1 |
static const char RCSid[] = "$Id: ambient.c,v 2.98 2015/08/23 00:17:12 greg Exp $"; |
2 |
3 |
* ambient.c - routines dealing with ambient (inter-reflected) component. |
4 |
5 |
* Declarations of external symbols in ambient.h |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <string.h> |
11 |
12 |
#include "platform.h" |
13 |
#include "ray.h" |
14 |
#include "otypes.h" |
15 |
#include "resolu.h" |
16 |
#include "ambient.h" |
17 |
#include "random.h" |
18 |
#include "pmapamb.h" |
19 |
20 |
#ifndef OCTSCALE |
21 |
#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ |
22 |
#endif |
23 |
24 |
extern char *shm_boundary; /* memory sharing boundary */ |
25 |
26 |
#ifndef MAXASET |
27 |
#define MAXASET 4095 /* maximum number of elements in ambient set */ |
28 |
#endif |
29 |
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ |
30 |
31 |
double maxarad; /* maximum ambient radius */ |
32 |
double minarad; /* minimum ambient radius */ |
33 |
34 |
static AMBTREE atrunk; /* our ambient trunk node */ |
35 |
36 |
static FILE *ambfp = NULL; /* ambient file pointer */ |
37 |
static int nunflshed = 0; /* number of unflushed ambient values */ |
38 |
39 |
#ifndef SORT_THRESH |
40 |
#ifdef SMLMEM |
41 |
#define SORT_THRESH ((16L<<20)/sizeof(AMBVAL)) |
42 |
#else |
43 |
#define SORT_THRESH ((64L<<20)/sizeof(AMBVAL)) |
44 |
#endif |
45 |
#endif |
46 |
#ifndef SORT_INTVL |
47 |
#define SORT_INTVL (SORT_THRESH<<1) |
48 |
#endif |
49 |
#ifndef MAX_SORT_INTVL |
50 |
#define MAX_SORT_INTVL (SORT_INTVL<<6) |
51 |
#endif |
52 |
53 |
54 |
static double avsum = 0.; /* computed ambient value sum (log) */ |
55 |
static unsigned int navsum = 0; /* number of values in avsum */ |
56 |
static unsigned int nambvals = 0; /* total number of indirect values */ |
57 |
static unsigned int nambshare = 0; /* number of values from file */ |
58 |
static unsigned long ambclock = 0; /* ambient access clock */ |
59 |
static unsigned long lastsort = 0; /* time of last value sort */ |
60 |
static long sortintvl = SORT_INTVL; /* time until next sort */ |
61 |
static FILE *ambinp = NULL; /* auxiliary file for input */ |
62 |
static long lastpos = -1; /* last flush position */ |
63 |
64 |
#define MAXACLOCK (1L<<30) /* clock turnover value */ |
65 |
66 |
* Track access times unless we are sharing ambient values |
67 |
* through memory on a multiprocessor, when we want to avoid |
68 |
* claiming our own memory (copy on write). Go ahead anyway |
69 |
* if more than two thirds of our values are unshared. |
70 |
* Compile with -Dtracktime=0 to turn this code off. |
71 |
72 |
#ifndef tracktime |
73 |
#define tracktime (shm_boundary == NULL || nambvals > 3*nambshare) |
74 |
#endif |
75 |
76 |
#define AMBFLUSH (BUFSIZ/AMBVALSIZ) |
77 |
78 |
#define newambval() (AMBVAL *)malloc(sizeof(AMBVAL)) |
79 |
#define freeav(av) free((void *)av); |
80 |
81 |
static void initambfile(int creat); |
82 |
static void avsave(AMBVAL *av); |
83 |
static AMBVAL *avstore(AMBVAL *aval); |
84 |
static AMBTREE *newambtree(void); |
85 |
static void freeambtree(AMBTREE *atp); |
86 |
87 |
typedef void unloadtf_t(AMBVAL *); |
88 |
static unloadtf_t avinsert; |
89 |
static unloadtf_t av2list; |
90 |
static unloadtf_t avfree; |
91 |
static void unloadatree(AMBTREE *at, unloadtf_t *f); |
92 |
93 |
static int aposcmp(const void *avp1, const void *avp2); |
94 |
static int avlmemi(AMBVAL *avaddr); |
95 |
static void sortambvals(int always); |
96 |
97 |
#ifdef F_SETLKW |
98 |
static void aflock(int typ); |
99 |
#endif |
100 |
101 |
102 |
void |
103 |
setambres( /* set ambient resolution */ |
104 |
int ar |
105 |
106 |
107 |
ambres = ar < 0 ? 0 : ar; /* may be done already */ |
108 |
/* set min & max radii */ |
109 |
if (ar <= 0) { |
110 |
minarad = 0; |
111 |
maxarad = thescene.cusize*0.2; |
112 |
} else { |
113 |
minarad = thescene.cusize / ar; |
114 |
maxarad = 64.0 * minarad; /* heuristic */ |
115 |
if (maxarad > thescene.cusize*0.2) |
116 |
117 |
118 |
if (minarad <= FTINY) |
119 |
minarad = 10.0*FTINY; |
120 |
if (maxarad <= minarad) |
121 |
maxarad = 64.0 * minarad; |
122 |
123 |
124 |
125 |
void |
126 |
setambacc( /* set ambient accuracy */ |
127 |
double newa |
128 |
129 |
130 |
static double olda; /* remember previous setting here */ |
131 |
132 |
newa *= (newa > 0); |
133 |
if (fabs(newa - olda) >= .05*(newa + olda)) { |
134 |
ambacc = newa; |
135 |
if (nambvals > 0) |
136 |
sortambvals(1); /* rebuild tree */ |
137 |
138 |
139 |
140 |
141 |
void |
142 |
setambient(void) /* initialize calculation */ |
143 |
144 |
int readonly = 0; |
145 |
long flen; |
146 |
