root/radiance/ray/src/rt/ambient.c
Revision: 2.37
Committed: Tue May 28 14:24:44 1996 UTC (28 years ago) by greg
Changes since 2.36: +18 -4 lines
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 */
10
11 #include "ray.h"
12
13 #include "octree.h"
14
15 #include "otypes.h"
16
17 #include "ambient.h"
18
19 #include "random.h"
20
21 #ifndef OCTSCALE
22 #define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */
23 #endif
24
25 typedef struct ambtree {
26 AMBVAL *alist; /* ambient value list */
27 struct ambtree *kid; /* 8 child nodes */
28 } AMBTREE; /* ambient octree */
29
30 extern CUBE thescene; /* contains space boundaries */
31
32 extern char *shm_boundary; /* memory sharing boundary */
33
34 #define MAXASET 511 /* maximum number of elements in ambient set */
35 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
36
37 double maxarad; /* maximum ambient radius */
38 double minarad; /* minimum ambient radius */
39
40 static AMBTREE atrunk; /* our ambient trunk node */
41
42 static FILE *ambfp = NULL; /* ambient file pointer */
43 static int nunflshed = 0; /* number of unflushed ambient values */
44
45 #ifndef SORT_THRESH
46 #ifdef BIGMEM
47 #define SORT_THRESH ((9L<<20)/sizeof(AMBVAL))
48 #else
49 #define SORT_THRESH ((3L<<20)/sizeof(AMBVAL))
50 #endif
51 #endif
52 #ifndef SORT_INTVL
53 #define SORT_INTVL (SORT_THRESH*256)
54 #endif
55 #ifndef MAX_SORT_INTVL
56 #define MAX_SORT_INTVL (SORT_INTVL<<4)
57 #endif
58
59 static COLOR avsum = BLKCOLOR; /* computed ambient value sum */
60 static unsigned int nambvals = 0; /* total number of indirect values */
61 static unsigned int nambshare = 0; /* number of values from file */
62 static unsigned long ambclock = 0; /* ambient access clock */
63 static unsigned long lastsort = 0; /* time of last value sort */
64 static long sortintvl = SORT_INTVL; /* time until next sort */
65
66 #define MAXACLOCK (1L<<30) /* clock turnover value */
67 /*
68 * Track access times unless we are sharing ambient values
69 * through memory on a multiprocessor, when we want to avoid
70 * claiming our own memory (copy on write). Go ahead anyway
71 * if more than two thirds of our values are unshared.
72 */
73 #define tracktime (shm_boundary == NULL || nambvals > 3*nambshare)
74
75 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
76
77 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
78
79 extern long ftell(), lseek();
80 static int initambfile(), avsave(), avinsert(), sortambvals();
81 static AMBVAL *avstore();
82 #ifdef F_SETLKW
83 static aflock();
84 #endif
85
86
87 setambres(ar) /* set ambient resolution */
88 int ar;
89 {
90 ambres = ar < 0 ? 0 : ar; /* may be done already */
91 /* set min & max radii */
92 if (ar <= 0) {
93 minarad = 0;
94 maxarad = thescene.cusize / 2.0;
95 } else {
96 minarad = thescene.cusize / ar;
97 maxarad = 64 * minarad; /* heuristic */
98 if (maxarad > thescene.cusize / 2.0)
99 maxarad = thescene.cusize / 2.0;
100 }
101 if (minarad <= FTINY)
102 minarad = 10*FTINY;
103 if (maxarad <= minarad)
104 maxarad = 64 * minarad;
105 }
106
107
108 setambacc(newa) /* set ambient accuracy */
109 double newa;
110 {
111 double ambdiff;
112
113 if (newa < 0.0)
114 newa = 0.0;
115 ambdiff = fabs(newa - ambacc);
116 if (ambdiff >= .01 && (ambacc = newa) > FTINY && nambvals > 0)
117 sortambvals(1); /* rebuild tree */
118 }
119
120
121 setambient(afile) /* initialize calculation */
122 char *afile;
