--- ray/src/rt/ambient.h 2003/06/07 00:54:58 2.9 +++ ray/src/rt/ambient.h 2005/05/28 22:27:54 2.14 @@ -1,4 +1,4 @@ -/* RCSid $Id: ambient.h,v 2.9 2003/06/07 00:54:58 schorsch Exp $ */ +/* RCSid $Id: ambient.h,v 2.14 2005/05/28 22:27:54 greg Exp $ */ /* * Common definitions for interreflection routines. * @@ -10,9 +10,6 @@ extern "C" { #endif - -#include "copyright.h" - /* * Since we've defined our vectors as float below to save space, * watch out for changes in the definitions of VCOPY() and DOT() @@ -22,7 +19,7 @@ typedef struct ambrec { unsigned long latick; /* last accessed tick */ float pos[3]; /* position in space */ float dir[3]; /* normal direction */ - int lvl; /* recursion level of parent ray */ + int lvl; /* recursion level of parent ray */ float weight; /* weight of parent ray */ float rad; /* validity radius */ COLOR val; /* computed ambient value */ @@ -45,38 +42,44 @@ typedef struct { } AMBSAMP; /* ambient sample division */ typedef struct { + COLOR acoef; /* ambient contribution coefficient */ + float drc; /* daughter ray coefficient */ FVECT ux, uy, uz; /* x, y and z axis directions */ short nt, np; /* number of theta and phi directions */ + int ns; /* number of super-samples */ } AMBHEMI; /* ambient sample hemisphere */ extern double maxarad; /* maximum ambient radius */ extern double minarad; /* minimum ambient radius */ +#ifndef AVGREFL #define AVGREFL 0.5 /* assumed average reflectance */ +#endif #define AMBVALSIZ 75 /* number of bytes in portable AMBVAL struct */ #define AMBMAGIC 557 /* magic number for ambient value files */ #define AMBFMT "Radiance_ambval" /* format id string */ - /* defined in ambcomp.c */ -extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); -extern double doambient(COLOR acol, RAY *r, double wt, FVECT pg, FVECT dg); -extern void inithemi(AMBHEMI *hp, RAY *r, double wt); -extern void comperrs(AMBSAMP *da, AMBHEMI *hp); -extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); -extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); /* defined in ambient.c */ extern void setambres(int ar); extern void setambacc(double newa); extern void setambient(void); +extern void multambient(COLOR aval, RAY *r, FVECT nrm); extern void ambdone(void); extern void ambnotify(OBJECT obj); -extern void ambient(COLOR acol, RAY *r, FVECT nrm); -extern double sumambient(COLOR acol, RAY *r, FVECT rn, int al, +extern double sumambient(COLOR acol, RAY *r, double rw, FVECT rn, int al, AMBTREE *at, FVECT c0, double s); -extern double makeambient(COLOR acol, RAY *r, FVECT rn, int al); +extern double makeambient(COLOR acol, RAY *r, COLOR ac, FVECT rn, int al); extern void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); extern int ambsync(void); + /* defined in ambcomp.c */ +extern double doambient(COLOR acol, RAY *r, COLOR ac, double wt, + FVECT pg, FVECT dg); +extern void inithemi(AMBHEMI *hp, RAY *r, COLOR ac, double wt); +extern int divsample(AMBSAMP *dp, AMBHEMI *h, RAY *r); +extern void comperrs(AMBSAMP *da, AMBHEMI *hp); +extern void posgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); +extern void dirgradient(FVECT gv, AMBSAMP *da, AMBHEMI *hp); /* defined in ambio.c */ extern void putambmagic(FILE *fp); extern int hasambmagic(FILE *fp);
