root/radiance/ray/src/rt/ambient.c
Revision: 2.9
Committed: Thu Jul 16 15:53:42 1992 UTC (31 years, 9 months ago) by greg
Changes since 2.8: +34 -33 lines
bug fix in misuse of lseek()
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 *
10 * The macro AMBFLUSH (if defined) is the number of ambient values
11 * to wait before flushing to the ambient file.
12 *
13 * 5/9/86
14 */
15
16 #include "ray.h"
17
18 #include "octree.h"
19
20 #include "otypes.h"
21
22 #include "ambient.h"
23
24 #include "random.h"
25
26 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
27
28 typedef struct ambtree {
29 AMBVAL *alist; /* ambient value list */
30 struct ambtree *kid; /* 8 child nodes */
31 } AMBTREE; /* ambient octree */
32
33 extern CUBE thescene; /* contains space boundaries */
34
35 #define MAXASET 511 /* maximum number of elements in ambient set */
36 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
37
38 double maxarad; /* maximum ambient radius */
39 double minarad; /* minimum ambient radius */
40
41 static AMBTREE atrunk; /* our ambient trunk node */
42
43 static FILE *ambfp = NULL; /* ambient file pointer */
44 static char *afname; /* ambient file name */
45
46 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
47
48 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
49
50 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
51
52 extern long ftell(), lseek();
53
54
55 setambres(ar) /* set ambient resolution */
56 int ar;
57 {
58 /* set min & max radii */
59 if (ar <= 0) {
60 minarad = 0.0;
61 maxarad = thescene.cusize / 2.0;
62 } else {
63 minarad = thescene.cusize / ar;
64 maxarad = 16.0 * minarad; /* heuristic */
65 if (maxarad > thescene.cusize / 2.0)
66 maxarad = thescene.cusize / 2.0;
67 }
68 if (maxarad <= FTINY)
69 maxarad = .001;
70 }
71
72
73 setambient(afile) /* initialize calculation */
74 char *afile;
75 {
76 long headlen;
77 AMBVAL amb;
78 /* init ambient limits */
79 setambres(ambres);
80 /* open ambient file */
81 if ((afname = afile) != NULL)
82 if ((ambfp = fopen(afile, "r+")) != NULL) {
83 initambfile(0);
84 headlen = ftell(ambfp);
85 while (readambval(&amb, ambfp))
86 avinsert(&amb, &atrunk, thescene.cuorg,
87 thescene.cusize);
88 /* align */
89 fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1);
90 } else if ((ambfp = fopen(afile, "w")) != NULL)
91 initambfile(1);
92 else {
93 sprintf(errmsg, "cannot open ambient file \"%s\"",
94 afile);
95 error(SYSTEM, errmsg);
96 }
97 }
98
99
100 ambnotify(obj) /* record new modifier */
101 OBJECT obj;
102 {
103 static int hitlimit = 0;
104 register OBJREC *o = objptr(obj);
105 register char **amblp;
106
107 if (hitlimit || !ismodifier(o->otype))
108 return;
109 for (amblp = amblist; *amblp != NULL; amblp++)
110 if (!strcmp(o->oname, *amblp)) {
111 if (ambset[0] >= MAXASET) {
112 error(WARNING, "too many modifiers in ambient list");
113 hitlimit++;
114 return; /* should this be fatal? */
115 }
116 insertelem(ambset, obj);
117 return;
118 }
119 }
120
121
122 ambient(acol, r) /* compute ambient component for ray */
123 COLOR acol;
124 register RAY *r;
125 {
126 static int rdepth = 0; /* ambient recursion */
127 double d;
128
129 if (ambdiv <= 0) /* no ambient calculation */
130 goto dumbamb;
131 /* check number of bounces */
132 if (rdepth >= ambounce)
133 goto dumbamb;
134 /* check ambient list */
135 if (ambincl != -1 && r->ro != NULL &&
136 ambincl != inset(ambset, r->ro->omod))
137 goto dumbamb;
138
139 if (ambacc <= FTINY) { /* no ambient storage */
140 rdepth++;
141 d = doambient(acol, r, r->rweight, NULL, NULL);
142 rdepth--;
143 if (d == 0.0)
144 goto dumbamb;
145 return;
146 }
147 /* get ambient value */
148 setcolor(acol, 0.0, 0.0, 0.0);
149 d = sumambient(acol, r, rdepth,
150 &atrunk, thescene.cuorg, thescene.cusize);
151 if (d > FTINY)
152 scalecolor(acol, 1.0/d);
153 else {
154 d = makeambient(acol, r, rdepth++);
155 rdepth--;
156 }
157 if (d > FTINY)
158 return;
159 dumbamb: /* return global value */
160 copycolor(acol, ambval);
161 }
162
163
164 double
165 sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
166 COLOR acol;
167 register RAY *r;
168 int al;
169 AMBTREE *at;
170 FVECT c0;
171 double s;
172 {
173 extern double sqrt();
174 double d, e1, e2, wt, wsum;
175 COLOR ct;
176 FVECT ck0;
177 int i;
178 register int j;
179 register AMBVAL *av;
180 /* do this node */
181 wsum = 0.0;
182 for (av = at->alist; av != NULL; av = av->next) {
183 /*
184 * Ambient level test.