123 {
124 long pos, flen;
125 AMBVAL amb;
126 /* init ambient limits */
127 setambres(ambres);
128 setambacc(ambacc);
129 if (afile == NULL)
130 return;
131 if (ambacc <= FTINY) {
132 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
133 afile);
134 error(WARNING, errmsg);
135 return;
136 }
137 /* open ambient file */
138 if ((ambfp = fopen(afile, "r+")) != NULL) {
139 initambfile(0);
140 pos = ftell(ambfp);
141 while (readambval(&amb, ambfp))
142 avinsert(avstore(&amb));
143 /* align */
144 pos += (long)nambvals*AMBVALSIZ;
145 flen = lseek(fileno(ambfp), 0L, 2);
146 if (flen != pos) {
147 error(WARNING,
148 "ignoring last %ld values in ambient file (corrupted)",
149 (flen - pos)/AMBVALSIZ);
150 fseek(ambfp, pos, 0);
151 ftruncate(fileno(ambfp), pos);
152 }
153 nambshare = nambvals;
154 } else if ((ambfp = fopen(afile, "w+")) != NULL)
155 initambfile(1);
156 else {
157 sprintf(errmsg, "cannot open ambient file \"%s\"", afile);
158 error(SYSTEM, errmsg);
159 }
160 nunflshed++; /* lie */
161 ambsync();
162 }
163
164
165 ambnotify(obj) /* record new modifier */
166 OBJECT obj;
167 {
168 static int hitlimit = 0;
169 register OBJREC *o = objptr(obj);
170 register char **amblp;
171
172 if (hitlimit || !ismodifier(o->otype))
173 return;
174 for (amblp = amblist; *amblp != NULL; amblp++)
175 if (!strcmp(o->oname, *amblp)) {
176 if (ambset[0] >= MAXASET) {
177 error(WARNING, "too many modifiers in ambient list");
178 hitlimit++;
179 return; /* should this be fatal? */
180 }
181 insertelem(ambset, obj);
182 return;
183 }
184 }
185
186
187 ambient(acol, r, nrm) /* compute ambient component for ray */
188 COLOR acol;
189 register RAY *r;
190 FVECT nrm;
191 {
192 static int rdepth = 0; /* ambient recursion */
193 double d;
194
195 if (ambdiv <= 0) /* no ambient calculation */
196 goto dumbamb;
197 /* check number of bounces */
198 if (rdepth >= ambounce)
199 goto dumbamb;
200 /* check ambient list */
201 if (ambincl != -1 && r->ro != NULL &&
202 ambincl != inset(ambset, r->ro->omod))
203 goto dumbamb;
204
205 if (ambacc <= FTINY) { /* no ambient storage */
206 rdepth++;
207 d = doambient(acol, r, r->rweight, NULL, NULL);
208 rdepth--;
209 if (d <= FTINY)
210 goto dumbamb;
211 return;
212 }
213 /* resort memory? */
214 sortambvals(0);
215 /* get ambient value */
216 setcolor(acol, 0.0, 0.0, 0.0);
217 d = sumambient(acol, r, nrm, rdepth,
218 &atrunk, thescene.cuorg, thescene.cusize);
219 if (d > FTINY) {
220 scalecolor(acol, 1.0/d);
221 return;
222 }
223 rdepth++; /* need to cache new value */
224 d = makeambient(acol, r, nrm, rdepth-1);
225 rdepth--;
226 if (d > FTINY)
227 return;
228 dumbamb: /* return global value */
229 copycolor(acol, ambval);
230 if (ambvwt <= 0 | nambvals == 0)
231 return;
232 scalecolor(acol, (double)ambvwt);
233 addcolor(acol, avsum); /* average in computations */
234 d = 1.0/(ambvwt+nambvals);
235 scalecolor(acol, d);
236 }
237
238
239 double
240 sumambient(acol, r, rn, al, at, c0, s) /* get interpolated ambient value */
241 COLOR acol;
242 register RAY *r;
243 FVECT rn;
244 int al;
245 AMBTREE *at;
246 FVECT c0;
247 double s;
248 {
249 double d, e1, e2, wt, wsum;
250 COLOR ct;
251 FVECT ck0;
252 int i;
253 register int j;
254 register AMBVAL *av;
255
256 wsum = 0.0;
257 /* do this node */
258 for (av = at->alist; av != NULL; av = av->next) {
259 if (tracktime)
260 av->latick = ambclock++;
261 /*
262 * Ambient level test.
