root/radiance/ray/src/rt/ambient.c
Revision: 2.86
Committed: Wed May 7 01:16:03 2014 UTC (9 years, 11 months ago) by greg
Changes since 2.85: +62 -9 lines
2 static const char RCSid[] = "$Id: ambient.c,v 2.85 2014/05/06 17:15:11 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 4095 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54
55 static double avsum = 0.; /* computed ambient value sum (log) */
56 static unsigned int navsum = 0; /* number of values in avsum */
57 static unsigned int nambvals = 0; /* total number of indirect values */
58 static unsigned int nambshare = 0; /* number of values from file */
59 static unsigned long ambclock = 0; /* ambient access clock */
60 static unsigned long lastsort = 0; /* time of last value sort */
61 static long sortintvl = SORT_INTVL; /* time until next sort */
62 static FILE *ambinp = NULL; /* auxiliary file for input */
63 static long lastpos = -1; /* last flush position */
64
65 #define MAXACLOCK (1L<<30) /* clock turnover value */
66 /*
67 * Track access times unless we are sharing ambient values
68 * through memory on a multiprocessor, when we want to avoid
69 * claiming our own memory (copy on write). Go ahead anyway
70 * if more than two thirds of our values are unshared.
71 * Compile with -Dtracktime=0 to turn this code off.
72 */
73 #ifndef tracktime
74 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
75 #endif
76
77 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
78
79 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
80 #define freeav(av) free((void *)av);
81
82 static void initambfile(int creat);
83 static void avsave(AMBVAL *av);
84 static AMBVAL *avstore(AMBVAL *aval);
85 static AMBTREE *newambtree(void);
86 static void freeambtree(AMBTREE *atp);
87
88 typedef void unloadtf_t(AMBVAL *);
89 static unloadtf_t avinsert;
90 static unloadtf_t av2list;
91 static unloadtf_t avfree;
92 static void unloadatree(AMBTREE *at, unloadtf_t *f);
93
94 static int aposcmp(const void *avp1, const void *avp2);
95 static int avlmemi(AMBVAL *avaddr);
96 static void sortambvals(int always);
97
98 #ifdef F_SETLKW
99 static void aflock(int typ);
100 #endif
101
102
103 void
104 setambres( /* set ambient resolution */
105 int ar
106 )
107 {
108 ambres = ar < 0 ? 0 : ar; /* may be done already */
109 /* set min & max radii */
110 if (ar <= 0) {
111 minarad = 0;
112 maxarad = thescene.cusize*0.5;
113 } else {
114 minarad = thescene.cusize / ar;
115 maxarad = 64.0 * minarad; /* heuristic */
116 if (maxarad > thescene.cusize*0.5)
117 maxarad = thescene.cusize*0.5;
118 }
119 if (minarad <= FTINY)
120 minarad = 10.0*FTINY;
121 if (maxarad <= minarad)
122 maxarad = 64.0 * minarad;
123 }
124
125
126 void
127 setambacc( /* set ambient accuracy */
128 double newa
129 )
130 {
131 static double olda; /* remember previous setting here */
132
133 newa *= (newa > 0);
134 if (fabs(newa - olda) >= .05*(newa + olda)) {
135 ambacc = newa;
136 if (nambvals > 0)
137 sortambvals(1); /* rebuild tree */
138 }
139 }
140
141
142 void
143 setambient(void) /* initialize calculation */
144 {
145 int readonly = 0;
146 long flen;
147 AMBVAL amb;
148 /* make sure we're fresh */
149 ambdone();
150 /* init ambient limits */
151 setambres(ambres);
152 setambacc(ambacc);
153 if (ambfile == NULL || !ambfile[0])
154 return;
155 if (ambacc <= FTINY) {
156 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
157 ambfile);
158 error(WARNING, errmsg);
159 return;
160 }
161 /* open ambient file */
162 if ((ambfp = fopen(ambfile, "r+")) == NULL)
163 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
164 if (ambfp != NULL) {
165 initambfile(0); /* file exists */
166 lastpos = ftell(ambfp);
167 while (readambval(&amb, ambfp))
168 avinsert(avstore(&amb));
169 nambshare = nambvals; /* share loaded values */
170 if (readonly) {
171 sprintf(errmsg,
172 "loaded %u values from read-only ambient file",
173 nambvals);
174 error(WARNING, errmsg);
175 fclose(ambfp); /* close file so no writes */
176 ambfp = NULL;
177 return; /* avoid ambsync() */
178 }
179 /* align file pointer */
180 lastpos += (long)nambvals*AMBVALSIZ;
181 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
182 if (flen != lastpos) {
183 sprintf(errmsg,
184 "ignoring last %ld values in ambient file (corrupted)",
185 (flen - lastpos)/AMBVALSIZ);
186 error(WARNING, errmsg);
187 fseek(ambfp, lastpos, SEEK_SET);
188 #ifndef _WIN32 /* XXX we need a replacement for that one */
189 ftruncate(fileno(ambfp), (off_t)lastpos);
