root/radiance/ray/src/rt/ambient.c
Revision: 2.71
Committed: Fri Apr 11 20:31:37 2014 UTC (11 years ago) by greg
Changes since 2.70: +362 -71 lines
2 static const char RCSid[] = "$Id: ambient.c,v 2.70 2011/09/22 02:15:56 greg Exp $";
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 #include "copyright.h"
11
12 #include <string.h>
13
14 #include "platform.h"
15 #include "ray.h"
16 #include "otypes.h"
17 #include "resolu.h"
18 #include "ambient.h"
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 extern char *shm_boundary; /* memory sharing boundary */
26
27 #ifndef MAXASET
28 #define MAXASET 4095 /* maximum number of elements in ambient set */
29 #endif
30 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
31
32 double maxarad; /* maximum ambient radius */
33 double minarad; /* minimum ambient radius */
34
35 static AMBTREE atrunk; /* our ambient trunk node */
36
37 static FILE *ambfp = NULL; /* ambient file pointer */
38 static int nunflshed = 0; /* number of unflushed ambient values */
39
40 #ifndef SORT_THRESH
41 #ifdef SMLMEM
42 #define SORT_THRESH ((16L<<20)/sizeof(AMBVAL))
43 #else
44 #define SORT_THRESH ((64L<<20)/sizeof(AMBVAL))
45 #endif
46 #endif
47 #ifndef SORT_INTVL
48 #define SORT_INTVL (SORT_THRESH<<1)
49 #endif
50 #ifndef MAX_SORT_INTVL
51 #define MAX_SORT_INTVL (SORT_INTVL<<6)
52 #endif
53
54 static double avsum = 0.; /* computed ambient value sum (log) */
55 static unsigned int navsum = 0; /* number of values in avsum */
56 static unsigned int nambvals = 0; /* total number of indirect values */
57 static unsigned int nambshare = 0; /* number of values from file */
58 static unsigned long ambclock = 0; /* ambient access clock */
59 static unsigned long lastsort = 0; /* time of last value sort */
60 static long sortintvl = SORT_INTVL; /* time until next sort */
61 static FILE *ambinp = NULL; /* auxiliary file for input */
62 static long lastpos = -1; /* last flush position */
63
64 #define MAXACLOCK (1L<<30) /* clock turnover value */
65 /*
66 * Track access times unless we are sharing ambient values
67 * through memory on a multiprocessor, when we want to avoid
68 * claiming our own memory (copy on write). Go ahead anyway
69 * if more than two thirds of our values are unshared.
70 * Compile with -Dtracktime=0 to turn this code off.
71 */
72 #ifndef tracktime
73 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
74 #endif
75
76 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
77
78 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
79 #define freeav(av) free((void *)av);
80
81 static void initambfile(int creat);
82 static void avsave(AMBVAL *av);
83 static AMBVAL *avstore(AMBVAL *aval);
84 static AMBTREE *newambtree(void);
85 static void freeambtree(AMBTREE *atp);
86
87 typedef void unloadtf_t(AMBVAL *);
88 static unloadtf_t avinsert;
89 static unloadtf_t av2list;
90 static unloadtf_t avfree;
91 static void unloadatree(AMBTREE *at, unloadtf_t *f);
92
93 static int aposcmp(const void *avp1, const void *avp2);
94 static int avlmemi(AMBVAL *avaddr);
95 static void sortambvals(int always);
96
97 #ifdef F_SETLKW
98 static void aflock(int typ);
99 #endif
100
101
102 void
103 setambres( /* set ambient resolution */
104 int ar
105 )
106 {
107 ambres = ar < 0 ? 0 : ar; /* may be done already */
108 /* set min & max radii */
109 if (ar <= 0) {
110 minarad = 0;
111 maxarad = thescene.cusize / 2.0;
112 } else {
113 minarad = thescene.cusize / ar;
114 maxarad = 64 * minarad; /* heuristic */
115 if (maxarad > thescene.cusize / 2.0)
116 maxarad = thescene.cusize / 2.0;
117 }
118 if (minarad <= FTINY)
119 minarad = 10*FTINY;
120 if (maxarad <= minarad)
121 maxarad = 64 * minarad;
122 }
123
124
125 void
126 setambacc( /* set ambient accuracy */
127 double newa
128 )
129 {
130 double ambdiff;
131
132 if (newa < 0.0)
133 newa = 0.0;
134 ambdiff = fabs(newa - ambacc);
135 if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
136 sortambvals(1); /* rebuild tree */
137 }
138
139
140 void
141 setambient(void) /* initialize calculation */