263 */
264 if (av->lvl > al) /* list sorted, so this works */
265 break;
266 if (av->weight < r->rweight-FTINY)
267 continue;
268 /*
269 * Ambient radius test.
270 */
271 d = av->pos[0] - r->rop[0];
272 e1 = d * d;
273 d = av->pos[1] - r->rop[1];
274 e1 += d * d;
275 d = av->pos[2] - r->rop[2];
276 e1 += d * d;
277 e1 /= av->rad * av->rad;
278 if (e1 > ambacc*ambacc*1.21)
279 continue;
280 /*
281 * Normal direction test.
282 */
283 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
284 if (e2 < 0.0) e2 = 0.0;
285 if (e1 + e2 > ambacc*ambacc*1.21)
286 continue;
287 /*
288 * Ray behind test.
289 */
290 d = 0.0;
291 for (j = 0; j < 3; j++)
292 d += (r->rop[j] - av->pos[j]) *
293 (av->dir[j] + r->ron[j]);
294 if (d*0.5 < -minarad*ambacc-.001)
295 continue;
296 /*
297 * Jittering final test reduces image artifacts.
298 */
299 wt = sqrt(e1) + sqrt(e2);
300 if (wt > ambacc*(.9+.2*urand(9015+samplendx)))
301 continue;
302 if (wt <= 1e-3)
303 wt = 1e3;
304 else
305 wt = 1.0 / wt;
306 wsum += wt;
307 extambient(ct, av, r->rop, rn);
308 scalecolor(ct, wt);
309 addcolor(acol, ct);
310 }
311 if (at->kid == NULL)
312 return(wsum);
313 /* do children */
314 s *= 0.5;
315 for (i = 0; i < 8; i++) {
316 for (j = 0; j < 3; j++) {
317 ck0[j] = c0[j];
318 if (1<<j & i)
319 ck0[j] += s;
320 if (r->rop[j] < ck0[j] - OCTSCALE*s)
321 break;
322 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
323 break;
324 }
325 if (j == 3)
326 wsum += sumambient(acol, r, rn, al, at->kid+i, ck0, s);
327 }
328 return(wsum);
329 }
330
331
332 double
333 makeambient(acol, r, rn, al) /* make a new ambient value */
334 COLOR acol;
335 register RAY *r;
336 FVECT rn;
337 int al;
338 {
339 AMBVAL amb;
340 FVECT gp, gd;
341 /* compute weight */
342 amb.weight = pow(AVGREFL, (double)al);
343 if (r->rweight < 0.1*amb.weight) /* heuristic */
344 amb.weight = r->rweight;
345 /* compute ambient */
346 amb.rad = doambient(acol, r, amb.weight, gp, gd);
347 if (amb.rad <= FTINY)
348 return(0.0);
349 /* store it */
350 VCOPY(amb.pos, r->rop);
351 VCOPY(amb.dir, r->ron);
352 amb.lvl = al;
353 copycolor(amb.val, acol);
354 VCOPY(amb.gpos, gp);
355 VCOPY(amb.gdir, gd);
356 /* insert into tree */
357 avsave(&amb); /* and save to file */
358 if (rn != r->ron)
359 extambient(acol, &amb, r->rop, rn); /* texture */
360 return(amb.rad);
361 }
362
363
364 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
365 COLOR cr;
366 register AMBVAL *ap;
367 FVECT pv, nv;
368 {
369 FVECT v1, v2;
370 register int i;
371 double d;
372
373 d = 1.0; /* zeroeth order */
374 /* gradient due to translation */
375 for (i = 0; i < 3; i++)
376 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
377 /* gradient due to rotation */
378 VCOPY(v1, ap->dir);
379 fcross(v2, v1, nv);
380 d += DOT(ap->gdir, v2);
381 if (d <= 0.0) {
382 setcolor(cr, 0.0, 0.0, 0.0);
383 return;
384 }
385 copycolor(cr, ap->val);
386 scalecolor(cr, d);
387 }
388
389
390 static
391 initambfile(creat) /* initialize ambient file */
392 int creat;
393 {
394 extern char *progname, *octname, VersionID[];
395
396 #ifdef F_SETLKW
397 aflock(creat ? F_WRLCK : F_RDLCK);
398 #endif
399 #ifdef MSDOS
400 setmode(fileno(ambfp), O_BINARY);
401 #endif
402 setbuf(ambfp, bmalloc(BUFSIZ+8));
403 if (creat) { /* new file */
404 newheader("RADIANCE", ambfp);
405 fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
406 progname, colval(ambval,RED),