190 #endif
191 }
192 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
193 initambfile(1); /* else create new file */
194 fflush(ambfp);
195 lastpos = ftell(ambfp);
196 } else {
197 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
198 error(SYSTEM, errmsg);
199 }
200 #ifdef getc_unlocked
201 flockfile(ambfp); /* application-level lock */
202 #endif
203 #ifdef F_SETLKW
204 aflock(F_UNLCK); /* release file */
205 #endif
206 }
207
208
209 void
210 ambdone(void) /* close ambient file and free memory */
211 {
212 if (ambfp != NULL) { /* close ambient file */
213 ambsync();
214 fclose(ambfp);
215 ambfp = NULL;
216 if (ambinp != NULL) {
217 fclose(ambinp);
218 ambinp = NULL;
219 }
220 lastpos = -1;
221 }
222 /* free ambient tree */
223 unloadatree(&atrunk, &avfree);
224 /* reset state variables */
225 avsum = 0.;
226 navsum = 0;
227 nambvals = 0;
228 nambshare = 0;
229 ambclock = 0;
230 lastsort = 0;
231 sortintvl = SORT_INTVL;
232 }
233
234
235 void
236 ambnotify( /* record new modifier */
237 OBJECT obj
238 )
239 {
240 static int hitlimit = 0;
241 OBJREC *o;
242 char **amblp;
243
244 if (obj == OVOID) { /* starting over */
245 ambset[0] = 0;
246 hitlimit = 0;
247 return;
248 }
249 o = objptr(obj);
250 if (hitlimit || !ismodifier(o->otype))
251 return;
252 for (amblp = amblist; *amblp != NULL; amblp++)
253 if (!strcmp(o->oname, *amblp)) {
254 if (ambset[0] >= MAXASET) {
255 error(WARNING, "too many modifiers in ambient list");
256 hitlimit++;
257 return; /* should this be fatal? */
258 }
259 insertelem(ambset, obj);
260 return;
261 }
262 }
263
264 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
265
266 #ifdef NEWAMB
267
268 #define tfunc(lwr, x, upr) (((x)-(lwr))/((upr)-(lwr)))
269
270 static int plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang);
271 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
272 AMBTREE *at, FVECT c0, double s);
273 static int makeambient(COLOR acol, RAY *r, FVECT rn, int al);
274 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv,
275 FVECT uvw[3]);
276
277 void
278 multambient( /* compute ambient component & multiply by coef. */
279 COLOR aval,
280 RAY *r,
281 FVECT nrm
282 )
283 {
284 static int rdepth = 0; /* ambient recursion */
285 COLOR acol;
286 int ok;
287 double d, l;
288
289 if (ambdiv <= 0) /* no ambient calculation */
290 goto dumbamb;
291 /* check number of bounces */
292 if (rdepth >= ambounce)
293 goto dumbamb;
294 /* check ambient list */
295 if (ambincl != -1 && r->ro != NULL &&
296 ambincl != inset(ambset, r->ro->omod))
297 goto dumbamb;
298
299 if (ambacc <= FTINY) { /* no ambient storage */
300 copycolor(acol, aval);
301 rdepth++;
302 ok = doambient(acol, r, r->rweight,
303 NULL, NULL, NULL, NULL, NULL);
304 rdepth--;
305 if (!ok)
306 goto dumbamb;
307 copycolor(aval, acol);
308 return;
309 }
310
311 if (tracktime) /* sort to minimize thrashing */
312 sortambvals(0);
313 /* interpolate ambient value */
314 setcolor(acol, 0.0, 0.0, 0.0);
315 d = sumambient(acol, r, nrm, rdepth,
316 &atrunk, thescene.cuorg, thescene.cusize);
317 if (d > FTINY) {
318 d = 1.0/d;
319 scalecolor(acol, d);
320 multcolor(aval, acol);
321 return;
322 }
323 rdepth++; /* need to cache new value */
324 ok = makeambient(acol, r, nrm, rdepth-1);
325 rdepth--;
326 if (ok) {
327 multcolor(aval, acol); /* computed new value */
328 return;
329 }
330 dumbamb: /* return global value */
331 if ((ambvwt <= 0) | (navsum == 0)) {
332 multcolor(aval, ambval);
333 return;
334 }
335 l = bright(ambval); /* average in computations */
336 if (l > FTINY) {
337 d = (log(l)*(double)ambvwt + avsum) /
338 (double)(ambvwt + navsum);
339 d = exp(d) / l;
340 scalecolor(aval, d);
341 multcolor(aval, ambval); /* apply color of ambval */
342 } else {
343 d = exp( avsum / (double)navsum );
344 scalecolor(aval, d); /* neutral color */
345 }
346 }
347
348
349 /* Plug a potential leak where ambient cache value is occluded */
350 static int
351 plugaleak(RAY *r, AMBVAL *ap, FVECT anorm, double ang)
352 {
353 const double cost70sq = 0.1169778; /* cos(70deg)^2 */
354 RAY rtst;
355 FVECT vdif;
356 double normdot, ndotd, nadotd;
357 double a, b, c, t[2];
358
359 ang += 2.*PI*(ang < 0); /* check direction flags */
360 if ( !(ap->corral>>(int)(ang*(16./PI)) & 1) )
361 return(0);
362 /*
363 * Generate test ray, targeting 20 degrees above sample point plane
364 * along surface normal from cache position. This should be high
365 * enough to miss local geometry we don't really care about.
