT c0, double s);
73 extern int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
74 extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
75 extern int ambsync(void);
76 /* defined in ambcomp.c */
77 extern int doambient(COLOR acol, RAY *r, double wt,
78 FVECT uv[2], float rad[2],
79 float gpos[2], float gdir[2]);
80 extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt);
81 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
82 extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
83 extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
84 extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
85 /* defined in ambio.c */
86 extern void putambmagic(FILE *fp);
87 extern int hasambmagic(FILE *fp);
88 extern int writambval(AMBVAL *av, FILE *fp);
89 extern int ambvalOK(AMBVAL *av);
90 extern int readambval(AMBVAL *av, FILE *fp);
91
92 #else /* ! NEWAMB */
93
94 /*
95 * Since we've defined our vectors as float below to save space,
96 * watch out for changes in the definitions of VCOPY() and DOT()
97 * and don't pass these vectors to fvect routines.
98 */
99 typedef struct ambrec {
100 struct ambrec *next; /* next in list */
101 unsigned long latick; /* last accessed tick */
102 float pos[3]; /* position in space */
103 float dir[3]; /* normal direction */
104 int lvl; /* recursion level of parent ray */
105 float weight; /* weight of parent ray */
106 float rad; /* validity radius */
107 COLOR val; /* computed ambient value */
108 float gpos[3]; /* gradient wrt. position */
109 float gdir[3]; /* gradient wrt. direction */
110 } AMBVAL; /* ambient value */
111
112 typedef struct ambtree {
113 AMBVAL *alist; /* ambient value list */
114 struct ambtree *kid; /* 8 child nodes */
115 } AMBTREE; /* ambient octree */
116
117 typedef struct {
118 COLOR v; /* division sum (partial) */
119 float r; /* 1/distance sum */
120 float k; /* variance for this division */
121 int n; /* number of subsamples */
122 unsigned short t, p; /* theta, phi indices */
123 } AMBSAMP; /* ambient sample division */
124
125 typedef struct {
126 FVECT ux, uy, uz; /* x, y and z axis directions */
127 COLOR acoef; /* division contribution coefficient */
128 int ns; /* number of super-samples */
129 int nt, np; /* number of theta and phi directions */
130 } AMBHEMI; /* ambient sample hemisphere */
131
132 extern double maxarad; /* maximum ambient radius */
133 extern double minarad; /* minimum ambient radius */
134
135 #ifndef AVGREFL
136 #define AVGREFL 0.5 /* assumed average reflectance */
137 #endif
138
139 #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */
140 #define AMBMAGIC 557 /* magic number for ambient value files */
141 #define AMBFMT "Radiance_ambval" /* format id string */
142
143 /* defined in ambient.c */
144 extern void setambres(int ar);
145 extern void setambacc(double newa);
146 extern void setambient(void);
147 extern void multambient(COLOR aval, RAY *r, FVECT nrm);
148 extern void ambdone(void);
149 extern void ambnotify(OBJECT obj);
150 extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
151 AMBTREE *at, FVECT c0, double s);
152 extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
153 extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
154 extern int ambsync(void);
155 /* defined in ambcomp.c */
156 extern double doambient(COLOR acol, RAY *r, double wt,
157 FVECT pg, FVECT dg);
158 extern void inithemi(AMBHEMI *hp, COLOR ac, RAY *r, double wt);
159 extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r);
160 extern void comperrs(AMBSAMP *da, AMBHEMI *hp);
161 extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
162 extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp);
163 /* defined in ambio.c */
164 extern void putambmagic(FILE *fp);
165 extern int hasambmagic(FILE *fp);
166 extern int writambval(AMBVAL *av, FILE *fp);
167 extern int ambvalOK(AMBVAL *av);
168 extern int readambval(AMBVAL *av, FILE *fp);
169
170 #endif /* ! NEWAMB */
171
172 #ifdef __cplusplus
173 }
174 #endif
175 #endif /* _RAD_AMBIENT_H_ */
176
