1 |
/* Copyright (c) 1995 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* ambient.c - routines dealing with ambient (inter-reflected) component. |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "octree.h" |
14 |
15 |
#include "otypes.h" |
16 |
17 |
#include "ambient.h" |
18 |
19 |
#include "random.h" |
20 |
21 |
#define OCTSCALE 1.0 /* ceil((valid rad.)/(cube size)) */ |
22 |
23 |
typedef struct ambtree { |
24 |
AMBVAL *alist; /* ambient value list */ |
25 |
struct ambtree *kid; /* 8 child nodes */ |
26 |
} AMBTREE; /* ambient octree */ |
27 |
28 |
extern CUBE thescene; /* contains space boundaries */ |
29 |
30 |
extern char *shm_boundary; /* memory sharing boundary */ |
31 |
32 |
#define MAXASET 511 /* maximum number of elements in ambient set */ |
33 |
OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ |
34 |
35 |
double maxarad; /* maximum ambient radius */ |
36 |
double minarad; /* minimum ambient radius */ |
37 |
38 |
static AMBTREE atrunk; /* our ambient trunk node */ |
39 |
40 |
static FILE *ambfp = NULL; /* ambient file pointer */ |
41 |
static int nunflshed = 0; /* number of unflushed ambient values */ |
42 |
43 |
#ifndef SORT_THRESH |
44 |
#ifdef BIGMEM |
45 |
#define SORT_THRESH ((9L<<20)/sizeof(AMBVAL)) |
46 |
#else |
47 |
#define SORT_THRESH ((3L<<20)/sizeof(AMBVAL)) |
48 |
#endif |
49 |
#endif |
50 |
#ifndef SORT_INTVL |
51 |
#define SORT_INTVL (SORT_THRESH*256) |
52 |
#endif |
53 |
#ifndef MAX_SORT_INTVL |
54 |
#define MAX_SORT_INTVL (SORT_INTVL<<4) |
55 |
#endif |
56 |
57 |
static unsigned long ambclock = 0; /* ambient access clock */ |
58 |
static unsigned int nambvals = 0; /* number of stored ambient values */ |
59 |
static unsigned long lastsort = 0; /* time of last value sort */ |
60 |
static long sortintvl = SORT_INTVL; /* time until next sort */ |
61 |
62 |
#define MAXACLOCK (1L<<30) /* clock turnover value */ |
63 |
64 |
* Track access times unless we are sharing ambient values |
65 |
* through memory on a multiprocessor, when we want to avoid |
66 |
* claiming our own memory (copy on write). |
67 |
68 |
#define tracktime (shm_boundary == NULL || ambfp == NULL) |
69 |
70 |
#define AMBFLUSH (BUFSIZ/AMBVALSIZ) |
71 |
72 |
#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) |
73 |
74 |
extern long ftell(), lseek(); |
75 |
static int initambfile(), avsave(), avinsert(), sortambvals(); |
76 |
static AMBVAL *avstore(); |
77 |
#ifdef F_SETLKW |
78 |
static aflock(); |
79 |
#endif |
80 |
81 |
82 |
setambres(ar) /* set ambient resolution */ |
83 |
int ar; |
84 |
85 |
ambres = ar < 0 ? 0 : ar; /* may be done already */ |
86 |
/* set min & max radii */ |
87 |
if (ar <= 0) { |
88 |
minarad = 0; |
89 |
maxarad = thescene.cusize / 2.0; |
90 |
} else { |
91 |
minarad = thescene.cusize / ar; |
92 |
maxarad = 64 * minarad; /* heuristic */ |
93 |
if (maxarad > thescene.cusize / 2.0) |
94 |
95 |
96 |
if (minarad <= FTINY) |
97 |
minarad = 10*FTINY; |
98 |
if (maxarad <= minarad) |
99 |
maxarad = 64 * minarad; |
100 |
101 |
102 |
103 |
setambacc(newa) /* set ambient accuracy */ |
104 |
double newa; |
105 |
106 |