366 */
367 VSUB(vdif, ap->pos, r->rop);
368 normdot = DOT(anorm, r->ron);
369 ndotd = DOT(vdif, r->ron);
370 nadotd = DOT(vdif, anorm);
371 a = normdot*normdot - cost70sq;
372 b = 2.0*(normdot*ndotd - nadotd*cost70sq);
373 c = ndotd*ndotd - DOT(vdif,vdif)*cost70sq;
374 if (quadratic(t, a, b, c) != 2)
375 return(1); /* should rarely happen */
376 if (t[1] <= FTINY)
377 return(0); /* should fail behind test */
378 rayorigin(&rtst, SHADOW, r, NULL);
379 VSUM(rtst.rdir, vdif, anorm, t[1]); /* further dist. > plane */
380 rtst.rmax = normalize(rtst.rdir); /* short ray test */
381 while (localhit(&rtst, &thescene)) { /* check for occluder */
382 if (rtst.ro->omod != OVOID &&
383 (rtst.clipset == NULL ||
384 !inset(rtst.clipset, rtst.ro->omod)))
385 return(1); /* plug light leak */
386 VCOPY(rtst.rorg, rtst.rop); /* skip invisible surface */
387 rtst.rmax -= rtst.rot;
388 rayclear(&rtst);
389 }
390 return(0); /* seems we're OK */
391 }
392
393
394 static double
395 sumambient( /* get interpolated ambient value */
396 COLOR acol,
397 RAY *r,
398 FVECT rn,
399 int al,
400 AMBTREE *at,
401 FVECT c0,
402 double s
403 )
404 { /* initial limit is 10 degrees plus ambacc radians */
405 const double minangle = 10.0 * PI/180.;
406 double maxangle = minangle + ambacc;
407 double wsum = 0.0;
408 FVECT ck0;
409 int i, j;
410 AMBVAL *av;
411
412 if (at->kid != NULL) { /* sum children first */
413 s *= 0.5;
414 for (i = 0; i < 8; i++) {
415 for (j = 0; j < 3; j++) {
416 ck0[j] = c0[j];
417 if (1<<j & i)
418 ck0[j] += s;
419 if (r->rop[j] < ck0[j] - OCTSCALE*s)
420 break;
421 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
422 break;
423 }
424 if (j == 3)
425 wsum += sumambient(acol, r, rn, al,
426 at->kid+i, ck0, s);
427 }
428 /* good enough? */
429 if (wsum >= 0.05 && s > minarad*10.0)
430 return(wsum);
431 }
432 /* adjust maximum angle */
433 if (at->alist != NULL && (at->alist->lvl <= al) & (r->rweight < 0.6))
434 maxangle = (maxangle - PI/2.)*pow(r->rweight,0.13) + PI/2.;
435 /* sum this node */
436 for (av = at->alist; av != NULL; av = av->next) {
437 double u, v, d, delta_r2, delta_t2;
438 COLOR ct;
439 FVECT uvw[3];
440 /* record access */
441 if (tracktime)
442 av->latick = ambclock;
443 /*
444 * Ambient level test
445 */
446 if (av->lvl > al) /* list sorted, so this works */
447 break;
448 if (av->weight < 0.9*r->rweight)
449 continue;
450 /*
451 * Direction test using unperturbed normal
452 */
453 decodedir(uvw[2], av->ndir);
454 d = DOT(uvw[2], r->ron);
455 if (d <= 0.0) /* >= 90 degrees */
456 continue;
457 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
458 if (delta_r2 >= maxangle*maxangle)
459 continue;
460 /*
461 * Modified ray behind test
462 */
463 VSUB(ck0, r->rop, av->pos);
464 d = DOT(ck0, uvw[2]);
465 if (d < -minarad*ambacc-.001)
466 continue;
467 d /= av->rad[0];
468 delta_t2 = d*d;
469 if (delta_t2 >= ambacc*ambacc)
470 continue;
471 /*
472 * Elliptical radii test based on Hessian
473 */
474 decodedir(uvw[0], av->udir);
475 VCROSS(uvw[1], uvw[2], uvw[0]);
476 d = (u = DOT(ck0, uvw[0])) / av->rad[0];
477 delta_t2 += d*d;
478 d = (v = DOT(ck0, uvw[1])) / av->rad[1];
479 delta_t2 += d*d;
480 if (delta_t2 >= ambacc*ambacc)
481 continue;
482 /*
483 * Test for potential light leak
484 */
485 if (av->corral && plugaleak(r, av, uvw[2], atan2a(v,u)))
486 continue;
487 /*
488 * Extrapolate value and compute final weight (hat function)
489 */
490 extambient(ct, av, r->rop, rn, uvw);
491 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
492 tfunc(ambacc, sqrt(delta_t2), 0.0);
493 scalecolor(ct, d);
494 addcolor(acol, ct);
495 wsum += d;
496 }
497 return(wsum);
498 }
499
500
501 static int
502 makeambient( /* make a new ambient value for storage */
503 COLOR acol,
504 RAY *r,
505 FVECT rn,
506 int al
507 )
508 {
509 AMBVAL amb;
510 FVECT uvw[3];
511 int i;
512
513 amb.weight = 1.0; /* compute weight */
514 for (i = al; i-- > 0; )
515 amb.weight *= AVGREFL;
