--- ray/src/rt/ambient.c 1992/07/16 12:09:08 2.6 +++ ray/src/rt/ambient.c 1993/01/20 10:48:23 2.15 @@ -1,4 +1,4 @@ -/* Copyright (c) 1991 Regents of the University of California */ +/* Copyright (c) 1993 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -6,11 +6,6 @@ static char SCCSid[] = "$SunId$ LBL"; /* * ambient.c - routines dealing with ambient (inter-reflected) component. - * - * The macro AMBFLUSH (if defined) is the number of ambient values - * to wait before flushing to the ambient file. - * - * 5/9/86 */ #include "ray.h" @@ -23,33 +18,36 @@ static char SCCSid[] = "$SunId$ LBL"; #include "random.h" -#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ +#define OCTSCALE 0.5 /* ceil((valid rad.)/(cube size)) */ typedef struct ambtree { - AMBVAL *alist; /* ambient value list */ - struct ambtree *kid; /* 8 child nodes */ + AMBVAL *alist; /* ambient value list */ + struct ambtree *kid; /* 8 child nodes */ } AMBTREE; /* ambient octree */ extern CUBE thescene; /* contains space boundaries */ -#define MAXASET 511 /* maximum number of elements in ambient set */ -OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ +#define MAXASET 511 /* maximum number of elements in ambient set */ +OBJECT ambset[MAXASET+1]={0}; /* ambient include/exclude set */ -double maxarad; /* maximum ambient radius */ -double minarad; /* minimum ambient radius */ +double maxarad; /* maximum ambient radius */ +double minarad; /* minimum ambient radius */ -static AMBTREE atrunk; /* our ambient trunk node */ +static AMBTREE atrunk; /* our ambient trunk node */ +static char *ambfname = NULL; /* ambient file name */ static FILE *ambfp = NULL; /* ambient file pointer */ -static int ambheadlen; /* length of ambient file header */ -#define AMBFLUSH (BUFSIZ/AMBVALSIZ) +#define AMBFLUSH (BUFSIZ/AMBVALSIZ) -#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) +#define newambval() (AMBVAL *)bmalloc(sizeof(AMBVAL)) -#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +#define newambtree() (AMBTREE *)calloc(8, sizeof(AMBTREE)) +extern long ftell(), lseek(); +static int initambfile(), avsave(), avinsert(), ambsync(); + setambres(ar) /* set ambient resolution */ int ar; { @@ -71,20 +69,21 @@ int ar; setambient(afile) /* initialize calculation */ char *afile; { - extern long ftell(); - AMBVAL amb; + long headlen; + AMBVAL amb; /* init ambient limits */ setambres(ambres); /* open ambient file */ - if (afile != NULL) + if ((ambfname = afile) != NULL) if ((ambfp = fopen(afile, "r+")) != NULL) { initambfile(0); + headlen = ftell(ambfp); while (readambval(&amb, ambfp)) avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); /* align */ - fseek(ambfp, -((ftell(ambfp)-ambheadlen)%AMBVALSIZ), 1); - } else if ((ambfp = fopen(afile, "w")) != NULL) + fseek(ambfp, -((ftell(ambfp)-headlen)%AMBVALSIZ), 1); + } else if ((ambfp = fopen(afile, "w+")) != NULL) initambfile(1); else { sprintf(errmsg, "cannot open ambient file \"%s\"", @@ -94,35 +93,11 @@ char *afile; } -initambfile(creat) /* initialize ambient file */ -int creat; -{ - extern char *progname, *octname; - - setbuf(ambfp, bmalloc(BUFSIZ)); - if (creat) { /* new file */ - fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", - progname, colval(ambval,RED), - colval(ambval,GRN), colval(ambval,BLU), - ambounce, ambacc); - fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", - ambdiv, ambssamp, ambres, - octname==NULL ? "" : octname); - fputformat(AMBFMT, ambfp); - putc('\n', ambfp); - putambmagic(ambfp); - fflush(ambfp); - } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) - error(USER, "ambient file format error"); - ambheadlen = ftell(ambfp); -} - - ambnotify(obj) /* record new modifier */ -OBJECT obj; +OBJECT obj; { static int hitlimit = 0; - register OBJREC *o = objptr(obj); + register OBJREC *o = objptr(obj); register char **amblp; if (hitlimit || !ismodifier(o->otype)) @@ -145,7 +120,7 @@ COLOR acol; register RAY *r; { static int rdepth = 0; /* ambient recursion */ - double d; + double d; if (ambdiv <= 0) /* no ambient calculation */ goto dumbamb; @@ -187,17 +162,16 @@ sumambient(acol, r, al, at, c0, s) /* get interpolated COLOR acol; register RAY *r; int al; -AMBTREE *at; +AMBTREE *at; FVECT c0; -double s; +double s; { - extern double sqrt(); - double d, e1, e2, wt, wsum; + double d, e1, e2, wt, wsum; COLOR ct; FVECT ck0; int i; register int j; - register AMBVAL *av; + register AMBVAL *av; /* do this node */ wsum = 0.0; for (av = at->alist; av != NULL; av = av->next) { @@ -276,7 +250,7 @@ COLOR acol; register RAY *r; int al; { - AMBVAL amb; + AMBVAL amb; FVECT gp, gd; /* compute weight */ amb.weight = pow(AVGREFL, (double)al); @@ -294,20 +268,19 @@ int al; VCOPY(amb.gpos, gp); VCOPY(amb.gdir, gd); /* insert into tree */ - avinsert(&amb, &atrunk, thescene.cuorg, thescene.cusize); - avsave(&amb); /* write to file */ + avsave(&amb); /* and save to file */ return(amb.rad); } extambient(cr, ap, pv, nv) /* extrapolate value at pv, nv */ COLOR cr; -register AMBVAL *ap; +register AMBVAL *ap; FVECT pv, nv; { FVECT v1, v2; register int i; - double d; + double d; d = 1.0; /* zeroeth order */ /* gradient due to translation */ @@ -327,17 +300,46 @@ FVECT pv, nv; static -avsave(av) /* save an ambient value */ -AMBVAL *av; +initambfile(creat) /* initialize ambient file */ +int creat; { + extern char *progname, *octname, VersionID[]; + +#ifdef MSDOS + setmode(fileno(ambfp), O_BINARY); +#endif + setbuf(ambfp, bmalloc(BUFSIZ)); + if (creat) { /* new file */ + fprintf(ambfp, "%s -av %g %g %g -ab %d -aa %g ", + progname, colval(ambval,RED), + colval(ambval,GRN), colval(ambval,BLU), + ambounce, ambacc); + fprintf(ambfp, "-ad %d -as %d -ar %d %s\n", + ambdiv, ambssamp, ambres, + octname==NULL ? "" : octname); + fprintf(ambfp, "SOFTWARE= %s\n", VersionID); + fputformat(AMBFMT, ambfp); + putc('\n', ambfp); + putambmagic(ambfp); + } else if (checkheader(ambfp, AMBFMT, NULL) < 0 || !hasambmagic(ambfp)) + error(USER, "bad ambient file"); + ambsync(); +} + + +static +avsave(av) /* insert and save an ambient value */ +AMBVAL *av; +{ static int nunflshed = 0; + avinsert(av, &atrunk, thescene.cuorg, thescene.cusize); if (ambfp == NULL) return; if (writambval(av, ambfp) < 0) goto writerr; if (++nunflshed >= AMBFLUSH) { - if (fflush(ambfp) == EOF) + if (ambsync() == EOF) goto writerr; nunflshed = 0; } @@ -349,14 +351,14 @@ writerr: static avinsert(aval, at, c0, s) /* insert ambient value in a tree */ -AMBVAL *aval; +AMBVAL *aval; register AMBTREE *at; FVECT c0; -double s; +double s; { FVECT ck0; int branch; - register AMBVAL *av; + register AMBVAL *av; register int i; if ((av = newambval()) == NULL) @@ -382,3 +384,61 @@ double s; memerr: error(SYSTEM, "out of memory in avinsert"); } + + +#ifdef NIX + +static +ambsync() /* flush ambient file */ +{ + return(fflush(ambfp)); +} + +#else + +static +ambsync() /* synchronize ambient file */ +{ + static FILE *ambinp = NULL; + static long lastpos = -1; + struct flock fls; + long flen; + AMBVAL avs; + register int n; + /* gain exclusive access */ + fls.l_type = F_WRLCK; + fls.l_whence = 0; + fls.l_start = 0L; + fls.l_len = 0L; + if (fcntl(fileno(ambfp), F_SETLKW, &fls) < 0) + error(SYSTEM, "cannot lock ambient file"); + if (lastpos < 0) /* initializing */ + goto syncend; + /* see if file has grown */ + if ((flen = lseek(fileno(ambfp), 0L, 2)) < 0) + error(SYSTEM, "cannot seek on ambient file"); + if (n = flen - lastpos) { /* file has grown */ + if (ambinp == NULL) { + ambinp = fopen(ambfname, "r"); + if (ambinp == NULL) + error(SYSTEM, "fopen failed in ambsync"); + } + if (fseek(ambinp, lastpos, 0) < 0) + error(SYSTEM, "fseek failed in ambsync"); + while (n >= AMBVALSIZ) { /* load contributed values */ + readambval(&avs, ambinp); + avinsert(&avs,&atrunk,thescene.cuorg,thescene.cusize); + n -= AMBVALSIZ; + } + if (n) /* alignment */ + lseek(fileno(ambfp), flen-n, 0); + } +syncend: + n = fflush(ambfp); /* calls write() at last */ + lastpos = lseek(fileno(ambfp), 0L, 1); + fls.l_type = F_UNLCK; /* release file */ + fcntl(fileno(ambfp), F_SETLKW, &fls); + return(n); +} + +#endif