AMBVAL amb; |
147 |
/* make sure we're fresh */ |
148 |
ambdone(); |
149 |
/* init ambient limits */ |
150 |
setambres(ambres); |
151 |
setambacc(ambacc); |
152 |
if (ambfile == NULL || !ambfile[0]) |
153 |
return; |
154 |
if (ambacc <= FTINY) { |
155 |
sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", |
156 |
ambfile); |
157 |
error(WARNING, errmsg); |
158 |
return; |
159 |
160 |
/* open ambient file */ |
161 |
if ((ambfp = fopen(ambfile, "r+")) == NULL) |
162 |
readonly = (ambfp = fopen(ambfile, "r")) != NULL; |
163 |
if (ambfp != NULL) { |
164 |
initambfile(0); /* file exists */ |
165 |
lastpos = ftell(ambfp); |
166 |
while (readambval(&amb, ambfp)) |
167 |
avstore(&amb); |
168 |
nambshare = nambvals; /* share loaded values */ |
169 |
if (readonly) { |
170 |
sprintf(errmsg, |
171 |
"loaded %u values from read-only ambient file", |
172 |
nambvals); |
173 |
174 |
fclose(ambfp); /* close file so no writes */ |
175 |
ambfp = NULL; |
176 |
return; /* avoid ambsync() */ |
177 |
178 |
/* align file pointer */ |
179 |
lastpos += (long)nambvals*AMBVALSIZ; |
180 |
flen = lseek(fileno(ambfp), (off_t)0, SEEK_END); |
181 |
if (flen != lastpos) { |
182 |
sprintf(errmsg, |
183 |
"ignoring last %ld values in ambient file (corrupted)", |
184 |
(flen - lastpos)/AMBVALSIZ); |
185 |
186 |
fseek(ambfp, lastpos, SEEK_SET); |
187 |
#ifndef _WIN32 /* XXX we need a replacement for that one */ |
188 |
ftruncate(fileno(ambfp), (off_t)lastpos); |
189 |
#endif |
190 |
191 |
} else if ((ambfp = fopen(ambfile, "w+")) != NULL) { |
192 |
initambfile(1); /* else create new file */ |
193 |
fflush(ambfp); |
194 |
195 |
} else { |
196 |
sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile); |
197 |
error(SYSTEM, errmsg); |
198 |
199 |
#ifdef F_SETLKW |
200 |
aflock(F_UNLCK); /* release file */ |
201 |
#endif |
202 |
203 |
204 |
205 |
void |
206 |
ambdone(void) /* close ambient file and free memory */ |
207 |
208 |
if (ambfp != NULL) { /* close ambient file */ |
209 |
ambsync(); |
210 |
fclose(ambfp); |
211 |
ambfp = NULL; |
212 |
if (ambinp != NULL) { |
213 |
fclose(ambinp); |
214 |
ambinp = NULL; |
215 |
216 |
lastpos = -1; |
217 |
218 |
/* free ambient tree */ |
219 |
unloadatree(&atrunk, avfree); |
220 |
freeambtree(NULL); |
221 |
/* reset state variables */ |
222 |
avsum = 0.; |
223 |
navsum = 0; |
224 |
nambvals = 0; |
225 |
nambshare = 0; |
226 |
ambclock = 0; |
227 |
lastsort = 0; |
228 |
sortintvl = SORT_INTVL; |
229 |
230 |
231 |
232 |
void |
233 |
ambnotify( /* record new modifier */ |
234 |
OBJECT obj |
235 |
236 |
237 |
static int hitlimit = 0; |
238 |
OBJREC *o; |
239 |
char **amblp; |
240 |
241 |
if (obj == OVOID) { /* starting over */ |
242 |
ambset[0] = 0; |
243 |
hitlimit = 0; |
244 |
return; |
245 |
246 |
o = objptr(obj); |
247 |
if (hitlimit || !ismodifier(o->otype)) |
248 |
return; |
249 |
for (amblp = amblist; *amblp != NULL; amblp++) |
250 |
if (!strcmp(o->oname, *amblp)) { |
251 |
if (ambset[0] >= MAXASET) { |
252 |
error(WARNING, "too many modifiers in ambient list"); |
253 |
hitlimit++; |
254 |
return; /* should this be fatal? */ |
255 |
256 |
insertelem(ambset, obj); |
257 |
return; |
258 |
259 |
260 |
261 |
/************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/ |
262 |
263 |
#ifndef OLDAMB |
264 |
265 |
#define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr))) |
266 |
267 |
static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang); |
268 |
static double sumambient(COLOR acol, RAY *r, FVECT rn, int al, |
269 |
AMBTREE *at, FVECT c0, double s); |
270 |
static int makeambient(COLOR acol, RAY *r, FVECT rn, int al); |
271 |
static int extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv, |
272 |
FVECT uvw[3]); |
273 |
274 |
void |
275 |
multambient( /* compute ambient component & multiply by coef. */ |
276 |
COLOR aval, |
277 |
RAY *r, |
278 |
FVECT nrm |
279 |
280 |
281 |
static int rdepth = 0; /* ambient recursion */ |
282 |
COLOR acol, caustic; |
283 |
int ok; |
284 |
double d, l; |
285 |
286 |
/* PMAP: Factor in ambient from photon map, if enabled and ray is |
287 |
* ambient. Return as all ambient components accounted for, else |
288 |
* continue. */ |
289 |
if (ambPmap(aval, r, rdepth)) |
290 |
return; |
291 |
292 |
/* PMAP: Factor in specular-diffuse ambient (caustics) from photon |
293 |
* map, if enabled and ray is primary, else caustic is zero. Continue |
294 |
* with RADIANCE ambient calculation */ |
295 |
copycolor(caustic, aval); |
296 |
ambPmapCaustic(caustic, r, rdepth); |
297 |
298 |
if (ambdiv <= 0) /* no ambient calculation */ |