static double oldambacc = -1.0; |
107 |
108 |
ambacc = newa < 0.0 ? 0.0 : newa; /* may be done already */ |
109 |
if (oldambacc < -FTINY) |
110 |
oldambacc = ambacc; /* do nothing first call */ |
111 |
if (fabs(newa - oldambacc) < 0.01) |
112 |
return; /* insignificant -- don't bother */ |
113 |
if (ambacc <= FTINY) |
114 |
return; /* cannot build new tree */ |
115 |
/* else need to rebuild tree */ |
116 |
sortambvals(1); |
117 |
oldambacc = ambacc; /* remeber setting for next call */ |
118 |
119 |
120 |
121 |
setambient(afile) /* initialize calculation */ |
122 |
char *afile; |
123 |
124 |
long headlen; |
125 |
AMBVAL amb; |
126 |
/* init ambient limits */ |
127 |
setambres(ambres); |
128 |
setambacc(ambacc); |
129 |
if (afile == NULL) |
130 |
return; |
131 |
if (ambacc <= FTINY) { |
132 |
sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened", |
133 |
afile); |
134 |
error(WARNING, errmsg); |
135 |
return; |
136 |
137 |
/* open ambient file */ |
138 |
if ((ambfp = fopen(afile, "r+")) != NULL) { |
139 |
initambfile(0); |
140 |
headlen = ftell(ambfp); |
141 |
while (readambval(&amb, ambfp)) |
142 |
avinsert(avstore(&amb)); |
143 |
/* align */ |
144 |
fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); |
145 |
} else if ((ambfp = fopen(afile, "w+")) != NULL) |
146 |
initambfile(1); |
147 |
else { |
148 |
sprintf(errmsg, "cannot open ambient file \"%s\"", afile); |
149 |
error(SYSTEM, errmsg); |
150 |
151 |
nunflshed++; /* lie */ |
152 |
ambsync(); |
153 |
154 |
155 |
156 |
ambnotify(obj) /* record new modifier */ |
157 |
OBJECT obj; |
158 |
159 |
static int hitlimit = 0; |
160 |
register OBJREC *o = objptr(obj); |
161 |
register char **amblp; |
162 |
163 |
if (hitlimit || !ismodifier(o->otype)) |
164 |
return; |
165 |
for (amblp = amblist; *amblp != NULL; amblp++) |
166 |
if (!strcmp(o->oname, *amblp)) { |
167 |
if (ambset[0] >= MAXASET) { |
168 |
error(WARNING, "too many modifiers in ambient list"); |
169 |
hitlimit++; |
170 |
return; /* should this be fatal? */ |
171 |
172 |
insertelem(ambset, obj); |
173 |
return; |
174 |
175 |
176 |
177 |
178 |
ambient(acol, r) /* compute ambient component for ray */ |
179 |
COLOR acol; |
180 |
register RAY *r; |
181 |
182 |
static int rdepth = 0; /* ambient recursion */ |
183 |
double d; |
184 |
185 |
if (ambdiv <= 0) /* no ambient calculation */ |
186 |
goto dumbamb; |
187 |
/* check number of bounces */ |
188 |
if (rdepth >= ambounce) |
189 |
goto dumbamb; |
190 |
/* check ambient list */ |
191 |
if (ambincl != -1 && r->ro != NULL && |
192 |
ambincl != inset(ambset, r->ro->omod)) |
193 |
goto dumbamb; |
194 |
195 |
if (ambacc <= FTINY) { /* no ambient storage */ |
196 |
rdepth++; |
197 |
d = doambient(acol, r, r->rweight, NULL, NULL); |
198 |
rdepth--; |
199 |
if (d == 0.0) |
200 |
goto dumbamb; |
201 |
return; |
202 |
203 |
/* resort memory? */ |
204 |
sortambvals(0); |
205 |
/* get ambient value */ |
206 |
setcolor(acol, 0.0, 0.0, 0.0); |
207 |
d = sumambient(acol, r, rdepth, |
208 |
&atrunk, thescene.cuorg, thescene.cusize); |
209 |
if (d > FTINY) |
210 |
scalecolor(acol, 1.0/d); |
211 |
