root/radiance/ray/src/rt/ambient.c
Revision: 2.47
Committed: Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.46: +183 -61 lines
5 * ambient.c - routines dealing with ambient (inter-reflected) component.
6 *
7 * Declarations of external symbols in ambient.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "ray.h"
68
69 #include "otypes.h"
70
71 #include "ambient.h"
72
73 #include "random.h"
74
75 #ifndef OCTSCALE
76 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
77 #endif
78
79 extern char *shm_boundary; /* memory sharing boundary */
80
81 #define MAXASET 511 /* maximum number of elements in ambient set */
82 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
83
84 double maxarad; /* maximum ambient radius */
85 double minarad; /* minimum ambient radius */
86
87 static AMBTREE atrunk; /* our ambient trunk node */
88
89 static FILE *ambfp = NULL; /* ambient file pointer */
90 static int nunflshed = 0; /* number of unflushed ambient values */
91
92 #ifndef SORT_THRESH
93 #ifdef BIGMEM
94 #define SORT_THRESH ((9L<<20)/sizeof(AMBVAL))
95 #else
96 #define SORT_THRESH ((3L<<20)/sizeof(AMBVAL))
97 #endif
98 #endif
99 #ifndef SORT_INTVL
100 #define SORT_INTVL (SORT_THRESH<<1)
101 #endif
102 #ifndef MAX_SORT_INTVL
103 #define MAX_SORT_INTVL (SORT_INTVL<<6)
104 #endif
105
106 static double avsum = 0.; /* computed ambient value sum (log) */
107 static unsigned int navsum = 0; /* number of values in avsum */
108 static unsigned int nambvals = 0; /* total number of indirect values */
109 static unsigned int nambshare = 0; /* number of values from file */
110 static unsigned long ambclock = 0; /* ambient access clock */
111 static unsigned long lastsort = 0; /* time of last value sort */
112 static long sortintvl = SORT_INTVL; /* time until next sort */
113 static FILE *ambinp = NULL; /* auxiliary file for input */
114 static long lastpos = -1; /* last flush position */
115
116 #define MAXACLOCK (1L<<30) /* clock turnover value */
117 /*
118 * Track access times unless we are sharing ambient values
119 * through memory on a multiprocessor, when we want to avoid
120 * claiming our own memory (copy on write). Go ahead anyway
121 * if more than two thirds of our values are unshared.
122 * Compile with -Dtracktime=0 to turn this code off.
123 */
124 #ifndef tracktime
125 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
126 #endif
127
128 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
129
130 #define newambval() (AMBVAL *)malloc(sizeof(AMBVAL))
131 #define freeav(av) free((void *)av);
132
133 static void initambfile(), avsave(), avinsert(), sortambvals(), unloadatree();
134 static int avlmemi();
135 static AMBVAL *avstore();
136 #ifdef F_SETLKW
137 static void aflock();
138 #endif
139
140
141 void
142 setambres(ar) /* set ambient resolution */
143 int ar;
144 {
145 ambres = ar < 0 ? 0 : ar; /* may be done already */
146 /* set min & max radii */
147 if (ar <= 0) {
148 minarad = 0;
149 maxarad = thescene.cusize / 2.0;
150 } else {
151 minarad = thescene.cusize / ar;
152 maxarad = 64 * minarad; /* heuristic */
153 if (maxarad > thescene.cusize / 2.0)
154 maxarad = thescene.cusize / 2.0;