142 {
143 int readonly = 0;
144 long flen;
145 AMBVAL amb;
146 /* make sure we're fresh */
147 ambdone();
148 /* init ambient limits */
149 setambres(ambres);
150 setambacc(ambacc);
151 if (ambfile == NULL || !ambfile[0])
152 return;
153 if (ambacc <= FTINY) {
154 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
155 ambfile);
156 error(WARNING, errmsg);
157 return;
158 }
159 /* open ambient file */
160 if ((ambfp = fopen(ambfile, "r+")) == NULL)
161 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
162 if (ambfp != NULL) {
163 initambfile(0); /* file exists */
164 lastpos = ftell(ambfp);
165 while (readambval(&amb, ambfp))
166 avinsert(avstore(&amb));
167 nambshare = nambvals; /* share loaded values */
168 if (readonly) {
169 sprintf(errmsg,
170 "loaded %u values from read-only ambient file",
171 nambvals);
172 error(WARNING, errmsg);
173 fclose(ambfp); /* close file so no writes */
174 ambfp = NULL;
175 return; /* avoid ambsync() */
176 }
177 /* align file pointer */
178 lastpos += (long)nambvals*AMBVALSIZ;
179 flen = lseek(fileno(ambfp), (off_t)0, SEEK_END);
180 if (flen != lastpos) {
181 sprintf(errmsg,
182 "ignoring last %ld values in ambient file (corrupted)",
183 (flen - lastpos)/AMBVALSIZ);
184 error(WARNING, errmsg);
185 fseek(ambfp, lastpos, SEEK_SET);
186 #ifndef _WIN32 /* XXX we need a replacement for that one */
187 ftruncate(fileno(ambfp), (off_t)lastpos);
188 #endif
189 }
190 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
191 initambfile(1); /* else create new file */
192 fflush(ambfp);
193 lastpos = ftell(ambfp);
194 } else {
195 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
196 error(SYSTEM, errmsg);
197 }
198 #ifdef getc_unlocked
199 flockfile(ambfp); /* application-level lock */
200 #endif
201 #ifdef F_SETLKW
202 aflock(F_UNLCK); /* release file */
203 #endif
204 }
205
206
207 void
208 ambdone(void) /* close ambient file and free memory */
209 {
210 if (ambfp != NULL) { /* close ambient file */
211 ambsync();
212 fclose(ambfp);
213 ambfp = NULL;
214 if (ambinp != NULL) {
215 fclose(ambinp);
216 ambinp = NULL;
217 }
218 lastpos = -1;
219 }
220 /* free ambient tree */
221 unloadatree(&atrunk, &avfree);
222 /* reset state variables */
223 avsum = 0.;
224 navsum = 0;
225 nambvals = 0;
226 nambshare = 0;
227 ambclock = 0;
228 lastsort = 0;
229 sortintvl = SORT_INTVL;
230 }
231
232
233 void
234 ambnotify( /* record new modifier */
235 OBJECT obj
236 )
237 {
238 static int hitlimit = 0;
239 OBJREC *o;
240 char **amblp;
241
242 if (obj == OVOID) { /* starting over */
243 ambset[0] = 0;
244 hitlimit = 0;
245 return;
246 }
247 o = objptr(obj);
248 if (hitlimit || !ismodifier(o->otype))
249 return;
250 for (amblp = amblist; *amblp != NULL; amblp++)
251 if (!strcmp(o->oname, *amblp)) {
252 if (ambset[0] >= MAXASET) {
253 error(WARNING, "too many modifiers in ambient list");
254 hitlimit++;
255 return; /* should this be fatal? */
256 }
257 insertelem(ambset, obj);
258 return;
259 }
260 }
261
262 /************ THE FOLLOWING ROUTINES DIFFER BETWEEN NEW & OLD ***************/
263
264 #ifdef NEWAMB
265
266 #define tfunc(lwr, x, upr) (((x)-(lwr)/((upr)-(lwr)))
267
268
269 void
270 multambient( /* compute ambient component & multiply by coef. */
271 COLOR aval,
272 RAY *r,
273 FVECT nrm
274 )
275 {
276 static int rdepth = 0; /* ambient recursion */
277 COLOR acol;
278 int ok;
279 double d, l;
280
281 if (ambdiv <= 0) /* no ambient calculation */
282 goto dumbamb;
283 /* check number of bounces */
284 if (rdepth >= ambounce)
285 goto dumbamb;
286 /* check ambient list */
287 if (ambincl != -1 && r->ro != NULL &&
288 ambincl != inset(ambset, r->ro->omod))
289 goto dumbamb;
290
291 if (ambacc <= FTINY) { /* no ambient storage */
292 copycolor(acol, aval);
293 rdepth++;
294 ok = doambient(acol, r, r->rweight, NULL, NULL, NULL, NULL);
295 rdepth--;
296 if (!ok)
297 goto dumbamb;
298 copycolor(aval, acol);
299 return;
300 }
301
302 if (tracktime) /* sort to minimize thrashing */
303 sortambvals(0);