407 colval(ambval,GRN), colval(ambval,BLU),
408 ambounce, ambacc);
409 fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
410 ambdiv, ambssamp, ambres,
411 octname==NULL ? "" : octname);
412 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
413 fputformat(AMBFMT, ambfp);
414 putc('\n', ambfp);
415 putambmagic(ambfp);
416 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
417 error(USER, "bad ambient file");
418 }
419
420
421 static
422 avsave(av) /* insert and save an ambient value */
423 AMBVAL *av;
424 {
425 avinsert(avstore(av));
426 if (ambfp == NULL)
427 return;
428 if (writambval(av, ambfp) < 0)
429 goto writerr;
430 if (++nunflshed >= AMBFLUSH)
431 if (ambsync() == EOF)
432 goto writerr;
433 return;
434 writerr:
435 error(SYSTEM, "error writing ambient file");
436 }
437
438
439 static AMBVAL *
440 avstore(aval) /* allocate memory and store aval */
441 register AMBVAL *aval;
442 {
443 register AMBVAL *av;
444
445 if ((av = newambval()) == NULL)
446 error(SYSTEM, "out of memory in avstore");
447 copystruct(av, aval);
448 av->latick = ambclock;
449 av->next = NULL;
450 addcolor(avsum, av->val); /* add to sum for averaging */
451 nambvals++;
452 return(av);
453 }
454
455
456 #define ATALLOCSZ 512 /* #/8 trees to allocate at once */
457
458 static AMBTREE *atfreelist = NULL; /* free ambient tree structures */
459
460
461 static
462 AMBTREE *
463 newambtree() /* allocate 8 ambient tree structs */
464 {
465 register AMBTREE *atp, *upperlim;
466
467 if (atfreelist == NULL) { /* get more nodes */
468 atfreelist = (AMBTREE *)bmalloc(ATALLOCSZ*8*sizeof(AMBTREE));
469 if (atfreelist == NULL)
470 return(NULL);
471 /* link new free list */
472 upperlim = atfreelist + 8*(ATALLOCSZ-1);
473 for (atp = atfreelist; atp < upperlim; atp += 8)
474 atp->kid = atp + 8;
475 atp->kid = NULL;
476 }
477 atp = atfreelist;
478 atfreelist = atp->kid;
479 bzero((char *)atp, 8*sizeof(AMBTREE));
480 return(atp);
481 }
482
483
484 static
485 freeambtree(atp) /* free 8 ambient tree structs */
486 AMBTREE *atp;
487 {
488 atp->kid = atfreelist;
489 atfreelist = atp;
490 }
491
492
493 static
494 avinsert(av) /* insert ambient value in our tree */
495 register AMBVAL *av;
496 {
497 register AMBTREE *at;
498 register AMBVAL *ap;
499 AMBVAL avh;
500 FVECT ck0;
501 double s;
502 int branch;
503 register int i;
504
505 if (av->rad <= FTINY)
506 error(CONSISTENCY, "zero ambient radius in avinsert");
507 at = &atrunk;
508 VCOPY(ck0, thescene.cuorg);
509 s = thescene.cusize;
510 while (s*(OCTSCALE/2) > av->rad*ambacc) {
511 if (at->kid == NULL)
512 if ((at->kid = newambtree()) == NULL)
513 error(SYSTEM, "out of memory in avinsert");
514 s *= 0.5;
515 branch = 0;
516 for (i = 0; i < 3; i++)
517 if (av->pos[i] > ck0[i] + s) {
518 ck0[i] += s;
519 branch |= 1 << i;
520 }
521 at = at->kid + branch;
522 }
523 avh.next = at->alist; /* order by increasing level */
524 for (ap = &avh; ap->next != NULL; ap = ap->next)
525 if (ap->next->lvl >= av->lvl)
526 break;
527 av->next = ap->next;
528 ap->next = av;
529 at->alist = avh.next;
530 }
531
532
533 static
534 unloadatree(at, f) /* unload an ambient value tree */
535 register AMBTREE *at;
536 int (*f)();
537 {
538 register AMBVAL *av;
539 register int i;
540 /* transfer values at this node */
541 for (av = at->alist; av != NULL; av = at->alist) {
542 at->alist = av->next;
543 (*f)(av);
544 }