155 }
156 if (minarad <= FTINY)
157 minarad = 10*FTINY;
158 if (maxarad <= minarad)
159 maxarad = 64 * minarad;
160 }
161
162
163 void
164 setambacc(newa) /* set ambient accuracy */
165 double newa;
166 {
167 double ambdiff;
168
169 if (newa < 0.0)
170 newa = 0.0;
171 ambdiff = fabs(newa - ambacc);
172 if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
173 sortambvals(1); /* rebuild tree */
174 }
175
176
177 void
178 setambient() /* initialize calculation */
179 {
180 int readonly = 0;
181 long pos, flen;
182 AMBVAL amb;
183 /* make sure we're fresh */
184 ambdone();
185 /* init ambient limits */
186 setambres(ambres);
187 setambacc(ambacc);
188 if (ambfile == NULL || !ambfile[0])
189 return;
190 if (ambacc <= FTINY) {
191 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
192 ambfile);
193 error(WARNING, errmsg);
194 return;
195 }
196 /* open ambient file */
197 if ((ambfp = fopen(ambfile, "r+")) == NULL)
198 readonly = (ambfp = fopen(ambfile, "r")) != NULL;
199 if (ambfp != NULL) {
200 initambfile(0); /* file exists */
201 pos = ftell(ambfp);
202 while (readambval(&amb, ambfp))
203 avinsert(avstore(&amb));
204 nambshare = nambvals; /* share loaded values */
205 if (readonly) {
206 sprintf(errmsg,
207 "loaded %u values from read-only ambient file",
208 nambvals);
209 error(WARNING, errmsg);
210 fclose(ambfp); /* close file so no writes */
211 ambfp = NULL;
212 return; /* avoid ambsync() */
213 }
214 /* align file pointer */
215 pos += (long)nambvals*AMBVALSIZ;
216 flen = lseek(fileno(ambfp), (off_t)0L, 2);
217 if (flen != pos) {
218 sprintf(errmsg,
219 "ignoring last %ld values in ambient file (corrupted)",
220 (flen - pos)/AMBVALSIZ);
221 error(WARNING, errmsg);
222 fseek(ambfp, pos, 0);
223 ftruncate(fileno(ambfp), (off_t)pos);
224 }
225 } else if ((ambfp = fopen(ambfile, "w+")) != NULL) {
226 initambfile(1); /* else create new file */
227 } else {
228 sprintf(errmsg, "cannot open ambient file \"%s\"", ambfile);
229 error(SYSTEM, errmsg);
230 }
231 nunflshed++; /* lie */
232 ambsync();
233 }
234
235
236 void
237 ambdone() /* close ambient file and free memory */
238 {
239 if (ambfp != NULL) { /* close ambient file */
240 ambsync();
241 fclose(ambfp);
242 ambfp = NULL;
243 if (ambinp != NULL) {
244 fclose(ambinp);
245 ambinp = NULL;
246 }
247 lastpos = -1;
248 }
249 /* free ambient tree */
250 unloadatree(&atrunk, free);
251 /* reset state variables */
252 avsum = 0.;
253 navsum = 0;
254 nambvals = 0;
255 nambshare = 0;
256 ambclock = 0;
257 lastsort = 0;
258 sortintvl = SORT_INTVL;
259 }
260
261
262 void
263 ambnotify(obj) /* record new modifier */
264 OBJECT obj;
265 {
266 static int hitlimit = 0;
267 register OBJREC *o;
268 register char **amblp;
269
270 if (obj == OVOID) { /* starting over */
271 ambset[0] = 0;
272 hitlimit = 0;
273 return;
274 }
275 o = objptr(obj);
276 if (hitlimit || !ismodifier(o->otype))
277 return;
278 for (amblp = amblist; *amblp != NULL; amblp++)
279 if (!strcmp(o->oname, *amblp)) {
280 if (ambset[0] >= MAXASET) {
281 error(WARNING, "too many modifiers in ambient list");
282 hitlimit++;
283 return; /* should this be fatal? */
284 }