304 /* interpolate ambient value */
305 setcolor(acol, 0.0, 0.0, 0.0);
306 d = sumambient(acol, r, nrm, rdepth,
307 &atrunk, thescene.cuorg, thescene.cusize);
308 if (d > FTINY) {
309 d = 1.0/d;
310 scalecolor(acol, d);
311 multcolor(aval, acol);
312 return;
313 }
314 rdepth++; /* need to cache new value */
315 ok = makeambient(acol, r, nrm, rdepth-1);
316 rdepth--;
317 if (ok) {
318 multcolor(aval, acol); /* got new value */
319 return;
320 }
321 dumbamb: /* return global value */
322 if ((ambvwt <= 0) | (navsum == 0)) {
323 multcolor(aval, ambval);
324 return;
325 }
326 l = bright(ambval); /* average in computations */
327 if (l > FTINY) {
328 d = (log(l)*(double)ambvwt + avsum) /
329 (double)(ambvwt + navsum);
330 d = exp(d) / l;
331 scalecolor(aval, d);
332 multcolor(aval, ambval); /* apply color of ambval */
333 } else {
334 d = exp( avsum / (double)navsum );
335 scalecolor(aval, d); /* neutral color */
336 }
337 }
338
339
340 double
341 sumambient( /* get interpolated ambient value */
342 COLOR acol,
343 RAY *r,
344 FVECT rn,
345 int al,
346 AMBTREE *at,
347 FVECT c0,
348 double s
349 )
350 { /* initial limit is ambacc radians */
351 const double maxangle = (ambacc-PI/2.)*pow(r->rweight,0.13) + PI/2.;
352 double wsum = 0.0;
353 FVECT ck0;
354 int i, j;
355 AMBVAL *av;
356 /* sum this node */
357 for (av = at->alist; av != NULL; av = av->next) {
358 double d, delta_r2, delta_t2;
359 COLOR ct;
360 FVECT uvw[3];
361 /* record access */
362 if (tracktime)
363 av->latick = ambclock;
364 /*
365 * Ambient level test.
366 */
367 if (av->lvl > al) /* list sorted, so this works */
368 break;
369 if (av->weight < 0.9*r->rweight)
370 continue;
371 /*
372 * Direction test using unperturbed normal.
373 */
374 decodedir(uvw[2], av->ndir);
375 d = DOT(uvw[2], r->ron);
376 if (d <= 0.0) /* >= 90 degrees */
377 continue;
378 delta_r2 = 2.0 - 2.0*d; /* approx. radians^2 */
379 if (delta_r2 >= maxangle*maxangle)
380 continue;
381 /*
382 * Ambient radius test.
383 */
384 decodedir(uvw[0], av->udir);
385 VCROSS(uvw[1], uvw[2], uvw[0]);
386 VSUB(ck0, av->pos, r->rop);
387 d = DOT(ck0, uvw[0]) / av->rad[0];
388 delta_t2 = d*d;
389 d = DOT(ck0, uvw[1]) / av->rad[1];
390 delta_t2 += d*d;
391 if (delta_t2 >= ambacc*ambacc)
392 continue;
393 /*
394 * Ray behind test.
395 */
396 d = 0.0;
397 for (j = 0; j < 3; j++)
398 d += (r->rop[j] - av->pos[j])*(uvw[2][j] + r->ron[j]);
399 if (d*0.5 < -minarad*ambacc-.001)
400 continue;
401 /*
402 * Convert to final weight (hat function)
403 */
404 d = tfunc(maxangle, sqrt(delta_r2), 0.0) *
405 tfunc(ambacc, sqrt(delta_t2), 0.0);
406 wsum += d;
407 extambient(ct, av, uvw, r->rop, rn);
408 scalecolor(ct, d);
409 addcolor(acol, ct);
410 }
411 if (at->kid == NULL)
412 return(wsum);
413 /* sum children */
414 s *= 0.5;
415 for (i = 0; i < 8; i++) {
416 for (j = 0; j < 3; j++) {
417 ck0[j] = c0[j];
418 if (1<<j & i)
419 ck0[j] += s;
420 if (r->rop[j] < ck0[j] - OCTSCALE*s)
421 break;
422 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
423 break;
424 }
425 if (j == 3)
426 wsum += sumambient(acol, r, rn, al,
427 at->kid+i, ck0, s);
428 }
429 return(wsum);
430 }
431
432
433 int
434 makeambient( /* make a new ambient value for storage */
435 COLOR acol,
436 RAY *r,
437 FVECT rn,
438 int al
439 )
440 {
441 AMBVAL amb;
442 FVECT uv[2];
443 int i;
444
445 amb.weight = 1.0; /* compute weight */
446 for (i = al; i-- > 0; )
447 amb.weight *= AVGREFL;
448 if (r->rweight < 0.1*amb.weight) /* heuristic override */
449 amb.weight = 1.25*r->rweight;
450 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
451 /* compute ambient */
452 if (!doambient(acol, r, amb.weight, uv, amb.rad, amb.gpos, amb.gdir)) {
453 setcolor(acol, 0.0, 0.0, 0.0);
454 return(0);
455 }
456 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
457 /* store value */
458 VCOPY(amb.pos, r->rop);
459 amb.ndir = encodedir(r->ron);
460 amb.udir = encodedir(uv[0]);
461 amb.lvl = al;
462 copycolor(amb.val, acol);
463 /* insert into tree */
