1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* ambient.c - routines dealing with ambient (inter-reflected) component. |
9 |
10 |
* The macro AMBFLUSH (if defined) is the number of ambient values |
11 |
* to wait before flushing to the ambient file. |
12 |
13 |
* 5/9/86 |
14 |
15 |
16 |
#include "ray.h" |
17 |
18 |
#include "octree.h" |
19 |
20 |
#include "random.h" |
21 |
22 |
#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ |
23 |
24 |
extern CUBE thescene; /* contains space boundaries */ |
25 |
26 |
extern COLOR ambval; /* global ambient component */ |
27 |
extern double ambacc; /* ambient accuracy */ |
28 |
extern int ambres; /* ambient resolution */ |
29 |
extern int ambdiv; /* number of divisions for calculation */ |
30 |
extern int ambssamp; /* number of super-samples */ |
31 |
extern int ambounce; /* number of ambient bounces */ |
32 |
extern char *amblist[]; /* ambient include/exclude list */ |
33 |
extern int ambincl; /* include == 1, exclude == 0 */ |
34 |
35 |
OBJECT ambset[128]; /* ambient include/exclude set */ |
36 |
37 |
double maxarad; /* maximum ambient radius */ |
38 |
double minarad; /* minimum ambient radius */ |
39 |
40 |
typedef struct ambval { |
41 |
FVECT pos; /* position in space */ |
42 |
FVECT dir; /* normal direction */ |
43 |
int lvl; /* recursion level of parent ray */ |
44 |
float weight; /* weight of parent ray */ |
45 |
COLOR val; /* computed ambient value */ |
46 |
float rad; /* validity radius */ |
47 |
struct ambval *next; /* next in list */ |
48 |
} AMBVAL; /* ambient value */ |
49 |
50 |
typedef struct ambtree { |
51 |
AMBVAL *alist; /* ambient value list */ |
52 |
struct ambtree *kid; /* 8 child nodes */ |
53 |
} AMBTREE; /* ambient octree */ |
54 |
55 |
typedef struct { |
56 |
float k; /* error contribution per sample */ |
57 |
COLOR v; /* ray sum */ |
58 |
int n; /* number of samples */ |
59 |
short t, p; /* theta, phi indices */ |
60 |
} AMBSAMP; /* ambient sample */ |
61 |
62 |
static AMBTREE atrunk; /* our ambient trunk node */ |
63 |
64 |
static FILE *ambfp = NULL; /* ambient file pointer */ |
65 |
66 |
#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) |
67 |
68 |
#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) |
69 |
70 |
double sumambient(), doambient(), makeambient(); |
71 |
72 |
73 |
setambient(afile) /* initialize calculation */ |
74 |
char *afile; |
75 |
76 |
long ftell(); |
77 |
char **amblp; |
78 |
OBJECT obj; |
79 |
AMBVAL amb; |
80 |
/* set up ambient set */ |
81 |
ambset[0] = 0; |
82 |
for (amblp = amblist; *amblp != NULL; amblp++) { |
83 |
if ((obj = modifier(*amblp)) == OVOID) { |
84 |
sprintf(errmsg, "unknown %s modifier \"%s\"", |
85 |
ambincl ? "include" : "exclude", *amblp); |
86 |
error(WARNING, errmsg); |
87 |
continue; |
88 |
89 |
if (!inset(ambset, obj)) |
90 |
insertelem(ambset, obj); |
91 |
92 |
maxarad = thescene.cusize / 2.0; /* maximum radius */ |
93 |
/* minimum radius */ |
94 |
minarad = ambres > 0 ? thescene.cusize/ambres : 0.0; |
95 |
96 |
/* open ambient file */ |
97 |
if (afile != NULL) |
98 |
if ((ambfp = fopen(afile, "r+")) != NULL) { |
99 |
while (fread(&amb, sizeof(AMBVAL), 1, ambfp) == 1) |
100 |
avinsert(&amb, &atrunk, thescene.cuorg, |
101 |
thescene.cusize); |
102 |
/* align */ |
103 |