285 insertelem(ambset, obj);
286 return;
287 }
288 }
289
290
291 void
292 ambient(acol, r, nrm) /* compute ambient component for ray */
293 COLOR acol;
294 register RAY *r;
295 FVECT nrm;
296 {
297 static int rdepth = 0; /* ambient recursion */
298 double d, l;
299
300 if (ambdiv <= 0) /* no ambient calculation */
301 goto dumbamb;
302 /* check number of bounces */
303 if (rdepth >= ambounce)
304 goto dumbamb;
305 /* check ambient list */
306 if (ambincl != -1 && r->ro != NULL &&
307 ambincl != inset(ambset, r->ro->omod))
308 goto dumbamb;
309
310 if (ambacc <= FTINY) { /* no ambient storage */
311 rdepth++;
312 d = doambient(acol, r, r->rweight, NULL, NULL);
313 rdepth--;
314 if (d <= FTINY)
315 goto dumbamb;
316 return;
317 }
318
319 if (tracktime) /* sort to minimize thrashing */
320 sortambvals(0);
321 /* get ambient value */
322 setcolor(acol, 0.0, 0.0, 0.0);
323 d = sumambient(acol, r, nrm, rdepth,
324 &atrunk, thescene.cuorg, thescene.cusize);
325 if (d > FTINY) {
326 scalecolor(acol, 1.0/d);
327 return;
328 }
329 rdepth++; /* need to cache new value */
330 d = makeambient(acol, r, nrm, rdepth-1);
331 rdepth--;
332 if (d > FTINY)
333 return;
334 dumbamb: /* return global value */
335 copycolor(acol, ambval);
336 if (ambvwt <= 0 | navsum == 0)
337 return;
338 l = bright(ambval); /* average in computations */
339 if (l > FTINY) {
340 d = (log(l)*(double)ambvwt + avsum) /
341 (double)(ambvwt + navsum);
342 d = exp(d) / l;
343 scalecolor(acol, d); /* apply color of ambval */
344 } else {
345 d = exp( avsum / (double)navsum );
346 setcolor(acol, d, d, d); /* neutral color */
347 }
348 }
349
350
351 double
352 sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */
353 COLOR acol;
354 register RAY *r;
355 FVECT rn;
356 int al;
357 AMBTREE *at;
358 FVECT c0;
359 double s;
360 {
361 double d, e1, e2, wt, wsum;
362 COLOR ct;
363 FVECT ck0;
364 int i;
365 register int j;
366 register AMBVAL *av;
367
368 wsum = 0.0;
369 /* do this node */
370 for (av = at->alist; av != NULL; av = av->next) {
371 double rn_dot = -2.0;
372 if (tracktime)
373 av->latick = ambclock;
374 /*
375 * Ambient level test.
376 */
377 if (av->lvl > al) /* list sorted, so this works */
378 break;
379 if (av->weight < r->rweight-FTINY)
380 continue;
381 /*
382 * Ambient radius test.
383 */
384 d = av->pos[0] - r->rop[0];
385 e1 = d * d;
386 d = av->pos[1] - r->rop[1];
387 e1 += d * d;
388 d = av->pos[2] - r->rop[2];
389 e1 += d * d;
390 e1 /= av->rad * av->rad;
391 if (e1 > ambacc*ambacc*1.21)
392 continue;
393 /*
394 * Direction test using closest normal.
395 */
396 d = DOT(av->dir, r->ron);
397 if (rn != r->ron) {
398 rn_dot = DOT(av->dir, rn);
399 if (rn_dot > 1.0-FTINY)
400 rn_dot = 1.0-FTINY;
401 if (rn_dot >= d-FTINY) {
402 d = rn_dot;
403 rn_dot = -2.0;
404 }
405 }
406 e2 = (1.0 - d) * r->rweight;
407 if (e2 < 0.0) e2 = 0.0;
408 if (e1 + e2 > ambacc*ambacc*1.21)
409 continue;
410 /*
411 * Ray behind test.
412 */
413 d = 0.0;
414 for (j = 0; j < 3; j++)
415 d += (r->rop[j] - av->pos[j]) *
416 (av->dir[j] + r->ron[j]);
417 if (d*0.5 < -minarad*ambacc-.001)
418 continue;
419 /*
420 * Jittering final test reduces image artifacts.