299 |
goto dumbamb; |
300 |
/* check number of bounces */ |
301 |
if (rdepth >= ambounce) |
302 |
goto dumbamb; |
303 |
/* check ambient list */ |
304 |
if (ambincl != -1 && r->ro != NULL && |
305 |
ambincl != inset(ambset, r->ro->omod)) |
306 |
goto dumbamb; |
307 |
308 |
if (ambacc <= FTINY) { /* no ambient storage */ |
309 |
copycolor(acol, aval); |
310 |
rdepth++; |
311 |
ok = doambient(acol, r, r->rweight, |
312 |
NULL, NULL, NULL, NULL, NULL); |
313 |
rdepth--; |
314 |
if (!ok) |
315 |
goto dumbamb; |
316 |
copycolor(aval, acol); |
317 |
318 |
/* PMAP: add in caustic */ |
319 |
addcolor(aval, caustic); |
320 |
return; |
321 |
322 |
323 |
if (tracktime) /* sort to minimize thrashing */ |
324 |
sortambvals(0); |
325 |
/* interpolate ambient value */ |
326 |
setcolor(acol, 0.0, 0.0, 0.0); |
327 |
d = sumambient(acol, r, nrm, rdepth, |
328 |
&atrunk, thescene.cuorg, thescene.cusize); |
329 |
330 |
if (d > FTINY) { |
331 |
d = 1.0/d; |
332 |
scalecolor(acol, d); |
333 |
multcolor(aval, acol); |
334 |
335 |
336 |
337 |
return; |
338 |
339 |
340 |
rdepth++; /* need to cache new value */ |
341 |
ok = makeambient(acol, r, nrm, rdepth-1); |
342 |
rdepth--; |
343 |
344 |
if (ok) { |
345 |
multcolor(aval, acol); /* computed new value */ |
346 |
347 |
348 |
349 |
return; |
350 |
351 |
352 |
dumbamb: /* return global value */ |
353 |
if ((ambvwt <= 0) | (navsum == 0)) { |
354 |
multcolor(aval, ambval); |
355 |
356 |
357 |
358 |
return; |
359 |
360 |
361 |
l = bright(ambval); /* average in computations */ |
362 |
if (l > FTINY) { |
363 |
d = (log(l)*(double)ambvwt + avsum) / |
364 |
(double)(ambvwt + navsum); |
365 |
d = exp(d) / l; |
366 |
scalecolor(aval, d); |
367 |
multcolor(aval, ambval); /* apply color of ambval */ |
368 |
} else { |
369 |
d = exp( avsum / (double)navsum ); |
370 |
scalecolor(aval, d); /* neutral color */ |
371 |
372 |
373 |
374 |
375 |
/* Plug a potential leak where ambient cache value is occluded */ |
376 |
static int |
377 |
plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang) |
378 |
379 |
const double cost70sq = 0.1169778; /* cos(70deg)^2 */ |
380 |
RAY rtst; |
381 |
FVECT vdif; |
382 |
double normdot, ndotd, nadotd; |
383 |
double a, b, c, t[2]; |
384 |
385 |
ang += 2.*PI*(ang < 0); /* check direction flags */ |
386 |
if ( !(ap->corral>>(int)(ang*(16./PI)) & 1) ) |
387 |
return(0); |
388 |
389 |
* Generate test ray, targeting 20 degrees above sample point plane |
390 |
* along surface normal from cache position. This should be high |
391 |
* enough to miss local geometry we don't really care about. |
392 |
393 |
VSUB(vdif, ap->pos, r->rop); |
394 |
normdot = DOT(anorm, r->ron); |
395 |
ndotd = DOT(vdif, r->ron); |
396 |
nadotd = DOT(vdif, anorm); |
397 |
a = normdot*normdot - cost70sq; |
398 |
b = 2.0*(normdot*ndotd - nadotd*cost70sq); |
399 |
c = ndotd*ndotd - DOT(vdif,vdif)*cost70sq; |
400 |
if (quadratic(t, a, b, c) != 2) |
401 |
return(1); /* should rarely happen */ |
402 |
if (t[1] <= FTINY) |
403 |
return(0); /* should fail behind test */ |
404 |
rayorigin(&rtst, SHADOW, r, NULL); |
405 |
VSUM(rtst.rdir, vdif, anorm, t[1]); /* further dist. > plane */ |
406 |
rtst.rmax = normalize(rtst.rdir); /* short ray test */ |
407 |
while (localhit(&rtst, &thescene)) { /* check for occluder */ |
408 |
if (rtst.ro->omod != OVOID && |
409 |
(rtst.clipset == NULL || |
410 |
!inset(rtst.clipset, rtst.ro->omod))) |
411 |
return(1); /* plug light leak */ |
412 |
VCOPY(rtst.rorg, rtst.rop); /* skip invisible surface */ |
413 |
rtst.rmax -= rtst.rot; |
414 |
rayclear(&rtst); |
415 |
416 |
return(0); /* seems we're OK */ |
417 |
418 |
419 |
420 |
static double |
421 |
sumambient( /* get interpolated ambient value */ |
422 |
COLOR acol, |
423 |
RAY *r, |
424 |
FVECT rn, |
425 |
int al, |
426 |
AMBTREE *at, |
427 |
FVECT c0, |
428 |
double s |
429 |
430 |
{ /* initial limit is 10 degrees plus ambacc radians */ |
431 |
const double minangle = 10.0 * PI/180.; |
432 |
double maxangle = minangle + ambacc; |
433 |
double wsum = 0.0; |
434 |
FVECT ck0; |
435 |
int i, j; |
436 |
AMBVAL *av; |
437 |
438 |
if (at->kid != NULL) { /* sum children first */ |
439 |
s *= 0.5; |
440 |
for (i = 0; i < 8; i++) { |
441 |
for (j = 0; j < 3; j++) { |
442 |
ck0[j] = c0[j]; |
443 |
if (1<<j & i) |
444 |
ck0[j] += s; |
445 |
if (r->rop[j] < ck0[j] - OCTSCALE*s) |
446 |
break; |
447 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) |
448 |
break; |
449 |
450 |
if (j == 3) |
451 |
wsum += sumambient(acol, r, rn, al, |
452 |
at->kid+i, ck0, s); |
453 |
454 |
/* good enough? */ |
455 |