516 if (r->rweight < 0.1*amb.weight) /* heuristic override */
517 amb.weight = 1.25*r->rweight;
518 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
519 /* compute ambient */
520 i = doambient(acol, r, amb.weight,
521 uvw, amb.rad, amb.gpos, amb.gdir, &amb.corral);
522 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
523 if (i <= 0 || amb.rad[0] <= FTINY) /* no Hessian or zero radius */
524 return(i);
525 /* store value */
526 VCOPY(amb.pos, r->rop);
527 amb.ndir = encodedir(r->ron);
528 amb.udir = encodedir(uvw[0]);
529 amb.lvl = al;
530 copycolor(amb.val, acol);
531 /* insert into tree */
532 avsave(&amb); /* and save to file */
533 if (rn != r->ron) { /* texture */
534 VCOPY(uvw[2], r->ron);
535 extambient(acol, &amb, r->rop, rn, uvw);
536 }
537 return(1);
538 }
539
540
541 static void
542 extambient( /* extrapolate value at pv, nv */
543 COLOR cr,
544 AMBVAL *ap,
545 FVECT pv,
546 FVECT nv,
547 FVECT uvw[3]
548 )
549 {
550 static FVECT my_uvw[3];
551 FVECT v1;
552 int i;
553 double d = 1.0; /* zeroeth order */
554
555 if (uvw == NULL) { /* need local coordinates? */
556 decodedir(my_uvw[2], ap->ndir);
557 decodedir(my_uvw[0], ap->udir);
558 VCROSS(my_uvw[1], my_uvw[2], my_uvw[0]);
559 uvw = my_uvw;
560 }
561 for (i = 3; i--; ) /* gradient due to translation */
562 d += (pv[i] - ap->pos[i]) *
563 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
564
565 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
566 for (i = 3; i--; )
567 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
568
569 if (d <= 0.0) {
570 setcolor(cr, 0.0, 0.0, 0.0);
571 return;
572 }
573 copycolor(cr, ap->val);
574 scalecolor(cr, d);
575 }
576
577
578 static void
579 avinsert( /* insert ambient value in our tree */
580 AMBVAL *av
581 )
582 {
583 AMBTREE *at;
584 AMBVAL *ap;
585 AMBVAL avh;
586 FVECT ck0;
587 double s;
588 int branch;
589 int i;
590
591 if (av->rad[0] <= FTINY)
592 error(CONSISTENCY, "zero ambient radius in avinsert");
593 at = &atrunk;
594 VCOPY(ck0, thescene.cuorg);
595 s = thescene.cusize;
596 while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
597 if (at->kid == NULL)
598 if ((at->kid = newambtree()) == NULL)
599 error(SYSTEM, "out of memory in avinsert");
600 s *= 0.5;
601 branch = 0;
602 for (i = 0; i < 3; i++)
603 if (av->pos[i] > ck0[i] + s) {
604 ck0[i] += s;
605 branch |= 1 << i;
606 }
607 at = at->kid + branch;
608 }
609 avh.next = at->alist; /* order by increasing level */
610 for (ap = &avh; ap->next != NULL; ap = ap->next)
611 if (ap->next->lvl >= av->lvl)
612 break;
613 av->next = ap->next;
614 ap->next = (AMBVAL*)av;
615 at->alist = avh.next;
616 }
617
618
619 #else /* ! NEWAMB */
620
621 static double sumambient(COLOR acol, RAY *r, FVECT rn, int al,
622 AMBTREE *at, FVECT c0, double s);
623 static double makeambient(COLOR acol, RAY *r, FVECT rn, int al);
624 static void extambient(COLOR cr, AMBVAL *ap, FVECT pv, FVECT nv);
625
626
627 void
628 multambient( /* compute ambient component & multiply by coef. */
629 COLOR aval,
630 RAY *r,
631 FVECT nrm
632 )
633 {
634 static int rdepth = 0; /* ambient recursion */
635 COLOR acol;
636 double d, l;
637
638 if (ambdiv <= 0) /* no ambient calculation */
639 goto dumbamb;
640 /* check number of bounces */
641 if (rdepth >= ambounce)
642 goto dumbamb;
643 /* check ambient list */
644 if (ambincl != -1 && r->ro != NULL &&
645 ambincl != inset(ambset, r->ro->omod))
646 goto dumbamb;
647
648 if (ambacc <= FTINY) { /* no ambient storage */
649 copycolor(acol, aval);
650 rdepth++;
651 d = doambient(acol, r, r->rweight, NULL, NULL);
652 rdepth--;
653 if (d <= FTINY)
654 goto dumbamb;
655 copycolor(aval, acol);
656 return;
657 }
658
659 if (tracktime) /* sort to minimize thrashing */
660 sortambvals(0);
661 /* interpolate ambient value */
662 setcolor(acol, 0.0, 0.0, 0.0);
663 d = sumambient(acol, r, nrm, rdepth,
664 &atrunk, thescene.cuorg, thescene.cusize);
665 if (d > FTINY) {
666 d = 1.0/d;
667 scalecolor(acol, d);
