root/radiance/ray/src/rt/ambient.c
Revision: 2.94
Committed: Tue Feb 24 19:39:26 2015 UTC (10 years, 4 months ago) by greg
Changes since 2.93: +63 -7 lines
1 static const char RCSid[] = "$Id: ambient.c,v 4.8 2014/12/01 17:32:56 taschreg Exp taschreg $";
2 /*
3 * ambient.c - routines dealing with ambient (inter-reflected) component.
4 *
5 * Declarations of external symbols in ambient.h
6 */
7
8 #include "copyright.h"
9
10 #include <string.h>
11
12 #include "platform.h"
13 #include "ray.h"
14 #include "otypes.h"
15 #include "resolu.h"
16 #include "ambient.h"
17 #include "random.h"
18 #include "pmapamb.h"
19
20 #ifndef OCTSCALE
21 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
22 #endif
23
24 extern char *shm_boundary; /* memory sharing boundary */
25
26 #ifndef MAXASET
27 #define MAXASET 4095 /* maximum number of elements in ambient set */
28 #endif
29 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
30
31 double maxarad; /* maximum ambient radius */
32 double minarad; /* minimum ambient radius */
33
34 static AMBTREE atrunk; /* our ambient trunk node */
35
36 static FILE *ambfp = NULL; /* ambient file pointer */
37 static int nunflshed = 0; /* number of unflushed ambient values */
38
39 #ifndef SORT_THRESH
40 #ifdef SMLMEM
41 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
42 #else
43 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
44 #endif
45 #endif
46 #ifndef SORT_INTVL
47 #define SORT_INTVL (SORT_THRESH<<1)
48 #endif
49 #ifndef MAX_SORT_INTVL
50 #define MAX_SORT_INTVL (SORT_INTVL<<6)
51 #endif
52
53
54 static double avsum = 0.; /* computed ambient value sum (log) */
55 static unsigned int navsum = 0; /* number of values in avsum */
56 static unsigned int nambvals = 0; /* total number of indirect values */
57 static unsigned int nambshare = 0; /* number of values from file */
58 static unsigned long ambclock = 0; /* ambient access clock */
59 static unsigned long lastsort = 0; /* time of last value sort */
60 static long sortintvl = SORT_INTVL; /* time until next sort */
61 static FILE *ambinp = NULL; /* auxiliary file for input */
62 static long lastpos = -1; /* last flush position */
63
64 #define MAXACLOCK (1L<<30) /* clock turnover value */
65 /*
66 * Track access times unless we are sharing ambient values
67 * through memory on a multiprocessor, when we want to avoid
68 * claiming our own memory (copy on write). Go ahead anyway
69 * if more than two thirds of our values are unshared.
70 * Compile with -Dtracktime=0 to turn this code off.
71 */
72 #ifndef tracktime
73 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
74 #endif
75
76 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
77
78 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
79 #define freeav(av) free((void *)av);
80
81 static void initambfile(int creat);
82 static void avsave(AMBVAL *av);
83 static AMBVAL *avstore(AMBVAL *aval);
84 static AMBTREE *newambtree(void);
85 static void freeambtree(AMBTREE *atp);
86
87 typedef void unloadtf_t(AMBVAL *);
88 static unloadtf_t avinsert;
89 static unloadtf_t av2list;
90 static unloadtf_t avfree;
91 static void unloadatree(AMBTREE *at, unloadtf_t *f);
92
93 static int aposcmp(const void *avp1, const void *avp2);
94 static int avlmemi(AMBVAL *avaddr);
95 static void sortambvals(int always);
96
97 #ifdef F_SETLKW
98 static void aflock(int typ);
99 #endif
100
101
102 void
103 setambres( /* set ambient resolution */
104 int ar
105 )
106 {
107 ambres = ar < 0 ? 0 : ar; /* may be done already */
108 /* set min & max radii */
109 if (ar <= 0) {
110 minarad = 0;
111 maxarad = thescene.cusize*0.2;
112 } else {
113 minarad = thescene.cusize / ar;
114 maxarad = 64.0 * minarad; /* heuristic */
115 if (maxarad > thescene.cusize*0.2)
116 maxarad = thescene.cusize*0.2;
117 }
118 if (minarad <= FTINY)
119 minarad = 10.0*FTINY;
120 if (maxarad <= minarad)
121 maxarad = 64.0 * minarad;
122 }
123
124
125 void
126 setambacc( /* set ambient accuracy */
127 double newa
128 )
129 {
130 static double olda; /* remember previous setting here */
131
132 newa *= (newa > 0);
133 if (fabs(newa - olda) >= .05*(newa + olda)) {
134 ambacc = newa;
135 if (nambvals > 0)
136 sortambvals(1); /* rebuild tree */
137 }
138 }
139
140
141 void
142 setambient(void) /* initialize calculation */
143 {
144 int readonly = 0;
145 long flen;
146 AMBVAL amb;
147 /* make sure we're fresh */