if (wsum >= 0.05 && s > minarad*10.0) |
456 |
return(wsum); |
457 |
458 |
/* adjust maximum angle */ |
459 |
if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6)) |
460 |
maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.; |
461 |
/* sum this node */ |
462 |
for (av = at->alist; av != NULL; av = av->next) { |
463 |
double u, v, d, delta_r2, delta_t2; |
464 |
COLOR ct; |
465 |
FVECT uvw[3]; |
466 |
/* record access */ |
467 |
if (tracktime) |
468 |
av->latick = ambclock; |
469 |
470 |
* Ambient level test |
471 |
472 |
if (av->lvl > al || /* list sorted, so this works */ |
473 |
(av->lvl == al) & (av->weight < 0.9*r->rweight)) |
474 |
break; |
475 |
476 |
* Direction test using unperturbed normal |
477 |
478 |
decodedir(uvw[2], av->ndir); |
479 |
d = DOT(uvw[2], r->ron); |
480 |
if (d <= 0.0) /* >= 90 degrees */ |
481 |
continue; |
482 |
delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */ |
483 |
if (delta_r2 >= maxangle*maxangle) |
484 |
continue; |
485 |
486 |
* Modified ray behind test |
487 |
488 |
VSUB(ck0, r->rop, av->pos); |
489 |
d = DOT(ck0, uvw[2]); |
490 |
if (d < -minarad*ambacc-.001) |
491 |
continue; |
492 |
d /= av->rad[0]; |
493 |
delta_t2 = d*d; |
494 |
if (delta_t2 >= ambacc*ambacc) |
495 |
continue; |
496 |
497 |
* Elliptical radii test based on Hessian |
498 |
499 |
decodedir(uvw[0], av->udir); |
500 |
VCROSS(uvw[1], uvw[2], uvw[0]); |
501 |
d = (u = DOT(ck0, uvw[0])) / av->rad[0]; |
502 |
delta_t2 += d*d; |
503 |
d = (v = DOT(ck0, uvw[1])) / av->rad[1]; |
504 |
delta_t2 += d*d; |
505 |
506 |
continue; |
507 |
508 |
* Test for potential light leak |
509 |
510 |
if (av->corral && plugaleak(r, av, uvw[2], atan2a(v,u))) |
511 |
continue; |
512 |
513 |
* Extrapolate value and compute final weight (hat function) |
514 |
515 |
if (!extambient(ct, av, r->rop, rn, uvw)) |
516 |
continue; |
517 |
d = tfunc(maxangle, sqrt(delta_r2), 0.0) * |
518 |
tfunc(ambacc, sqrt(delta_t2), 0.0); |
519 |
scalecolor(ct, d); |
520 |
addcolor(acol, ct); |
521 |
wsum += d; |
522 |
523 |
return(wsum); |
524 |
525 |
526 |
527 |
static int |
528 |
makeambient( /* make a new ambient value for storage */ |
529 |
COLOR acol, |
530 |
RAY *r, |
531 |
FVECT rn, |
532 |
int al |
533 |
534 |
535 |
AMBVAL amb; |
536 |
FVECT uvw[3]; |
537 |
int i; |
538 |
539 |
amb.weight = 1.0; /* compute weight */ |
540 |
for (i = al; i-- > 0; ) |
541 |
amb.weight *= AVGREFL; |
542 |
if (r->rweight < 0.1*amb.weight) /* heuristic override */ |
543 |
amb.weight = 1.25*r->rweight; |
544 |
setcolor(acol, AVGREFL, AVGREFL, AVGREFL); |
545 |
/* compute ambient */ |
546 |
i = doambient(acol, r, amb.weight, |
547 |
uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral); |
548 |
scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */ |
549 |
if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */ |
550 |
return(i); |
551 |
/* store value */ |
552 |
VCOPY(amb.pos, r->rop); |
553 |
amb.ndir = encodedir(r->ron); |
554 |
amb.udir = encodedir(uvw[0]); |
555 |
amb.lvl = al; |
556 |
copycolor(amb.val, acol); |
557 |
/* insert into tree */ |
558 |
avsave(&amb); /* and save to file */ |
559 |
if (rn != r->ron) { /* texture */ |
560 |
VCOPY(uvw[2], r->ron); |
561 |
extambient(acol, &amb, r->rop, rn, uvw); |
562 |
563 |
return(1); |
564 |
565 |
566 |
567 |
static int |
568 |
extambient( /* extrapolate value at pv, nv */ |
569 |
COLOR cr, |
570 |
AMBVAL *ap, |
571 |
FVECT pv, |
572 |
FVECT nv, |
573 |
FVECT uvw[3] |
574 |
575 |
576 |
const double min_d = 0.05; |
577 |
static FVECT my_uvw[3]; |
578 |
FVECT v1; |
579 |
int i; |
580 |
double d = 1.0; /* zeroeth order */ |
581 |
582 |
if (uvw == NULL) { /* need local coordinates? */ |
583 |
decodedir(my_uvw[2], ap->ndir); |
584 |
decodedir(my_uvw[0], ap->udir); |
585 |
VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]); |
586 |
uvw = my_uvw; |
587 |
588 |
for (i = 3; i--; ) /* gradient due to translation */ |
589 |
d += (pv[i] - ap->pos[i]) * |
590 |
(ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]); |
591 |
592 |
VCROSS(v1, uvw[2], nv); /* gradient due to rotation */ |
593 |
for (i = 3; i--; ) |
594 |
d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]); |
595 |
596 |
if (d < min_d) /* should not use if we can avoid it */ |
597 |
d = min_d; |
598 |
copycolor(cr, ap->val); |
599 |
scalecolor(cr, d); |
600 |
return(d > min_d); |
601 |
602 |
603 |
604 |
static void |
605 |
avinsert( /* insert ambient value in our tree */ |
606 |
AMBVAL *av |
607 |
608 |
609 |
AMBTREE *at; |
610 |
AMBVAL *ap; |
611 |
AMBVAL avh; |
612 |
FVECT ck0; |
613 |
double s; |
614 |
