root/radiance/ray/src/rt/ambient.c
Revision: 2.22
Committed: Fri Aug 6 17:24:24 1993 UTC (31 years, 10 months ago) by greg
changed code to always seek even when it shouldn't be necessary
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 */
10
11 #include "ray.h"
12
13 #include "octree.h"
14
15 #include "otypes.h"
16
17 #include "ambient.h"
18
19 #include "random.h"
20
21 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
22
23 typedef struct ambtree {
24 AMBVAL *alist; /* ambient value list */
25 struct ambtree *kid; /* 8 child nodes */
26 } AMBTREE; /* ambient octree */
27
28 extern CUBE thescene; /* contains space boundaries */
29
30 #define MAXASET 511 /* maximum number of elements in ambient set */
31 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
32
33 double maxarad; /* maximum ambient radius */
34 double minarad; /* minimum ambient radius */
35
36 static AMBTREE atrunk; /* our ambient trunk node */
37
38 static FILE *ambfp = NULL; /* ambient file pointer */
39 static int nunflshed = 0; /* number of unflushed ambient values */
40
41 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
42
43 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
44
45 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
46 #define freeambtree(t) free((char *)(t))
47
48 extern long ftell(), lseek();
49 static int initambfile(), avsave(), avinsert(), loadatree();
50 static AMBVAL *avstore();
51 #ifdef F_SETLKW
52 static aflock();
53 #endif
54
55
56 setambres(ar) /* set ambient resolution */
57 int ar;
58 {
59 ambres = ar < 0 ? 0 : ar; /* may be done already */
60 /* set min & max radii */
61 if (ar <= 0) {
62 minarad = 0.0;
63 maxarad = thescene.cusize / 2.0;
64 } else {
65 minarad = thescene.cusize / ar;
66 maxarad = 16.0 * minarad; /* heuristic */
67 if (maxarad > thescene.cusize / 2.0)
68 maxarad = thescene.cusize / 2.0;
69 }
70 if (maxarad <= FTINY)
71 maxarad = .001;
72 }
73
74
75 setambacc(newa) /* set ambient accuracy */
76 double newa;
77 {
78 static double oldambacc = -1.0;
79 AMBTREE oldatrunk;
80
81 ambacc = newa < 0.0 ? 0.0 : newa; /* may be done already */
82 if (oldambacc < -FTINY)
83 oldambacc = ambacc; /* do nothing first call */
84 if (fabs(newa - oldambacc) < 0.01)
85 return; /* insignificant -- don't bother */
86 if (ambacc <= FTINY)
87 return; /* cannot build new tree */
88 /* else need to rebuild tree */
89 copystruct(&oldatrunk, &atrunk);
90 atrunk.alist = NULL;
91 atrunk.kid = NULL;
92 loadatree(&oldatrunk);
93 oldambacc = ambacc; /* remeber setting for next call */
94 }
95
96
97 setambient(afile) /* initialize calculation */
98 char *afile;
99 {
100 long headlen;
101 AMBVAL amb;
102 /* init ambient limits */
103 setambres(ambres);
104 setambacc(ambacc);
105 if (afile == NULL)
106 return;
107 if (ambacc <= FTINY) {
108 sprintf(errmsg, "zero ambient accuracy so \"%s\" not opened",
109 afile);
110 error(WARNING, errmsg);
111 return;
112 }
113 /* open ambient file */
114 if ((ambfp = fopen(afile, "r+")) != NULL) {
115 initambfile(0);
116 headlen = ftell(ambfp);
