root/radiance/ray/src/rt/ambient.c
Revision: 2.17
Committed: Tue Jan 26 09:08:20 1993 UTC (31 years, 4 months ago) by greg
Changes since 2.16: +7 -11 lines
took out ambfname again
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * ambient.c - routines dealing with ambient (inter-reflected) component.
9 */
10
11 #include "ray.h"
12
13 #include "octree.h"
14
15 #include "otypes.h"
16
17 #include "ambient.h"
18
19 #include "random.h"
20
21 #define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */
22
23 typedef struct ambtree {
24 AMBVAL *alist; /* ambient value list */
25 struct ambtree *kid; /* 8 child nodes */
26 } AMBTREE; /* ambient octree */
27
28 extern CUBE thescene; /* contains space boundaries */
29
30 #define MAXASET 511 /* maximum number of elements in ambient set */
31 OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */
32
33 double maxarad; /* maximum ambient radius */
34 double minarad; /* minimum ambient radius */
35
36 static AMBTREE atrunk; /* our ambient trunk node */
37
38 static FILE *ambfp = NULL; /* ambient file pointer */
39 static int nunflshed = 0; /* number of unflushed ambient values */
40
41 #define AMBFLUSH (BUFSIZ/AMBVALSIZ)
42
43 #define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL))
44
45 #define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE))
46
47 extern long ftell(), lseek();
48 static int initambfile(), avsave(), avinsert();
49
50
51 setambres(ar) /* set ambient resolution */
52 int ar;
53 {
54 /* set min & max radii */
55 if (ar <= 0) {
56 minarad = 0.0;
57 maxarad = thescene.cusize / 2.0;
58 } else {
59 minarad = thescene.cusize / ar;
60 maxarad = 16.0 * minarad; /* heuristic */
61 if (maxarad > thescene.cusize / 2.0)
62 maxarad = thescene.cusize / 2.0;
63 }
64 if (maxarad <= FTINY)
65 maxarad = .001;
66 }
67
68
69 setambient(afile) /* initialize calculation */
70 char *afile;
71 {
72 long headlen;
73 AMBVAL amb;
74 /* init ambient limits */
75 setambres(ambres);
76 /* open ambient file */
77 if (afile != NULL) {
78 if ((ambfp = fopen(afile, "r+")) != NULL) {
79 initambfile(0);
80 headlen = ftell(ambfp);
81 while (readambval(&amb, ambfp))
82 avinsert(&amb, &atrunk, thescene.cuorg,
83 thescene.cusize);
84 /* align */
85 fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1);
86 } else if ((ambfp = fopen(afile, "w+")) != NULL)
87 initambfile(1);
88 else {
89 sprintf(errmsg, "cannot open ambient file \"%s\"",
90 afile);
91 error(SYSTEM, errmsg);
92 }
93 nunflshed++; /* lie */
94 ambsync();
95 }
96 }
97
98
99 ambnotify(obj) /* record new modifier */
100 OBJECT obj;
101 {
102 static int hitlimit = 0;
103 register OBJREC *o = objptr(obj);
104 register char **amblp;
105
106 if (hitlimit || !ismodifier(o->otype))
107 return;
108 for (amblp = amblist; *amblp != NULL; amblp++)
109 if (!strcmp(o->oname, *amblp)) {
110 if (ambset[0] >= MAXASET) {
111 error(WARNING, "too many modifiers in ambient list");
112 hitlimit++;
113 return; /* should this be fatal? */
114 }
115 insertelem(ambset, obj);
116 return;
117 }
118 }
119
120
121 ambient(acol, r) /* compute ambient component for ray */
122 COLOR acol;
123 register RAY *r;
124 {
125 static int rdepth = 0; /* ambient recursion */
126 double d;
127
128 if (ambdiv <= 0) /* no ambient calculation */
129 goto dumbamb;
130 /* check number of bounces */
131 if (rdepth >= ambounce)
132 goto dumbamb;
133 /* check ambient list */
134 if (ambincl != -1 && r->ro != NULL &&
135 ambincl != inset(ambset, r->ro->omod))
136 goto dumbamb;
137
138 if (ambacc <= FTINY) { /* no ambient storage */
139 rdepth++;
140 d = doambient(acol, r, r->rweight, NULL, NULL);
141 rdepth--;
142 if (d == 0.0)
143 goto dumbamb;
144 return;
145 }
146 /* get ambient value */
147 setcolor(acol, 0.0, 0.0, 0.0);
148 d = sumambient(acol, r, rdepth,
149 &atrunk, thescene.cuorg, thescene.cusize);
150 if (d > FTINY)
151 scalecolor(acol, 1.0/d);
152 else {
153 d = makeambient(acol, r, rdepth++);
154 rdepth--;
155 }
156 if (d > FTINY)
157 return;
158 dumbamb: /* return global value */
159 copycolor(acol, ambval);
160 }
161
162
163 double
164 sumambient(acol, r, al, at, c0, s) /* get interpolated ambient value */
165 COLOR acol;
166 register RAY *r;
167 int al;
168 AMBTREE *at;
169 FVECT c0;
170 double s;
171 {
172 double d, e1, e2, wt, wsum;
173 COLOR ct;
174 FVECT ck0;
175 int i;
176 register int j;
177 register AMBVAL *av;
178 /* do this node */
179 wsum = 0.0;
180 for (av = at->alist; av != NULL; av = av->next) {
181 /*
182 * Ambient level test.