464 avsave(&amb); /* and save to file */
465 if (rn != r->ron)
466 extambient(acol, &amb, r->rop, rn); /* texture */
467 return(1);
468 }
469
470
471 void
472 extambient( /* extrapolate value at pv, nv */
473 COLOR cr,
474 AMBVAL *ap,
475 FVECT uvw[3],
476 FVECT pv,
477 FVECT nv
478 )
479 {
480 FVECT v1;
481 int i;
482 double d = 1.0; /* zeroeth order */
483
484 for (i = 3; i--; ) /* gradient due to translation */
485 d += (pv[i] - ap->pos[i]) *
486 (ap->gpos[0]*uvw[0][i] + ap->gpos[1]*uvw[1][i]);
487
488 VCROSS(v1, uvw[2], nv); /* gradient due to rotation */
489 for (i = 3; i--; )
490 d += v1[i] * (ap->gdir[0]*uvw[0][i] + ap->gdir[1]*uvw[1][i]);
491
492 if (d <= 0.0) {
493 setcolor(cr, 0.0, 0.0, 0.0);
494 return;
495 }
496 copycolor(cr, ap->val);
497 scalecolor(cr, d);
498 }
499
500
501 static void
502 avinsert( /* insert ambient value in our tree */
503 AMBVAL *av
504 )
505 {
506 AMBTREE *at;
507 AMBVAL *ap;
508 AMBVAL avh;
509 FVECT ck0;
510 double s;
511 int branch;
512 int i;
513
514 if (av->rad[0] <= FTINY)
515 error(CONSISTENCY, "zero ambient radius in avinsert");
516 at = &atrunk;
517 VCOPY(ck0, thescene.cuorg);
518 s = thescene.cusize;
519 while (s*(OCTSCALE/2) > av->rad[1]*ambacc) {
520 if (at->kid == NULL)
521 if ((at->kid = newambtree()) == NULL)
522 error(SYSTEM, "out of memory in avinsert");
523 s *= 0.5;
524 branch = 0;
525 for (i = 0; i < 3; i++)
526 if (av->pos[i] > ck0[i] + s) {
527 ck0[i] += s;
528 branch |= 1 << i;
529 }
530 at = at->kid + branch;
531 }
532 avh.next = at->alist; /* order by increasing level */
533 for (ap = &avh; ap->next != NULL; ap = ap->next)
534 if (ap->next->lvl >= av->lvl)
535 break;
536 av->next = ap->next;
537 ap->next = (AMBVAL*)av;
538 at->alist = avh.next;
539 }
540
541
542 #else /* ! NEWAMB */
543
544
545 void
546 multambient( /* compute ambient component & multiply by coef. */
547 COLOR aval,
548 RAY *r,
549 FVECT nrm
550 )
551 {
552 static int rdepth = 0; /* ambient recursion */
553 COLOR acol;
554 double d, l;
555
556 if (ambdiv <= 0) /* no ambient calculation */
557 goto dumbamb;
558 /* check number of bounces */
559 if (rdepth >= ambounce)
560 goto dumbamb;
561 /* check ambient list */
562 if (ambincl != -1 && r->ro != NULL &&
563 ambincl != inset(ambset, r->ro->omod))
564 goto dumbamb;
565
566 if (ambacc <= FTINY) { /* no ambient storage */
567 copycolor(acol, aval);
568 rdepth++;
569 d = doambient(acol, r, r->rweight, NULL, NULL);
570 rdepth--;
571 if (d <= FTINY)
572 goto dumbamb;
573 copycolor(aval, acol);
574 return;
575 }
576
577 if (tracktime) /* sort to minimize thrashing */
578 sortambvals(0);
579 /* interpolate ambient value */
580 setcolor(acol, 0.0, 0.0, 0.0);
581 d = sumambient(acol, r, nrm, rdepth,
582 &atrunk, thescene.cuorg, thescene.cusize);
583 if (d > FTINY) {
584 d = 1.0/d;
585 scalecolor(acol, d);
586 multcolor(aval, acol);
587 return;
588 }
589 rdepth++; /* need to cache new value */
590 d = makeambient(acol, r, nrm, rdepth-1);
591 rdepth--;
592 if (d > FTINY) {
593 multcolor(aval, acol); /* got new value */
594 return;
595 }
596 dumbamb: /* return global value */
597 if ((ambvwt <= 0) | (navsum == 0)) {
598 multcolor(aval, ambval);
599 return;
600 }
601 l = bright(ambval); /* average in computations */
602 if (l > FTINY) {
603 d = (log(l)*(double)ambvwt + avsum) /
604 (double)(ambvwt + navsum);
605 d = exp(d) / l;
606 scalecolor(aval, d);
607 multcolor(aval, ambval); /* apply color of ambval */
608 } else {
609 d = exp( avsum / (double)navsum );
610 scalecolor(aval, d); /* neutral color */
611 }
612 }
613
614
615 double
616 sumambient( /* get interpolated ambient value */
617 COLOR acol,
618 RAY *r,
619 FVECT rn,
620 int al,
621 AMBTREE *at,
622 FVECT c0,
623 double s
624 )
625 {
626 double d, e1, e2, wt, wsum;
627 COLOR ct;
628 FVECT ck0;
629 int i;
630 int j;
631 AMBVAL *av;
632
633 wsum = 0.0;
634 /* do this node */
635 for (av = at->alist; av != NULL; av = av->next) {
636 double rn_dot = -2.0;
637 if (tracktime)
638 av->latick = ambclock;
639 /*
640 * Ambient level test.