148 ambdone();
149 /* init ambient limits */
150 setambres(ambres);
151 setambacc(ambacc);
152 if (ambfile == NULL || !ambfile[0])
153 return;
154 if (ambacc <= FTINY) {
155 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
156 ambfile);
157 error(WARNING, errmsg);
158 return;
159 }
160 /* open ambient file */
161 if ((ambfp = fopen(ambfile, "r+")) == NULL)
162 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
163 if (ambfp != NULL) {
164 initambfile(0); /* file exists */
165 lastpos = ftell(ambfp);
166 while (readambval(&amb, ambfp))
167 avstore(&amb);
168 nambshare = nambvals; /* share loaded values */
169 if (readonly) {
170 sprintf(errmsg,
171 "loaded %u values from read-only ambient file",
172 nambvals);
173 error(WARNING, errmsg);
174 fclose(ambfp); /* close file so no writes */
175 ambfp = NULL;
176 return; /* avoid ambsync() */
177 }
178 /* align file pointer */
179 lastpos += (long)nambvals*AMBVALSIZ;
180 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
181 if (flen != lastpos) {
182 sprintf(errmsg,
183 "ignoring last %ld values in ambient file (corrupted)",
184 (flen - lastpos)/AMBVALSIZ);
185 error(WARNING, errmsg);
186 fseek(ambfp, lastpos, SEEK_SET);
187 #ifndef _WIN32 /* XXX we need a replacement for that one */
188 ftruncate(fileno(ambfp), (off_t)lastpos);
189 #endif
190 }
191 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
192 initambfile(1); /* else create new file */
193 fflush(ambfp);
194 lastpos = ftell(ambfp);
195 } else {
196 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
197 error(SYSTEM, errmsg);
198 }
199 #ifdef getc_unlocked
200 flockfile(ambfp); /* application-level lock */
201 #endif
202 #ifdef F_SETLKW
203 aflock(F_UNLCK); /* release file */
204 #endif
205 }
206
207
208 void
209 ambdone(void) /* close ambient file and free memory */
210 {
211 if (ambfp != NULL) { /* close ambient file */
212 ambsync();
213 fclose(ambfp);
214 ambfp = NULL;
215 if (ambinp != NULL) {
216 fclose(ambinp);
217 ambinp = NULL;
218 }
219 lastpos = -1;
220 }
221 /* free ambient tree */
222 unloadatree(&atrunk, &avfree);
223 /* reset state variables */
224 avsum = 0.;
225 navsum = 0;
226 nambvals = 0;
227 nambshare = 0;
228 ambclock = 0;
229 lastsort = 0;
230 sortintvl = SORT_INTVL;
231 }
232
233
234 void
235 ambnotify( /* record new modifier */
236 OBJECT obj
237 )
238 {
239 static int hitlimit = 0;
240 OBJREC *o;
241 char **amblp;
242
243 if (obj == OVOID) { /* starting over */
244 ambset[0] = 0;
245 hitlimit = 0;
246 return;
247 }
248 o = objptr(obj);
249 if (hitlimit || !ismodifier(o->otype))
250 return;
251 for (amblp = amblist; *amblp != NULL; amblp++)
252 if (!strcmp(o->oname, *amblp)) {
253 if (ambset[0] >= MAXASET) {
254 error(WARNING, "too many modifiers in ambient list");
255 hitlimit++;
256 return; /* should this be fatal? */
257 }
258 insertelem(ambset, obj);
259 return;
260 }
261 }
262
263 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
264
265 #ifndef OLDAMB
266
267 #define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
268
269 static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang);
270 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
271 AMBTREE *at, FVECT c0, double s);
272 static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
273 static int extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
274 FVECT uvw[3]);
275
276 void
277 multambient( /* compute ambient component & multiply by coef. */
278 COLOR aval,
279 RAY *r,
280 FVECT nrm
281 )
282 {
283 static int rdepth = 0; /* ambient recursion */
284 COLOR acol, caustic;
285 int ok;
286 double d, l;
287
288 /* PMAP: Factor in ambient from photon map, if enabled and ray is
289 * ambient. Return as all ambient components accounted for, else
290 * continue. */
291 if (ambPmap(aval, r, rdepth))
292 return;
293
294 /* PMAP: Factor in specular-diffuse ambient (caustics) from photon
295 * map, if enabled and ray is primary, else caustic is zero. Continue
296 * with RADIANCE ambient calculation */
297 copycolor(caustic, aval);
298 ambPmapCaustic(caustic, r, rdepth);
299
300 if (ambdiv <= 0) /* no ambient calculation */
301 goto dumbamb;
302 /* check number of bounces */
303 if (rdepth >= ambounce)
304 goto dumbamb;
305 /* check ambient list */
306 if (ambincl != -1 && r->ro != NULL &&
307 ambincl != inset(ambset, r->ro->omod))
308 goto dumbamb;
309
