root/radiance/ray/src/rt/ambient.c
Revision: 2.3
Committed: Wed Mar 4 16:52:13 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +19 -6 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 *
10 * The macro AMBFLUSH (if defined) is the number of ambient values
11 * to wait before flushing to the ambient file.
12 *
13 * 5/9/86
14 */
15
16 #include "ray.h"
17
18 #include "octree.h"
19
20 #include "otypes.h"
21
22 #include "ambient.h"
23
24 #include "random.h"
25
26 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
27
28 typedef struct ambtree {
29 AMBVAL *alist; /* ambient value list */
30 struct ambtree *kid; /* 8 child nodes */
31 } AMBTREE; /* ambient octree */
32
33 extern CUBE thescene; /* contains space boundaries */
34
35 #define MAXASET 511 /* maximum number of elements in ambient set */
36 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
37
38 double maxarad; /* maximum ambient radius */
39 double minarad; /* minimum ambient radius */
40
41 static AMBTREE atrunk; /* our ambient trunk node */
42
43 static FILE *ambfp = NULL; /* ambient file pointer */
44
45 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
46
47 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
48
49
50 setambres(ar) /* set ambient resolution */
51 int ar;
52 {
53 /* set min & max radii */
54 if (ar <= 0) {
55 minarad = 0.0;
56 maxarad = thescene.cusize / 2.0;
57 } else {
58 minarad = thescene.cusize / ar;
59 maxarad = 16.0 * minarad; /* heuristic */
60 if (maxarad > thescene.cusize / 2.0)
61 maxarad = thescene.cusize / 2.0;
62 }
63 }
64
65
66 setambient(afile) /* initialize calculation */
67 char *afile;
68 {
69 long ftell();
70 AMBVAL amb;
71 /* init ambient limits */
72 setambres(ambres);
73 /* open ambient file */
74 if (afile != NULL)
75 if ((ambfp = fopen(afile, "r+")) != NULL) {
76 while (fread((char *)&amb,sizeof(AMBVAL),1,ambfp) == 1)
77 avinsert(&amb, &atrunk, thescene.cuorg,
78 thescene.cusize);
79 /* align */
80 fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1);
81 } else if ((ambfp = fopen(afile, "w")) == NULL) {
82 sprintf(errmsg, "cannot open ambient file \"%s\"",
83 afile);
84 error(SYSTEM, errmsg);
85 }
86 }
87
88
89 ambnotify(obj) /* record new modifier */
90 OBJECT obj;
91 {
92 static int hitlimit = 0;
93 register OBJREC *o = objptr(obj);
94 register char **amblp;
95
96 if (hitlimit || !ismodifier(o->otype))
97 return;
98 for (amblp = amblist; *amblp != NULL; amblp++)
99 if (!strcmp(o->oname, *amblp)) {
100 if (ambset[0] >= MAXASET) {
101 error(WARNING, "too many modifiers in ambient list");
102 hitlimit++;
103 return; /* should this be fatal? */
104 }
105 insertelem(ambset, obj);
106 return;
107 }
108 }
109
110
111 ambient(acol, r) /* compute ambient component for ray */
112 COLOR acol;
113 register RAY *r;
114 {
115 static int rdepth = 0; /* ambient recursion */
116 double d;
117
118 if (ambdiv <= 0) /* no ambient calculation */
119 goto dumbamb;
120 /* check number of bounces */
121 if (rdepth >= ambounce)
122 goto dumbamb;
123 /* check ambient list */
124 if (ambincl != -1 && r->ro != NULL &&
125 ambincl != inset(ambset, r->ro->omod))
126 goto dumbamb;
127
128 if (ambacc <= FTINY) { /* no ambient storage */
129 rdepth++;
130 d = doambient(acol, r, r->rweight, NULL, NULL);
131 rdepth--;
132 if (d == 0.0)
133 goto dumbamb;
134 return;
135 }
136 /* get ambient value */
137 setcolor(acol, 0.0, 0.0, 0.0);
138 d = sumambient(acol, r, rdepth,
139 &atrunk, thescene.cuorg, thescene.cusize);
140 if (d > FTINY)
141 scalecolor(acol, 1.0/d);
142 else {
143 d = makeambient(acol, r, rdepth++);
144 rdepth--;
145 }
146 if (d > FTINY)
147 return;
148 dumbamb: /* return global value */
149 copycolor(acol, ambval);
150 }
151
152
153 double
154 sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
155 COLOR acol;
156 register RAY *r;
157 int al;
158 AMBTREE *at;
159 FVECT c0;
160 double s;
161 {
162 extern double sqrt();
163 double d, e1, e2, wt, wsum;
164 COLOR ct;
165 FVECT ck0;
166 int i;
167 register int j;
168 register AMBVAL *av;
169 /* do this node */
170 wsum = 0.0;
171 for (av = at->alist; av != NULL; av = av->next) {
172 /*
173 * Ambient level test.
174 */
175 if (av->lvl > al || av->weight < r->rweight-FTINY)
176 continue;
177 /*
178 * Ambient radius test.