641 */
642 if (av->lvl > al) /* list sorted, so this works */
643 break;
644 if (av->weight < 0.9*r->rweight)
645 continue;
646 /*
647 * Ambient radius test.
648 */
649 VSUB(ck0, av->pos, r->rop);
650 e1 = DOT(ck0, ck0) / (av->rad * av->rad);
651 if (e1 > ambacc*ambacc*1.21)
652 continue;
653 /*
654 * Direction test using closest normal.
655 */
656 d = DOT(av->dir, r->ron);
657 if (rn != r->ron) {
658 rn_dot = DOT(av->dir, rn);
659 if (rn_dot > 1.0-FTINY)
660 rn_dot = 1.0-FTINY;
661 if (rn_dot >= d-FTINY) {
662 d = rn_dot;
663 rn_dot = -2.0;
664 }
665 }
666 e2 = (1.0 - d) * r->rweight;
667 if (e2 < 0.0)
668 e2 = 0.0;
669 else if (e1 + e2 > ambacc*ambacc*1.21)
670 continue;
671 /*
672 * Ray behind test.
673 */
674 d = 0.0;
675 for (j = 0; j < 3; j++)
676 d += (r->rop[j] - av->pos[j]) *
677 (av->dir[j] + r->ron[j]);
678 if (d*0.5 < -minarad*ambacc-.001)
679 continue;
680 /*
681 * Jittering final test reduces image artifacts.
682 */
683 e1 = sqrt(e1);
684 e2 = sqrt(e2);
685 wt = e1 + e2;
686 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
687 continue;
688 /*
689 * Recompute directional error using perturbed normal
690 */
691 if (rn_dot > 0.0) {
692 e2 = sqrt((1.0 - rn_dot)*r->rweight);
693 wt = e1 + e2;
694 }
695 if (wt <= 1e-3)
696 wt = 1e3;
697 else
698 wt = 1.0 / wt;
699 wsum += wt;
700 extambient(ct, av, r->rop, rn);
701 scalecolor(ct, wt);
702 addcolor(acol, ct);
703 }
704 if (at->kid == NULL)
705 return(wsum);
706 /* do children */
707 s *= 0.5;
708 for (i = 0; i < 8; i++) {
709 for (j = 0; j < 3; j++) {
710 ck0[j] = c0[j];
711 if (1<<j & i)
712 ck0[j] += s;
713 if (r->rop[j] < ck0[j] - OCTSCALE*s)
714 break;
715 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
716 break;
717 }
718 if (j == 3)
719 wsum += sumambient(acol, r, rn, al,
720 at->kid+i, ck0, s);
721 }
722 return(wsum);
723 }
724
725
726 double
727 makeambient( /* make a new ambient value for storage */
728 COLOR acol,
729 RAY *r,
730 FVECT rn,
731 int al
732 )
733 {
734 AMBVAL amb;
735 FVECT gp, gd;
736 int i;
737
738 amb.weight = 1.0; /* compute weight */
739 for (i = al; i-- > 0; )
740 amb.weight *= AVGREFL;
741 if (r->rweight < 0.1*amb.weight) /* heuristic override */
742 amb.weight = 1.25*r->rweight;
743 setcolor(acol, AVGREFL, AVGREFL, AVGREFL);
744 /* compute ambient */
745 amb.rad = doambient(acol, r, amb.weight, gp, gd);
746 if (amb.rad <= FTINY) {
747 setcolor(acol, 0.0, 0.0, 0.0);
748 return(0.0);
749 }
750 scalecolor(acol, 1./AVGREFL); /* undo assumed reflectance */
751 /* store value */
752 VCOPY(amb.pos, r->rop);
753 VCOPY(amb.dir, r->ron);
754 amb.lvl = al;
755 copycolor(amb.val, acol);
756 VCOPY(amb.gpos, gp);
757 VCOPY(amb.gdir, gd);
758 /* insert into tree */
759 avsave(&amb); /* and save to file */
760 if (rn != r->ron)
761 extambient(acol, &amb, r->rop, rn); /* texture */
762 return(amb.rad);
763 }
764
765
766 void
767 extambient( /* extrapolate value at pv, nv */
768 COLOR cr,
769 AMBVAL *ap,
770 FVECT pv,
771 FVECT nv
772 )
773 {
774 FVECT v1;
775 int i;
776 double d;
777
778 d = 1.0; /* zeroeth order */
779 /* gradient due to translation */
780 for (i = 0; i < 3; i++)
781 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
782 /* gradient due to rotation */
783 VCROSS(v1, ap->dir, nv);
784 d += DOT(ap->gdir, v1);
785 if (d <= 0.0) {
786 setcolor(cr, 0.0, 0.0, 0.0);
787 return;
788 }
789 copycolor(cr, ap->val);
790 scalecolor(cr, d);
791 }
792
793
794 static void
795 avinsert( /* insert ambient value in our tree */
796 AMBVAL *av
797 )
798 {
799 AMBTREE *at;
800 AMBVAL *ap;
801 AMBVAL avh;
802 FVECT ck0;
803 double s;
804 int branch;
805 int i;
806
807 if (av->rad <= FTINY)
808 error(CONSISTENCY, "zero ambient radius in avinsert");
809 at = &atrunk;