668 multcolor(aval, acol);
669 return;
670 }
671 rdepth++; /* need to cache new value */
672 d = makeambient(acol, r, nrm, rdepth-1);
673 rdepth--;
674 if (d > FTINY) {
675 multcolor(aval, acol); /* got new value */
676 return;
677 }
678 dumbamb: /* return global value */
679 if ((ambvwt <= 0) | (navsum == 0)) {
680 multcolor(aval, ambval);
681 return;
682 }
683 l = bright(ambval); /* average in computations */
684 if (l > FTINY) {
685 d = (log(l)*(double)ambvwt + avsum) /
686 (double)(ambvwt + navsum);
687 d = exp(d) / l;
688 scalecolor(aval, d);
689 multcolor(aval, ambval); /* apply color of ambval */
690 } else {
691 d = exp( avsum / (double)navsum );
692 scalecolor(aval, d); /* neutral color */
693 }
694 }
695
696
697 static double
698 sumambient( /* get interpolated ambient value */
699 COLOR acol,
700 RAY *r,
701 FVECT rn,
702 int al,
703 AMBTREE *at,
704 FVECT c0,
705 double s
706 )
707 {
708 double d, e1, e2, wt, wsum;
709 COLOR ct;
710 FVECT ck0;
711 int i;
712 int j;
713 AMBVAL *av;
714
715 wsum = 0.0;
716 /* do this node */
717 for (av = at->alist; av != NULL; av = av->next) {
718 double rn_dot = -2.0;
719 if (tracktime)
720 av->latick = ambclock;
721 /*
722 * Ambient level test.
723 */
724 if (av->lvl > al) /* list sorted, so this works */
725 break;
726 if (av->weight < 0.9*r->rweight)
727 continue;
728 /*
729 * Ambient radius test.
730 */
731 VSUB(ck0, av->pos, r->rop);
732 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
733 if (e1 > ambacc*ambacc*1.21)
734 continue;
735 /*
736 * Direction test using closest normal.
737 */
738 d = DOT(av->dir, r->ron);
739 if (rn != r->ron) {
740 rn_dot = DOT(av->dir, rn);
741 if (rn_dot > 1.0-FTINY)
742 rn_dot = 1.0-FTINY;
743 if (rn_dot >= d-FTINY) {
744 d = rn_dot;
745 rn_dot = -2.0;
746 }
747 }
748 e2 = (1.0 - d) * r->rweight;
749 if (e2 < 0.0)
750 e2 = 0.0;
751 else if (e1 + e2 > ambacc*ambacc*1.21)
752 continue;
753 /*
754 * Ray behind test.
755 */
756 d = 0.0;
757 for (j = 0; j < 3; j++)
758 d += (r->rop[j] - av->pos[j]) *
759 (av->dir[j] + r->ron[j]);
760 if (d*0.5 < -minarad*ambacc-.001)
761 continue;
762 /*
763 * Jittering final test reduces image artifacts.
764 */
765 e1 = sqrt(e1);
766 e2 = sqrt(e2);
767 wt = e1 + e2;
768 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
769 continue;
770 /*
771 * Recompute directional error using perturbed normal
772 */
773 if (rn_dot > 0.0) {
774 e2 = sqrt((1.0 - rn_dot)*r->rweight);
775 wt = e1 + e2;
776 }
777 if (wt <= 1e-3)
778 wt = 1e3;
779 else
780 wt = 1.0 / wt;
781 wsum += wt;
782 extambient(ct, av, r->rop, rn);
783 scalecolor(ct, wt);
784 addcolor(acol, ct);
785 }
786 if (at->kid == NULL)
787 return(wsum);
788 /* do children */
789 s *= 0.5;
790 for (i = 0; i < 8; i++) {
791 for (j = 0; j < 3; j++) {
792 ck0[j] = c0[j];
793 if (1<<j & i)
794 ck0[j] += s;
795 if (r->rop[j] < ck0[j] - OCTSCALE*s)
796 break;
797 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
798 break;
799 }
800 if (j == 3)
801 wsum += sumambient(acol, r, rn, al,
802 at->kid+i, ck0, s);
803 }
804 return(wsum);
805 }
806
807
808 static double
809 makeambient( /* make a new ambient value for storage */
810 COLOR acol,
811 RAY *r,
812 FVECT rn,
813 int al
814 )
815 {
816 AMBVAL amb;
817 FVECT gp, gd;
818 int i;
819
820 amb.weight = 1.0; /* compute weight */
821 for (i = al; i-- > 0; )
822 amb.weight *= AVGREFL;
823 if (r->rweight < 0.1*amb.weight) /* heuristic override */
824 amb.weight = 1.25*r->rweight;
825 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
826 /* compute ambient */
827 amb.rad = doambient(acol, r, amb.weight, gp, gd);
828 if (amb.rad <= FTINY) {
829 setcolor(acol, 0.0, 0.0, 0.0);
830 return(0.0);
831 }
832 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
833 /* store value */
834 VCOPY(amb.pos, r->rop);
835 VCOPY(amb.dir, r->ron);
836 amb.lvl = al;
837 copycolor(amb.val, acol);
838 VCOPY(amb.gpos, gp);
839 VCOPY(amb.gdir, gd);
840 /* insert into tree */