else { |
212 |
d = makeambient(acol, r, rdepth++); |
213 |
rdepth--; |
214 |
215 |
if (d > FTINY) |
216 |
return; |
217 |
dumbamb: /* return global value */ |
218 |
copycolor(acol, ambval); |
219 |
220 |
221 |
222 |
double |
223 |
sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */ |
224 |
COLOR acol; |
225 |
register RAY *r; |
226 |
int al; |
227 |
AMBTREE *at; |
228 |
FVECT c0; |
229 |
double s; |
230 |
231 |
double d, e1, e2, wt, wsum; |
232 |
COLOR ct; |
233 |
FVECT ck0; |
234 |
int i; |
235 |
register int j; |
236 |
register AMBVAL *av; |
237 |
238 |
wsum = 0.0; |
239 |
/* do this node */ |
240 |
for (av = at->alist; av != NULL; av = av->next) { |
241 |
if (tracktime) |
242 |
av->latick = ambclock++; |
243 |
244 |
* Ambient level test. |
245 |
246 |
if (av->lvl > al) /* list sorted, so this works */ |
247 |
break; |
248 |
if (av->weight < r->rweight-FTINY) |
249 |
continue; |
250 |
251 |
* Ambient radius test. |
252 |
253 |
d = av->pos[0] - r->rop[0]; |
254 |
e1 = d * d; |
255 |
d = av->pos[1] - r->rop[1]; |
256 |
e1 += d * d; |
257 |
d = av->pos[2] - r->rop[2]; |
258 |
e1 += d * d; |
259 |
e1 /= av->rad * av->rad; |
260 |
if (e1 > ambacc*ambacc*1.21) |
261 |
continue; |
262 |
263 |
* Normal direction test. |
264 |
265 |
e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight; |
266 |
if (e2 < 0.0) e2 = 0.0; |
267 |
if (e1 + e2 > ambacc*ambacc*1.21) |
268 |
continue; |
269 |
270 |
* Ray behind test. |
271 |
272 |
d = 0.0; |
273 |
for (j = 0; j < 3; j++) |
274 |
d += (r->rop[j] - av->pos[j]) * |
275 |
(av->dir[j] + r->ron[j]); |
276 |
if (d*0.5 < -minarad*ambacc-.001) |
277 |
continue; |
278 |
279 |
* Jittering final test reduces image artifacts. |
280 |
281 |
wt = sqrt(e1) + sqrt(e2); |
282 |
wt *= .9 + .2*urand(9015+samplendx); |
283 |
if (wt > ambacc) |
284 |
continue; |
285 |
if (wt <= 1e-3) |
286 |
wt = 1e3; |
287 |
else |
288 |
wt = 1.0 / wt; |
289 |
wsum += wt; |
290 |
extambient(ct, av, r->rop, r->ron); |
291 |
scalecolor(ct, wt); |
292 |
addcolor(acol, ct); |
293 |
294 |
if (at->kid == NULL) |
295 |
return(wsum); |
296 |
/* do children */ |
297 |
s *= 0.5; |
298 |
for (i = 0; i < 8; i++) { |
299 |
for (j = 0; j < 3; j++) { |
300 |
ck0[j] = c0[j]; |
301 |
if (1<<j & i) |
302 |
ck0[j] += s; |
303 |
if (r->rop[j] < ck0[j] - OCTSCALE*s) |
304 |
break; |
305 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) |
306 |
break; |
307 |
308 |
if (j == 3) |
309 |
wsum += sumambient(acol, r, al, at->kid+i, ck0, s); |
310 |
311 |
return(wsum); |
312 |
313 |
314 |
315 |
double |
316 |
makeambient(acol, r, al) /* make a new ambient value */ |
317 |
COLOR acol; |
318 |
register RAY *r; |
319 |
int al; |
320 |
321 |
AMBVAL amb; |
322 |
FVECT gp, gd; |
323 |
/* compute weight */ |
324 |
amb.weight = pow(AVGREFL, (double)al); |
325 |
if (r->rweight < 0.2*amb.weight) /* heuristic */ |
326 |
amb.weight = r->rweight; |
327 |
/* compute ambient */ |
328 |
amb.rad = doambient(acol, r, amb.weight, gp, gd); |
329 |
if (amb.rad == 0.0) |
330 |
return(0.0); |
331 |
/* store it */ |
332 |
VCOPY(amb.pos, r->rop); |
333 |
VCOPY(amb.dir, r->ron); |