810 VCOPY(ck0, thescene.cuorg);
811 s = thescene.cusize;
812 while (s*(OCTSCALE/2) > av->rad*ambacc) {
813 if (at->kid == NULL)
814 if ((at->kid = newambtree()) == NULL)
815 error(SYSTEM, "out of memory in avinsert");
816 s *= 0.5;
817 branch = 0;
818 for (i = 0; i < 3; i++)
819 if (av->pos[i] > ck0[i] + s) {
820 ck0[i] += s;
821 branch |= 1 << i;
822 }
823 at = at->kid + branch;
824 }
825 avh.next = at->alist; /* order by increasing level */
826 for (ap = &avh; ap->next != NULL; ap = ap->next)
827 if (ap->next->lvl >= av->lvl)
828 break;
829 av->next = ap->next;
830 ap->next = (AMBVAL*)av;
831 at->alist = avh.next;
832 }
833
834 #endif /* ! NEWAMB */
835
836 /************* FOLLOWING ROUTINES SAME FOR NEW & OLD METHODS ***************/
837
838 static void
839 initambfile( /* initialize ambient file */
840 int cre8
841 )
842 {
843 extern char *progname, *octname;
844 static char *mybuf = NULL;
845
846 #ifdef F_SETLKW
847 aflock(cre8 ? F_WRLCK : F_RDLCK);
848 #endif
849 SET_FILE_BINARY(ambfp);
850 if (mybuf == NULL)
851 mybuf = (char *)bmalloc(BUFSIZ+8);
852 setbuf(ambfp, mybuf);
853 if (cre8) { /* new file */
854 newheader("RADIANCE", ambfp);
855 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
856 progname, colval(ambval,RED),
857 colval(ambval,GRN), colval(ambval,BLU),
858 ambvwt, ambounce, ambacc);
859 fprintf(ambfp, "-ad %d -as %d -ar %d ",
860 ambdiv, ambssamp, ambres);
861 if (octname != NULL)
862 fputs(octname, ambfp);
863 fputc('\n', ambfp);
864 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
865 fputnow(ambfp);
866 fputformat(AMBFMT, ambfp);
867 fputc('\n', ambfp);
868 putambmagic(ambfp);
869 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
870 error(USER, "bad ambient file");
871 }
872
873
874 static void
875 avsave( /* insert and save an ambient value */
876 AMBVAL *av
877 )
878 {
879 avinsert(avstore(av));
880 if (ambfp == NULL)
881 return;
882 if (writambval(av, ambfp) < 0)
883 goto writerr;
884 if (++nunflshed >= AMBFLUSH)
885 if (ambsync() == EOF)
886 goto writerr;
887 return;
888 writerr:
889 error(SYSTEM, "error writing to ambient file");
890 }
891
892
893 static AMBVAL *
894 avstore( /* allocate memory and store aval */
895 AMBVAL *aval
896 )
897 {
898 AMBVAL *av;
899 double d;
900
901 if ((av = newambval()) == NULL)
902 error(SYSTEM, "out of memory in avstore");
903 *av = *aval;
904 av->latick = ambclock;
905 av->next = NULL;
906 nambvals++;
907 d = bright(av->val);
908 if (d > FTINY) { /* add to log sum for averaging */
909 avsum += log(d);
910 navsum++;
911 }
912 return(av);
913 }
914
915
916 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
917
918 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
919
920
921 static AMBTREE *
922 newambtree(void) /* allocate 8 ambient tree structs */
923 {
924 AMBTREE *atp, *upperlim;
925
926 if (atfreelist == NULL) { /* get more nodes */
927 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
928 if (atfreelist == NULL)
929 return(NULL);
930 /* link new free list */
931 upperlim = atfreelist + 8*(ATALLOCSZ-1);
932 for (atp = atfreelist; atp < upperlim; atp += 8)
933 atp->kid = atp + 8;
934 atp->kid = NULL;
935 }
936 atp = atfreelist;
937 atfreelist = atp->kid;
938 memset((char *)atp, '\0', 8*sizeof(AMBTREE));
939 return(atp);
940 }
941
942
943 static void
944 freeambtree( /* free 8 ambient tree structs */
945 AMBTREE *atp
946 )
947 {
948 atp->kid = atfreelist;
949 atfreelist = atp;
950 }
951
952
953 static void
954 unloadatree( /* unload an ambient value tree */
955 AMBTREE *at,
956 unloadtf_t *f
957 )
958 {
959 AMBVAL *av;
960 int i;
961 /* transfer values at this node */
962 for (av = at->alist; av != NULL; av = at->alist) {
963 at->alist = av->next;
964 (*f)(av);
965 }