841 avsave(&amb); /* and save to file */
842 if (rn != r->ron)
843 extambient(acol, &amb, r->rop, rn); /* texture */
844 return(amb.rad);
845 }
846
847
848 static void
849 extambient( /* extrapolate value at pv, nv */
850 COLOR cr,
851 AMBVAL *ap,
852 FVECT pv,
853 FVECT nv
854 )
855 {
856 FVECT v1;
857 int i;
858 double d;
859
860 d = 1.0; /* zeroeth order */
861 /* gradient due to translation */
862 for (i = 0; i < 3; i++)
863 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
864 /* gradient due to rotation */
865 VCROSS(v1, ap->dir, nv);
866 d += DOT(ap->gdir, v1);
867 if (d <= 0.0) {
868 setcolor(cr, 0.0, 0.0, 0.0);
869 return;
870 }
871 copycolor(cr, ap->val);
872 scalecolor(cr, d);
873 }
874
875
876 static void
877 avinsert( /* insert ambient value in our tree */
878 AMBVAL *av
879 )
880 {
881 AMBTREE *at;
882 AMBVAL *ap;
883 AMBVAL avh;
884 FVECT ck0;
885 double s;
886 int branch;
887 int i;
888
889 if (av->rad <= FTINY)
890 error(CONSISTENCY, "zero ambient radius in avinsert");
891 at = &atrunk;
892 VCOPY(ck0, thescene.cuorg);
893 s = thescene.cusize;
894 while (s*(OCTSCALE/2) > av->rad*ambacc) {
895 if (at->kid == NULL)
896 if ((at->kid = newambtree()) == NULL)
897 error(SYSTEM, "out of memory in avinsert");
898 s *= 0.5;
899 branch = 0;
900 for (i = 0; i < 3; i++)
901 if (av->pos[i] > ck0[i] + s) {
902 ck0[i] += s;
903 branch |= 1 << i;
904 }
905 at = at->kid + branch;
906 }
907 avh.next = at->alist; /* order by increasing level */
908 for (ap = &avh; ap->next != NULL; ap = ap->next)
909 if (ap->next->lvl >= av->lvl)
910 break;
911 av->next = ap->next;
912 ap->next = (AMBVAL*)av;
913 at->alist = avh.next;
914 }
915
916 #endif /* ! NEWAMB */
917
918 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
919
920 static void
921 initambfile( /* initialize ambient file */
922 int cre8
923 )
924 {
925 extern char *progname, *octname;
926 static char *mybuf = NULL;
927
928 #ifdef F_SETLKW
929 aflock(cre8 ? F_WRLCK : F_RDLCK);
930 #endif
931 SET_FILE_BINARY(ambfp);
932 if (mybuf == NULL)
933 mybuf = (char *)bmalloc(BUFSIZ+8);
934 setbuf(ambfp, mybuf);
935 if (cre8) { /* new file */
936 newheader("RADIANCE", ambfp);
937 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
938 progname, colval(ambval,RED),
939 colval(ambval,GRN), colval(ambval,BLU),
940 ambvwt, ambounce, ambacc);
941 fprintf(ambfp, "-ad %d -as %d -ar %d ",
942 ambdiv, ambssamp, ambres);
943 if (octname != NULL)
944 fputs(octname, ambfp);
945 fputc('\n', ambfp);
946 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
947 fputnow(ambfp);
948 fputformat(AMBFMT, ambfp);
949 fputc('\n', ambfp);
950 putambmagic(ambfp);
951 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
952 error(USER, "bad ambient file");
953 }
954
955
956 static void
957 avsave( /* insert and save an ambient value */
958 AMBVAL *av
959 )
960 {
961 avinsert(avstore(av));
962 if (ambfp == NULL)
963 return;
964 if (writambval(av, ambfp) < 0)
965 goto writerr;
966 if (++nunflshed >= AMBFLUSH)
967 if (ambsync() == EOF)
968 goto writerr;
969 return;
970 writerr:
971 error(SYSTEM, "error writing to ambient file");
972 }
973
974
975 static AMBVAL *
976 avstore( /* allocate memory and store aval */
977 AMBVAL *aval
978 )
979 {
980 AMBVAL *av;
981 double d;
982
983 if ((av = newambval()) == NULL)
984 error(SYSTEM, "out of memory in avstore");
985 *av = *aval;
986 av->latick = ambclock;
987 av->next = NULL;
988 nambvals++;
989 d = bright(av->val);
990 if (d > FTINY) { /* add to log sum for averaging */
991 avsum += log(d);
992 navsum++;
993 }
994 return(av);
995 }
996
997
998 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
999
1000 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
1001
1002
1003 static AMBTREE *
1004 newambtree(void) /* allocate 8 ambient tree structs */
1005 {
1006 AMBTREE *atp, *upperlim;
1007
1008 if (atfreelist == NULL) { /* get more nodes */
1009 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