421 */
422 e1 = sqrt(e1);
423 e2 = sqrt(e2);
424 wt = e1 + e2;
425 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
426 continue;
427 /*
428 * Recompute directional error using perturbed normal
429 */
430 if (rn_dot > 0.0) {
431 e2 = sqrt((1.0 - rn_dot)*r->rweight);
432 wt = e1 + e2;
433 }
434 if (wt <= 1e-3)
435 wt = 1e3;
436 else
437 wt = 1.0 / wt;
438 wsum += wt;
439 extambient(ct, av, r->rop, rn);
440 scalecolor(ct, wt);
441 addcolor(acol, ct);
442 }
443 if (at->kid == NULL)
444 return(wsum);
445 /* do children */
446 s *= 0.5;
447 for (i = 0; i < 8; i++) {
448 for (j = 0; j < 3; j++) {
449 ck0[j] = c0[j];
450 if (1<<j & i)
451 ck0[j] += s;
452 if (r->rop[j] < ck0[j] - OCTSCALE*s)
453 break;
454 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
455 break;
456 }
457 if (j == 3)
458 wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s);
459 }
460 return(wsum);
461 }
462
463
464 double
465 makeambient(acol, r, rn, al) /* make a new ambient value */
466 COLOR acol;
467 register RAY *r;
468 FVECT rn;
469 int al;
470 {
471 AMBVAL amb;
472 FVECT gp, gd;
473 /* compute weight */
474 amb.weight = pow(AVGREFL, (double)al);
475 if (r->rweight < 0.1*amb.weight) /* heuristic */
476 amb.weight = r->rweight;
477 /* compute ambient */
478 amb.rad = doambient(acol, r, amb.weight, gp, gd);
479 if (amb.rad <= FTINY)
480 return(0.0);
481 /* store it */
482 VCOPY(amb.pos, r->rop);
483 VCOPY(amb.dir, r->ron);
484 amb.lvl = al;
485 copycolor(amb.val, acol);
486 VCOPY(amb.gpos, gp);
487 VCOPY(amb.gdir, gd);
488 /* insert into tree */
489 avsave(&amb); /* and save to file */
490 if (rn != r->ron)
491 extambient(acol, &amb, r->rop, rn); /* texture */
492 return(amb.rad);
493 }
494
495
496 void
497 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
498 COLOR cr;
499 register AMBVAL *ap;
500 FVECT pv, nv;
501 {
502 FVECT v1;
503 register int i;
504 double d;
505
506 d = 1.0; /* zeroeth order */
507 /* gradient due to translation */
508 for (i = 0; i < 3; i++)
509 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
510 /* gradient due to rotation */
511 VCROSS(v1, ap->dir, nv);
512 d += DOT(ap->gdir, v1);
513 if (d <= 0.0) {
514 setcolor(cr, 0.0, 0.0, 0.0);
515 return;
516 }
517 copycolor(cr, ap->val);
518 scalecolor(cr, d);
519 }
520
521
522 static void
523 initambfile(creat) /* initialize ambient file */
524 int creat;
525 {
526 extern char *progname, *octname;
527 static char *mybuf = NULL;
528
529 #ifdef F_SETLKW
530 aflock(creat ? F_WRLCK : F_RDLCK);
531 #endif
532 #ifdef MSDOS
533 setmode(fileno(ambfp), O_BINARY);
534 #endif
535 if (mybuf == NULL)
536 mybuf = (char *)bmalloc(BUFSIZ+8);
537 setbuf(ambfp, mybuf);
538 if (creat) { /* new file */
539 newheader("RADIANCE", ambfp);
540 fprintf(ambfp, "%s -av %g %g %g -aw %d -ab %d -aa %g ",
541 progname, colval(ambval,RED),
542 colval(ambval,GRN), colval(ambval,BLU),
543 ambvwt, ambounce, ambacc);
544 fprintf(ambfp, "-ad %d -as %d -ar %d ",
545 ambdiv, ambssamp, ambres);
546 if (octname != NULL)
547 printargs(1, &octname, ambfp);
548 else
549 fputc('\n', ambfp);
550 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
551 fputnow(ambfp);
552 fputformat(AMBFMT, ambfp);
553 putc('\n', ambfp);
554 putambmagic(ambfp);
555 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
556 error(USER, "bad ambient file");
557 }
558
559
560 static void
561 avsave(av) /* insert and save an ambient value */
562 AMBVAL *av;
563 {
564 avinsert(avstore(av));
565 if (ambfp == NULL)
566 return;
567 if (writambval(av, ambfp) < 0)
568 goto writerr;
569 if (++nunflshed >= AMBFLUSH)
570 if (ambsync() == EOF)
571 goto writerr;
572 return;
573 writerr:
574 error(SYSTEM, "error writing to ambient file");
575 }
576
577
578 static AMBVAL *
579 avstore(aval) /* allocate memory and store aval */