int branch; |
615 |
int i; |
616 |
617 |
if (av->rad[0] <= FTINY) |
618 |
error(CONSISTENCY, "zero ambient radius in avinsert"); |
619 |
at = &atrunk; |
620 |
VCOPY(ck0, thescene.cuorg); |
621 |
s = thescene.cusize; |
622 |
while (s*(OCTSCALE/2) > av->rad[1]*ambacc) { |
623 |
if (at->kid == NULL) |
624 |
if ((at->kid = newambtree()) == NULL) |
625 |
error(SYSTEM, "out of memory in avinsert"); |
626 |
s *= 0.5; |
627 |
branch = 0; |
628 |
for (i = 0; i < 3; i++) |
629 |
if (av->pos[i] > ck0[i] + s) { |
630 |
ck0[i] += s; |
631 |
branch |= 1 << i; |
632 |
633 |
at = at->kid + branch; |
634 |
635 |
avh.next = at->alist; /* order by increasing level */ |
636 |
for (ap = &avh; ap->next != NULL; ap = ap->next) |
637 |
if ( ap->next->lvl > av->lvl || |
638 |
(ap->next->lvl == av->lvl) & |
639 |
(ap->next->weight <= av->weight) ) |
640 |
break; |
641 |
av->next = ap->next; |
642 |
ap->next = (AMBVAL*)av; |
643 |
at->alist = avh.next; |
644 |
645 |
646 |
647 |
#else /* ! NEWAMB */ |
648 |
649 |
650 |
651 |
static double makeambient(COLOR acol, RAY *r, FVECT rn, int al); |
652 |
static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv); |
653 |
654 |
655 |
void |
656 |
657 |
COLOR aval, |
658 |
RAY *r, |
659 |
FVECT nrm |
660 |
661 |
662 |
663 |
664 |
double d, l; |
665 |
666 |
/* PMAP: Factor in ambient from global photon map (if enabled) and return |
667 |
* as all ambient components accounted for */ |
668 |
669 |
return; |
670 |
671 |
/* PMAP: Otherwise factor in ambient from caustic photon map |
672 |
* (ambPmapCaustic() returns zero if caustic photons disabled) and |
673 |
* continue with RADIANCE ambient calculation */ |
674 |
675 |
676 |
677 |
678 |
goto dumbamb; |
679 |
680 |
681 |
goto dumbamb; |
682 |
683 |
684 |
685 |
goto dumbamb; |
686 |
687 |
688 |
689 |
rdepth++; |
690 |
d = doambient(acol, r, r->rweight, NULL, NULL); |
691 |
rdepth--; |
692 |
if (d <= FTINY) |
693 |
goto dumbamb; |
694 |
695 |
696 |
697 |
698 |
return; |
699 |
700 |
701 |
702 |
sortambvals(0); |
703 |
704 |
705 |
706 |
707 |
708 |
if (d > FTINY) { |
709 |
d = 1.0/d; |
710 |
711 |
712 |
713 |
714 |
715 |
return; |
716 |
717 |
718 |
719 |
d = makeambient(acol, r, nrm, rdepth-1); |
720 |
rdepth--; |
721 |
722 |
if (d > FTINY) { |
723 |
multcolor(aval, acol); /* got new value */ |
724 |
725 |
726 |
727 |
return; |
728 |
729 |
730 |
731 |
732 |
733 |
734 |
735 |
736 |
return; |
737 |
738 |
739 |
740 |
if (l > FTINY) { |
741 |
742 |
743 |
d = exp(d) / l; |
744 |
745 |
746 |
} else { |
747 |
748 |
749 |
750 |
751 |
752 |
753 |
static double |
754 |
755 |
COLOR acol, |
756 |
RAY *r, |
757 |
FVECT rn, |
758 |
int al, |
759 |
AMBTREE *at, |
760 |
FVECT c0, |
761 |
double s |
762 |
763 |
764 |
double d, e1, e2, wt, wsum; |
765 |
COLOR ct; |
766 |
FVECT ck0; |
767 |
int i; |
768 |
int j; |
769 |
AMBVAL *av; |
770 |
771 |
wsum = 0.0; |
772 |
/* do this node */ |
773 |
774 |
double rn_dot = -2.0; |
775 |
if (tracktime) |
776 |
777 |
778 |
* Ambient level test. |
779 |
780 |
781 |
782 |
break; |
783 |
784 |
* Ambient radius test. |
785 |
786 |
VSUB(ck0, av->pos, r->rop); |
787 |
e1 = DOT(ck0, ck0) / (av->rad * av->rad); |
788 |
if (e1 > ambacc*ambacc*1.21) |
789 |
continue; |
790 |
791 |
* Direction test using closest normal. |
792 |
793 |
d = DOT(av->dir, r->ron); |
794 |
if (rn != r->ron) { |
795 |
rn_dot = DOT(av->dir, rn); |
796 |
if (rn_dot > 1.0-FTINY) |
797 |
rn_dot = 1.0-FTINY; |
798 |
if (rn_dot >= d-FTINY) { |
799 |
d = rn_dot; |
800 |
rn_dot = -2.0; |
801 |
802 |
803 |
e2 = (1.0 - d) * r->rweight; |
804 |
if (e2 < 0.0) |
805 |
e2 = 0.0; |
806 |
else if (e1 + e2 > ambacc*ambacc*1.21) |
807 |
continue; |
808 |
809 |
* Ray behind test. |
810 |
811 |
d = 0.0; |
812 |
for (j = 0; j < 3; j++) |
813 |
d += (r->rop[j] - av->pos[j]) * |
814 |
(av->dir[j] + r->ron[j]); |
815 |
if (d*0.5 < -minarad*ambacc-.001) |
816 |
continue; |
817 |
818 |
* Jittering final test reduces image artifacts. |
819 |
820 |
e1 = sqrt(e1); |
821 |
e2 = sqrt(e2); |
822 |
wt = e1 + e2; |
823 |
if (wt > ambacc*(.9+.2*urand(9015+samplendx))) |
824 |
continue; |
825 |
826 |
* Recompute directional error using perturbed normal |
827 |
828 |
if (rn_dot > 0.0) { |
829 |
e2 = sqrt((1.0 - rn_dot)*r->rweight); |
830 |
wt = e1 + e2; |
831 |
832 |
if (wt <= 1e-3) |
833 |
wt = 1e3; |
834 |
else |
835 |
wt = 1.0 / wt; |
836 |
wsum += wt; |
837 |
extambient(ct, av, r->rop, rn); |
838 |
scalecolor(ct, wt); |
839 |
840 |
841 |
842 |
return(wsum); |
843 |
/* do children */ |
844 |
s *= 0.5; |
845 |
846 |
847 |
ck0[j] = c0[j]; |
848 |
if (1<<j & i) |
849 |
