root/radiance/ray/src/rt/ambient.h
Fri Sep 23 19:04:53 2005 UTC (18 years, 8 months ago) by greg
Changes since 2.14: +7 -8 lines
Sat May 28 22:27:54 2005 UTC (19 years ago) by greg
Changes since 2.13: +6 -4 lines
Wed May 25 18:06:22 2005 UTC (19 years ago) by greg
Fixed bug introduced with ray contribution output in ambient calculation
Tue Apr 19 01:15:06 2005 UTC (19 years, 2 months ago) by greg
Changes since 2.11: +12 -10 lines
Wed Feb 23 18:18:21 2005 UTC (19 years, 3 months ago) by greg
Added ability to redefine AVGREFL with a compile switch
Fri Jun 27 06:53:22 2003 UTC (20 years, 11 months ago) by greg
Changes since 2.9: +1 -4 lines
Sat Jun 7 00:54:58 2003 UTC (21 years ago) by schorsch
Changes since 2.8: +12 -28 lines
Removed NOPROTO sections.
Changes since 2.6: +136 -15 lines
Wed Feb 14 15:18:19 1996 UTC (28 years, 4 months ago) by greg
Thu Apr 27 14:12:09 1995 UTC (29 years, 1 month ago) by greg
added memory sorting to ambient caching module
Mon Aug 10 08:46:38 1992 UTC (31 years, 10 months ago) by greg
changed magic number for ambient files
Thu Jul 16 12:08:46 1992 UTC (31 years, 11 months ago) by greg
Mon Jul 13 16:17:48 1992 UTC (31 years, 11 months ago) by greg
Tue Nov 12 17:10:27 1991 UTC (32 years, 7 months ago) by greg
Tue Aug 20 10:02:43 1991 UTC (32 years, 10 months ago) by greg
made ambient value weighting incremental (fewer stored values)
Fri Jun 7 10:03:51 1991 UTC (33 years ago) by greg
Diff to selected 2.2