117 while (readambval(&amb, ambfp))
118 avinsert(avstore(&amb));
119 /* align */
120 fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1);
121 } else if ((ambfp = fopen(afile, "w+")) != NULL)
122 initambfile(1);
123 else {
124 sprintf(errmsg, "cannot open ambient file \"%s\"", afile);
125 error(SYSTEM, errmsg);
126 }
127 nunflshed++; /* lie */
128 ambsync();
129 }
130
131
132 ambnotify(obj) /* record new modifier */
133 OBJECT obj;
134 {
135 static int hitlimit = 0;
136 register OBJREC *o = objptr(obj);
137 register char **amblp;
138
139 if (hitlimit || !ismodifier(o->otype))
140 return;
141 for (amblp = amblist; *amblp != NULL; amblp++)
142 if (!strcmp(o->oname, *amblp)) {
143 if (ambset[0] >= MAXASET) {
144 error(WARNING, "too many modifiers in ambient list");
145 hitlimit++;
146 return; /* should this be fatal? */
147 }
148 insertelem(ambset, obj);
149 return;
150 }
151 }
152
153
154 ambient(acol, r) /* compute ambient component for ray */
155 COLOR acol;
156 register RAY *r;
157 {
158 static int rdepth = 0; /* ambient recursion */
159 double d;
160
161 if (ambdiv <= 0) /* no ambient calculation */
162 goto dumbamb;
163 /* check number of bounces */
164 if (rdepth >= ambounce)
165 goto dumbamb;
166 /* check ambient list */
167 if (ambincl != -1 && r->ro != NULL &&
168 ambincl != inset(ambset, r->ro->omod))
169 goto dumbamb;
170
171 if (ambacc <= FTINY) { /* no ambient storage */
172 rdepth++;
173 d = doambient(acol, r, r->rweight, NULL, NULL);
174 rdepth--;
175 if (d == 0.0)
176 goto dumbamb;
177 return;
178 }
179 /* get ambient value */
180 setcolor(acol, 0.0, 0.0, 0.0);
181 d = sumambient(acol, r, rdepth,
182 &atrunk, thescene.cuorg, thescene.cusize);
183 if (d > FTINY)
184 scalecolor(acol, 1.0/d);
185 else {
186 d = makeambient(acol, r, rdepth++);
187 rdepth--;
188 }
189 if (d > FTINY)
190 return;
191 dumbamb: /* return global value */
192 copycolor(acol, ambval);
193 }
194
195
196 double
197 sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
198 COLOR acol;
199 register RAY *r;
200 int al;
201 AMBTREE *at;
202 FVECT c0;
203 double s;
204 {
205 double d, e1, e2, wt, wsum;
206 COLOR ct;
207 FVECT ck0;
208 int i;
209 register int j;
210 register AMBVAL *av;
211 /* do this node */
212 wsum = 0.0;
213 for (av = at->alist; av != NULL; av = av->next) {
214 /*
215 * Ambient level test.
216 */
217 if (av->lvl > al || av->weight < r->rweight-FTINY)
218 continue;
219 /*
220 * Ambient radius test.
221 */
222 e1 = 0.0;
223 for (j = 0; j < 3; j++) {
224 d = av->pos[j] - r->rop[j];
225 e1 += d * d;
226 }
227 e1 /= av->rad * av->rad;
228 if (e1 > ambacc*ambacc*1.21)
229 continue;
230 /*
231 * Normal direction test.
232 */
233 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
234 if (e2 < 0.0) e2 = 0.0;
235 if (e1 + e2 > ambacc*ambacc*1.21)
236 continue;
237 /*
238 * Ray behind test.
239 */
240 d = 0.0;
241 for (j = 0; j < 3; j++)
242 d += (r->rop[j] - av->pos[j]) *
243 (av->dir[j] + r->ron[j]);
244 if (d*0.5 < -minarad*ambacc-.001)
245 continue;
246 /*
247 * Jittering final test reduces image artifacts.