fseek(ambfp, -(ftell(ambfp)%sizeof(AMBVAL)), 1); |
104 |
} else if ((ambfp = fopen(afile, "w")) == NULL) { |
105 |
sprintf(errmsg, "cannot open ambient file \"%s\"", |
106 |
afile); |
107 |
error(SYSTEM, errmsg); |
108 |
109 |
110 |
111 |
112 |
ambient(acol, r) /* compute ambient component for ray */ |
113 |
COLOR acol; |
114 |
register RAY *r; |
115 |
116 |
static int rdepth = 0; /* ambient recursion */ |
117 |
double wsum; |
118 |
119 |
rdepth++; /* increment level */ |
120 |
121 |
if (ambdiv <= 0) /* no ambient calculation */ |
122 |
goto dumbamb; |
123 |
/* check number of bounces */ |
124 |
if (rdepth > ambounce) |
125 |
goto dumbamb; |
126 |
/* check ambient list */ |
127 |
if (ambincl != -1 && r->ro != NULL && |
128 |
ambincl != inset(ambset, r->ro->omod)) |
129 |
goto dumbamb; |
130 |
131 |
if (ambacc <= FTINY) { /* no ambient storage */ |
132 |
if (doambient(acol, r) == 0.0) |
133 |
goto dumbamb; |
134 |
goto done; |
135 |
136 |
/* get ambient value */ |
137 |
setcolor(acol, 0.0, 0.0, 0.0); |
138 |
wsum = sumambient(acol, r, &atrunk, thescene.cuorg, thescene.cusize); |
139 |
if (wsum > FTINY) |
140 |
scalecolor(acol, 1.0/wsum); |
141 |
else if (makeambient(acol, r) == 0.0) |
142 |
goto dumbamb; |
143 |
goto done; |
144 |
145 |
dumbamb: /* return global value */ |
146 |
copycolor(acol, ambval); |
147 |
done: /* must finish here! */ |
148 |
rdepth--; |
149 |
150 |
151 |
152 |
double |
153 |
sumambient(acol, r, at, c0, s) /* get interpolated ambient value */ |
154 |
COLOR acol; |
155 |
register RAY *r; |
156 |
AMBTREE *at; |
157 |
FVECT c0; |
158 |
double s; |
159 |
160 |
extern double sqrt(); |
161 |
double d, e1, e2, wt, wsum; |
162 |
COLOR ct; |
163 |
FVECT ck0; |
164 |
int i; |
165 |
register int j; |
166 |
register AMBVAL *av; |
167 |
/* do this node */ |
168 |
wsum = 0.0; |
169 |
for (av = at->alist; av != NULL; av = av->next) { |
170 |
171 |
* Ray strength test. |
172 |
173 |
if (av->lvl > r->rlvl || av->weight < r->rweight-FTINY) |
174 |
continue; |
175 |
176 |
* Ambient radius test. |
177 |
178 |
e1 = 0.0; |
179 |
for (j = 0; j < 3; j++) { |
180 |
d = av->pos[j] - r->rop[j]; |
181 |
e1 += d * d; |
182 |
183 |
e1 /= av->rad * av->rad; |
184 |
if (e1 > ambacc*ambacc*1.21) |
185 |
continue; |
186 |
187 |
* Normal direction test. |
188 |
189 |
e2 = (1.0 - DOT(av->dir, r->ron)) * r->rweight; |
190 |
if (e2 < 0.0) e2 = 0.0; |
191 |
if (e1 + e2 > ambacc*ambacc*1.21) |
192 |
continue; |
193 |
194 |
* Ray behind test. |
195 |
196 |
d = 0.0; |
197 |
for (j = 0; j < 3; j++) |
198 |
d += (r->rop[j] - av->pos[j]) * |
199 |
(av->dir[j] + r->ron[j]); |
200 |
if (d < -minarad) |
201 |
continue; |
202 |
203 |
* Jittering final test reduces image artifacts. |
204 |
205 |
wt = sqrt(e1) + sqrt(e2); |
206 |
if (wt > ambacc*(0.9 + 0.2*frandom())) |
207 |
continue; |
208 |
if (wt <= 1e-3) |
209 |
wt = 1e3; |
210 |
else |
211 |
wt = 1.0 / wt; |
212 |
wsum += wt; |
213 |
copycolor(ct, av->val); |
214 |
scalecolor(ct, wt); |
215 |
addcolor(acol, ct); |
216 |
217 |
if (at->kid == NULL) |
218 |
return(wsum); |
219 |
/* do children */ |
220 |
s *= 0.5; |
221 |
for (i = 0; i < 8; i++) { |
222 |
223 |
ck0[j] = c0[j]; |
224 |
if (1<<j & i) |
225 |
ck0[j] += s; |
226 |
if (r->rop[j] < ck0[j] - OCTSCALE*s) |
227 |
break; |
228 |
if (r->rop[j] > ck0[j] + (1.0+OCTSCALE)*s) |