310 if (ambacc <= FTINY) { /* no ambient storage */
311 copycolor(acol, aval);
312 rdepth++;
313 ok = doambient(acol, r, r->rweight,
314 NULL, NULL, NULL, NULL, NULL);
315 rdepth--;
316 if (!ok)
317 goto dumbamb;
318 copycolor(aval, acol);
319
320 /* PMAP: add in caustic */
321 addcolor(aval, caustic);
322 return;
323 }
324
325 if (tracktime) /* sort to minimize thrashing */
326 sortambvals(0);
327 /* interpolate ambient value */
328 setcolor(acol, 0.0, 0.0, 0.0);
329 d = sumambient(acol, r, nrm, rdepth,
330 &atrunk, thescene.cuorg, thescene.cusize);
331
332 if (d > FTINY) {
333 d = 1.0/d;
334 scalecolor(acol, d);
335 multcolor(aval, acol);
336
337 /* PMAP: add in caustic */
338 addcolor(aval, caustic);
339 return;
340 }
341
342 rdepth++; /* need to cache new value */
343 ok = makeambient(acol, r, nrm, rdepth-1);
344 rdepth--;
345
346 if (ok) {
347 multcolor(aval, acol); /* computed new value */
348
349 /* PMAP: add in caustic */
350 addcolor(aval, caustic);
351 return;
352 }
353
354 dumbamb: /* return global value */
355 if ((ambvwt <= 0) | (navsum == 0)) {
356 multcolor(aval, ambval);
357
358 /* PMAP: add in caustic */
359 addcolor(aval, caustic);
360 return;
361 }
362
363 l = bright(ambval); /* average in computations */
364 if (l > FTINY) {
365 d = (log(l)*(double)ambvwt + avsum) /
366 (double)(ambvwt + navsum);
367 d = exp(d) / l;
368 scalecolor(aval, d);
369 multcolor(aval, ambval); /* apply color of ambval */
370 } else {
371 d = exp( avsum / (double)navsum );
372 scalecolor(aval, d); /* neutral color */
373 }
374 }
375
376
377 /* Plug a potential leak where ambient cache value is occluded */
378 static int
379 plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang)
380 {
381 const double cost70sq = 0.1169778; /* cos(70deg)^2 */
382 RAY rtst;
383 FVECT vdif;
384 double normdot, ndotd, nadotd;
385 double a, b, c, t[2];
386
387 ang += 2.*PI*(ang < 0); /* check direction flags */
388 if ( !(ap->corral>>(int)(ang*(16./PI)) & 1) )
389 return(0);
390 /*
391 * Generate test ray, targeting 20 degrees above sample point plane
392 * along surface normal from cache position. This should be high
393 * enough to miss local geometry we don't really care about.
394 */
395 VSUB(vdif, ap->pos, r->rop);
396 normdot = DOT(anorm, r->ron);
397 ndotd = DOT(vdif, r->ron);
398 nadotd = DOT(vdif, anorm);
399 a = normdot*normdot - cost70sq;
400 b = 2.0*(normdot*ndotd - nadotd*cost70sq);
401 c = ndotd*ndotd - DOT(vdif,vdif)*cost70sq;
402 if (quadratic(t, a, b, c) != 2)
403 return(1); /* should rarely happen */
404 if (t[1] <= FTINY)
405 return(0); /* should fail behind test */
406 rayorigin(&rtst, SHADOW, r, NULL);
407 VSUM(rtst.rdir, vdif, anorm, t[1]); /* further dist. > plane */
408 rtst.rmax = normalize(rtst.rdir); /* short ray test */
409 while (localhit(&rtst, &thescene)) { /* check for occluder */
410 if (rtst.ro->omod != OVOID &&
411 (rtst.clipset == NULL ||
412 !inset(rtst.clipset, rtst.ro->omod)))
413 return(1); /* plug light leak */
414 VCOPY(rtst.rorg, rtst.rop); /* skip invisible surface */
415 rtst.rmax -= rtst.rot;
416 rayclear(&rtst);
417 }
418 return(0); /* seems we're OK */
419 }
420
421
422 static double
423 sumambient( /* get interpolated ambient value */
424 COLOR acol,
425 RAY *r,
426 FVECT rn,
427 int al,
428 AMBTREE *at,
429 FVECT c0,
430 double s
431 )
432 { /* initial limit is 10 degrees plus ambacc radians */
433 const double minangle = 10.0 * PI/180.;
434 double maxangle = minangle + ambacc;
435 double wsum = 0.0;
436 FVECT ck0;
437 int i, j;
438 AMBVAL *av;
439
440 if (at->kid != NULL) { /* sum children first */
441 s *= 0.5;
442 for (i = 0; i < 8; i++) {
443 for (j = 0; j < 3; j++) {
444 ck0[j] = c0[j];
445 if (1<<j & i)
446 ck0[j] += s;
447 if (r->rop[j] < ck0[j] - OCTSCALE*s)
448 break;
449 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
450 break;
451 }
452 if (j == 3)
453 wsum += sumambient(acol, r, rn, al,
454 at->kid+i, ck0, s);
455 }
456 /* good enough? */
457 if (wsum >= 0.05 && s > minarad*10.0)
458 return(wsum);
459 }
460 /* adjust maximum angle */
461 if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6))
462 maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.;
463 /* sum this node */
464 for (av = at->alist; av != NULL; av = av->next) {
465 double u, v, d, delta_r2, delta_t2;
466 COLOR ct;
467 FVECT uvw[3];
468 /* record access */
469 if (tracktime)