248 */
249 wt = sqrt(e1) + sqrt(e2);
250 wt *= .9 + .2*urand(9015+samplendx);
251 if (wt > ambacc)
252 continue;
253 if (wt <= 1e-3)
254 wt = 1e3;
255 else
256 wt = 1.0 / wt;
257 wsum += wt;
258 extambient(ct, av, r->rop, r->ron);
259 scalecolor(ct, wt);
260 addcolor(acol, ct);
261 }
262 if (at->kid == NULL)
263 return(wsum);
264 /* do children */
265 s *= 0.5;
266 for (i = 0; i < 8; i++) {
267 for (j = 0; j < 3; j++) {
268 ck0[j] = c0[j];
269 if (1<<j & i)
270 ck0[j] += s;
271 if (r->rop[j] < ck0[j] - OCTSCALE*s)
272 break;
273 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
274 break;
275 }
276 if (j == 3)
277 wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
278 }
279 return(wsum);
280 }
281
282
283 double
284 makeambient(acol, r, al) /* make a new ambient value */
285 COLOR acol;
286 register RAY *r;
287 int al;
288 {
289 AMBVAL amb;
290 FVECT gp, gd;
291 /* compute weight */
292 amb.weight = pow(AVGREFL, (double)al);
293 if (r->rweight < 0.2*amb.weight) /* heuristic */
294 amb.weight = r->rweight;
295 /* compute ambient */
296 amb.rad = doambient(acol, r, amb.weight, gp, gd);
297 if (amb.rad == 0.0)
298 return(0.0);
299 /* store it */
300 VCOPY(amb.pos, r->rop);
301 VCOPY(amb.dir, r->ron);
302 amb.lvl = al;
303 copycolor(amb.val, acol);
304 VCOPY(amb.gpos, gp);
305 VCOPY(amb.gdir, gd);
306 /* insert into tree */
307 avsave(&amb); /* and save to file */
308 return(amb.rad);
309 }
310
311
312 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
313 COLOR cr;
314 register AMBVAL *ap;
315 FVECT pv, nv;
316 {
317 FVECT v1, v2;
318 register int i;
319 double d;
320
321 d = 1.0; /* zeroeth order */
322 /* gradient due to translation */
323 for (i = 0; i < 3; i++)
324 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
325 /* gradient due to rotation */
326 VCOPY(v1, ap->dir);
327 fcross(v2, v1, nv);
328 d += DOT(ap->gdir, v2);
329 if (d <= 0.0) {
330 setcolor(cr, 0.0, 0.0, 0.0);
331 return;
332 }
333 copycolor(cr, ap->val);
334 scalecolor(cr, d);
335 }
336
337
338 static
339 initambfile(creat) /* initialize ambient file */
340 int creat;
341 {
342 extern char *progname, *octname, VersionID[];
343
344 #ifdef F_SETLKW
345 aflock(creat ? F_WRLCK : F_RDLCK);
346 #endif
347 #ifdef MSDOS
348 setmode(fileno(ambfp), O_BINARY);
349 #endif
350 setbuf(ambfp, bmalloc(BUFSIZ+8));
351 if (creat) { /* new file */
352 fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
353 progname, colval(ambval,RED),
354 colval(ambval,GRN), colval(ambval,BLU),
355 ambounce, ambacc);
356 fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
357 ambdiv, ambssamp, ambres,
358 octname==NULL ? "" : octname);
359 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
360 fputformat(AMBFMT, ambfp);
361 putc('\n', ambfp);
362 putambmagic(ambfp);
363 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
364 error(USER, "bad ambient file");
365 }
366
367
368 static
369 avsave(av) /* insert and save an ambient value */
370 AMBVAL *av;
371 {
372 avinsert(avstore(av));
373 if (ambfp == NULL)
374 return;
375 if (writambval(av, ambfp) < 0)
376 goto writerr;
377 if (++nunflshed >= AMBFLUSH)
378 if (ambsync() == EOF)
379 goto writerr;
380 return;
381 writerr:
382 error(SYSTEM, "error writing ambient file");
383 }
384
385
386 static AMBVAL *
387 avstore(aval) /* allocate memory and store aval */
388 register AMBVAL *aval;
389 {
390 register AMBVAL *av;