334 |
amb.lvl = al; |
335 |
copycolor(amb.val, acol); |
336 |
VCOPY(amb.gpos, gp); |
337 |
VCOPY(amb.gdir, gd); |
338 |
/* insert into tree */ |
339 |
avsave(&amb); /* and save to file */ |
340 |
return(amb.rad); |
341 |
342 |
343 |
344 |
extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ |
345 |
COLOR cr; |
346 |
register AMBVAL *ap; |
347 |
FVECT pv, nv; |
348 |
349 |
FVECT v1, v2; |
350 |
register int i; |
351 |
double d; |
352 |
353 |
d = 1.0; /* zeroeth order */ |
354 |
/* gradient due to translation */ |
355 |
for (i = 0; i < 3; i++) |
356 |
d += ap->gpos[i]*(pv[i]-ap->pos[i]); |
357 |
/* gradient due to rotation */ |
358 |
VCOPY(v1, ap->dir); |
359 |
fcross(v2, v1, nv); |
360 |
d += DOT(ap->gdir, v2); |
361 |
if (d <= 0.0) { |
362 |
setcolor(cr, 0.0, 0.0, 0.0); |
363 |
return; |
364 |
365 |
copycolor(cr, ap->val); |
366 |
scalecolor(cr, d); |
367 |
368 |
369 |
370 |
static |
371 |
initambfile(creat) /* initialize ambient file */ |
372 |
int creat; |
373 |
374 |
extern char *progname, *octname, VersionID[]; |
375 |
376 |
#ifdef F_SETLKW |
377 |
aflock(creat ? F_WRLCK : F_RDLCK); |
378 |
#endif |
379 |
#ifdef MSDOS |
380 |
setmode(fileno(ambfp), O_BINARY); |
381 |
#endif |
382 |
setbuf(ambfp, bmalloc(BUFSIZ+8)); |
383 |
if (creat) { /* new file */ |
384 |
newheader("RADIANCE", ambfp); |
385 |
fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", |
386 |
progname, colval(ambval,RED), |
387 |
colval(ambval,GRN), colval(ambval,BLU), |
388 |
ambounce, ambacc); |
389 |
fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", |
390 |
ambdiv, ambssamp, ambres, |
391 |
octname==NULL ? "" : octname); |
392 |
fprintf(ambfp, "SOFTWARE= %s\n", VersionID); |
393 |
fputformat(AMBFMT, ambfp); |
394 |
putc('\n', ambfp); |
395 |
putambmagic(ambfp); |
396 |
} else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) |
397 |
error(USER, "bad ambient file"); |
398 |
399 |
400 |
401 |
static |
402 |
avsave(av) /* insert and save an ambient value */ |
403 |
AMBVAL *av; |
404 |
405 |
avinsert(avstore(av)); |
406 |
if (ambfp == NULL) |
407 |
return; |
408 |
if (writambval(av, ambfp) < 0) |
409 |
goto writerr; |
410 |
if (++nunflshed >= AMBFLUSH) |
411 |
if (ambsync() == EOF) |
412 |
goto writerr; |
413 |
return; |
414 |
writerr: |
415 |
error(SYSTEM, "error writing ambient file"); |
416 |
417 |
418 |
419 |
static AMBVAL * |
420 |
avstore(aval) /* allocate memory and store aval */ |
421 |
register AMBVAL *aval; |
422 |
423 |
424 |
425 |
if ((av = newambval()) == NULL) |
426 |
error(SYSTEM, "out of memory in avstore"); |
427 |
copystruct(av, aval); |
428 |
av->latick = ambclock; |
429 |
av->next = NULL; |
430 |
nambvals++; |
431 |
return(av); |
432 |
433 |
434 |
435 |
#define ATALLOCSZ 512 /* #/8 trees to allocate at once */ |
436 |
437 |
static AMBTREE *atfreelist = NULL; /* free ambient tree structures */ |
438 |
439 |
440 |
static |
441 |
AMBTREE * |
442 |
newambtree() /* allocate 8 ambient tree structs */ |
443 |
444 |
register AMBTREE *atp, *upperlim; |
445 |
446 |
if (atfreelist == NULL) { /* get more nodes */ |
447 |
