root/radiance/ray/src/rt/ambient.h
Revision: 2.27
Committed: Wed Nov 15 18:02:52 2023 UTC (20 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 2.26: +9 -6 lines
1 /* RCSid $Id: ambient.h,v 2.26 2022/03/07 17:52:14 greg Exp $ */
2 /*
3 * Common definitions for interreflection routines.
4 *
5 * Include after ray.h
6 */
7
8 #ifndef _RAD_AMBIENT_H_
9 #define _RAD_AMBIENT_H_
10 #ifdef __cplusplus
11 extern "C" {
12 #endif
13
14 /*
15 * Normal and u-vector directions encoded using dircode.c
16 */
17 typedef struct ambrec {
18 struct ambrec *next; /* next in list */
19 float pos[3]; /* position in space */
20 int32 ndir; /* encoded surface normal */
21 int32 udir; /* u-vector direction */
22 short lvl; /* recursion level of parent ray */
23 float weight; /* weight of parent ray */
24 float rad[2]; /* anisotropic radii (rad[0] <= rad[1]) */
25 float gpos[2]; /* (u,v) gradient wrt. position */
26 float gdir[2]; /* (u,v) gradient wrt. direction */
27 uint32 corral; /* potential light leak direction flags */
28 SCOLOR val; /* computed indirect irradiance (last!) */
29 } AMBVAL; /* ambient value */
30
31 typedef struct ambtree {
32 AMBVAL *alist; /* ambient value list */
33 struct ambtree *kid; /* 8 child nodes */
34 } AMBTREE; /* ambient octree */
35
36 extern double maxarad; /* maximum ambient radius */
37 extern double minarad; /* minimum ambient radius */
38
39 #ifndef AVGREFL
40 #define AVGREFL 0.5 /* assumed average reflectance */
41 #endif
42
43 #define AMBVALSIZ (64+AMB_CNDX[3]) /* number of bytes in portable AMBVAL */
44 #define AMBMAGIC 561 /* magic number for ambient value file */
45 #define AMBFMT "Radiance_ambval" /* format id string */
46
47 /* defined in ambient.c */
48 extern void setambres(int ar);
49 extern void setambacc(double newa);
50 extern void setambient(void);
51 extern void multambient(SCOLOR aval, RAY *r, FVECT nrm);
52 extern void ambdone(void);
53 extern void ambnotify(OBJECT obj);
54 extern int ambsync(void);
55 /* defined in ambcomp.c */
56 extern int doambient(SCOLOR acol, RAY *r, double wt,
57 FVECT uv[2], float rad[2],
58 float gpos[2], float gdir[2], uint32 *crlp);
59 /* defined in ambio.c */
60 extern int *AMB_CNDX; /* open ambient file RGBE indices */
61 extern float *AMB_WLPART; /* open ambient file spectral range */
62 extern int amb_headline(char *hl, void *p);
63 extern void putambmagic(FILE *fp);
64 extern int hasambmagic(FILE *fp);
65 extern int writambval(AMBVAL *av, FILE *fp);
66 extern int readambval(AMBVAL *av, FILE *fp);
67 extern int ambvalOK(AMBVAL *av);
68
69 #ifdef __cplusplus
70 }
71 #endif
72 #endif /* _RAD_AMBIENT_H_ */
73