1010 if (atfreelist == NULL)
1011 return(NULL);
1012 /* link new free list */
1013 upperlim = atfreelist + 8*(ATALLOCSZ-1);
1014 for (atp = atfreelist; atp < upperlim; atp += 8)
1015 atp->kid = atp + 8;
1016 atp->kid = NULL;
1017 }
1018 atp = atfreelist;
1019 atfreelist = atp->kid;
1020 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
1021 return(atp);
1022 }
1023
1024
1025 static void
1026 freeambtree( /* free 8 ambient tree structs */
1027 AMBTREE *atp
1028 )
1029 {
1030 atp->kid = atfreelist;
1031 atfreelist = atp;
1032 }
1033
1034
1035 static void
1036 unloadatree( /* unload an ambient value tree */
1037 AMBTREE *at,
1038 unloadtf_t *f
1039 )
1040 {
1041 AMBVAL *av;
1042 int i;
1043 /* transfer values at this node */
1044 for (av = at->alist; av != NULL; av = at->alist) {
1045 at->alist = av->next;
1046 (*f)(av);
1047 }
1048 if (at->kid == NULL)
1049 return;
1050 for (i = 0; i < 8; i++) /* transfer and free children */
1051 unloadatree(at->kid+i, f);
1052 freeambtree(at->kid);
1053 at->kid = NULL;
1054 }
1055
1056
1057 static struct avl {
1058 AMBVAL *p;
1059 unsigned long t;
1060 } *avlist1; /* ambient value list with ticks */
1061 static AMBVAL **avlist2; /* memory positions for sorting */
1062 static int i_avlist; /* index for lists */
1063
1064 static int alatcmp(const void *av1, const void *av2);
1065
1066 static void
1067 avfree(AMBVAL *av)
1068 {
1069 free(av);
1070 }
1071
1072 static void
1073 av2list(
1074 AMBVAL *av
1075 )
1076 {
1077 #ifdef DEBUG
1078 if (i_avlist >= nambvals)
1079 error(CONSISTENCY, "too many ambient values in av2list1");
1080 #endif
1081 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1082 avlist1[i_avlist++].t = av->latick;
1083 }
1084
1085
1086 static int
1087 alatcmp( /* compare ambient values for MRA */
1088 const void *av1,
1089 const void *av2
1090 )
1091 {
1092 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1093 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1094 }
1095
1096
1097 /* GW NOTE 2002/10/3:
1098 * I used to compare AMBVAL pointers, but found that this was the
1099 * cause of a serious consistency error with gcc, since the optimizer
1100 * uses some dangerous trick in pointer subtraction that
1101 * assumes pointers differ by exact struct size increments.
1102 */
1103 static int
1104 aposcmp( /* compare ambient value positions */
1105 const void *avp1,
1106 const void *avp2
1107 )
1108 {
1109 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1110 if (diff < 0)
1111 return(-1);
1112 return(diff > 0);
1113 }
1114
1115
1116 static int
1117 avlmemi( /* find list position from address */
1118 AMBVAL *avaddr
1119 )
1120 {
1121 AMBVAL **avlpp;
1122
1123 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1124 nambvals, sizeof(AMBVAL *), &aposcmp);
1125 if (avlpp == NULL)
1126 error(CONSISTENCY, "address not found in avlmemi");
1127 return(avlpp - avlist2);
1128 }
1129
1130
1131 static void
1132 sortambvals( /* resort ambient values */
1133 int always
1134 )
1135 {
1136 AMBTREE oldatrunk;
1137 AMBVAL tav, *tap, *pnext;
1138 int i, j;
1139 /* see if it's time yet */
1140 if (!always && (ambclock++ < lastsort+sortintvl ||
1141 nambvals < SORT_THRESH))
1142 return;
1143 /*
1144 * The idea here is to minimize memory thrashing
1145 * in VM systems by improving reference locality.
1146 * We do this by periodically sorting our stored ambient
1147 * values in memory in order of most recently to least
1148 * recently accessed. This ordering was chosen so that new
1149 * ambient values (which tend to be less important) go into
1150 * higher memory with the infrequently accessed values.
1151 * Since we expect our values to need sorting less
1152 * frequently as the process continues, we double our
1153 * waiting interval after each call.
1154 * This routine is also called by setambacc() with
1155 * the "always" parameter set to 1 so that the ambient
1156 * tree will be rebuilt with the new accuracy parameter.