185 */
186 if (av->lvl > al || av->weight < r->rweight-FTINY)
187 continue;
188 /*
189 * Ambient radius test.
190 */
191 e1 = 0.0;
192 for (j = 0; j < 3; j++) {
193 d = av->pos[j] - r->rop[j];
194 e1 += d * d;
195 }
196 e1 /= av->rad * av->rad;
197 if (e1 > ambacc*ambacc*1.21)
198 continue;
199 /*
200 * Normal direction test.
201 */
202 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
203 if (e2 < 0.0) e2 = 0.0;
204 if (e1 + e2 > ambacc*ambacc*1.21)
205 continue;
206 /*
207 * Ray behind test.
208 */
209 d = 0.0;
210 for (j = 0; j < 3; j++)
211 d += (r->rop[j] - av->pos[j]) *
212 (av->dir[j] + r->ron[j]);
213 if (d*0.5 < -minarad*ambacc-.001)
214 continue;
215 /*
216 * Jittering final test reduces image artifacts.
217 */
218 wt = sqrt(e1) + sqrt(e2);
219 wt *= .9 + .2*urand(9015+samplendx);
220 if (wt > ambacc)
221 continue;
222 if (wt <= 1e-3)
223 wt = 1e3;
224 else
225 wt = 1.0 / wt;
226 wsum += wt;
227 extambient(ct, av, r->rop, r->ron);
228 scalecolor(ct, wt);
229 addcolor(acol, ct);
230 }
231 if (at->kid == NULL)
232 return(wsum);
233 /* do children */
234 s *= 0.5;
235 for (i = 0; i < 8; i++) {
236 for (j = 0; j < 3; j++) {
237 ck0[j] = c0[j];
238 if (1<<j & i)
239 ck0[j] += s;
240 if (r->rop[j] < ck0[j] - OCTSCALE*s)
241 break;
242 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
243 break;
244 }
245 if (j == 3)
246 wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
247 }
248 return(wsum);
249 }
250
251
252 double
253 makeambient(acol, r, al) /* make a new ambient value */
254 COLOR acol;
255 register RAY *r;
256 int al;
257 {
258 AMBVAL amb;
259 FVECT gp, gd;
260 /* compute weight */
261 amb.weight = pow(AVGREFL, (double)al);
262 if (r->rweight < 0.2*amb.weight) /* heuristic */
263 amb.weight = r->rweight;
264 /* compute ambient */
265 amb.rad = doambient(acol, r, amb.weight, gp, gd);
266 if (amb.rad == 0.0)
267 return(0.0);
268 /* store it */
269 VCOPY(amb.pos, r->rop);
270 VCOPY(amb.dir, r->ron);
271 amb.lvl = al;
272 copycolor(amb.val, acol);
273 VCOPY(amb.gpos, gp);
274 VCOPY(amb.gdir, gd);
275 /* insert into tree */
276 avsave(&amb); /* and save to file */
277 return(amb.rad);
278 }
279
280
281 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
282 COLOR cr;
283 register AMBVAL *ap;
284 FVECT pv, nv;
285 {
286 FVECT v1, v2;
287 register int i;
288 double d;
289
290 d = 1.0; /* zeroeth order */
291 /* gradient due to translation */
292 for (i = 0; i < 3; i++)
293 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
294 /* gradient due to rotation */
295 VCOPY(v1, ap->dir);
296 fcross(v2, v1, nv);
297 d += DOT(ap->gdir, v2);
298 if (d <= 0.0) {
299 setcolor(cr, 0.0, 0.0, 0.0);
300 return;
301 }
302 copycolor(cr, ap->val);
303 scalecolor(cr, d);
304 }
305
306
307 static
308 initambfile(creat) /* initialize ambient file */
309 int creat;
310 {
311 extern char *progname, *octname, VersionID[];
312
313 setbuf(ambfp, bmalloc(BUFSIZ));
314 if (creat) { /* new file */
315 fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
316 progname, colval(ambval,RED),