229 |
break; |
230 |
231 |
if (j == 3) |
232 |
wsum += sumambient(acol, r, at->kid+i, ck0, s); |
233 |
234 |
return(wsum); |
235 |
236 |
237 |
238 |
double |
239 |
makeambient(acol, r) /* make a new ambient value */ |
240 |
COLOR acol; |
241 |
register RAY *r; |
242 |
243 |
AMBVAL amb; |
244 |
245 |
amb.rad = doambient(acol, r); /* compute ambient */ |
246 |
if (amb.rad == 0.0) |
247 |
return(0.0); |
248 |
/* store it */ |
249 |
VCOPY(amb.pos, r->rop); |
250 |
VCOPY(amb.dir, r->ron); |
251 |
amb.lvl = r->rlvl; |
252 |
amb.weight = r->rweight; |
253 |
copycolor(amb.val, acol); |
254 |
/* insert into tree */ |
255 |
avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); |
256 |
avsave(&amb); /* write to file */ |
257 |
return(amb.rad); |
258 |
259 |
260 |
261 |
double |
262 |
doambient(acol, r) /* compute ambient component */ |
263 |
COLOR acol; |
264 |
register RAY *r; |
265 |
266 |
extern int ambcmp(); |
267 |
extern double sin(), cos(), sqrt(); |
268 |
double phi, xd, yd, zd; |
269 |
register AMBSAMP *div; |
270 |
AMBSAMP dnew; |
271 |
RAY ar; |
272 |
FVECT ux, uy; |
273 |
double arad; |
274 |
int ndivs, nt, np, ns, ne, i, j; |
275 |
register int k; |
276 |
277 |
278 |
/* set number of divisions */ |
279 |
nt = sqrt(ambdiv * r->rweight * 0.5) + 0.5; |
280 |
np = 2 * nt; |
281 |
ndivs = nt * np; |
282 |
/* check first */ |
283 |
if (ndivs == 0 || rayorigin(&ar, r, AMBIENT, 0.5) < 0) |
284 |
return(0.0); |
285 |
/* set number of super-samples */ |
286 |
ns = ambssamp * r->rweight + 0.5; |
287 |
if (ns > 0) { |
288 |
div = (AMBSAMP *)malloc(ndivs*sizeof(AMBSAMP)); |
289 |
if (div == NULL) |
290 |
error(SYSTEM, "out of memory in doambient"); |
291 |
292 |
/* make axes */ |
293 |
uy[0] = uy[1] = uy[2] = 0.0; |
294 |
for (k = 0; k < 3; k++) |
295 |
if (r->ron[k] < 0.6 && r->ron[k] > -0.6) |
296 |
break; |
297 |
uy[k] = 1.0; |
298 |
fcross(ux, r->ron, uy); |
299 |
normalize(ux); |
300 |
fcross(uy, ux, r->ron); |
301 |
/* sample divisions */ |
302 |
arad = 0.0; |
303 |
ne = 0; |
304 |
for (i = 0; i < nt; i++) |
305 |
for (j = 0; j < np; j++) { |
306 |
rayorigin(&ar, r, AMBIENT, 0.5); /* pretested */ |
307 |
zd = sqrt((i+frandom())/nt); |
308 |
phi = 2.0*PI * (j+frandom())/np; |
309 |
xd = cos(phi) * zd; |
310 |
yd = sin(phi) * zd; |
311 |
zd = sqrt(1.0 - zd*zd); |
312 |
313 |
ar.rdir[k] = xd*ux[k]+yd*uy[k]+zd*r->ron[k]; |
314 |
rayvalue(&ar); |
315 |
if (ar.rot < FHUGE) |
316 |
arad += 1.0 / ar.rot; |
317 |
if (ns > 0) { /* save division */ |
318 |
div[ne].k = 0.0; |
319 |
copycolor(div[ne].v, ar.rcol); |
320 |
div[ne].n = 0; |
321 |
div[ne].t = i; div[ne].p = j; |
322 |
/* sum errors */ |
323 |
xd = bright(ar.rcol); |
324 |
if (i > 0) { /* from above */ |
325 |
yd = bright(div[ne-np].v) - xd; |
326 |
yd *= yd * 0.25; |
327 |
div[ne].k += yd; |
328 |
div[ne].n++; |
329 |
div[ne-np].k += yd; |
330 |
div[ne-np].n++; |
331 |
332 |
if (j > 0) { /* from behind */ |
333 |
yd = bright(div[ne-1].v) - xd; |
334 |
yd *= yd * 0.25; |
335 |
div[ne].k += yd; |
336 |
div[ne].n++; |
337 |
div[ne-1].k += yd; |
338 |
div[ne-1].n++; |
339 |
340 |
if (j == np-1) { /* around */ |
341 |
yd = bright(div[ne-(np-1)].v) - xd; |
342 |
yd *= yd * 0.25; |
343 |
div[ne].k += yd; |
344 |
div[ne].n++; |
345 |
div[ne-(np-1)].k += yd; |
346 |