atfreelist = (AMBTREE *)bmalloc(ATALLOCSZ*8*sizeof(AMBTREE)); |
448 |
if (atfreelist == NULL) |
449 |
return(NULL); |
450 |
/* link new free list */ |
451 |
upperlim = atfreelist + 8*(ATALLOCSZ-1); |
452 |
for (atp = atfreelist; atp < upperlim; atp += 8) |
453 |
atp->kid = atp + 8; |
454 |
atp->kid = NULL; |
455 |
456 |
atp = atfreelist; |
457 |
atfreelist = atp->kid; |
458 |
bzero((char *)atp, 8*sizeof(AMBTREE)); |
459 |
return(atp); |
460 |
461 |
462 |
463 |
static |
464 |
freeambtree(atp) /* free 8 ambient tree structs */ |
465 |
AMBTREE *atp; |
466 |
467 |
atp->kid = atfreelist; |
468 |
atfreelist = atp; |
469 |
470 |
471 |
472 |
static |
473 |
avinsert(av) /* insert ambient value in our tree */ |
474 |
475 |
476 |
register AMBTREE *at; |
477 |
478 |
AMBVAL avh; |
479 |
FVECT ck0; |
480 |
double s; |
481 |
int branch; |
482 |
register int i; |
483 |
484 |
if (av->rad <= FTINY) |
485 |
error(CONSISTENCY, "zero ambient radius in avinsert"); |
486 |
at = &atrunk; |
487 |
VCOPY(ck0, thescene.cuorg); |
488 |
s = thescene.cusize; |
489 |
while (s*(OCTSCALE/2) > av->rad*ambacc) { |
490 |
491 |
if ((at->kid = newambtree()) == NULL) |
492 |
error(SYSTEM, "out of memory in avinsert"); |
493 |
s *= 0.5; |
494 |
branch = 0; |
495 |
496 |
if (av->pos[i] > ck0[i] + s) { |
497 |
ck0[i] += s; |
498 |
branch |= 1 << i; |
499 |
500 |
at = at->kid + branch; |
501 |
502 |
avh.next = at->alist; /* order by increasing level */ |
503 |
for (ap = &avh; ap->next != NULL; ap = ap->next) |
504 |
if (ap->next->lvl >= av->lvl) |
505 |
break; |
506 |
av->next = ap->next; |
507 |
ap->next = av; |
508 |
at->alist = avh.next; |
509 |
510 |
511 |
512 |
static |
513 |
unloadatree(at, f) /* unload an ambient value tree */ |
514 |
515 |
int (*f)(); |
516 |
517 |
518 |
register int i; |
519 |
/* transfer values at this node */ |
520 |
for (av = at->alist; av != NULL; av = at->alist) { |
521 |
at->alist = av->next; |
522 |
(*f)(av); |
523 |
524 |
525 |
return; |
526 |
for (i = 0; i < 8; i++) /* transfer and free children */ |
527 |
unloadatree(at->kid+i, f); |
528 |
freeambtree(at->kid); |
529 |
at->kid = NULL; |
530 |
531 |
532 |
533 |
static AMBVAL **avlist1, **avlist2; /* ambient value lists for sorting */ |
534 |
static int i_avlist; /* index for lists */ |
535 |
536 |
537 |
static |
538 |
av2list(av) |
539 |
AMBVAL *av; |
540 |
541 |
#ifdef DEBUG |
542 |
if (i_avlist >= nambvals) |
543 |
error(CONSISTENCY, "too many ambient values in av2list1"); |
544 |
#endif |
545 |
avlist1[i_avlist] = avlist2[i_avlist] = av; |
546 |
i_avlist++; |
547 |
548 |
549 |
550 |
static int |
551 |
alatcmp(avp1, avp2) /* compare ambient values for MRA */ |
552 |
AMBVAL **avp1, **avp2; |
553 |
554 |
return((**avp2).latick - (**avp1).latick); |
555 |
556 |
557 |
558 |
static int |
559 |
aposcmp(avp1, avp2) /* compare ambient value positions */ |
560 |
561 |
562 |
return(*avp1 - *avp2); |
563 |
564 |
565 |
566 |
#ifdef DEBUG |
567 |
static int |
568 |
avlmemi(avaddr) /* find list position from address */ |
569 |
AMBVAL *avaddr; |
570 |
571 |
register AMBVAL **avlpp; |
572 |
573 |
avlpp = (AMBVAL **)bsearch((char *)&avaddr, (char *)avlist2, |