470 av->latick = ambclock;
471 /*
472 * Ambient level test
473 */
474 if (av->lvl > al || /* list sorted, so this works */
475 (av->lvl == al) & (av->weight < 0.9*r->rweight))
476 break;
477 /*
478 * Direction test using unperturbed normal
479 */
480 decodedir(uvw[2], av->ndir);
481 d = DOT(uvw[2], r->ron);
482 if (d <= 0.0) /* >= 90 degrees */
483 continue;
484 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
485 if (delta_r2 >= maxangle*maxangle)
486 continue;
487 /*
488 * Modified ray behind test
489 */
490 VSUB(ck0, r->rop, av->pos);
491 d = DOT(ck0, uvw[2]);
492 if (d < -minarad*ambacc-.001)
493 continue;
494 d /= av->rad[0];
495 delta_t2 = d*d;
496 if (delta_t2 >= ambacc*ambacc)
497 continue;
498 /*
499 * Elliptical radii test based on Hessian
500 */
501 decodedir(uvw[0], av->udir);
502 VCROSS(uvw[1], uvw[2], uvw[0]);
503 d = (u = DOT(ck0, uvw[0])) / av->rad[0];
504 delta_t2 += d*d;
505 d = (v = DOT(ck0, uvw[1])) / av->rad[1];
506 delta_t2 += d*d;
507 if (delta_t2 >= ambacc*ambacc)
508 continue;
509 /*
510 * Test for potential light leak
511 */
512 if (av->corral && plugaleak(r, av, uvw[2], atan2a(v,u)))
513 continue;
514 /*
515 * Extrapolate value and compute final weight (hat function)
516 */
517 if (!extambient(ct, av, r->rop, rn, uvw))
518 continue;
519 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
520 tfunc(ambacc, sqrt(delta_t2), 0.0);
521 scalecolor(ct, d);
522 addcolor(acol, ct);
523 wsum += d;
524 }
525 return(wsum);
526 }
527
528
529 static int
530 makeambient( /* make a new ambient value for storage */
531 COLOR acol,
532 RAY *r,
533 FVECT rn,
534 int al
535 )
536 {
537 AMBVAL amb;
538 FVECT uvw[3];
539 int i;
540
541 amb.weight = 1.0; /* compute weight */
542 for (i = al; i-- > 0; )
543 amb.weight *= AVGREFL;
544 if (r->rweight < 0.1*amb.weight) /* heuristic override */
545 amb.weight = 1.25*r->rweight;
546 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
547 /* compute ambient */
548 i = doambient(acol, r, amb.weight,
549 uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral);
550 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
551 if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
552 return(i);
553 /* store value */
554 VCOPY(amb.pos, r->rop);
555 amb.ndir = encodedir(r->ron);
556 amb.udir = encodedir(uvw[0]);
557 amb.lvl = al;
558 copycolor(amb.val, acol);
559 /* insert into tree */
560 avsave(&amb); /* and save to file */
561 if (rn != r->ron) { /* texture */
562 VCOPY(uvw[2], r->ron);
563 extambient(acol, &amb, r->rop, rn, uvw);
564 }
565 return(1);
566 }
567
568
569 static int
570 extambient( /* extrapolate value at pv, nv */
571 COLOR cr,
572 AMBVAL *ap,
573 FVECT pv,
574 FVECT nv,
575 FVECT uvw[3]
576 )
577 {
578 const double min_d = 0.05;
579 static FVECT my_uvw[3];
580 FVECT v1;
581 int i;
582 double d = 1.0; /* zeroeth order */
583
584 if (uvw == NULL) { /* need local coordinates? */
585 decodedir(my_uvw[2], ap->ndir);
586 decodedir(my_uvw[0], ap->udir);
587 VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
588 uvw = my_uvw;
589 }
590 for (i = 3; i--; ) /* gradient due to translation */
591 d += (pv[i] - ap->pos[i]) *
592 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
593
594 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
595 for (i = 3; i--; )
596 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
597
598 if (d < min_d) /* should not use if we can avoid it */
599 d = min_d;
600 copycolor(cr, ap->val);
601 scalecolor(cr, d);
602 return(d > min_d);
603 }
604
605
606 static void
607 avinsert( /* insert ambient value in our tree */
608 AMBVAL *av
609 )
610 {
611 AMBTREE *at;
612 AMBVAL *ap;
613 AMBVAL avh;
614 FVECT ck0;
615 double s;
616 int branch;
617 int i;
618
619 if (av->rad[0] <= FTINY)
620 error(CONSISTENCY, "zero ambient radius in avinsert");
621 at = &atrunk;
622 VCOPY(ck0, thescene.cuorg);
623 s = thescene.cusize;
624 while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
625 if (at->kid == NULL)
626 if ((at->kid = newambtree()) == NULL)
627 error(SYSTEM, "out of memory in avinsert");
628 s *= 0.5;
629 branch = 0;
630 for (i = 0; i < 3; i++)
631 if (av->pos[i] > ck0[i] + s) {
632 ck0[i] += s;
633 branch |= 1 << i;
634 }
635 at = at->kid + branch;
636 }
637 avh.next = at->alist; /* order by increasing level */
638 for (ap = &avh; ap->next != NULL; ap = ap->next)
639 if ( ap->next->lvl > av->lvl ||