div[ne-(np-1)].n++; |
347 |
348 |
ne++; |
349 |
} else |
350 |
addcolor(acol, ar.rcol); |
351 |
352 |
for (k = 0; k < ne; k++) { /* compute errors */ |
353 |
if (div[k].n > 1) |
354 |
div[k].k /= div[k].n; |
355 |
div[k].n = 1; |
356 |
357 |
/* sort the divisions */ |
358 |
qsort(div, ne, sizeof(AMBSAMP), ambcmp); |
359 |
/* skim excess */ |
360 |
while (ne > ns) { |
361 |
ne--; |
362 |
addcolor(acol, div[ne].v); |
363 |
364 |
/* super-sample */ |
365 |
for (i = ns; i > 0; i--) { |
366 |
367 |
zd = sqrt((div[0].t+frandom())/nt); |
368 |
phi = 2.0*PI * (div[0].p+frandom())/np; |
369 |
370 |
371 |
372 |
373 |
374 |
rayvalue(&ar); |
375 |
376 |
377 |
/* recompute error */ |
378 |
copycolor(dnew.v, div[0].v); |
379 |
addcolor(dnew.v, ar.rcol); |
380 |
dnew.n = div[0].n + 1; |
381 |
dnew.t = div[0].t; dnew.p = div[0].p; |
382 |
yd = bright(dnew.v)/dnew.n - bright(ar.rcol); |
383 |
yd = yd*yd + div[0].k*(div[0].n*div[0].n); |
384 |
dnew.k = yd/(dnew.n*dnew.n); |
385 |
/* reinsert */ |
386 |
for (k = 0; k < ne-1 && dnew.k < div[k+1].k; k++) |
387 |
bcopy(&div[k+1], &div[k], sizeof(AMBSAMP)); |
388 |
bcopy(&dnew, &div[k], sizeof(AMBSAMP)); |
389 |
390 |
if (ne >= i) { /* extract darkest division */ |
391 |
ne--; |
392 |
if (div[ne].n > 1) |
393 |
scalecolor(div[ne].v, 1.0/div[ne].n); |
394 |
395 |
396 |
397 |
scalecolor(acol, 1.0/ndivs); |
398 |
if (arad <= FTINY) |
399 |
arad = FHUGE; |
400 |
else |
401 |
arad = (ndivs+ns) / arad / sqrt(r->rweight); |
402 |
if (arad > maxarad) |
403 |
arad = maxarad; |
404 |
else if (arad < minarad) |
405 |
arad = minarad; |
406 |
if (ns > 0) |
407 |
free((char *)div); |
408 |
return(arad); |
409 |
410 |
411 |
412 |
static int |
413 |
ambcmp(d1, d2) /* decreasing order */ |
414 |
AMBSAMP *d1, *d2; |
415 |
416 |
if (d1->k < d2->k) |
417 |
return(1); |
418 |
if (d1->k > d2->k) |
419 |
return(-1); |
420 |
return(0); |
421 |
422 |
423 |
424 |
static |
425 |
avsave(av) /* save an ambient value */ |
426 |
AMBVAL *av; |
427 |
428 |
#ifdef AMBFLUSH |
429 |
static int nunflshed = 0; |
430 |
#endif |
431 |
if (ambfp == NULL) |
432 |
return; |
433 |
if (fwrite(av, sizeof(AMBVAL), 1, ambfp) != 1) |
434 |
goto writerr; |
435 |
#ifdef AMBFLUSH |
436 |
if (++nunflshed >= AMBFLUSH) { |
437 |
if (fflush(ambfp) == EOF) |
438 |
goto writerr; |
439 |
nunflshed = 0; |
440 |
441 |
#endif |
442 |
return; |
443 |
writerr: |
444 |
error(SYSTEM, "error writing ambient file"); |
445 |
446 |
447 |
448 |
static |
449 |
avinsert(aval, at, c0, s) /* insert ambient value in a tree */ |
450 |
AMBVAL *aval; |
451 |
register AMBTREE *at; |
452 |
FVECT c0; |
453 |
double s; |
454 |
455 |
FVECT ck0; |
456 |
int branch; |
457 |
458 |
register int i; |
459 |
460 |
if ((av = newambval()) == NULL) |
461 |
goto memerr; |
462 |
bcopy(aval, av, sizeof(AMBVAL)); |
463 |
VCOPY(ck0, c0); |
464 |
while (s*(OCTSCALE/2) > av->rad*ambacc) { |
465 |
466 |
if ((at->kid = newambtree()) == NULL) |
467 |
goto memerr; |
468 |
s *= 0.5; |
469 |
branch = 0; |
470 |
for (i = 0; i < 3; i++) |
471 |
if (av->pos[i] > ck0[i] + s) { |
472 |
ck0[i] += s; |
473 |
branch |= 1 << i; |
474 |
475 |
at = at->kid + branch; |
476 |
477 |
av->next = at->alist; |
478 |
at->alist = av; |
479 |
return; |
480 |
memerr: |
481 |
error(SYSTEM, "out of memory in avinsert"); |
482 |