183 */
184 if (av->lvl > al || av->weight < r->rweight-FTINY)
185 continue;
186 /*
187 * Ambient radius test.
188 */
189 e1 = 0.0;
190 for (j = 0; j < 3; j++) {
191 d = av->pos[j] - r->rop[j];
192 e1 += d * d;
193 }
194 e1 /= av->rad * av->rad;
195 if (e1 > ambacc*ambacc*1.21)
196 continue;
197 /*
198 * Normal direction test.
199 */
200 e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight;
201 if (e2 < 0.0) e2 = 0.0;
202 if (e1 + e2 > ambacc*ambacc*1.21)
203 continue;
204 /*
205 * Ray behind test.
206 */
207 d = 0.0;
208 for (j = 0; j < 3; j++)
209 d += (r->rop[j] - av->pos[j]) *
210 (av->dir[j] + r->ron[j]);
211 if (d*0.5 < -minarad*ambacc-.001)
212 continue;
213 /*
214 * Jittering final test reduces image artifacts.
215 */
216 wt = sqrt(e1) + sqrt(e2);
217 wt *= .9 + .2*urand(9015+samplendx);
218 if (wt > ambacc)
219 continue;
220 if (wt <= 1e-3)
221 wt = 1e3;
222 else
223 wt = 1.0 / wt;
224 wsum += wt;
225 extambient(ct, av, r->rop, r->ron);
226 scalecolor(ct, wt);
227 addcolor(acol, ct);
228 }
229 if (at->kid == NULL)
230 return(wsum);
231 /* do children */
232 s *= 0.5;
233 for (i = 0; i < 8; i++) {
234 for (j = 0; j < 3; j++) {
235 ck0[j] = c0[j];
236 if (1<<j & i)
237 ck0[j] += s;
238 if (r->rop[j] < ck0[j] - OCTSCALE*s)
239 break;
240 if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s)
241 break;
242 }
243 if (j == 3)
244 wsum += sumambient(acol, r, al, at->kid+i, ck0, s);
245 }
246 return(wsum);
247 }
248
249
250 double
251 makeambient(acol, r, al) /* make a new ambient value */
252 COLOR acol;
253 register RAY *r;
254 int al;
255 {
256 AMBVAL amb;
257 FVECT gp, gd;
258 /* compute weight */
259 amb.weight = pow(AVGREFL, (double)al);
260 if (r->rweight < 0.2*amb.weight) /* heuristic */
261 amb.weight = r->rweight;
262 /* compute ambient */
263 amb.rad = doambient(acol, r, amb.weight, gp, gd);
264 if (amb.rad == 0.0)
265 return(0.0);
266 /* store it */
267 VCOPY(amb.pos, r->rop);
268 VCOPY(amb.dir, r->ron);
269 amb.lvl = al;
270 copycolor(amb.val, acol);
271 VCOPY(amb.gpos, gp);
272 VCOPY(amb.gdir, gd);
273 /* insert into tree */
274 avsave(&amb); /* and save to file */
275 return(amb.rad);
276 }
277
278
279 extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */
280 COLOR cr;
281 register AMBVAL *ap;
282 FVECT pv, nv;
283 {
284 FVECT v1, v2;
285 register int i;
286 double d;
287
288 d = 1.0; /* zeroeth order */
289 /* gradient due to translation */
290 for (i = 0; i < 3; i++)
291 d += ap->gpos[i]*(pv[i]-ap->pos[i]);
292 /* gradient due to rotation */
293 VCOPY(v1, ap->dir);
294 fcross(v2, v1, nv);
295 d += DOT(ap->gdir, v2);
296 if (d <= 0.0) {
297 setcolor(cr, 0.0, 0.0, 0.0);
298 return;
299 }
300 copycolor(cr, ap->val);
301 scalecolor(cr, d);
302 }
303
304
305 static
306 initambfile(creat) /* initialize ambient file */
307 int creat;
308 {
309 extern char *progname, *octname, VersionID[];
310
311 #ifdef MSDOS
312 setmode(fileno(ambfp), O_BINARY);
313 #endif
314 setbuf(ambfp, bmalloc(BUFSIZ));
315 if (creat) { /* new file */
316 fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ",
317 progname, colval(ambval,RED),
318 colval(ambval,GRN), colval(ambval,BLU),
319 ambounce, ambacc);