966 if (at->kid == NULL)
967 return;
968 for (i = 0; i < 8; i++) /* transfer and free children */
969 unloadatree(at->kid+i, f);
970 freeambtree(at->kid);
971 at->kid = NULL;
972 }
973
974
975 static struct avl {
976 AMBVAL *p;
977 unsigned long t;
978 } *avlist1; /* ambient value list with ticks */
979 static AMBVAL **avlist2; /* memory positions for sorting */
980 static int i_avlist; /* index for lists */
981
982 static int alatcmp(const void *av1, const void *av2);
983
984 static void
985 avfree(AMBVAL *av)
986 {
987 free(av);
988 }
989
990 static void
991 av2list(
992 AMBVAL *av
993 )
994 {
995 #ifdef DEBUG
996 if (i_avlist >= nambvals)
997 error(CONSISTENCY, "too many ambient values in av2list1");
998 #endif
999 avlist1[i_avlist].p = avlist2[i_avlist] = (AMBVAL*)av;
1000 avlist1[i_avlist++].t = av->latick;
1001 }
1002
1003
1004 static int
1005 alatcmp( /* compare ambient values for MRA */
1006 const void *av1,
1007 const void *av2
1008 )
1009 {
1010 long lc = ((struct avl *)av2)->t - ((struct avl *)av1)->t;
1011 return(lc<0 ? -1 : lc>0 ? 1 : 0);
1012 }
1013
1014
1015 /* GW NOTE 2002/10/3:
1016 * I used to compare AMBVAL pointers, but found that this was the
1017 * cause of a serious consistency error with gcc, since the optimizer
1018 * uses some dangerous trick in pointer subtraction that
1019 * assumes pointers differ by exact struct size increments.
1020 */
1021 static int
1022 aposcmp( /* compare ambient value positions */
1023 const void *avp1,
1024 const void *avp2
1025 )
1026 {
1027 long diff = *(char * const *)avp1 - *(char * const *)avp2;
1028 if (diff < 0)
1029 return(-1);
1030 return(diff > 0);
1031 }
1032
1033
1034 static int
1035 avlmemi( /* find list position from address */
1036 AMBVAL *avaddr
1037 )
1038 {
1039 AMBVAL **avlpp;
1040
1041 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
1042 nambvals, sizeof(AMBVAL *), &aposcmp);
1043 if (avlpp == NULL)
1044 error(CONSISTENCY, "address not found in avlmemi");
1045 return(avlpp - avlist2);
1046 }
1047
1048
1049 static void
1050 sortambvals( /* resort ambient values */
1051 int always
1052 )
1053 {
1054 AMBTREE oldatrunk;
1055 AMBVAL tav, *tap, *pnext;
1056 int i, j;
1057 /* see if it's time yet */
1058 if (!always && (ambclock++ < lastsort+sortintvl ||
1059 nambvals < SORT_THRESH))
1060 return;
1061 /*
1062 * The idea here is to minimize memory thrashing
1063 * in VM systems by improving reference locality.
1064 * We do this by periodically sorting our stored ambient
1065 * values in memory in order of most recently to least
1066 * recently accessed. This ordering was chosen so that new
1067 * ambient values (which tend to be less important) go into
1068 * higher memory with the infrequently accessed values.
1069 * Since we expect our values to need sorting less
1070 * frequently as the process continues, we double our
1071 * waiting interval after each call.
1072 * This routine is also called by setambacc() with
1073 * the "always" parameter set to 1 so that the ambient
1074 * tree will be rebuilt with the new accuracy parameter.
1075 */
1076 if (tracktime) { /* allocate pointer arrays to sort */
1077 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
1078 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
1079 } else {
1080 avlist2 = NULL;
1081 avlist1 = NULL;
1082 }
1083 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
1084 if (avlist2 != NULL)
1085 free((void *)avlist2);
1086 if (always) { /* rebuild without sorting */
1087 oldatrunk = atrunk;
1088 atrunk.alist = NULL;
1089 atrunk.kid = NULL;
1090 unloadatree(&oldatrunk, &avinsert);
1091 }
1092 } else { /* sort memory by last access time */
1093 /*
1094 * Sorting memory is tricky because it isn't contiguous.