580 register AMBVAL *aval;
581 {
582 register AMBVAL *av;
583 double d;
584
585 if ((av = newambval()) == NULL)
586 error(SYSTEM, "out of memory in avstore");
587 copystruct(av, aval);
588 av->latick = ambclock;
589 av->next = NULL;
590 nambvals++;
591 d = bright(av->val);
592 if (d > FTINY) { /* add to log sum for averaging */
593 avsum += log(d);
594 navsum++;
595 }
596 return(av);
597 }
598
599
600 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
601
602 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
603
604
605 static AMBTREE *
606 newambtree() /* allocate 8 ambient tree structs */
607 {
608 register AMBTREE *atp, *upperlim;
609
610 if (atfreelist == NULL) { /* get more nodes */
611 atfreelist = (AMBTREE *)malloc(ATALLOCSZ*8*sizeof(AMBTREE));
612 if (atfreelist == NULL)
613 return(NULL);
614 /* link new free list */
615 upperlim = atfreelist + 8*(ATALLOCSZ-1);
616 for (atp = atfreelist; atp < upperlim; atp += 8)
617 atp->kid = atp + 8;
618 atp->kid = NULL;
619 }
620 atp = atfreelist;
621 atfreelist = atp->kid;
622 bzero((char *)atp, 8*sizeof(AMBTREE));
623 return(atp);
624 }
625
626
627 static void
628 freeambtree(atp) /* free 8 ambient tree structs */
629 AMBTREE *atp;
630 {
631 atp->kid = atfreelist;
632 atfreelist = atp;
633 }
634
635
636 static void
637 avinsert(av) /* insert ambient value in our tree */
638 register AMBVAL *av;
639 {
640 register AMBTREE *at;
641 register AMBVAL *ap;
642 AMBVAL avh;
643 FVECT ck0;
644 double s;
645 int branch;
646 register int i;
647
648 if (av->rad <= FTINY)
649 error(CONSISTENCY, "zero ambient radius in avinsert");
650 at = &atrunk;
651 VCOPY(ck0, thescene.cuorg);
652 s = thescene.cusize;
653 while (s*(OCTSCALE/2) > av->rad*ambacc) {
654 if (at->kid == NULL)
655 if ((at->kid = newambtree()) == NULL)
656 error(SYSTEM, "out of memory in avinsert");
657 s *= 0.5;
658 branch = 0;
659 for (i = 0; i < 3; i++)
660 if (av->pos[i] > ck0[i] + s) {
661 ck0[i] += s;
662 branch |= 1 << i;
663 }
664 at = at->kid + branch;
665 }
666 avh.next = at->alist; /* order by increasing level */
667 for (ap = &avh; ap->next != NULL; ap = ap->next)
668 if (ap->next->lvl >= av->lvl)
669 break;
670 av->next = ap->next;
671 ap->next = av;
672 at->alist = avh.next;
673 }
674
675
676 static void
677 unloadatree(at, f) /* unload an ambient value tree */
678 register AMBTREE *at;
679 void (*f)();
680 {
681 register AMBVAL *av;
682 register int i;
683 /* transfer values at this node */
684 for (av = at->alist; av != NULL; av = at->alist) {
685 at->alist = av->next;
686 (*f)(av);
687 }
688 if (at->kid == NULL)
689 return;
690 for (i = 0; i < 8; i++) /* transfer and free children */
691 unloadatree(at->kid+i, f);
692 freeambtree(at->kid);
693 at->kid = NULL;
694 }
695
696
697 static struct avl {
698 AMBVAL *p;
699 unsigned long t;
700 } *avlist1; /* ambient value list with ticks */
701 static AMBVAL **avlist2; /* memory positions for sorting */
702 static int i_avlist; /* index for lists */
703
704
705 static int
706 av2list(av)
707 register AMBVAL *av;
708 {
709 #ifdef DEBUG
710 if (i_avlist >= nambvals)
711 error(CONSISTENCY, "too many ambient values in av2list1");
712 #endif
713 avlist1[i_avlist].p = avlist2[i_avlist] = av;
714 avlist1[i_avlist++].t = av->latick;
715 }
716
717
718 static int
719 alatcmp(av1, av2) /* compare ambient values for MRA */
720 struct avl *av1, *av2;
721 {
722 register long lc = av2->t - av1->t;
723 return(lc<0 ? -1 : lc>0 ? 1 : 0);
724 }
725
726
727 /* GW NOTE 2002/10/3:
728 * I used to compare AMBVAL pointers, but found that this was the
729 * cause of a serious consistency error with gcc, since the optimizer
730 * uses some dangerous trick in pointer subtraction that
731 * assumes pointers differ by exact struct size increments.