ck0[j] += s; |
850 |
851 |
break; |
852 |
853 |
break; |
854 |
855 |
if (j == 3) |
856 |
857 |
858 |
859 |
return(wsum); |
860 |
861 |
862 |
863 |
static double |
864 |
865 |
COLOR acol, |
866 |
RAY *r, |
867 |
FVECT rn, |
868 |
int al |
869 |
870 |
871 |
AMBVAL amb; |
872 |
FVECT gp, gd; |
873 |
int i; |
874 |
875 |
876 |
877 |
878 |
879 |
880 |
881 |
882 |
amb.rad = doambient(acol, r, amb.weight, gp, gd); |
883 |
if (amb.rad <= FTINY) { |
884 |
885 |
return(0.0); |
886 |
887 |
888 |
/* store value */ |
889 |
890 |
VCOPY(amb.dir, r->ron); |
891 |
amb.lvl = al; |
892 |
893 |
VCOPY(amb.gpos, gp); |
894 |
VCOPY(amb.gdir, gd); |
895 |
896 |
897 |
if (rn != r->ron) |
898 |
extambient(acol, &amb, r->rop, rn); /* texture */ |
899 |
return(amb.rad); |
900 |
901 |
902 |
903 |
static void |
904 |
905 |
COLOR cr, |
906 |
AMBVAL *ap, |
907 |
FVECT pv, |
908 |
FVECT nv |
909 |
910 |
911 |
FVECT v1; |
912 |
int i; |
913 |
double d; |
914 |
915 |
916 |
917 |
918 |
d += ap->gpos[i]*(pv[i]-ap->pos[i]); |
919 |
920 |
VCROSS(v1, ap->dir, nv); |
921 |
d += DOT(ap->gdir, v1); |
922 |
if (d <= 0.0) { |
923 |
setcolor(cr, 0.0, 0.0, 0.0); |
924 |
return; |
925 |
926 |
927 |
928 |
929 |
930 |
931 |
static void |
932 |
933 |
AMBVAL *av |
934 |
935 |
936 |
AMBTREE *at; |
937 |
AMBVAL *ap; |
938 |
AMBVAL avh; |
939 |
FVECT ck0; |
940 |
double s; |
941 |
int branch; |
942 |
int i; |
943 |
944 |
if (av->rad <= FTINY) |
945 |
946 |
at = &atrunk; |
947 |
948 |
949 |
while (s*(OCTSCALE/2) > av->rad*ambacc) { |
950 |
951 |
952 |
953 |
s *= 0.5; |
954 |
branch = 0; |
955 |
956 |
957 |
ck0[i] += s; |
958 |
branch |= 1 << i; |
959 |
960 |
961 |
962 |
963 |
964 |
965 |
966 |
967 |
break; |
968 |
969 |
970 |
971 |
972 |
973 |
#endif /* ! NEWAMB */ |
974 |
975 |
/************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/ |
976 |
977 |
static void |
978 |
initambfile( /* initialize ambient file */ |
979 |
int cre8 |
980 |
981 |
982 |
extern char *progname, *octname; |
983 |
static char *mybuf = NULL; |
984 |
985 |
#ifdef F_SETLKW |
986 |
aflock(cre8 ? F_WRLCK : F_RDLCK); |
987 |
#endif |
988 |
SET_FILE_BINARY(ambfp); |
989 |
if (mybuf == NULL) |
990 |
mybuf = (char *)bmalloc(BUFSIZ+8); |
991 |
setbuf(ambfp, mybuf); |
992 |
if (cre8) { /* new file */ |
993 |
newheader("RADIANCE", ambfp); |
994 |
fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ", |
995 |
progname, colval(ambval,RED), |
996 |
colval(ambval,GRN), colval(ambval,BLU), |
997 |
ambvwt, ambounce, ambacc); |
998 |
fprintf(ambfp, "-ad %d -as %d -ar %d ", |
999 |
ambdiv, ambssamp, ambres); |
1000 |
if (octname != NULL) |
1001 |
fputs(octname, ambfp); |
1002 |
fputc('\n', ambfp); |
1003 |
fprintf(ambfp, "SOFTWARE= %s\n", VersionID); |
1004 |
fputnow(ambfp); |
1005 |
fputformat(AMBFMT, ambfp); |
1006 |
1007 |
putambmagic(ambfp); |
1008 |
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) |
1009 |
error(USER, "bad ambient file"); |
1010 |
1011 |
1012 |
1013 |
static void |
1014 |
avsave( /* insert and save an ambient value */ |
1015 |
AMBVAL *av |
1016 |
1017 |
1018 |
avstore(av); |
1019 |
if (ambfp == NULL) |
1020 |
return; |
1021 |
if (writambval(av, ambfp) < 0) |
1022 |
goto writerr; |
1023 |
if (++nunflshed >= AMBFLUSH) |
1024 |
if (ambsync() == EOF) |
1025 |
goto writerr; |
1026 |
return; |
1027 |
writerr: |
1028 |
error(SYSTEM, "error writing to ambient file"); |
1029 |
1030 |
1031 |
1032 |
static AMBVAL * |
1033 |
avstore( /* allocate memory and save aval */ |
1034 |
AMBVAL *aval |
1035 |
1036 |
1037 |
AMBVAL *av; |
1038 |
double d; |
1039 |
1040 |
if ((av = newambval()) == NULL) |
1041 |
error(SYSTEM, "out of memory in avstore"); |
1042 |
*av = *aval; |
1043 |
1044 |
av->next = NULL; |
1045 |
nambvals++; |
1046 |
d = bright(av->val); |
1047 |
if (d > FTINY) { /* add to log sum for averaging */ |
1048 |
avsum += log(d); |
1049 |
navsum++; |
1050 |
1051 |
avinsert(av); /* insert in our cache tree */ |
1052 |
return(av); |
1053 |
1054 |
1055 |
1056 |
#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ |
1057 |
1058 |
static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ |
1059 |
1060 |
1061 |
static AMBTREE * |
1062 |
newambtree(void) /* allocate 8 ambient tree structs */ |
1063 |
1064 |
AMBTREE *atp, *upperlim; |
1065 |
1066 |
if (atfreelist == NULL) { /* get more nodes */ |
1067 |
atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE)); |
1068 |
if (atfreelist == NULL) |
1069 |
return(NULL); |
1070 |
/* link new free list */ |
1071 |
upperlim = atfreelist + 8*(ATALLOCSZ-1); |
1072 |
for (atp = atfreelist; atp < upperlim; atp += 8) |
1073 |