1157 */
1158 if (tracktime) { /* allocate pointer arrays to sort */
1159 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1160 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1161 } else {
1162 avlist2 = NULL;
1163 avlist1 = NULL;
1164 }
1165 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1166 if (avlist2 != NULL)
1167 free((void *)avlist2);
1168 if (always) { /* rebuild without sorting */
1169 oldatrunk = atrunk;
1170 atrunk.alist = NULL;
1171 atrunk.kid = NULL;
1172 unloadatree(&oldatrunk, &avinsert);
1173 }
1174 } else { /* sort memory by last access time */
1175 /*
1176 * Sorting memory is tricky because it isn't contiguous.
1177 * We have to sort an array of pointers by MRA and also
1178 * by memory position. We then copy values in "loops"
1179 * to minimize memory hits. Nevertheless, we will visit
1180 * everyone at least twice, and this is an expensive process
1181 * when we're thrashing, which is when we need to do it.
1182 */
1183 #ifdef DEBUG
1184 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1185 nambvals, ambclock);
1186 eputs(errmsg);
1187 #endif
1188 i_avlist = 0;
1189 unloadatree(&atrunk, &av2list); /* empty current tree */
1190 #ifdef DEBUG
1191 if (i_avlist < nambvals)
1192 error(CONSISTENCY, "missing ambient values in sortambvals");
1193 #endif
1194 qsort((char *)avlist1, nambvals, sizeof(struct avl), &alatcmp);
1195 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), &aposcmp);
1196 for (i = 0; i < nambvals; i++) {
1197 if (avlist1[i].p == NULL)
1198 continue;
1199 tap = avlist2[i];
1200 tav = *tap;
1201 for (j = i; (pnext = avlist1[j].p) != tap;
1202 j = avlmemi(pnext)) {
1203 *(avlist2[j]) = *pnext;
1204 avinsert(avlist2[j]);
1205 avlist1[j].p = NULL;
1206 }
1207 *(avlist2[j]) = tav;
1208 avinsert(avlist2[j]);
1209 avlist1[j].p = NULL;
1210 }
1211 free((void *)avlist1);
1212 free((void *)avlist2);
1213 /* compute new sort interval */
1214 sortintvl = ambclock - lastsort;
1215 if (sortintvl >= MAX_SORT_INTVL/2)
1216 sortintvl = MAX_SORT_INTVL;
1217 else
1218 sortintvl <<= 1; /* wait twice as long next */
1219 #ifdef DEBUG
1220 eputs("done\n");
1221 #endif
1222 }
1223 if (ambclock >= MAXACLOCK)
1224 ambclock = MAXACLOCK/2;
1225 lastsort = ambclock;
1226 }
1227
1228
1229 #ifdef F_SETLKW
1230
1231 static void
1232 aflock( /* lock/unlock ambient file */
1233 int typ
1234 )
1235 {
1236 static struct flock fls; /* static so initialized to zeroes */
1237
1238 if (typ == fls.l_type) /* already called? */
1239 return;
1240 fls.l_type = typ;
1241 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1242 error(SYSTEM, "cannot (un)lock ambient file");
1243 }
1244
1245
1246 int
1247 ambsync(void) /* synchronize ambient file */
1248 {
1249 long flen;
1250 AMBVAL avs;
1251 int n;
1252
1253 if (ambfp == NULL) /* no ambient file? */
1254 return(0);
1255 /* gain appropriate access */
1256 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1257 /* see if file has grown */
1258 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1259 goto seekerr;
1260 if ((n = flen - lastpos) > 0) { /* file has grown */
1261 if (ambinp == NULL) { /* use duplicate filedes */
1262 ambinp = fdopen(dup(fileno(ambfp)), "r");
1263 if (ambinp == NULL)
1264 error(SYSTEM, "fdopen failed in ambsync");
1265 }
1266 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1267 goto seekerr;
1268 while (n >= AMBVALSIZ) { /* load contributed values */
1269 if (!readambval(&avs, ambinp)) {
1270 sprintf(errmsg,
1271 "ambient file \"%s\" corrupted near character %ld",
1272 ambfile, flen - n);
1273 error(WARNING, errmsg);
1274 break;
1275 }
1276 avinsert(avstore(&avs));
1277 n -= AMBVALSIZ;
1278 }
1279 lastpos = flen - n;
1280 /*** seek always as safety measure
1281 if (n) ***/ /* alignment */
1282 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1283 goto seekerr;
1284 }
1285 n = fflush(ambfp); /* calls write() at last */
1286 if (n != EOF)
1287 lastpos += (long)nunflshed*AMBVALSIZ;
1288 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1289 goto seekerr;
1290
1291 aflock(F_UNLCK); /* release file */
1292 nunflshed = 0;
1293 return(n);
1294 seekerr:
1295 error(SYSTEM, "seek failed in ambsync");
1296 return -1; /* pro forma return */
1297 }
1298
1299 #else /* ! F_SETLKW */
1300
1301 int
1302 ambsync(void) /* flush ambient file */
1303 {
1304 if (ambfp == NULL)
1305 return(0);
1306 nunflshed = 0;
1307 return(fflush(ambfp));
1308 }
1309
1310 #endif /* ! F_SETLKW */