545 if (at->kid == NULL)
546 return;
547 for (i = 0; i < 8; i++) /* transfer and free children */
548 unloadatree(at->kid+i, f);
549 freeambtree(at->kid);
550 at->kid = NULL;
551 }
552
553
554 static AMBVAL **avlist1, **avlist2; /* ambient value lists for sorting */
555 static int i_avlist; /* index for lists */
556
557
558 static
559 av2list(av)
560 AMBVAL *av;
561 {
562 #ifdef DEBUG
563 if (i_avlist >= nambvals)
564 error(CONSISTENCY, "too many ambient values in av2list1");
565 #endif
566 avlist1[i_avlist] = avlist2[i_avlist] = av;
567 i_avlist++;
568 }
569
570
571 static int
572 alatcmp(avp1, avp2) /* compare ambient values for MRA */
573 AMBVAL **avp1, **avp2;
574 {
575 return((**avp2).latick - (**avp1).latick);
576 }
577
578
579 static int
580 aposcmp(avp1, avp2) /* compare ambient value positions */
581 AMBVAL **avp1, **avp2;
582 {
583 return(*avp1 - *avp2);
584 }
585
586
587 #ifdef DEBUG
588 static int
589 avlmemi(avaddr) /* find list position from address */
590 AMBVAL *avaddr;
591 {
592 register AMBVAL **avlpp;
593
594 avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2,
595 nambvals, sizeof(AMBVAL *), aposcmp);
596 if (avlpp == NULL)
597 error(CONSISTENCY, "address not found in avlmemi");
598 return(avlpp - avlist2);
599 }
600 #else
601 #define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \
602 nambvals,sizeof(AMBVAL *),aposcmp) - avlist2)
603 #endif
604
605
606 static
607 sortambvals(always) /* resort ambient values */
608 int always;
609 {
610 AMBTREE oldatrunk;
611 AMBVAL tav, *tap, *pnext;
612 register int i, j;
613 /* see if it's time yet */
614 if (!always && (ambclock < lastsort+sortintvl ||
615 nambvals < SORT_THRESH))
616 return;
617 /*
618 * The idea here is to minimize memory thrashing
619 * in VM systems by improving reference locality.
620 * We do this by periodically sorting our stored ambient
621 * values in memory in order of most recently to least
622 * recently accessed. This ordering was chosen so that new
623 * ambient values (which tend to be less important) go into
624 * higher memory with the infrequently accessed values.
625 * Since we expect our values to need sorting less
626 * frequently as the process continues, we double our
627 * waiting interval after each call.
628 * This routine is also called by setambacc() with
629 * the "always" parameter set to 1 so that the ambient
630 * tree will be rebuilt with the new accuracy parameter.
631 */
632 if (tracktime) { /* allocate pointer arrays to sort */
633 avlist1 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
634 avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *));
635 } else
636 avlist1 = avlist2 = NULL;
637 if (avlist2 == NULL) { /* no time tracking -- rebuild tree? */
638 if (avlist1 != NULL)
639 free((char *)avlist1);
640 if (always) { /* rebuild without sorting */
641 copystruct(&oldatrunk, &atrunk);
642 atrunk.alist = NULL;
643 atrunk.kid = NULL;
644 unloadatree(&oldatrunk, avinsert);
645 }
646 } else { /* sort memory by last access time */
647 /*
648 * Sorting memory is tricky because it isn't contiguous.
649 * We have to sort an array of pointers by MRA and also
650 * by memory position. We then copy values in "loops"
651 * to minimize memory hits. Nevertheless, we will visit
652 * everyone at least twice, and this is an expensive process
653 * when we're thrashing, which is when we need to do it.