732 */
733 static int
734 aposcmp(avp1, avp2) /* compare ambient value positions */
735 const void *avp1, *avp2;
736 {
737 register long diff = *(char * const *)avp1 - *(char * const *)avp2;
738 if (diff < 0)
739 return(-1);
740 return(diff > 0);
741 }
742
743 #if 1
744 static int
745 avlmemi(avaddr) /* find list position from address */
746 AMBVAL *avaddr;
747 {
748 register AMBVAL **avlpp;
749
750 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
751 nambvals, sizeof(AMBVAL *), aposcmp);
752 if (avlpp == NULL)
753 error(CONSISTENCY, "address not found in avlmemi");
754 return(avlpp - avlist2);
755 }
756 #else
757 #define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \
758 nambvals,sizeof(AMBVAL *),aposcmp) - avlist2)
759 #endif
760
761
762 static void
763 sortambvals(always) /* resort ambient values */
764 int always;
765 {
766 AMBTREE oldatrunk;
767 AMBVAL tav, *tap, *pnext;
768 register int i, j;
769 /* see if it's time yet */
770 if (!always && (ambclock++ < lastsort+sortintvl ||
771 nambvals < SORT_THRESH))
772 return;
773 /*
774 * The idea here is to minimize memory thrashing
775 * in VM systems by improving reference locality.
776 * We do this by periodically sorting our stored ambient
777 * values in memory in order of most recently to least
778 * recently accessed. This ordering was chosen so that new
779 * ambient values (which tend to be less important) go into
780 * higher memory with the infrequently accessed values.
781 * Since we expect our values to need sorting less
782 * frequently as the process continues, we double our
783 * waiting interval after each call.
784 * This routine is also called by setambacc() with
785 * the "always" parameter set to 1 so that the ambient
786 * tree will be rebuilt with the new accuracy parameter.
787 */
788 if (tracktime) { /* allocate pointer arrays to sort */
789 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
790 avlist1 = (struct avl *)malloc(nambvals*sizeof(struct avl));
791 } else {
792 avlist2 = NULL;
793 avlist1 = NULL;
794 }
795 if (avlist1 == NULL) { /* no time tracking -- rebuild tree? */
796 if (avlist2 != NULL)
797 free((void *)avlist2);
798 if (always) { /* rebuild without sorting */
799 copystruct(&oldatrunk, &atrunk);
800 atrunk.alist = NULL;
801 atrunk.kid = NULL;
802 unloadatree(&oldatrunk, avinsert);
803 }
804 } else { /* sort memory by last access time */
805 /*
806 * Sorting memory is tricky because it isn't contiguous.
807 * We have to sort an array of pointers by MRA and also
808 * by memory position. We then copy values in "loops"
809 * to minimize memory hits. Nevertheless, we will visit
810 * everyone at least twice, and this is an expensive process
811 * when we're thrashing, which is when we need to do it.