574 |
nambvals, sizeof(AMBVAL *), aposcmp); |
575 |
if (avlpp == NULL) |
576 |
error(CONSISTENCY, "address not found in avlmemi"); |
577 |
return(avlpp - avlist2); |
578 |
579 |
#else |
580 |
#define avlmemi(avaddr) ((AMBVAL **)bsearch((char *)&avaddr,(char *)avlist2, \ |
581 |
nambvals,sizeof(AMBVAL *),aposcmp) - avlist2) |
582 |
#endif |
583 |
584 |
585 |
static |
586 |
sortambvals(always) /* resort ambient values */ |
587 |
int always; |
588 |
589 |
AMBTREE oldatrunk; |
590 |
AMBVAL tav, *tap, *pnext; |
591 |
register int i, j; |
592 |
/* see if it's time yet */ |
593 |
if (!always && (ambclock < lastsort+sortintvl || |
594 |
nambvals < SORT_THRESH)) |
595 |
return; |
596 |
597 |
* The idea here is to minimize memory thrashing |
598 |
* in VM systems by improving reference locality. |
599 |
* We do this by periodically sorting our stored ambient |
600 |
* values in memory in order of most recently to least |
601 |
* recently accessed. This ordering was chosen so that new |
602 |
* ambient values (which tend to be less important) go into |
603 |
* higher memory with the infrequently accessed values. |
604 |
* Since we expect our values to need sorting less |
605 |
* frequently as the process continues, we double our |
606 |
* waiting interval after each call. |
607 |
* This routine is also called by setambacc() with |
608 |
* the "always" parameter set to 1 so that the ambient |
609 |
* tree will be rebuilt with the new accuracy parameter. |
610 |
611 |
if (tracktime) { /* allocate pointer arrays to sort */ |
612 |
avlist1 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); |
613 |
avlist2 = (AMBVAL **)malloc(nambvals*sizeof(AMBVAL *)); |
614 |
} else |
615 |
avlist1 = avlist2 = NULL; |
616 |
if (avlist2 == NULL) { /* no time tracking -- rebuild tree? */ |
617 |
if (avlist1 != NULL) |
618 |
free((char *)avlist1); |
619 |
if (always) { /* rebuild without sorting */ |
620 |
copystruct(&oldatrunk, &atrunk); |
621 |
atrunk.alist = NULL; |
622 |
atrunk.kid = NULL; |
623 |
unloadatree(&oldatrunk, avinsert); |
624 |
625 |
} else { /* sort memory by last access time */ |
626 |
627 |
* Sorting memory is tricky because it isn't contiguous. |
628 |
* We have to sort an array of pointers by MRA and also |
629 |
* by memory position. We then copy values in "loops" |
630 |
* to minimize memory hits. Nevertheless, we will visit |
631 |
* everyone at least twice, and this is an expensive process |
632 |
* when we're thrashing, which is when we need to do it. |
633 |
634 |
#ifdef DEBUG |
635 |
sprintf(errmsg, "sorting %u ambient values at ambclock=%lu...", |
636 |
nambvals, ambclock); |
637 |
eputs(errmsg); |
638 |
#endif |
639 |
i_avlist = 0; |
640 |
unloadatree(&atrunk, av2list); /* empty current tree */ |
641 |
#ifdef DEBUG |
642 |
if (i_avlist < nambvals) |
643 |
error(CONSISTENCY, "missing ambient values in sortambvals"); |
644 |
#endif |
645 |
qsort((char *)avlist1, nambvals, sizeof(AMBVAL *), alatcmp); |
646 |
qsort((char *)avlist2, nambvals, sizeof(AMBVAL *), aposcmp); |
647 |
for (i = 0; i < nambvals; i++) { |