atp->kid = atp + 8; |
1074 |
atp->kid = NULL; |
1075 |
1076 |
atp = atfreelist; |
1077 |
atfreelist = atp->kid; |
1078 |
memset((char *)atp, '\0', 8*sizeof(AMBTREE)); |
1079 |
return(atp); |
1080 |
1081 |
1082 |
1083 |
static void |
1084 |
freeambtree( /* free 8 ambient tree structs */ |
1085 |
AMBTREE *atp |
1086 |
1087 |
1088 |
if (atp == NULL) { /* freeing free list? */ |
1089 |
while ((atp = atfreelist) != NULL) { |
1090 |
1091 |
free(atp); |
1092 |
1093 |
return; |
1094 |
1095 |
atp->kid = atfreelist; /* else push node onto free list */ |
1096 |
atfreelist = atp; |
1097 |
1098 |
1099 |
1100 |
static void |
1101 |
unloadatree( /* unload an ambient value tree */ |
1102 |
AMBTREE *at, |
1103 |
unloadtf_t *f |
1104 |
1105 |
1106 |
AMBVAL *av; |
1107 |
int i; |
1108 |
/* transfer values at this node */ |
1109 |
for (av = at->alist; av != NULL; av = at->alist) { |
1110 |
at->alist = av->next; |
1111 |
(*f)(av); |
1112 |
1113 |
1114 |
return; |
1115 |
for (i = 0; i < 8; i++) /* transfer and free children */ |
1116 |
unloadatree(at->kid+i, f); |
1117 |
freeambtree(at->kid); |
1118 |
at->kid = NULL; |
1119 |
1120 |
1121 |
1122 |
static struct avl { |
1123 |
AMBVAL *p; |
1124 |
unsigned long t; |
1125 |
} *avlist1; /* ambient value list with ticks */ |
1126 |
static AMBVAL **avlist2; /* memory positions for sorting */ |
1127 |
static int i_avlist; /* index for lists */ |
1128 |
1129 |
static int alatcmp(const void *av1, const void *av2); |
1130 |
1131 |
static void |
1132 |
avfree(AMBVAL *av) |
1133 |
1134 |
free(av); |
1135 |
1136 |
1137 |
static void |
1138 |
av2list( |
1139 |
AMBVAL *av |
1140 |
1141 |
1142 |
#ifdef DEBUG |
1143 |
if (i_avlist >= nambvals) |
1144 |
error(CONSISTENCY, "too many ambient values in av2list1"); |
1145 |
#endif |
1146 |
avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av; |
1147 |
avlist1[i_avlist++].t = av->latick; |
1148 |
1149 |
1150 |
1151 |
static int |
1152 |
alatcmp( /* compare ambient values for MRA */ |
1153 |
const void *av1, |
1154 |
const void *av2 |
1155 |
1156 |
1157 |
long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t; |
1158 |
return(lc<0 ? -1 : lc>0 ? 1 : 0); |
1159 |
1160 |
1161 |
1162 |
/* GW NOTE 2002/10/3: |
1163 |
* I used to compare AMBVAL pointers, but found that this was the |
1164 |
* cause of a serious consistency error with gcc, since the optimizer |
1165 |
* uses some dangerous trick in pointer subtraction that |
1166 |
* assumes pointers differ by exact struct size increments. |
1167 |
1168 |
static int |
1169 |
aposcmp( /* compare ambient value positions */ |
1170 |
const void *avp1, |
1171 |
const void *avp2 |
1172 |
1173 |
1174 |
long diff = *(char * const *)avp1 - *(char * const *)avp2; |
1175 |
if (diff < 0) |
1176 |
return(-1); |
1177 |
return(diff > 0); |
1178 |
1179 |
1180 |
1181 |
static int |
1182 |
avlmemi( /* find list position from address */ |
1183 |
AMBVAL *avaddr |
1184 |
1185 |
1186 |
AMBVAL **avlpp; |
1187 |
1188 |
avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, |
1189 |
nambvals, sizeof(AMBVAL *), &aposcmp); |
1190 |
if (avlpp == NULL) |
1191 |
error(CONSISTENCY, "address not found in avlmemi"); |
1192 |
return(avlpp - avlist2); |
1193 |
1194 |
1195 |
1196 |
static void |
1197 |
sortambvals( /* resort ambient values */ |
1198 |
int always |
1199 |
1200 |
1201 |
AMBTREE oldatrunk; |
1202 |
AMBVAL tav, *tap, *pnext; |
1203 |
int i, j; |
1204 |
/* see if it's time yet */ |
1205 |
if (!always && (ambclock++ < lastsort+sortintvl || |
1206 |
nambvals < SORT_THRESH)) |
1207 |
return; |
1208 |
1209 |
* The idea here is to minimize memory thrashing |
1210 |
* in VM systems by improving reference locality. |
1211 |
* We do this by periodically sorting our stored ambient |
1212 |
* values in memory in order of most recently to least |
1213 |
* recently accessed. This ordering was chosen so that new |
1214 |
* ambient values (which tend to be less important) go into |
1215 |
* higher memory with the infrequently accessed values. |
1216 |
* Since we expect our values to need sorting less |
1217 |
* frequently as the process continues, we double our |
1218 |
* waiting interval after each call. |
1219 |
* This routine is also called by setambacc() with |
1220 |
* the "always" parameter set to 1 so that the ambient |
1221 |
* tree will be rebuilt with the new accuracy parameter. |
1222 |
1223 |
if (tracktime) { /* allocate pointer arrays to sort */ |
1224 |
avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); |
1225 |
avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl)); |
1226 |
} else { |