391
392 if ((av = newambval()) == NULL)
393 error(SYSTEM, "out of memory in avstore");
394 copystruct(av, aval);
395 return(av);
396 }
397
398
399 static
400 avinsert(av) /* insert ambient value in our tree */
401 register AMBVAL *av;
402 {
403 register AMBTREE *at;
404 FVECT ck0;
405 double s;
406 int branch;
407 register int i;
408
409 if (av->rad <= FTINY)
410 error(CONSISTENCY, "zero ambient radius in avinsert");
411 at = &atrunk;
412 VCOPY(ck0, thescene.cuorg);
413 s = thescene.cusize;
414 while (s*(OCTSCALE/2) > av->rad*ambacc) {
415 if (at->kid == NULL)
416 if ((at->kid = newambtree()) == NULL)
417 error(SYSTEM, "out of memory in avinsert");
418 s *= 0.5;
419 branch = 0;
420 for (i = 0; i < 3; i++)
421 if (av->pos[i] > ck0[i] + s) {
422 ck0[i] += s;
423 branch |= 1 << i;
424 }
425 at = at->kid + branch;
426 }
427 av->next = at->alist;
428 at->alist = av;
429 }
430
431
432 static
433 loadatree(at) /* move tree to main store */
434 register AMBTREE *at;
435 {
436 register AMBVAL *av;
437 register int i;
438 /* transfer values at this node */
439 for (av = at->alist; av != NULL; av = at->alist) {
440 at->alist = av->next;
441 avinsert(av);
442 }
443 if (at->kid == NULL)
444 return;
445 for (i = 0; i < 8; i++) /* transfer and free children */
446 loadatree(at->kid+i);
447 freeambtree(at->kid);
448 }
449
450
451 #ifdef F_SETLKW
452
453 static
454 aflock(typ) /* lock/unlock ambient file */
455 int typ;
456 {
457 static struct flock fls; /* static so initialized to zeroes */
458
459 fls.l_type = typ;
460 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
461 error(SYSTEM, "cannot (un)lock ambient file");
462 }
463
464
465 int
466 ambsync() /* synchronize ambient file */
467 {
468 static FILE *ambinp = NULL;
469 static long lastpos = -1;
470 long flen;
471 AMBVAL avs;
472 register int n;
473
474 if (nunflshed == 0)
475 return(0);
476 if (lastpos < 0) /* initializing (locked in initambfile) */
477 goto syncend;
478 /* gain exclusive access */
479 aflock(F_WRLCK);
480 /* see if file has grown */
481 if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0)
482 goto seekerr;
483 if (n = flen - lastpos) { /* file has grown */
484 if (ambinp == NULL) { /* use duplicate filedes */
485 ambinp = fdopen(dup(fileno(ambfp)), "r");
486 if (ambinp == NULL)
487 error(SYSTEM, "fdopen failed in ambsync");
488 }
489 if (fseek(ambinp, lastpos, 0) < 0)
490 goto seekerr;
491 while (n >= AMBVALSIZ) { /* load contributed values */
492 readambval(&avs, ambinp);
493 avinsert(avstore(&avs));
494 n -= AMBVALSIZ;
495 }
496 /*** seek always as safety measure
497 if (n) ***/ /* alignment */
498 if (lseek(fileno(ambfp), flen-n, 0) < 0)
499 goto seekerr;
500 }
501 #ifdef DEBUG
502 if (ambfp->_ptr - ambfp->_base != nunflshed*AMBVALSIZ) {
503 sprintf(errmsg, "ambient file buffer at %d rather than %d",
504 ambfp->_ptr - ambfp->_base,
505 nunflshed*AMBVALSIZ);
506 error(CONSISTENCY, errmsg);
507 }
508 #endif
509 syncend:
510 n = fflush(ambfp); /* calls write() at last */
511 if ((lastpos = lseek(fileno(ambfp), 0L, 1)) < 0)
512 goto seekerr;
513 aflock(F_UNLCK); /* release file */
514 nunflshed = 0;
515 return(n);
516 seekerr:
517 error(SYSTEM, "seek failed in ambsync");
518 }
519
520 #else
521
522 int
523 ambsync() /* flush ambient file */
524 {
525 if (nunflshed == 0)
526 return(0);
527 nunflshed = 0;
528 return(fflush(ambfp));
529 }
530
531 #endif