320 fprintf(ambfp, "-ad %d -as %d -ar %d %s\n",
321 ambdiv, ambssamp, ambres,
322 octname==NULL ? "" : octname);
323 fprintf(ambfp, "SOFTWARE= %s\n", VersionID);
324 fputformat(AMBFMT, ambfp);
325 putc('\n', ambfp);
326 putambmagic(ambfp);
327 } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp))
328 error(USER, "bad ambient file");
329 }
330
331
332 static
333 avsave(av) /* insert and save an ambient value */
334 AMBVAL *av;
335 {
336 avinsert(av, &atrunk, thescene.cuorg, thescene.cusize);
337 if (ambfp == NULL)
338 return;
339 if (writambval(av, ambfp) < 0)
340 goto writerr;
341 if (++nunflshed >= AMBFLUSH)
342 if (ambsync() == EOF)
343 goto writerr;
344 return;
345 writerr:
346 error(SYSTEM, "error writing ambient file");
347 }
348
349
350 static
351 avinsert(aval, at, c0, s) /* insert ambient value in a tree */
352 AMBVAL *aval;
353 register AMBTREE *at;
354 FVECT c0;
355 double s;
356 {
357 FVECT ck0;
358 int branch;
359 register AMBVAL *av;
360 register int i;
361
362 if ((av = newambval()) == NULL)
363 goto memerr;
364 copystruct(av, aval);
365 VCOPY(ck0, c0);
366 while (s*(OCTSCALE/2) > av->rad*ambacc) {
367 if (at->kid == NULL)
368 if ((at->kid = newambtree()) == NULL)
369 goto memerr;
370 s *= 0.5;
371 branch = 0;
372 for (i = 0; i < 3; i++)
373 if (av->pos[i] > ck0[i] + s) {
374 ck0[i] += s;
375 branch |= 1 << i;
376 }
377 at = at->kid + branch;
378 }
379 av->next = at->alist;
380 at->alist = av;
381 return;
382 memerr:
383 error(SYSTEM, "out of memory in avinsert");
384 }
385
386
387 #ifdef NIX
388
389 int
390 ambsync() /* flush ambient file */
391 {
392 if (nunflshed == 0)
393 return(0);
394 nunflshed = 0;
395 return(fflush(ambfp));
396 }
397
398 #else
399
400 int
401 ambsync() /* synchronize ambient file */
402 {
403 static FILE *ambinp = NULL;
404 static long lastpos = -1;
405 struct flock fls;
406 long flen;
407 AMBVAL avs;
408 register int n;
409
410 if (nunflshed == 0)
411 return(0);
412 /* gain exclusive access */
413 fls.l_type = F_WRLCK;
414 fls.l_whence = 0;
415 fls.l_start = 0L;
416 fls.l_len = 0L;
417 if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0)
418 error(SYSTEM, "cannot lock ambient file");
419 if (lastpos < 0) /* initializing */
420 goto syncend;
421 /* see if file has grown */
422 if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0)
423 error(SYSTEM, "cannot seek on ambient file");
424 if (n = flen - lastpos) { /* file has grown */
425 if (ambinp == NULL) { /* use duplicate filedes */
426 ambinp = fdopen(dup(fileno(ambfp)), "r");
427 if (ambinp == NULL)
428 error(SYSTEM, "fdopen failed in ambsync");
429 }
430 if (fseek(ambinp, lastpos, 0) < 0)
431 error(SYSTEM, "fseek failed in ambsync");
432 while (n >= AMBVALSIZ) { /* load contributed values */
433 readambval(&avs, ambinp);
434 avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize);
435 n -= AMBVALSIZ;
436 }
437 if (n) /* alignment */
438 lseek(fileno(ambfp), flen-n, 0);
439 }
440 syncend:
441 n = fflush(ambfp); /* calls write() at last */
442 lastpos = lseek(fileno(ambfp), 0L, 1);
443 fls.l_type = F_UNLCK; /* release file */
444 fcntl(fileno(ambfp), F_SETLKW, &fls);
445 nunflshed = 0;
446 return(n);
447 }
448
449 #endif