812 */
813 #ifdef DEBUG
814 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
815 nambvals, ambclock);
816 eputs(errmsg);
817 #endif
818 i_avlist = 0;
819 unloadatree(&atrunk, av2list); /* empty current tree */
820 #ifdef DEBUG
821 if (i_avlist < nambvals)
822 error(CONSISTENCY, "missing ambient values in sortambvals");
823 #endif
824 qsort((char *)avlist1, nambvals, sizeof(struct avl), alatcmp);
825 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
826 for (i = 0; i < nambvals; i++) {
827 if (avlist1[i].p == NULL)
828 continue;
829 tap = avlist2[i];
830 copystruct(&tav, tap);
831 for (j = i; (pnext = avlist1[j].p) != tap;
832 j = avlmemi(pnext)) {
833 copystruct(avlist2[j], pnext);
834 avinsert(avlist2[j]);
835 avlist1[j].p = NULL;
836 }
837 copystruct(avlist2[j], &tav);
838 avinsert(avlist2[j]);
839 avlist1[j].p = NULL;
840 }
841 free((void *)avlist1);
842 free((void *)avlist2);
843 /* compute new sort interval */
844 sortintvl = ambclock - lastsort;
845 if (sortintvl >= MAX_SORT_INTVL/2)
846 sortintvl = MAX_SORT_INTVL;
847 else
848 sortintvl <<= 1; /* wait twice as long next */
849 #ifdef DEBUG
850 eputs("done\n");
851 #endif
852 }
853 if (ambclock >= MAXACLOCK)
854 ambclock = MAXACLOCK/2;
855 lastsort = ambclock;
856 }
857
858
859 #ifdef F_SETLKW
860
861 static void
862 aflock(typ) /* lock/unlock ambient file */
863 int typ;
864 {
865 static struct flock fls; /* static so initialized to zeroes */
866
867 fls.l_type = typ;
868 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
869 error(SYSTEM, "cannot (un)lock ambient file");
870 }
871
872
873 int
874 ambsync() /* synchronize ambient file */
875 {
876 long flen;
877 AMBVAL avs;
878 register int n;
879
880 if (nunflshed == 0)
881 return(0);
882 if (lastpos < 0) /* initializing (locked in initambfile) */
883 goto syncend;
884 /* gain exclusive access */
885 aflock(F_WRLCK);
886 /* see if file has grown */
887 if ((flen = lseek(fileno(ambfp), (off_t)0L, 2)) < 0)
888 goto seekerr;
889 if (n = flen - lastpos) { /* file has grown */
890 if (ambinp == NULL) { /* use duplicate filedes */
891 ambinp = fdopen(dup(fileno(ambfp)), "r");
892 if (ambinp == NULL)
893 error(SYSTEM, "fdopen failed in ambsync");
894 }
895 if (fseek(ambinp, lastpos, 0) < 0)
896 goto seekerr;
897 while (n >= AMBVALSIZ) { /* load contributed values */
898 if (!readambval(&avs, ambinp)) {
899 sprintf(errmsg,
900 "ambient file \"%s\" corrupted near character %ld",
901 ambfile, flen - n);
902 error(WARNING, errmsg);
903 break;
904 }
905 avinsert(avstore(&avs));
906 n -= AMBVALSIZ;
907 }
908 /*** seek always as safety measure
909 if (n) ***/ /* alignment */
910 if (lseek(fileno(ambfp), (off_t)(flen-n), 0) < 0)
911 goto seekerr;
912 }
913 #ifdef DEBUG
914 if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
915 sprintf(errmsg, "ambient file buffer at %d rather than %d",
916 ambfp->_ptr - ambfp->_base,
917 nunflshed*AMBVALSIZ);
918 error(CONSISTENCY, errmsg);
919 }
920 #endif
921 syncend:
922 n = fflush(ambfp); /* calls write() at last */
923 if ((lastpos = lseek(fileno(ambfp), (off_t)0L, 1)) < 0)
924 goto seekerr;
925 aflock(F_UNLCK); /* release file */
926 nunflshed = 0;
927 return(n);
928 seekerr:
929 error(SYSTEM, "seek failed in ambsync");
930 }
931
932 #else
933
934 int
935 ambsync() /* flush ambient file */
936 {
937 if (nunflshed == 0)
938 return(0);
939 nunflshed = 0;
940 return(fflush(ambfp));
941 }
942
943 #endif