640 (ap->next->lvl == av->lvl) &
641 (ap->next->weight <= av->weight) )
642 break;
643 av->next = ap->next;
644 ap->next = (AMBVAL*)av;
645 at->alist = avh.next;
646 }
647
648
649 #else /* ! NEWAMB */
650
651 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
652 AMBTREE *at, FVECT c0, double s);
653 static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
654 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
655
656
657 void
658 multambient( /* compute ambient component & multiply by coef. */
659 COLOR aval,
660 RAY *r,
661 FVECT nrm
662 )
663 {
664 static int rdepth = 0; /* ambient recursion */
665 COLOR acol, caustic;
666 double d, l;
667
668 /* PMAP: Factor in ambient from global photon map (if enabled) and return
669 * as all ambient components accounted for */
670 if (ambGlobalPmap(aval, r, rdepth))
671 return;
672
673 /* PMAP: Otherwise factor in ambient from caustic photon map
674 * (ambCausticPmap() returns zero if caustic photons disabled) and
675 * continue with RADIANCE ambient calculation */
676 copycolor(caustic, aval);
677 ambCausticPmap(caustic, r, rdepth);
678
679 if (ambdiv <= 0) /* no ambient calculation */
680 goto dumbamb;
681 /* check number of bounces */
682 if (rdepth >= ambounce)
683 goto dumbamb;
684 /* check ambient list */
685 if (ambincl != -1 && r->ro != NULL &&
686 ambincl != inset(ambset, r->ro->omod))
687 goto dumbamb;
688
689 if (ambacc <= FTINY) { /* no ambient storage */
690 copycolor(acol, aval);
691 rdepth++;
692 d = doambient(acol, r, r->rweight, NULL, NULL);
693 rdepth--;
694 if (d <= FTINY)
695 goto dumbamb;
696 copycolor(aval, acol);
697
698 /* PMAP: add in caustic */
699 addcolor(aval, caustic);
700 return;
701 }
702
703 if (tracktime) /* sort to minimize thrashing */
704 sortambvals(0);
705 /* interpolate ambient value */
706 setcolor(acol, 0.0, 0.0, 0.0);
707 d = sumambient(acol, r, nrm, rdepth,
708 &atrunk, thescene.cuorg, thescene.cusize);
709
710 if (d > FTINY) {
711 d = 1.0/d;
712 scalecolor(acol, d);
713 multcolor(aval, acol);
714
715 /* PMAP: add in caustic */
716 addcolor(aval, caustic);
717 return;
718 }
719
720 rdepth++; /* need to cache new value */
721 d = makeambient(acol, r, nrm, rdepth-1);
722 rdepth--;
723
724 if (d > FTINY) {
725 multcolor(aval, acol); /* got new value */
726
727 /* PMAP: add in caustic */
728 addcolor(aval, caustic);
729 return;
730 }
731
732 dumbamb: /* return global value */
733 if ((ambvwt <= 0) | (navsum == 0)) {
734 multcolor(aval, ambval);
735
736 /* PMAP: add in caustic */
737 addcolor(aval, caustic);
738 return;
739 }
740
741 l = bright(ambval); /* average in computations */
742 if (l > FTINY) {
743 d = (log(l)*(double)ambvwt + avsum) /
744 (double)(ambvwt + navsum);
745 d = exp(d) / l;
746 scalecolor(aval, d);
747 multcolor(aval, ambval); /* apply color of ambval */
748 } else {
749 d = exp( avsum / (double)navsum );
750 scalecolor(aval, d); /* neutral color */
751 }
752 }
753
754
755 static double
756 sumambient( /* get interpolated ambient value */
757 COLOR acol,
758 RAY *r,
759 FVECT rn,
760 int al,
761 AMBTREE *at,
762 FVECT c0,
763 double s
764 )
765 {
766 double d, e1, e2, wt, wsum;
767 COLOR ct;
768 FVECT ck0;
769 int i;
770 int j;
771 AMBVAL *av;
772
773 wsum = 0.0;
774 /* do this node */
775 for (av = at->alist; av != NULL; av = av->next) {
776 double rn_dot = -2.0;
777 if (tracktime)
778 av->latick = ambclock;
779 /*
780 * Ambient level test.
781 */
782 if (av->lvl > al || /* list sorted, so this works */
783 (av->lvl == al) & (av->weight < 0.9*r->rweight))
784 break;
785 /*
786 * Ambient radius test.
787 */
788 VSUB(ck0, av->pos, r->rop);
789 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
790 if (e1 > ambacc*ambacc*1.21)
791 continue;
792 /*
793 * Direction test using closest normal.
794 */
795 d = DOT(av->dir, r->ron);
796 if (rn != r->ron) {
797 rn_dot = DOT(av->dir, rn);
798 if (rn_dot > 1.0-FTINY)
799 rn_dot = 1.0-FTINY;
800 if (rn_dot >= d-FTINY) {
801 d = rn_dot;
802 rn_dot = -2.0;
803 }
804 }
805 e2 = (1.0 - d) * r->rweight;
806 if (e2 < 0.0)
807 e2 = 0.0;
808 else if (e1 + e2 > ambacc*ambacc*1.21)
809 continue;
810 /*
811 * Ray behind test.
812 */
813 d = 0.0;
814 for (j = 0; j < 3; j++)
815 d += (r->rop[j] - av->pos[j]) *
816 (av->dir[j] + r->ron[j]);
817 if (d*0.5 < -minarad*ambacc-.001)
818 continue;
819 /*
820 * Jittering final test reduces image artifacts.