317 colval(ambval,GRN), colval(ambval,BLU),
318 ambounce, ambacc);
319 fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
320 ambdiv, ambssamp, ambres,
321 octname==NULL ? "" : octname);
322 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
323 fputformat(AMBFMT, ambfp);
324 putc('\n', ambfp);
325 putambmagic(ambfp);
326 fflush(ambfp);
327 } else if (checkheader(ambfp, AMBFMT, NULL) < 0
328 || !hasambmagic(ambfp)) {
329 sprintf(errmsg, "\"%s\" is not an ambient file", afname);
330 error(USER, errmsg);
331 }
332 }
333
334
335 static
336 avsave(av) /* insert and save an ambient value */
337 AMBVAL *av;
338 {
339 static int nunflshed = 0;
340
341 avinsert(av, &atrunk, thescene.cuorg, thescene.cusize);
342 if (ambfp == NULL)
343 return;
344 if (writambval(av, ambfp) < 0)
345 goto writerr;
346 if (++nunflshed >= AMBFLUSH) {
347 if (ambsync() == EOF)
348 goto writerr;
349 nunflshed = 0;
350 }
351 return;
352 writerr:
353 error(SYSTEM, "error writing ambient file");
354 }
355
356
357 static
358 avinsert(aval, at, c0, s) /* insert ambient value in a tree */
359 AMBVAL *aval;
360 register AMBTREE *at;
361 FVECT c0;
362 double s;
363 {
364 FVECT ck0;
365 int branch;
366 register AMBVAL *av;
367 register int i;
368
369 if ((av = newambval()) == NULL)
370 goto memerr;
371 copystruct(av, aval);
372 VCOPY(ck0, c0);
373 while (s*(OCTSCALE/2) > av->rad*ambacc) {
374 if (at->kid == NULL)
375 if ((at->kid = newambtree()) == NULL)
376 goto memerr;
377 s *= 0.5;
378 branch = 0;
379 for (i = 0; i < 3; i++)
380 if (av->pos[i] > ck0[i] + s) {
381 ck0[i] += s;
382 branch |= 1 << i;
383 }
384 at = at->kid + branch;
385 }
386 av->next = at->alist;
387 at->alist = av;
388 return;
389 memerr:
390 error(SYSTEM, "out of memory in avinsert");
391 }
392
393
394 #include <fcntl.h>
395
396
397 static
398 ambsync() /* synchronize ambient file */
399 {
400 static FILE *ambinp = NULL;
401 struct flock fls;
402 AMBVAL avs;
403 long lastpos, flen;
404 register int n;
405 /* gain exclusive access */
406 fls.l_type = F_WRLCK;
407 fls.l_whence = 0;
408 fls.l_start = 0L;
409 fls.l_len = 0L;
410 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
411 error(SYSTEM, "cannot lock ambient file");
412 /* see if file has grown */
413 lastpos = lseek(fileno(ambfp), 0L, 1); /* get previous position */
414 flen = lseek(fileno(ambfp), 0L, 2); /* new(?) file length */
415 if (n = (flen - lastpos)%AMBVALSIZ) /* assure alignment */
416 lseek(fileno(ambfp), (long)-n, 1);
417 if (n = (flen - lastpos)/AMBVALSIZ) { /* file has grown */
418 if (ambinp == NULL && (ambinp = fopen(afname, "r")) == NULL)
419 error(SYSTEM, "cannot reopen ambient file");
420 fseek(ambinp, lastpos, 0); /* go to previous position */
421 while (n--) { /* load contributed values */
422 readambval(&avs, ambinp);
423 avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize);
424 }
425 }
426 n = fflush(ambfp); /* calls write() at last */
427 fls.l_type = F_UNLCK; /* release file */
428 fcntl(fileno(ambfp), F_SETLKW, &fls);
429 return(n);
430 }