654 */
655 #ifdef DEBUG
656 sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...",
657 nambvals, ambclock);
658 eputs(errmsg);
659 #endif
660 i_avlist = 0;
661 unloadatree(&atrunk, av2list); /* empty current tree */
662 #ifdef DEBUG
663 if (i_avlist < nambvals)
664 error(CONSISTENCY, "missing ambient values in sortambvals");
665 #endif
666 qsort((char *)avlist1, nambvals, sizeof(AMBVAL *), alatcmp);
667 qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp);
668 for (i = 0; i < nambvals; i++) {
669 if (avlist1[i] == NULL)
670 continue;
671 tap = avlist2[i];
672 copystruct(&tav, tap);
673 for (j = i; (pnext = avlist1[j]) != tap;
674 j = avlmemi(pnext)) {
675 copystruct(avlist2[j], pnext);
676 avinsert(avlist2[j]);
677 avlist1[j] = NULL;
678 }
679 copystruct(avlist2[j], &tav);
680 avinsert(avlist2[j]);
681 avlist1[j] = NULL;
682 }
683 free((char *)avlist1);
684 free((char *)avlist2);
685 /* compute new sort interval */
686 sortintvl = ambclock - lastsort;
687 if (sortintvl >= MAX_SORT_INTVL/2)
688 sortintvl = MAX_SORT_INTVL;
689 else
690 sortintvl <<= 1; /* wait twice as long next */
691 #ifdef DEBUG
692 eputs("done\n");
693 #endif
694 }
695 if (ambclock >= MAXACLOCK)
696 ambclock = MAXACLOCK/2;
697 lastsort = ambclock;
698 }
699
700
701 #ifdef F_SETLKW
702
703 static
704 aflock(typ) /* lock/unlock ambient file */
705 int typ;
706 {
707 static struct flock fls; /* static so initialized to zeroes */
708
709 fls.l_type = typ;
710 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
711 error(SYSTEM, "cannot (un)lock ambient file");
712 }
713
714
715 int
716 ambsync() /* synchronize ambient file */
717 {
718 static FILE *ambinp = NULL;
719 static long lastpos = -1;
720 long flen;
721 AMBVAL avs;
722 register int n;
723
724 if (nunflshed == 0)
725 return(0);
726 if (lastpos < 0) /* initializing (locked in initambfile) */
727 goto syncend;
728 /* gain exclusive access */
729 aflock(F_WRLCK);
730 /* see if file has grown */
731 if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0)
732 goto seekerr;
733 if (n = flen - lastpos) { /* file has grown */
734 if (ambinp == NULL) { /* use duplicate filedes */
735 ambinp = fdopen(dup(fileno(ambfp)), "r");
736 if (ambinp == NULL)
737 error(SYSTEM, "fdopen failed in ambsync");
738 }
739 if (fseek(ambinp, lastpos, 0) < 0)
740 goto seekerr;
741 while (n >= AMBVALSIZ) { /* load contributed values */
742 if (!readambval(&avs, ambinp)) {
743 sprintf(errmsg,
744 "ambient file corrupted near character %ld",
745 flen - n);
746 error(WARNING, errmsg);
747 break;
748 }
749 avinsert(avstore(&avs));
750 n -= AMBVALSIZ;
751 }
752 /*** seek always as safety measure
753 if (n) ***/ /* alignment */
754 if (lseek(fileno(ambfp), flen-n, 0) < 0)
755 goto seekerr;
756 }
757 #ifdef DEBUG
758 if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
759 sprintf(errmsg, "ambient file buffer at %d rather than %d",
760 ambfp->_ptr - ambfp->_base,
761 nunflshed*AMBVALSIZ);
762 error(CONSISTENCY, errmsg);
763 }
764 #endif
765 syncend:
766 n = fflush(ambfp); /* calls write() at last */
767 if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0)
768 goto seekerr;
769 aflock(F_UNLCK); /* release file */
770 nunflshed = 0;
771 return(n);
772 seekerr:
773 error(SYSTEM, "seek failed in ambsync");
774 }
775
776 #else
777
778 int
779 ambsync() /* flush ambient file */
780 {
781 if (nunflshed == 0)
782 return(0);
783 nunflshed = 0;
784 return(fflush(ambfp));
785 }
786
787 #endif