821 */
822 e1 = sqrt(e1);
823 e2 = sqrt(e2);
824 wt = e1 + e2;
825 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
826 continue;
827 /*
828 * Recompute directional error using perturbed normal
829 */
830 if (rn_dot > 0.0) {
831 e2 = sqrt((1.0 - rn_dot)*r->rweight);
832 wt = e1 + e2;
833 }
834 if (wt <= 1e-3)
835 wt = 1e3;
836 else
837 wt = 1.0 / wt;
838 wsum += wt;
839 extambient(ct, av, r->rop, rn);
840 scalecolor(ct, wt);
841 addcolor(acol, ct);
842 }
843 if (at->kid == NULL)
844 return(wsum);
845 /* do children */
846 s *= 0.5;
847 for (i = 0; i < 8; i++) {
848 for (j = 0; j < 3; j++) {
849 ck0[j] = c0[j];
850 if (1<<j & i)
851 ck0[j] += s;
852 if (r->rop[j] < ck0[j] - OCTSCALE*s)
853 break;
854 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
855 break;
856 }
857 if (j == 3)
858 wsum += sumambient(acol, r, rn, al,
859 at->kid+i, ck0, s);
860 }
861 return(wsum);
862 }
863
864
865 static double
866 makeambient( /* make a new ambient value for storage */
867 COLOR acol,
868 RAY *r,
869 FVECT rn,
870 int al
871 )
872 {
873 AMBVAL amb;
874 FVECT gp, gd;
875 int i;
876
877 amb.weight = 1.0; /* compute weight */
878 for (i = al; i-- > 0; )
879 amb.weight *= AVGREFL;
880 if (r->rweight < 0.1*amb.weight) /* heuristic override */
881 amb.weight = 1.25*r->rweight;
882 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
883 /* compute ambient */
884 amb.rad = doambient(acol, r, amb.weight, gp, gd);
885 if (amb.rad <= FTINY) {
886 setcolor(acol, 0.0, 0.0, 0.0);
887 return(0.0);
888 }
889 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
890 /* store value */
891 VCOPY(amb.pos, r->rop);
892 VCOPY(amb.dir, r->ron);
893 amb.lvl = al;
894 copycolor(amb.val, acol);
895 VCOPY(amb.gpos, gp);
896 VCOPY(amb.gdir, gd);
897 /* insert into tree */
898 avsave(&amb); /* and save to file */
899 if (rn != r->ron)
900 extambient(acol, &amb, r->rop, rn); /* texture */
901 return(amb.rad);
902 }
903
904
905 static void
906 extambient( /* extrapolate value at pv, nv */
907 COLOR cr,
908 AMBVAL *ap,
909 FVECT pv,
910 FVECT nv
911 )
912 {
913 FVECT v1;
914 int i;
915 double d;
916
917 d = 1.0; /* zeroeth order */
918 /* gradient due to translation */
919 for (i = 0; i < 3; i++)
920 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
921 /* gradient due to rotation */
922 VCROSS(v1, ap->dir, nv);
923 d += DOT(ap->gdir, v1);
924 if (d <= 0.0) {
925 setcolor(cr, 0.0, 0.0, 0.0);
926 return;
927 }
928 copycolor(cr, ap->val);
929 scalecolor(cr, d);
930 }
931
932
933 static void
934 avinsert( /* insert ambient value in our tree */
935 AMBVAL *av
936 )
937 {
938 AMBTREE *at;
939 AMBVAL *ap;
940 AMBVAL avh;
941 FVECT ck0;
942 double s;
943 int branch;
944 int i;
945
946 if (av->rad <= FTINY)
947 error(CONSISTENCY, "zero ambient radius in avinsert");
948 at = &atrunk;
949 VCOPY(ck0, thescene.cuorg);
950 s = thescene.cusize;
951 while (s*(OCTSCALE/2) > av->rad*ambacc) {
952 if (at->kid == NULL)
953 if ((at->kid = newambtree()) == NULL)
954 error(SYSTEM, "out of memory in avinsert");
955 s *= 0.5;
956 branch = 0;
957 for (i = 0; i < 3; i++)
958 if (av->pos[i] > ck0[i] + s) {
959 ck0[i] += s;
960 branch |= 1 << i;
961 }
962 at = at->kid + branch;
963 }
964 avh.next = at->alist; /* order by increasing level */
965 for (ap = &avh; ap->next != NULL; ap = ap->next)
966 if ( ap->next->lvl > av->lvl ||
967 (ap->next->lvl == av->lvl) &
968 (ap->next->weight <= av->weight) )
969 break;
970 av->next = ap->next;
971 ap->next = (AMBVAL*)av;
972 at->alist = avh.next;
973 }
974
975 #endif /* ! NEWAMB */
976
977 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
978
979 static void
980 initambfile( /* initialize ambient file */
981 int cre8
982 )
983 {
984 extern char *progname, *octname;
985 static char *mybuf = NULL;
986
987 #ifdef F_SETLKW
988 aflock(cre8 ? F_WRLCK : F_RDLCK);
989 #endif
990 SET_FILE_BINARY(ambfp);
991 if (mybuf == NULL)
992 mybuf = (char *)bmalloc(BUFSIZ+8);
993 setbuf(ambfp, mybuf);
994 if (cre8) { /* new file */
995 newheader("RADIANCE", ambfp);
996 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
997 progname, colval(ambval,RED),
998 colval(ambval,GRN), colval(ambval,BLU),
999 ambvwt, ambounce, ambacc);
1000 fprintf(ambfp, "-ad %d -as %d -ar %d ",
1001 ambdiv, ambssamp, ambres);
1002 if (octname != NULL)
1003 fputs(octname, ambfp);
1004 fputc('\n', ambfp);
1005 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
1006 fputnow(ambfp);
1007 fputformat(AMBFMT, ambfp);
1008 fputc('\n', ambfp);
1009 putambmagic(ambfp);
1010 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
1011 error(USER, "bad ambient file");
1012 }
1013
1014
1015 static void
1016 avsave( /* insert and save an ambient value */
1017 AMBVAL *av
1018 )
1019 {
1020 avstore(av);
1021 if (ambfp == NULL)