179 */
180 e1 = 0.0;
181 for (j = 0; j < 3; j++) {
182 d = av->pos[j] - r->rop[j];
183 e1 += d * d;
184 }
185 e1 /= av->rad * av->rad;
186 if (e1 > ambacc*ambacc*1.21)
187 continue;
188 /*
189 * Normal direction test.
190 */
191 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
192 if (e2 < 0.0) e2 = 0.0;
193 if (e1 + e2 > ambacc*ambacc*1.21)
194 continue;
195 /*
196 * Ray behind test.
197 */
198 d = 0.0;
199 for (j = 0; j < 3; j++)
200 d += (r->rop[j] - av->pos[j]) *
201 (av->dir[j] + r->ron[j]);
202 if (d*0.5 < -minarad*ambacc-.001)
203 continue;
204 /*
205 * Jittering final test reduces image artifacts.
206 */
207 wt = sqrt(e1) + sqrt(e2);
208 wt *= .9 + .2*urand(9015+samplendx);
209 if (wt > ambacc)
210 continue;
211 if (wt <= 1e-3)
212 wt = 1e3;
213 else
214 wt = 1.0 / wt;
215 wsum += wt;
216 extambient(ct, av, r->rop, r->ron);
217 scalecolor(ct, wt);
218 addcolor(acol, ct);
219 }
220 if (at->kid == NULL)
221 return(wsum);
222 /* do children */
223 s *= 0.5;
224 for (i = 0; i < 8; i++) {
225 for (j = 0; j < 3; j++) {
226 ck0[j] = c0[j];
227 if (1<<j & i)
228 ck0[j] += s;
229 if (r->rop[j] < ck0[j] - OCTSCALE*s)
230 break;
231 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
232 break;
233 }
234 if (j == 3)
235 wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
236 }
237 return(wsum);
238 }
239
240
241 double
242 makeambient(acol, r, al) /* make a new ambient value */
243 COLOR acol;
244 register RAY *r;
245 int al;
246 {
247 AMBVAL amb;
248 FVECT gp, gd;
249 /* compute weight */
250 amb.weight = pow(AVGREFL, (double)al);
251 if (r->rweight < 0.2*amb.weight) /* heuristic */
252 amb.weight = r->rweight;
253 /* compute ambient */
254 amb.rad = doambient(acol, r, amb.weight, gp, gd);
255 if (amb.rad == 0.0)
256 return(0.0);
257 /* store it */
258 VCOPY(amb.pos, r->rop);
259 VCOPY(amb.dir, r->ron);
260 amb.lvl = al;
261 copycolor(amb.val, acol);
262 VCOPY(amb.gpos, gp);
263 VCOPY(amb.gdir, gd);
264 /* insert into tree */
265 avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize);
266 avsave(&amb); /* write to file */
267 return(amb.rad);
268 }
269
270
271 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
272 COLOR cr;
273 register AMBVAL *ap;
274 FVECT pv, nv;
275 {
276 FVECT v1, v2;
277 register int i;
278 double d;
279
280 d = 1.0; /* zeroeth order */
281 /* gradient due to translation */
282 for (i = 0; i < 3; i++)
283 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
284 /* gradient due to rotation */
285 VCOPY(v1, ap->dir);
286 fcross(v2, v1, nv);
287 d += DOT(ap->gdir, v2);
288 if (d <= 0.0) {
289 setcolor(cr, 0.0, 0.0, 0.0);
290 return;
291 }
292 copycolor(cr, ap->val);
293 scalecolor(cr, d);
294 }
295
296
297 static
298 avsave(av) /* save an ambient value */
299 AMBVAL *av;
300 {
301 #ifdef AMBFLUSH
302 static int nunflshed = 0;
303 #endif
304 if (ambfp == NULL)
305 return;
306 if (fwrite((char *)av, sizeof(AMBVAL), 1, ambfp) != 1)
307 goto writerr;
308 #ifdef AMBFLUSH
309 if (++nunflshed >= AMBFLUSH) {
310 if (fflush(ambfp) == EOF)
311 goto writerr;
312 nunflshed = 0;
313 }
314 #endif
315 return;
316 writerr:
317 error(SYSTEM, "error writing ambient file");
318 }
319
320
321 static
322 avinsert(aval, at, c0, s) /* insert ambient value in a tree */
323 AMBVAL *aval;
324 register AMBTREE *at;
325 FVECT c0;
326 double s;
327 {
328 FVECT ck0;
329 int branch;
330 register AMBVAL *av;
331 register int i;
332
333 if ((av = newambval()) == NULL)
334 goto memerr;
335 copystruct(av, aval);
336 VCOPY(ck0, c0);
337 while (s*(OCTSCALE/2) > av->rad*ambacc) {
338 if (at->kid == NULL)
339 if ((at->kid = newambtree()) == NULL)
340 goto memerr;
341 s *= 0.5;
342 branch = 0;
343 for (i = 0; i < 3; i++)
344 if (av->pos[i] > ck0[i] + s) {
345 ck0[i] += s;
346 branch |= 1 << i;
347 }
348 at = at->kid + branch;
349 }
350 av->next = at->alist;
351 at->alist = av;
352 return;
353 memerr:
354 error(SYSTEM, "out of memory in avinsert");
355 }