648 |
if (avlist1[i] == NULL) |
649 |
continue; |
650 |
tap = avlist2[i]; |
651 |
copystruct(&tav, tap); |
652 |
for (j = i; (pnext = avlist1[j]) != tap; |
653 |
j = avlmemi(pnext)) { |
654 |
copystruct(avlist2[j], pnext); |
655 |
avinsert(avlist2[j]); |
656 |
avlist1[j] = NULL; |
657 |
658 |
copystruct(avlist2[j], &tav); |
659 |
660 |
661 |
662 |
663 |
free((char *)avlist2); |
664 |
/* compute new sort interval */ |
665 |
sortintvl = ambclock - lastsort; |
666 |
if (sortintvl > MAX_SORT_INTVL) |
667 |
sortintvl = MAX_SORT_INTVL; |
668 |
else |
669 |
sortintvl <<= 1; /* wait twice as long next */ |
670 |
#ifdef DEBUG |
671 |
eputs("done\n"); |
672 |
#endif |
673 |
674 |
if (ambclock >= MAXACLOCK) |
675 |
ambclock = MAXACLOCK/2; |
676 |
lastsort = ambclock; |
677 |
678 |
679 |
680 |
#ifdef F_SETLKW |
681 |
682 |
static |
683 |
aflock(typ) /* lock/unlock ambient file */ |
684 |
int typ; |
685 |
686 |
static struct flock fls; /* static so initialized to zeroes */ |
687 |
688 |
fls.l_type = typ; |
689 |
if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) |
690 |
error(SYSTEM, "cannot (un)lock ambient file"); |
691 |
692 |
693 |
694 |
int |
695 |
ambsync() /* synchronize ambient file */ |
696 |
697 |
static FILE *ambinp = NULL; |
698 |
static long lastpos = -1; |
699 |
long flen; |
700 |
AMBVAL avs; |
701 |
register int n; |
702 |
703 |
if (nunflshed == 0) |
704 |
return(0); |
705 |
if (lastpos < 0) /* initializing (locked in initambfile) */ |
706 |
goto syncend; |
707 |
/* gain exclusive access */ |
708 |
aflock(F_WRLCK); |
709 |
/* see if file has grown */ |
710 |
if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) |
711 |
goto seekerr; |
712 |
if (n = flen - lastpos) { /* file has grown */ |
713 |
if (ambinp == NULL) { /* use duplicate filedes */ |
714 |
ambinp = fdopen(dup(fileno(ambfp)), "r"); |
715 |
if (ambinp == NULL) |
716 |
error(SYSTEM, "fdopen failed in ambsync"); |
717 |
718 |
if (fseek(ambinp, lastpos, 0) < 0) |
719 |
goto seekerr; |
720 |
while (n >= AMBVALSIZ) { /* load contributed values */ |
721 |
readambval(&avs, ambinp); |
722 |
avinsert(avstore(&avs)); |
723 |
n -= AMBVALSIZ; |
724 |
725 |
/*** seek always as safety measure |
726 |
if (n) ***/ /* alignment */ |
727 |
if (lseek(fileno(ambfp), flen-n, 0) < 0) |
728 |
goto seekerr; |
729 |
730 |
#ifdef DEBUG |
731 |
if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) { |
732 |
sprintf(errmsg, "ambient file buffer at %d rather than %d", |
733 |
ambfp->_ptr - ambfp->_base, |
734 |
nunflshed*AMBVALSIZ); |
735 |
error(CONSISTENCY, errmsg); |
736 |
737 |
#endif |
738 |
syncend: |
739 |
n = fflush(ambfp); /* calls write() at last */ |
740 |
if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0) |
741 |
goto seekerr; |
742 |
aflock(F_UNLCK); /* release file */ |
743 |
nunflshed = 0; |
744 |
return(n); |
745 |
seekerr: |
746 |
error(SYSTEM, "seek failed in ambsync"); |
747 |
748 |
749 |
#else |
750 |
751 |
int |
752 |
ambsync() /* flush ambient file */ |
753 |
754 |
755 |
return(0); |
756 |
nunflshed = 0; |
757 |
return(fflush(ambfp)); |
758 |
759 |
760 |
#endif |