1095 * We have to sort an array of pointers by MRA and also
1096 * by memory position. We then copy values in "loops"
1097 * to minimize memory hits. Nevertheless, we will visit
1098 * everyone at least twice, and this is an expensive process
1099 * when we're thrashing, which is when we need to do it.
1100 */
1101 #ifdef DEBUG
1102 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
1103 nambvals, ambclock);
1104 eputs(errmsg);
1105 #endif
1106 i_avlist = 0;
1107 unloadatree(&atrunk, &av2list); /* empty current tree */
1108 #ifdef DEBUG
1109 if (i_avlist < nambvals)
1110 error(CONSISTENCY, "missing ambient values in sortambvals");
1111 #endif
1112 qsort((char *)avlist1, nambvals, sizeof(struct avl), &alatcmp);
1113 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), &aposcmp);
1114 for (i = 0; i < nambvals; i++) {
1115 if (avlist1[i].p == NULL)
1116 continue;
1117 tap = avlist2[i];
1118 tav = *tap;
1119 for (j = i; (pnext = avlist1[j].p) != tap;
1120 j = avlmemi(pnext)) {
1121 *(avlist2[j]) = *pnext;
1122 avinsert(avlist2[j]);
1123 avlist1[j].p = NULL;
1124 }
1125 *(avlist2[j]) = tav;
1126 avinsert(avlist2[j]);
1127 avlist1[j].p = NULL;
1128 }
1129 free((void *)avlist1);
1130 free((void *)avlist2);
1131 /* compute new sort interval */
1132 sortintvl = ambclock - lastsort;
1133 if (sortintvl >= MAX_SORT_INTVL/2)
1134 sortintvl = MAX_SORT_INTVL;
1135 else
1136 sortintvl <<= 1; /* wait twice as long next */
1137 #ifdef DEBUG
1138 eputs("done\n");
1139 #endif
1140 }
1141 if (ambclock >= MAXACLOCK)
1142 ambclock = MAXACLOCK/2;
1143 lastsort = ambclock;
1144 }
1145
1146
1147 #ifdef F_SETLKW
1148
1149 static void
1150 aflock( /* lock/unlock ambient file */
1151 int typ
1152 )
1153 {
1154 static struct flock fls; /* static so initialized to zeroes */
1155
1156 if (typ == fls.l_type) /* already called? */
1157 return;
1158 fls.l_type = typ;
1159 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
1160 error(SYSTEM, "cannot (un)lock ambient file");
1161 }
1162
1163
1164 int
1165 ambsync(void) /* synchronize ambient file */
1166 {
1167 long flen;
1168 AMBVAL avs;
1169 int n;
1170
1171 if (ambfp == NULL) /* no ambient file? */
1172 return(0);
1173 /* gain appropriate access */
1174 aflock(nunflshed ? F_WRLCK : F_RDLCK);
1175 /* see if file has grown */
1176 if ((flen = lseek(fileno(ambfp), (off_t)0, SEEK_END)) < 0)
1177 goto seekerr;
1178 if ((n = flen - lastpos) > 0) { /* file has grown */
1179 if (ambinp == NULL) { /* use duplicate filedes */
1180 ambinp = fdopen(dup(fileno(ambfp)), "r");
1181 if (ambinp == NULL)
1182 error(SYSTEM, "fdopen failed in ambsync");
1183 }
1184 if (fseek(ambinp, lastpos, SEEK_SET) < 0)
1185 goto seekerr;
1186 while (n >= AMBVALSIZ) { /* load contributed values */
1187 if (!readambval(&avs, ambinp)) {
1188 sprintf(errmsg,
1189 "ambient file \"%s\" corrupted near character %ld",
1190 ambfile, flen - n);
1191 error(WARNING, errmsg);
1192 break;
1193 }
1194 avinsert(avstore(&avs));
1195 n -= AMBVALSIZ;
1196 }
1197 lastpos = flen - n;
1198 /*** seek always as safety measure
1199 if (n) ***/ /* alignment */
1200 if (lseek(fileno(ambfp), (off_t)lastpos, SEEK_SET) < 0)
1201 goto seekerr;
1202 }
1203 n = fflush(ambfp); /* calls write() at last */
1204 if (n != EOF)
1205 lastpos += (long)nunflshed*AMBVALSIZ;
1206 else if ((lastpos = lseek(fileno(ambfp), (off_t)0, SEEK_CUR)) < 0)
1207 goto seekerr;
1208
1209 aflock(F_UNLCK); /* release file */
1210 nunflshed = 0;
1211 return(n);
1212 seekerr:
1213 error(SYSTEM, "seek failed in ambsync");
1214 return -1; /* pro forma return */
1215 }
1216
1217 #else /* ! F_SETLKW */
1218
1219 int
1220 ambsync(void) /* flush ambient file */
1221 {
1222 if (ambfp == NULL)
1223 return(0);
1224 nunflshed = 0;
1225 return(fflush(ambfp));
1226 }
1227
1228 #endif /* ! F_SETLKW */