1022 return;
1023 if (writambval(av, ambfp) < 0)
1024 goto writerr;
1025 if (++nunflshed >= AMBFLUSH)
1026 if (ambsync() == EOF)
1027 goto writerr;
1028 return;
1029 writerr:
1030 error(SYSTEM, "error writing to ambient file");
1031 }
1032
1033
1034 static AMBVAL *
1035 avstore( /* allocate memory and save aval */
1036 AMBVAL *aval
1037 )
1038 {
1039 AMBVAL *av;
1040 double d;
1041
1042 if ((av = newambval()) == NULL)
1043 error(SYSTEM, "out of memory in avstore");
1044 *av = *aval;
1045 av->latick = ambclock;
1046 av->next = NULL;
1047 nambvals++;
1048 d = bright(av->val);
1049 if (d > FTINY) { /* add to log sum for averaging */
1050 avsum += log(d);
1051 navsum++;
1052 }
1053 avinsert(av); /* insert in our cache tree */
1054 return(av);
1055 }
1056
1057
1058 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
1059
1060 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
1061
1062
1063 static AMBTREE *
1064 newambtree(void) /* allocate 8 ambient tree structs */
1065 {
1066 AMBTREE *atp, *upperlim;
1067
1068 if (atfreelist == NULL) { /* get more nodes */
1069 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
1070 if (atfreelist == NULL)
1071 return(NULL);
1072 /* link new free list */
1073 upperlim = atfreelist + 8*(ATALLOCSZ-1);
1074 for (atp = atfreelist; atp < upperlim; atp += 8)
1075 atp->kid = atp + 8;
1076 atp->kid = NULL;
1077 }
1078 atp = atfreelist;
1079 atfreelist = atp->kid;
1080 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
1081 return(atp);
1082 }
1083
1084
1085 static void
1086 freeambtree( /* free 8 ambient tree structs */
1087 AMBTREE *atp
1088 )
1089 {
1090 atp->kid = atfreelist;
1091 atfreelist = atp;
1092 }
1093
1094
1095 static void
1096 unloadatree( /* unload an ambient value tree */
1097 AMBTREE *at,
1098 unloadtf_t *f
1099 )
1100 {
1101 AMBVAL *av;
1102 int i;
1103 /* transfer values at this node */
1104 for (av = at->alist; av != NULL; av = at->alist) {
1105 at->alist = av->next;
1106 (*f)(av);
1107 }
1108 if (at->kid == NULL)
1109 return;
1110 for (i = 0; i < 8; i++) /* transfer and free children */
1111 unloadatree(at->kid+i, f);
1112 freeambtree(at->kid);
1113 at->kid = NULL;
1114 }
1115
1116
1117 static struct avl {
1118 AMBVAL *p;
1119 unsigned long t;
1120 } *avlist1; /* ambient value list with ticks */
1121 static AMBVAL **avlist2; /* memory positions for sorting */
1122 static int i_avlist; /* index for lists */
1123
1124 static int alatcmp(const void *av1, const void *av2);
1125
1126 static void
1127 avfree(AMBVAL *av)
1128 {
1129 free(av);
1130 }
1131
1132 static void
1133 av2list(
1134 AMBVAL *av
1135 )
1136 {
1137 #ifdef DEBUG
1138 if (i_avlist >= nambvals)
1139 error(CONSISTENCY, "too many ambient values in av2list1");
1140 #endif
1141 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1142 avlist1[i_avlist++].t = av->latick;
1143 }
1144
1145
1146 static int
1147 alatcmp( /* compare ambient values for MRA */
1148 const void *av1,
1149 const void *av2
1150 )
1151 {
1152 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1153 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1154 }
1155
1156
1157 /* GW NOTE 2002/10/3:
1158 * I used to compare AMBVAL pointers, but found that this was the
1159 * cause of a serious consistency error with gcc, since the optimizer
1160 * uses some dangerous trick in pointer subtraction that
1161 * assumes pointers differ by exact struct size increments.
1162 */
1163 static int
1164 aposcmp( /* compare ambient value positions */
1165 const void *avp1,
1166 const void *avp2
1167 )
1168 {
1169 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1170 if (diff < 0)
1171 return(-1);
1172 return(diff > 0);
1173 }
1174
1175
1176 static int
1177 avlmemi( /* find list position from address */
1178 AMBVAL *avaddr
1179 )
1180 {
1181 AMBVAL **avlpp;
1182
1183 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1184 nambvals, sizeof(AMBVAL *), &aposcmp);
1185 if (avlpp == NULL)
1186 error(CONSISTENCY, "address not found in avlmemi");
1187 return(avlpp - avlist2);
1188 }
1189
1190
1191 static void
1192 sortambvals( /* resort ambient values */
1193 int always
1194 )
1195 {
1196 AMBTREE oldatrunk;
1197 AMBVAL tav, *tap, *pnext;
1198 int i, j;
1199 /* see if it's time yet */
1200 if (!always && (ambclock++ < lastsort+sortintvl ||
1201 nambvals < SORT_THRESH))
1202 return;
1203 /*
1204 * The idea here is to minimize memory thrashing
1205 * in VM systems by improving reference locality.
1206 * We do this by periodically sorting our stored ambient
1207 * values in memory in order of most recently to least
1208 * recently accessed. This ordering was chosen so that new
1209 * ambient values (which tend to be less important) go into
1210 * higher memory with the infrequently accessed values.