1227 |
avlist2 = NULL; |
1228 |
avlist1 = NULL; |
1229 |
1230 |
if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */ |
1231 |
if (avlist2 != NULL) |
1232 |
free((void *)avlist2); |
1233 |
if (always) { /* rebuild without sorting */ |
1234 |
oldatrunk = atrunk; |
1235 |
atrunk.alist = NULL; |
1236 |
atrunk.kid = NULL; |
1237 |
unloadatree(&oldatrunk, avinsert); |
1238 |
1239 |
} else { /* sort memory by last access time */ |
1240 |
1241 |
* Sorting memory is tricky because it isn't contiguous. |
1242 |
* We have to sort an array of pointers by MRA and also |
1243 |
* by memory position. We then copy values in "loops" |
1244 |
* to minimize memory hits. Nevertheless, we will visit |
1245 |
* everyone at least twice, and this is an expensive process |
1246 |
* when we're thrashing, which is when we need to do it. |
1247 |
1248 |
#ifdef DEBUG |
1249 |
sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", |
1250 |
nambvals, ambclock); |
1251 |
eputs(errmsg); |
1252 |
#endif |
1253 |
i_avlist = 0; |
1254 |
unloadatree(&atrunk, av2list); /* empty current tree */ |
1255 |
#ifdef DEBUG |
1256 |
if (i_avlist < nambvals) |
1257 |
error(CONSISTENCY, "missing ambient values in sortambvals"); |
1258 |
#endif |
1259 |
qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp); |
1260 |
qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); |
1261 |
for (i = 0; i < nambvals; i++) { |
1262 |
if (avlist1[i].p == NULL) |
1263 |
continue; |
1264 |
tap = avlist2[i]; |
1265 |
tav = *tap; |
1266 |
for (j = i; (pnext = avlist1[j].p) != tap; |
1267 |
j = avlmemi(pnext)) { |
1268 |
*(avlist2[j]) = *pnext; |
1269 |
avinsert(avlist2[j]); |
1270 |
avlist1[j].p = NULL; |
1271 |
1272 |
*(avlist2[j]) = tav; |
1273 |
1274 |
1275 |
1276 |
free((void *)avlist1); |
1277 |
1278 |
/* compute new sort interval */ |
1279 |
sortintvl = ambclock - lastsort; |
1280 |
if (sortintvl >= MAX_SORT_INTVL/2) |
1281 |
sortintvl = MAX_SORT_INTVL; |
1282 |
else |
1283 |
sortintvl <<= 1; /* wait twice as long next */ |
1284 |
#ifdef DEBUG |
1285 |
eputs("done\n"); |
1286 |
#endif |
1287 |
1288 |
if (ambclock >= MAXACLOCK) |
1289 |
ambclock = MAXACLOCK/2; |
1290 |
lastsort = ambclock; |
1291 |
1292 |
1293 |
1294 |
#ifdef F_SETLKW |
1295 |
1296 |
static void |
1297 |
aflock( /* lock/unlock ambient file */ |
1298 |
int typ |
1299 |
1300 |
1301 |
static struct flock fls; /* static so initialized to zeroes */ |
1302 |
1303 |
if (typ == fls.l_type) /* already called? */ |
1304 |
return; |
1305 |
fls.l_type = typ; |
1306 |
if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) |
1307 |
error(SYSTEM, "cannot (un)lock ambient file"); |
1308 |
1309 |
1310 |
1311 |
int |
1312 |
ambsync(void) /* synchronize ambient file */ |
1313 |
1314 |
long flen; |
1315 |
AMBVAL avs; |
1316 |
int n; |
1317 |
1318 |
if (ambfp == NULL) /* no ambient file? */ |
1319 |
return(0); |
1320 |
/* gain appropriate access */ |
1321 |
aflock(nunflshed ? F_WRLCK : F_RDLCK); |
1322 |
/* see if file has grown */ |
1323 |
if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0) |
1324 |
goto seekerr; |
1325 |
if ((n = flen - lastpos) > 0) { /* file has grown */ |
1326 |
if (ambinp == NULL) { /* use duplicate filedes */ |
1327 |
ambinp = fdopen(dup(fileno(ambfp)), "r"); |
1328 |
if (ambinp == NULL) |
1329 |
error(SYSTEM, "fdopen failed in ambsync"); |
1330 |
1331 |
if (fseek(ambinp, lastpos, SEEK_SET) < 0) |
1332 |
goto seekerr; |
1333 |
while (n >= AMBVALSIZ) { /* load contributed values */ |
1334 |
if (!readambval(&avs, ambinp)) { |
1335 |
sprintf(errmsg, |
1336 |
"ambient file \"%s\" corrupted near character %ld", |
1337 |
ambfile, flen - n); |
1338 |
1339 |
break; |
1340 |
1341 |
avstore(&avs); |
1342 |
n -= AMBVALSIZ; |
1343 |
1344 |
lastpos = flen - n; |
1345 |
/*** seek always as safety measure |
1346 |
if (n) ***/ /* alignment */ |
1347 |
if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0) |
1348 |
goto seekerr; |
1349 |
1350 |
n = fflush(ambfp); /* calls write() at last */ |
1351 |
if (n != EOF) |
1352 |
lastpos += (long)nunflshed*AMBVALSIZ; |
1353 |
else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0) |
1354 |
goto seekerr; |
1355 |
1356 |
1357 |
nunflshed = 0; |
1358 |
return(n); |
1359 |
seekerr: |
1360 |
error(SYSTEM, "seek failed in ambsync"); |
1361 |
return -1; /* pro forma return */ |
1362 |
1363 |
1364 |
#else /* ! F_SETLKW */ |
1365 |
1366 |
int |
1367 |
ambsync(void) /* flush ambient file */ |
1368 |
1369 |
1370 |
return(0); |
1371 |
nunflshed = 0; |
1372 |
return(fflush(ambfp)); |
1373 |
1374 |
1375 |
#endif /* ! F_SETLKW */ |