1211 * Since we expect our values to need sorting less
1212 * frequently as the process continues, we double our
1213 * waiting interval after each call.
1214 * This routine is also called by setambacc() with
1215 * the "always" parameter set to 1 so that the ambient
1216 * tree will be rebuilt with the new accuracy parameter.
1217 */
1218 if (tracktime) { /* allocate pointer arrays to sort */
1219 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1220 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1221 } else {
1222 avlist2 = NULL;
1223 avlist1 = NULL;
1224 }
1225 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1226 if (avlist2 != NULL)
1227 free((void *)avlist2);
1228 if (always) { /* rebuild without sorting */
1229 oldatrunk = atrunk;
1230 atrunk.alist = NULL;
1231 atrunk.kid = NULL;
1232 unloadatree(&oldatrunk, &avinsert);
1233 }
1234 } else { /* sort memory by last access time */
1235 /*
1236 * Sorting memory is tricky because it isn't contiguous.
1237 * We have to sort an array of pointers by MRA and also
1238 * by memory position. We then copy values in "loops"
1239 * to minimize memory hits. Nevertheless, we will visit
1240 * everyone at least twice, and this is an expensive process
1241 * when we're thrashing, which is when we need to do it.
1242 */
1243 #ifdef DEBUG
1244 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1245 nambvals, ambclock);
1246 eputs(errmsg);
1247 #endif
1248 i_avlist = 0;
1249 unloadatree(&atrunk, &av2list); /* empty current tree */
1250 #ifdef DEBUG
1251 if (i_avlist < nambvals)
1252 error(CONSISTENCY, "missing ambient values in sortambvals");
1253 #endif
1254 qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
1255 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
1256 for (i = 0; i < nambvals; i++) {
1257 if (avlist1[i].p == NULL)
1258 continue;
1259 tap = avlist2[i];
1260 tav = *tap;
1261 for (j = i; (pnext = avlist1[j].p) != tap;
1262 j = avlmemi(pnext)) {
1263 *(avlist2[j]) = *pnext;
1264 avinsert(avlist2[j]);
1265 avlist1[j].p = NULL;
1266 }
1267 *(avlist2[j]) = tav;
1268 avinsert(avlist2[j]);
1269 avlist1[j].p = NULL;
1270 }
1271 free((void *)avlist1);
1272 free((void *)avlist2);
1273 /* compute new sort interval */
1274 sortintvl = ambclock - lastsort;
1275 if (sortintvl >= MAX_SORT_INTVL/2)
1276 sortintvl = MAX_SORT_INTVL;
1277 else
1278 sortintvl <<= 1; /* wait twice as long next */
1279 #ifdef DEBUG
1280 eputs("done\n");
1281 #endif
1282 }
1283 if (ambclock >= MAXACLOCK)
1284 ambclock = MAXACLOCK/2;
1285 lastsort = ambclock;
1286 }
1287
1288
1289 #ifdef F_SETLKW
1290
1291 static void
1292 aflock( /* lock/unlock ambient file */
1293 int typ
1294 )
1295 {
1296 static struct flock fls; /* static so initialized to zeroes */
1297
1298 if (typ == fls.l_type) /* already called? */
1299 return;
1300 fls.l_type = typ;
1301 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1302 error(SYSTEM, "cannot (un)lock ambient file");
1303 }
1304
1305
1306 int
1307 ambsync(void) /* synchronize ambient file */
1308 {
1309 long flen;
1310 AMBVAL avs;
1311 int n;
1312
1313 if (ambfp == NULL) /* no ambient file? */
1314 return(0);
1315 /* gain appropriate access */
1316 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1317 /* see if file has grown */
1318 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1319 goto seekerr;
1320 if ((n = flen - lastpos) > 0) { /* file has grown */
1321 if (ambinp == NULL) { /* use duplicate filedes */
1322 ambinp = fdopen(dup(fileno(ambfp)), "r");
1323 if (ambinp == NULL)
1324 error(SYSTEM, "fdopen failed in ambsync");
1325 }
1326 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1327 goto seekerr;
1328 while (n >= AMBVALSIZ) { /* load contributed values */
1329 if (!readambval(&avs, ambinp)) {
1330 sprintf(errmsg,
1331 "ambient file \"%s\" corrupted near character %ld",
1332 ambfile, flen - n);
1333 error(WARNING, errmsg);
1334 break;
1335 }
1336 avstore(&avs);
1337 n -= AMBVALSIZ;
1338 }
1339 lastpos = flen - n;
1340 /*** seek always as safety measure
1341 if (n) ***/ /* alignment */
1342 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1343 goto seekerr;
1344 }
1345 n = fflush(ambfp); /* calls write() at last */
1346 if (n != EOF)
1347 lastpos += (long)nunflshed*AMBVALSIZ;
1348 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1349 goto seekerr;
1350
1351 aflock(F_UNLCK); /* release file */
1352 nunflshed = 0;
1353 return(n);
1354 seekerr:
1355 error(SYSTEM, "seek failed in ambsync");
1356 return -1; /* pro forma return */
1357 }
1358
1359 #else /* ! F_SETLKW */
1360
1361 int
1362 ambsync(void) /* flush ambient file */
1363 {
1364 if (ambfp == NULL)
1365 return(0);
1366 nunflshed = 0;
1367 return(fflush(ambfp));
1368 }
1369
1370 #endif /* ! F_SETLKW */
